[Résolu] Smart Siren timeout
thanks
Message par thanks »
Je suis nouveau dans le zigbee hors Xiaomi gateway et du coup voici une description de mon installation:
Raspberry Pi 4 sous Buster
Zigate+ USB avec le firmware 0321
Domoticz : 2021.1
Plugin : 5.1.017
Je viens d'acquérir une Smart Siren HEIMAN HS2WD-E celle-ci fonctionne au début puis elle tombe en timeout :
 2022-01-27 19:26:59.657 zigate: (zigate) UpdateDevice - ( Sirène Zigbee) 1:10
2022-01-27 19:26:59.621 Status: User: Admin (IP: 192.168.****) initiated a switch command (156/Sirène Zigbee/Set Level)
2022-01-27 19:27:06.134 zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_Voltage-847127fffead4501-01 -> True from 0:
2022-01-27 19:27:06.383 zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_Door-847127fffead4501-01 -> True from 0:Closed
2022-01-27 19:27:06.385 zigate: (zigate) timeout_widget unit Sirène Zigbee -> True from 1:10
2022-01-27 19:27:06.396 zigate: (zigate) Receive NACK from 45c1 clusterId: 0502 Status: a7
2022-01-27 19:27:07.897 zigate: (zigate) UpdateDevice - ( Sirène Zigbee) 0:Off
2022-01-27 19:27:07.849 Status: User: Admin (IP: 192.168.****) initiated a switch command (156/Sirène Zigbee/Set Level)
2022-01-27 19:27:09.610 zigate: (zigate) UpdateDevice - ( Sirène Zigbee) 1:10
2022-01-27 19:27:09.555 Status: User: Admin (IP: 192.168.****) initiated a switch command (156/Sirène Zigbee/Set Level)
2022-01-27 19:27:14.376 zigate: (zigate) timeout_widget unit Sirène Zigbee -> True from 1:10
2022-01-27 19:27:14.379 zigate: (zigate) Receive NACK from 45c1 clusterId: 0502 Status: a7
2022-01-27 19:27:15.745 zigate: (zigate) UpdateDevice - ( Sirène Zigbee) 0:Off
j'ai vu cela dans les logs de domoticz lors de l'appareillage :
2022-01-27 17:00:06.039 Error: zigate: (zigate) Zigate not correctly initialized
2022-01-27 17:00:06.196 Error: zigate: (zigate) Zigate not correctly initialized
2022-01-27 17:00:18.856 Error: zigate: (zigate) 'onStart' failed 'KeyError'.
2022-01-27 17:00:18.856 Error: zigate: (zigate) ----> Line 1342 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py', function onStart
2022-01-27 17:00:18.856 Error: zigate: (zigate) ----> Line 243 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py', function onStart
2022-01-27 17:00:36.257 Error: zigate: (zigate) No transport, write directive to '192.168.1.2:63181' ignored.
2022-01-27 17:02:11.124 Error: zigate: (zigate) 'onHeartbeat' failed 'KeyError'.
2022-01-27 17:02:11.124 Error: zigate: (zigate) ----> Line 1377 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py', function onHeartbeat
2022-01-27 17:02:11.124 Error: zigate: (zigate) ----> Line 877 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py', function onHeartbeat
2022-01-27 17:02:11.124 Error: zigate: (zigate) ----> Line 784 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py', function processListOfDevices
2022-01-27 17:02:11.124 Error: zigate: (zigate) ----> Line 103 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/pairingProcess.py', function processNotinDBDevices
2022-01-27 17:02:11.124 Error: zigate: (zigate) ----> Line 354 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/pairingProcess.py', function interview_state_createDB
2022-01-27 17:02:11.124 Error: zigate: (zigate) ----> Line 396 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/pairingProcess.py', function full_provision_device
2022-01-27 17:02:11.124 Error: zigate: (zigate) ----> Line 416 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/pairingProcess.py', function zigbee_provision_device
2022-01-27 17:02:11.124 Error: zigate: (zigate) ----> Line 515 in '/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/pairingProcess.py', function delay_binding_and_reporting
2022-01-27 17:18:23.488 Error: zigate: (zigate) Decode8000 - PacketType: 0083 TypeSqn: 00 sqn_app: 00 sqn_aps: 93 Status: [Unhandled Command]
2022-01-27 17:18:59.804 Error: zigate: (zigate) Decode8000 - PacketType: 0083 TypeSqn: 00 sqn_app: 00 sqn_aps: 93 Status: [Unhandled Command]
 2022-01-27 20:05:59.730 Error: zigate: (zigate) No transport, write directive to '192.168.1.2:53281' ignored.
