J'ai fait l'installation de la Pizigate comme indiqué dans les documentations.
Je lance domoticz et j'installe la Zigate mais ou bout de quelques temps apparait dans les log les erreurs suivantes:
2019-04-27 10:46:14.353 (cle_usb_zigate) Debug: 0
2019-04-27 10:46:14.383 (cle_usb_zigate) Configure Permit To Join
2019-04-27 10:46:14.383 (cle_usb_zigate) Request discovery mode for 254 seconds
2019-04-27 10:46:14.101 Status: (cle_usb_zigate) Started.
2019-04-27 10:46:14.351 Status: (cle_usb_zigate) Entering work loop.
2019-04-27 10:46:14.352 Status: (cle_usb_zigate) Initialized version beta-4.2.0, author 'zaraki673 pipiche38'
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) Zigate plugin beta-4.2.0 started
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-04-27 10:46:14.353 [GCC 6.3.0 20170516]
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) Switching Hearbeat to 5 s interval
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) DomoticzVersion: 4.9700
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) DomoticzHash: a3a45906
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) DomoticzBuildTime: 2018-06-23 16:24:51
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) The current Domoticz version doesn't support the plugin to enable a number of features
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) switching to Domoticz V 4.10355 and above would help
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) load PluginConf
2019-04-27 10:46:14.354 Status: (cle_usb_zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-04-27 10:46:14.354 Status: (cle_usb_zigate) -vibrationAqarasensitivity: medium
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -enablegroupmanagement: 0
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -resetMotiondelay: 30
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -logFORMAT: 0
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -logLQI: 0
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-04-27 10:46:14.358 Status: (cle_usb_zigate) Plugin Database: DeviceList-2.txt
2019-04-27 10:46:14.374 Status: (cle_usb_zigate) DeviceConf loaded
2019-04-27 10:46:14.374 Status: (cle_usb_zigate) load ListOfDevice
2019-04-27 10:46:14.380 Status: (cle_usb_zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-2.txt : 1
2019-04-27 10:46:14.381 Status: (cle_usb_zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2019-04-27 10:46:14.485 Status: (cle_usb_zigate) Major Version Num: 0003
2019-04-27 10:46:14.485 Status: (cle_usb_zigate) Installer Version Number: 030f
2019-04-27 10:46:14.686 Status: (cle_usb_zigate) Permit Join: Off
2019-04-27 10:46:14.790 Status: (cle_usb_zigate) Zigate addresses ieee: 00158d0001ede6da , short addr: ffff
2019-04-27 10:46:14.790 Status: (cle_usb_zigate) Network state UP, PANID: dca9 extPANID: 0x0000000000000000 Channel: 11
2019-04-27 10:46:14.893 Status: (cle_usb_zigate) Number of devices recently active in Zigate = 0
2019-04-27 10:46:23.861 Status: (cle_usb_zigate) Plugin with Zigate firmware 030f correctly initialized
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) 'onHeartbeat' failed 'KeyError'.
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) ----> Line 657 in /home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py, function onHeartbeat
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) ----> Line 533 in /home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py, function onHeartbeat
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) ----> Line 439 in /home/pi/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py, function processListOfDevices
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) ----> Line 633 in /home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py, function processConfigureReporting
2019-04-27 10:47:22.584 Status: New sensors allowed for 5 minutes...
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) 'onHeartbeat' failed 'KeyError'.
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) ----> Line 657 in /home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py, function onHeartbeat
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) ----> Line 533 in /home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py, function onHeartbeat
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) ----> Line 439 in /home/pi/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py, function processListOfDevices
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) ----> Line 633 in /home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py, function processConfigureReporting
Pouvez-vous m'aider sur l'origine de ces ereeurs?
Erreur d'installation de la Pizigate avec domoticz
bpasquereau
Revenir à « DomoticZ : Question et réponses »
Aller
- DomoticZ : Généralités
- ↳ DomoticZ : Question et réponses
- ↳ DomoticZ : Les mises à jour
- DomoticZ : les protocoles et les objets
- ↳ Z-Wave
- ↳ ZigBee
- ↳ Le plugin ZigBeeForDomoticZ
- ↳ Toutes les infos sur le plugin ZigBeeForDomoticZ
- ↳ Rfxcom (433 et 866 Mhz)
- ↳ Rflink
- ↳ 1-Wire
- ↳ MQTT
- ↳ Le plugin MQTTMapper
- ↳ MySensors.org
- ↳ Xiaomi
- ↳ Les autres protocoles
- ↳ DIY, ESPEasy, Tasmota
- ↳ OpenKarotz et Domoticz
- ↳ La vidéo-surveillance
- ↳ Les autres objets
- DomoticZ : l'hébergement
- ↳ Raspberry, Linux et autres geekeries
- ↳ Docker, NAS, VM
- ↳ Windows & Domoticz
- DomoticZ : l’automatisation
- ↳ Scripts DzVents, LUA, Blockly, Shell, Python, Perl ...
- ↳ La Bibliothèque Scripts et Tutos (PAS DE QUESTIONS ICI, que des tutos SVP)
- DomoticZ : personnalisation et accès
- ↳ Domoticz et Internet
- ↳ Custom Pages
- ↳ Thèmes et Styles
- ↳ Android Domoticz App 2.0
- ↳ Applis Android et Apple
- Divers
- ↳ Bien utiliser le forum
- ↳ Achat-Vente matériel d'occasion
- ↳ De tout et de rien
- ↳ Présentation de votre installation domotique
