Erreur d'installation de la Pizigate avec domoticz
Publié : 02 mai 2019, 08:41
par bpasquereau
J'ai fait l'installation de la Pizigate comme indiqué dans les documentations.
Je lance domoticz et j'installe la Zigate mais ou bout de quelques temps apparait dans les log les erreurs suivantes:
2019-04-27 10:46:14.353 (cle_usb_zigate) Debug: 0
2019-04-27 10:46:14.383 (cle_usb_zigate) Configure Permit To Join
2019-04-27 10:46:14.383 (cle_usb_zigate) Request discovery mode for 254 seconds
2019-04-27 10:46:14.101 Status: (cle_usb_zigate) Started.
2019-04-27 10:46:14.351 Status: (cle_usb_zigate) Entering work loop.
2019-04-27 10:46:14.352 Status: (cle_usb_zigate) Initialized version beta-4.2.0, author 'zaraki673 pipiche38'
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) Zigate plugin beta-4.2.0 started
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-04-27 10:46:14.353 [GCC 6.3.0 20170516]
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) Switching Hearbeat to 5 s interval
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) DomoticzVersion: 4.9700
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) DomoticzHash: a3a45906
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) DomoticzBuildTime: 2018-06-23 16:24:51
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) The current Domoticz version doesn't support the plugin to enable a number of features
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) switching to Domoticz V 4.10355 and above would help
2019-04-27 10:46:14.353 Status: (cle_usb_zigate) load PluginConf
2019-04-27 10:46:14.354 Status: (cle_usb_zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-04-27 10:46:14.354 Status: (cle_usb_zigate) -vibrationAqarasensitivity: medium
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -enablegroupmanagement: 0
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -resetMotiondelay: 30
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -logFORMAT: 0
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -logLQI: 0
2019-04-27 10:46:14.355 Status: (cle_usb_zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-04-27 10:46:14.358 Status: (cle_usb_zigate) Plugin Database: DeviceList-2.txt
2019-04-27 10:46:14.374 Status: (cle_usb_zigate) DeviceConf loaded
2019-04-27 10:46:14.374 Status: (cle_usb_zigate) load ListOfDevice
2019-04-27 10:46:14.380 Status: (cle_usb_zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-2.txt : 1
2019-04-27 10:46:14.381 Status: (cle_usb_zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2019-04-27 10:46:14.485 Status: (cle_usb_zigate) Major Version Num: 0003
2019-04-27 10:46:14.485 Status: (cle_usb_zigate) Installer Version Number: 030f
2019-04-27 10:46:14.686 Status: (cle_usb_zigate) Permit Join: Off
2019-04-27 10:46:14.790 Status: (cle_usb_zigate) Zigate addresses ieee: 00158d0001ede6da , short addr: ffff
2019-04-27 10:46:14.790 Status: (cle_usb_zigate) Network state UP, PANID: dca9 extPANID: 0x0000000000000000 Channel: 11
2019-04-27 10:46:14.893 Status: (cle_usb_zigate) Number of devices recently active in Zigate = 0
2019-04-27 10:46:23.861 Status: (cle_usb_zigate) Plugin with Zigate firmware 030f correctly initialized
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) 'onHeartbeat' failed 'KeyError'.
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) ----> Line 657 in /home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py, function onHeartbeat
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) ----> Line 533 in /home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py, function onHeartbeat
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) ----> Line 439 in /home/pi/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py, function processListOfDevices
2019-04-27 10:47:18.878 Error: (cle_usb_zigate) ----> Line 633 in /home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py, function processConfigureReporting
2019-04-27 10:47:22.584 Status: New sensors allowed for 5 minutes...
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) 'onHeartbeat' failed 'KeyError'.
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) ----> Line 657 in /home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py, function onHeartbeat
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) ----> Line 533 in /home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py, function onHeartbeat
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) ----> Line 439 in /home/pi/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py, function processListOfDevices
2019-04-27 10:48:18.900 Error: (cle_usb_zigate) ----> Line 633 in /home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py, function processConfigureReporting
Pouvez-vous m'aider sur l'origine de ces ereeurs?