2022-01-27 20:05:59.730 Error: zigate: (zigate) No transport, write directive to '192.168.1.2:53360' ignored.
Je ne sais pas trop ou regarder mais la sirène répond de manière aléatoire.
Voici également les logs de démarrage de domoticz :
2022-01-27 20:10:59.231  Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2022-01-27 20:10:59.232  Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2022-01-27 20:10:59.232  Status: Startup Path: /home/pi/domoticz/
2022-01-27 20:10:59.252  Sunrise: 08:27:00 SunSet: 18:03:00
2022-01-27 20:10:59.252  Day length: 09:36:00 Sun at south: 13:15:00
2022-01-27 20:10:59.252  Civil twilight start: 07:56:00 Civil twilight end: 18:35:00
2022-01-27 20:10:59.252  Nautical twilight start: 07:20:00 Nautical twilight end: 19:10:00
2022-01-27 20:10:59.252  Astronomical twilight start: 06:46:00 Astronomical twilight end: 19:45:00
2022-01-27 20:10:59.317  Status: PluginSystem: Started, Python version '3.7.3'.
2022-01-27 20:10:59.321  Active notification Subsystems: email (1/13)
2022-01-27 20:10:59.322  Status: WebServer(HTTP) started on address: :: with port 8080
2022-01-27 20:10:59.326  Error: [web:443] missing SSL DH parameters from file ./server_cert.pem
2022-01-27 20:10:59.327  Status: WebServer(SSL) started on address: :: with port 443
2022-01-27 20:10:59.383  Starting shared server on: :::6144
2022-01-27 20:10:59.384  Status: TCPServer: shared server started...
2022-01-27 20:10:59.384  Status: RxQueue: queue worker started...
2022-01-27 20:11:01.385  Status: Box: XiaomiGateway (ID=3): Delaying worker startup...
2022-01-27 20:11:06.385  Status: Box: XiaomiGateway (ID=3): Selected as main Gateway
2022-01-27 20:11:06.385  Status: Box: XiaomiGateway (ID=3): Worker started...
2022-01-27 20:11:06.386  Status: Meteo Eysines: Started...
2022-01-27 20:11:06.386  Status: RFXCOM: Worker started...
2022-01-27 20:11:06.386  zigate hardware started.
2022-01-27 20:11:06.386  Status: Box: XiaomiGateway (ID=3): Using 192.168.1.4 for local IP address.
2022-01-27 20:11:06.386  Status: zigate: (zigate) Entering work loop.
2022-01-27 20:11:06.386  Status: zigate: (zigate) Started.
2022-01-27 20:11:06.387  Status: NotificationSystem: thread started...
2022-01-27 20:11:06.387  Status: EventSystem: reset all events...
2022-01-27 20:11:06.388  Status: EventSystem: reset all device statuses...
2022-01-27 20:11:06.476  Status: XiaomiGateway: RGB Gateway Detected
2022-01-27 20:11:06.491  Box: Color Switch (Xiaomi RGB Gateway)
2022-01-27 20:11:06.755  Status: PluginSystem: 1 plugins started.
2022-01-27 20:11:06.772  Status: zigate: (zigate) Initialized version 5.1, author 'zaraki673  pipiche38'
2022-01-27 20:11:06.773  zigate: (zigate) ZiGate plugin started!
2022-01-27 20:11:06.774  zigate: (zigate) load PluginConf
2022-01-27 20:11:06.774  zigate: (zigate) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2022-01-27 20:11:06.774  zigate: (zigate) is_domoticz_db_available: True
2022-01-27 20:11:06.775  zigate: (zigate) /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-21.json timestamp is 1643299210.183952
2022-01-27 20:11:06.775  zigate: (zigate) Dz PluginConf is older than Json Dz: 0 Json: 1643299210.183952
2022-01-27 20:11:06.775  zigate: (zigate) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2022-01-27 20:11:06.775  zigate: (zigate) is_domoticz_db_available: True
2022-01-27 20:11:06.775  Status: zigate: (zigate) channel set to 11
2022-01-27 20:11:06.775  Status: zigate: (zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-21.json
2022-01-27 20:11:06.775  Status: zigate: (zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-01-27 20:11:06.775  Status: zigate: (zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-01-27 20:11:06.776  Status: zigate: (zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2022-01-27 20:11:06.776  Status: zigate: (zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-01-27 20:11:06.776  Status: zigate: (zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-01-27 20:11:06.776  Status: zigate: (zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-01-27 20:11:06.776  Status: zigate: (zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2022-01-27 20:11:06.776  Status: zigate: (zigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-01-27 20:11:06.776  zigate: (zigate) Starting LoggingManagement thread
2022-01-27 20:11:06.776  zigate: (zigate) start_logging_thread
2022-01-27 20:11:06.777  zigate: (zigate) logging_thread - listening
2022-01-27 20:11:06.779  Status: zigate: (zigate) Zigate plugin stable5-5.1.017 started
2022-01-27 20:11:06.791  zigate: (zigate) Plugin Database: DeviceList-21.txt
2022-01-27 20:11:06.796  Status: zigate: (zigate) DeviceConf loaded - 24 confs loaded
2022-01-27 20:11:06.900  Box: Temp + Humidity (Xiaomi TempHum)
2022-01-27 20:11:06.903  Box: Temp + Humidity (Xiaomi TempHum)
2022-01-27 20:11:06.905  Box: Temp + Humidity + Baro (Xiaomi TempHumBaro)
2022-01-27 20:11:06.907  Box: Temp + Humidity (Xiaomi TempHum)
2022-01-27 20:11:06.925  zigate: (zigate) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2022-01-27 20:11:06.925  zigate: (zigate) is_domoticz_db_available: True
2022-01-27 20:11:06.925  Status: zigate: (zigate) DeviceConf loaded - 320 confs loaded
2022-01-27 20:11:06.925  Status: zigate: (zigate) load ListOfDevice
2022-01-27 20:11:06.943  zigate: (zigate) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2022-01-27 20:11:06.943  zigate: (zigate) is_domoticz_db_available: True
2022-01-27 20:11:06.946  Status: zigate: (zigate) 2 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-21.txt
2022-01-27 20:11:06.946  Status: zigate: (zigate) Transport mode: V2-USB
2022-01-27 20:11:07.391  Status: RFXCOM: Using serial port: /dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO5O5BHC-if00-port0
2022-01-27 20:11:07.453  Status: zigate: (zigate) ZigateTransport: Serial Connection open: Serial<id=0xa9ca6330, open=True>(port='/dev/serial/by-id/usb-FTDI_ZiGate_ZIGATE+-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2022-01-27 20:11:07.455  Status: zigate: (zigate) ZigateTransport: writer_thread Thread start.
2022-01-27 20:11:07.456  Status: zigate: (zigate) ZigateTransport: thread_processing_and_sending Thread start.
2022-01-27 20:11:07.457  zigate: (zigate) Connection open: Serial<id=0xa9ca6330, open=True>(port='/dev/serial/by-id/usb-FTDI_ZiGate_ZIGATE+-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2022-01-27 20:11:07.457  Status: zigate: (zigate) Start Web Server connection
2022-01-27 20:11:07.470  Status: zigate: (zigate) Web backend for Web User Interface started on port: 9440
2022-01-27 20:11:07.519  Status: Python EventSystem: Initalizing event module.
2022-01-27 20:11:07.520  Status: EventSystem: Started
2022-01-27 20:11:07.520  Status: EventSystem: Queue thread started...
2022-01-27 20:11:11.153  Status: zigate: (zigate) ==> Transport Mode switch to full mode
2022-01-27 20:11:11.155  Status: zigate: (zigate) ZiGate+ (V2)
2022-01-27 20:11:11.155  Status: zigate: (zigate) Installer Version Number: 0321
2022-01-27 20:11:11.155  Status: zigate: (zigate) Branch Version: ==> Production <==
2022-01-27 20:11:11.205  Status: zigate: (zigate) Upgrade Serial line to RTS/CTS HW flow control
2022-01-27 20:11:16.950  Meteo Eysines: Temp + Humidity + Baro (Meteo Eysines)
2022-01-27 20:11:16.955  Meteo Eysines: Wind (Unknown)
2022-01-27 20:11:16.961  Meteo Eysines: UV (UV Index)
2022-01-27 20:11:16.974  Meteo Eysines: Rain (Rain)
2022-01-27 20:11:16.978  Meteo Eysines: General/Visibility (Unknown)
2022-01-27 20:11:16.982  Meteo Eysines: General/Custom Sensor (Ozone Sensor)
2022-01-27 20:11:16.985  Meteo Eysines: General/Percentage (Cloud Cover)
2022-01-27 20:11:21.184  Status: zigate: (zigate) Zigate addresses ieee: 00158d0006a3fcbb , short addr: 0000
2022-01-27 20:11:21.184  Status: zigate: (zigate) Network state UP, PANID: 8131 extPANID: 0xe6eb7e709aecf247 Channel: 11
2022-01-27 20:11:26.062  Status: zigate: (zigate) Request Disabling Accepting new Hardware
2022-01-27 20:11:26.062  zigate: (zigate) zdp_permit_joining_request FFFC 00 00
2022-01-27 20:11:26.574  Status: zigate: (zigate) Accepting new Hardware: Disable (Off)
2022-01-27 20:11:26.677  Status: zigate: (zigate) Number of devices recently active in Zigate = 1
2022-01-27 20:11:26.678  Status: zigate: (zigate) [00] DevID: 14 Network addr: 45c1 IEEE: 847127fffead4501 LQI: 057 power: 01 Model: WarningDevice-EF-3.0 (  )
2022-01-27 20:11:31.071  zigate: (zigate) Switch Blue Led On
2022-01-27 20:11:31.071  Status: zigate: (zigate) Zigate set to Certification : CE
2022-01-27 20:11:31.078  Status: zigate: (zigate) Plugin with Zigate+, firmware 0321 correctly initialized
En vous remerciant pour votre aide.
Dernière modification par thanks le 28 janv. 2022, 21:59, modifié 1 fois.
pipiche
Re: [Zigate+] Smart Siren timeout
Message par pipiche »
Bonsoir et bienvenu.
1/ la sirene est-elle éloignée de la ZiGate ?
2/ peux-tu basculer sur la branche beta
git checkout beta
git pull
3/ ensuite tu supprimes les widgets qui ont été créés dans Domoticz
4/ tu relances le plugin
5/ tu refais un appairage en ayant la Sirene a proximité et branchée sur le secteur
thanks
Bonjour Pipiche,
Dans un premier temps merci pour ton aide.
Par la suite voici les informations demandées :
1/ la sirene est-elle éloignée de la ZiGate ? Elle se trouve a trois mètre de la clé usb
2/ peux-tu basculer sur la branche beta :
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo service domoticz stop
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo git checkout beta
Branch 'beta' set up to track remote branch 'beta' from 'origin'.
Switched to a new branch 'beta'
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo git pull
remote: Enumerating objects: 23, done.
remote: Counting objects: 100% (23/23), done.
remote: Compressing objects: 100% (5/5), done.
remote: Total 15 (delta 8), reused 15 (delta 8), pack-reused 0
Unpacking objects: 100% (15/15), done.
From https://github.com/zigbeefordomoticz/Domoticz-Zigbee
   9fe106fa..362f049d  zigpy      -> origin/zigpy
Already up to date.
3/ ensuite tu supprimes les widgets qui ont été créés dans Domoticz : Réalisé
2022-01-28 09:05:50.774  Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2022-01-28 09:05:50.774  Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2022-01-28 09:05:50.774  Status: Startup Path: /home/pi/domoticz/
2022-01-28 09:05:50.791  Sunrise: 08:26:00 SunSet: 18:05:00
2022-01-28 09:05:50.791  Day length: 09:38:00 Sun at south: 13:16:00
2022-01-28 09:05:50.791  Civil twilight start: 07:55:00 Civil twilight end: 18:36:00
2022-01-28 09:05:50.791  Nautical twilight start: 07:19:00 Nautical twilight end: 19:12:00
2022-01-28 09:05:50.791  Astronomical twilight start: 06:45:00 Astronomical twilight end: 19:46:00
2022-01-28 09:05:50.856  Status: PluginSystem: Started, Python version '3.7.3'.
2022-01-28 09:05:50.859  Active notification Subsystems: email (1/13)
2022-01-28 09:05:50.860  Status: WebServer(HTTP) started on address: :: with port 8080
2022-01-28 09:05:50.865  Error: [web:443] missing SSL DH parameters from file ./server_cert.pem
2022-01-28 09:05:50.865  Status: WebServer(SSL) started on address: :: with port 443
2022-01-28 09:05:50.913  Starting shared server on: :::6144
2022-01-28 09:05:50.914  Status: TCPServer: shared server started...
2022-01-28 09:05:50.914  Status: RxQueue: queue worker started...
2022-01-28 09:05:52.915  Status: Box: XiaomiGateway (ID=3): Delaying worker startup...
2022-01-28 09:05:57.915  Status: Box: XiaomiGateway (ID=3): Selected as main Gateway
2022-01-28 09:05:57.916  Status: Box: XiaomiGateway (ID=3): Worker started...
2022-01-28 09:05:57.923  Status: Meteo Eysines: Started...
2022-01-28 09:05:57.924  Status: RFXCOM: Worker started...
2022-01-28 09:05:57.925  Status: Box: XiaomiGateway (ID=3): Using 192.168.1.86 for local IP address.
2022-01-28 09:05:57.925  Status: zigate: (zigate) Entering work loop.
2022-01-28 09:05:57.924  zigate hardware started.
2022-01-28 09:05:57.926  Status: zigate: (zigate) Started.
2022-01-28 09:05:57.926  Status: NotificationSystem: thread started...
2022-01-28 09:05:57.926  Status: EventSystem: reset all events...
2022-01-28 09:05:57.927  Status: EventSystem: reset all device statuses...
2022-01-28 09:05:57.978  Status: XiaomiGateway: RGB Gateway Detected
2022-01-28 09:05:58.019  Box: Color Switch (Xiaomi RGB Gateway)
2022-01-28 09:05:58.028  Box: Temp + Humidity (Xiaomi TempHum)
2022-01-28 09:05:58.029  Box: Temp + Humidity (Xiaomi TempHum)
2022-01-28 09:05:58.030  Box: Temp + Humidity + Baro (Xiaomi TempHumBaro)
2022-01-28 09:05:58.031  Box: Temp + Humidity (Xiaomi TempHum)
2022-01-28 09:05:58.286  Status: zigate: (zigate) Initialized version 6.0, author 'zaraki673  pipiche38'
2022-01-28 09:05:58.288  zigate: (zigate) ZiGate plugin started!
2022-01-28 09:05:58.288  zigate: (zigate) load PluginConf
2022-01-28 09:05:58.289  zigate: (zigate) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2022-01-28 09:05:58.289  zigate: (zigate) is_domoticz_db_available: True
2022-01-28 09:05:58.289  zigate: (zigate) /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-21.json timestamp is 1643299210.183952
2022-01-28 09:05:58.289  zigate: (zigate) Dz PluginConf is older than Json Dz: 0 Json: 1643299210.183952
2022-01-28 09:05:58.290  Status: zigate: (zigate) channel set to 11
2022-01-28 09:05:58.290  Status: zigate: (zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-21.json
2022-01-28 09:05:58.290  Status: zigate: (zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-01-28 09:05:58.290  Status: zigate: (zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-01-28 09:05:58.290  Status: zigate: (zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2022-01-28 09:05:58.290  Status: zigate: (zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-01-28 09:05:58.290  Status: zigate: (zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-01-28 09:05:58.290  Status: zigate: (zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-01-28 09:05:58.290  Status: zigate: (zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2022-01-28 09:05:58.290  Status: zigate: (zigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-01-28 09:05:58.290  zigate: (zigate) Starting LoggingManagement thread
2022-01-28 09:05:58.290  zigate: (zigate) start_logging_thread
2022-01-28 09:05:58.291  zigate: (zigate) logging_thread - listening
2022-01-28 09:05:58.293  Status: zigate: (zigate) Zigate plugin beta-6.0.015 started
2022-01-28 09:05:58.294  Status: PluginSystem: 1 plugins started.
2022-01-28 09:05:58.304  zigate: (zigate) Plugin Database: DeviceList-21.txt
2022-01-28 09:05:58.308  Status: zigate: (zigate) DeviceConf loaded - 24 confs loaded
2022-01-28 09:05:58.429  zigate: (zigate) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2022-01-28 09:05:58.430  zigate: (zigate) is_domoticz_db_available: True
2022-01-28 09:05:58.430  Status: zigate: (zigate) DeviceConf loaded - 326 confs loaded
2022-01-28 09:05:58.430  Status: zigate: (zigate) load ListOfDevice
2022-01-28 09:05:58.448  zigate: (zigate) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2022-01-28 09:05:58.448  zigate: (zigate) is_domoticz_db_available: True
2022-01-28 09:05:58.450  Status: zigate: (zigate) 2 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-21.txt
2022-01-28 09:05:58.451  Status: zigate: (zigate) Transport mode: V2-USB
2022-01-28 09:05:58.929  Status: RFXCOM: Using serial port: /dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO5O5BHC-if00-port0
2022-01-28 09:05:58.957  Status: zigate: (zigate) ZigateTransport: Serial Connection open: Serial<id=0xaa52b970, open=True>(port='/dev/serial/by-id/usb-FTDI_ZiGate_ZIGATE+-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2022-01-28 09:05:58.959  Status: zigate: (zigate) ZigateTransport: writer_thread Thread start.
2022-01-28 09:05:58.959  Status: zigate: (zigate) ZigateTransport: thread_processing_and_sending Thread start.
2022-01-28 09:05:58.960  zigate: (zigate) Connection open: Serial<id=0xaa52b970, open=True>(port='/dev/serial/by-id/usb-FTDI_ZiGate_ZIGATE+-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2022-01-28 09:05:58.960  Status: zigate: (zigate) Start Web Server connection
2022-01-28 09:05:58.968  Status: zigate: (zigate) Web backend for Web User Interface started on port: 9440
2022-01-28 09:05:59.026  Status: Python EventSystem: Initalizing event module.
2022-01-28 09:05:59.026  Status: EventSystem: Started
2022-01-28 09:05:59.026  Status: EventSystem: Queue thread started...
2022-01-28 09:06:03.160  Status: zigate: (zigate) ==> Transport Mode switch to full mode
2022-01-28 09:06:03.161  Status: zigate: (zigate) ZiGate+ (V2)
2022-01-28 09:06:03.161  Status: zigate: (zigate) Installer Version Number: 0321
2022-01-28 09:06:03.162  Status: zigate: (zigate) Branch Version: ==> Production <==
2022-01-28 09:06:03.212  Status: zigate: (zigate) Upgrade Serial line to RTS/CTS HW flow control
2022-01-28 09:06:08.445  Meteo Eysines: Temp + Humidity + Baro (Meteo Eysines)
2022-01-28 09:06:08.447  Meteo Eysines: Wind (Unknown)
2022-01-28 09:06:08.448  Meteo Eysines: UV (UV Index)
2022-01-28 09:06:08.450  Meteo Eysines: Rain (Rain)
2022-01-28 09:06:08.453  Meteo Eysines: General/Visibility (Unknown)
2022-01-28 09:06:08.454  Meteo Eysines: General/Custom Sensor (Ozone Sensor)
2022-01-28 09:06:08.455  Meteo Eysines: General/Percentage (Cloud Cover)
2022-01-28 09:06:13.124  Status: zigate: (zigate) Zigate addresses ieee: 00158d0006a3fcbb , short addr: 0000
2022-01-28 09:06:13.125  Status: zigate: (zigate) Network state UP, PANID: 8131 extPANID: 0xe6eb7e709aecf247 Channel: 11
2022-01-28 09:06:18.066  Status: zigate: (zigate) Request Disabling Accepting new Hardware
2022-01-28 09:06:18.066  zigate: (zigate) zdp_permit_joining_request FFFC 00 00
2022-01-28 09:06:18.598  Status: zigate: (zigate) Accepting new Hardware: Disable (Off)
2022-01-28 09:06:23.075  zigate: (zigate) Switch Blue Led On
2022-01-28 09:06:23.075  Status: zigate: (zigate) Zigate set to Certification : CE
2022-01-28 09:06:23.078  Status: zigate: (zigate) Plugin with Zigate+, firmware 0321 correctly initialized
2022-01-28 09:06:23.877  Status: Incoming connection from: 192.168.1.2
2022-01-28 09:06:32.234  zigate: (zigate) removeDeviceInList - request to remove Device: 45c1 with IEEE: 847127fffead4501
2022-01-28 09:06:32.235  zigate: (zigate) removeDeviceInList - removing : 154 with Ep: 01 in - {'154': 'Voltage', '155': 'Door', '156': 'AlarmWD'}
2022-01-28 09:06:32.235  zigate: (zigate) removeDeviceInList - exitsing Ep 'ClusterTpe'
2022-01-28 09:06:32.237  Status: zigate: (zigate) onDeviceRemoved - removing End Device
2022-01-28 09:06:36.898  zigate: (zigate) removeDeviceInList - request to remove Device: 45c1 with IEEE: 847127fffead4501
2022-01-28 09:06:36.898  zigate: (zigate) removeDeviceInList - removing : 155 with Ep: 01 in - {'155': 'Door', '156': 'AlarmWD'}
2022-01-28 09:06:36.898  zigate: (zigate) removeDeviceInList - exitsing Ep 'ClusterTpe'
2022-01-28 09:06:36.900  Status: zigate: (zigate) onDeviceRemoved - removing End Device
2022-01-28 09:06:40.359  zigate: (zigate) removeDeviceInList - request to remove Device: 45c1 with IEEE: 847127fffead4501
2022-01-28 09:06:40.359  zigate: (zigate) removeDeviceInList - removing : 156 with Ep: 01 in - {'156': 'AlarmWD'}
2022-01-28 09:06:40.359  zigate: (zigate) removeDeviceInList - exitsing Ep 'ClusterTpe'
2022-01-28 09:06:40.361  Status: zigate: (zigate) onDeviceRemoved - removing End Device
2022-01-28 09:06:40.364  Status: zigate: (zigate) Device Sirène Zigbee with IEEE: 847127fffead4501 fully removed from the system.
2022-01-28 09:06:40.365  zigate: (zigate) zdp_management_leave_request 45c1 847127fffead4501 00 00
2022-01-28 09:06:40.365  Status: zigate: (zigate) onDeviceRemoved - removing Device Sirène Zigbee -> 847127fffead4501 in Zigate
2022-01-28 09:06:46.970  zigate: (zigate) Remove Device cmd statusSuccess
2022-01-28 09:08:53.164  Status: zigate: (zigate) Zigate addresses ieee: 00158d0006a3fcbb , short addr: 0000
2022-01-28 09:08:53.165  Status: zigate: (zigate) Network state UP, PANID: 8131 extPANID: 0xe6eb7e709aecf247 Channel: 11
2022-01-28 09:08:58.091  Status: zigate: (zigate) Request Disabling Accepting new Hardware
2022-01-28 09:08:58.092  zigate: (zigate) zdp_permit_joining_request FFFC 00 00
2022-01-28 09:08:58.578  Status: zigate: (zigate) Accepting new Hardware: Disable (Off)
2022-01-28 09:09:03.099  zigate: (zigate) Switch Blue Led On
2022-01-28 09:09:03.099  Status: zigate: (zigate) Zigate set to Certification : CE
2022-01-28 09:09:03.102  Status: zigate: (zigate) Plugin with Zigate+, firmware 0321 correctly initialized
2022-01-28 09:09:55.931  Error: zigate: (zigate) No transport, write directive to '192.168.1.2:55494' ignored.
2022-01-28 09:09:55.932  Error: zigate: (zigate) No transport, write directive to '192.168.1.2:55489' ignored.
2022-01-28 09:10:01.663  Status: zigate: (zigate) Request Accepting new Hardware for ever
2022-01-28 09:10:01.664  zigate: (zigate) zdp_permit_joining_request FFFC ff 00
2022-01-28 09:10:01.834  Status: zigate: (zigate) Accepting new Hardware: Enable (On)
2022-01-28 09:10:03.569  zigate: (zigate) zdp_permit_joining_request FFFC ff 00
2022-01-28 09:10:24.929  zigate: (zigate) --> Adding device 45c1 in self.DevicesInPairingMode
2022-01-28 09:10:24.929  zigate: (zigate) --> ['45c1']
2022-01-28 09:10:24.929  Status: zigate: (zigate) [None] NEW OBJECT: 45c1 None
2022-01-28 09:10:24.930  zigate: (zigate) zdp_simple_descriptor_request 45c1
2022-01-28 09:10:24.930  zigate: (zigate) zdp_raw_active_endpoint_request 45c1
2022-01-28 09:10:25.103  Status: zigate: (zigate) [-] NEW OBJECT: 45c1 Active Endpoint Response Ep: 01 LQI: 75
2022-01-28 09:10:25.103  Status: zigate: (zigate) [-] NEW OBJECT: 45c1 Active Endpoint Response Ep: f2 LQI: 75
2022-01-28 09:10:25.103  Status: zigate: (zigate) [-] NEW OBJECT: 45c1 Request Simple Descriptor for Ep: 01
2022-01-28 09:10:25.104  zigate: (zigate) zdp_active_endpoint_request 45c1 01
2022-01-28 09:10:25.104  Status: zigate: (zigate) [-] NEW OBJECT: 45c1 Request Simple Descriptor for Ep: f2
2022-01-28 09:10:25.104  zigate: (zigate) zdp_active_endpoint_request 45c1 f2
2022-01-28 09:10:25.213  Status: zigate: (zigate) [-] NEW OBJECT: 45c1 Simple Descriptor Response EP: 0x01 LQI: 73
2022-01-28 09:10:25.213  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 ProfileID 0104
2022-01-28 09:10:25.213  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 ZDeviceID 0403
2022-01-28 09:10:25.214  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 Application Version 0001
2022-01-28 09:10:25.214  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 Cluster IN Count: 07
2022-01-28 09:10:25.214  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster In 1: 0000 (Basic)
2022-01-28 09:10:25.214  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster In 2: 0001 (Power Configuration)
2022-01-28 09:10:25.214  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster In 3: 0003 (Identify)
2022-01-28 09:10:25.214  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster In 4: 0004 (Groups)
2022-01-28 09:10:25.215  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster In 5: 0500 (IAS Zone)
2022-01-28 09:10:25.215  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster In 6: 0502 (IAS WD (Warning Device))
2022-01-28 09:10:25.215  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster In 7: 0b05 (Diagnostics)
2022-01-28 09:10:25.215  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 Cluster OUT Count: 01
2022-01-28 09:10:25.215  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2022-01-28 09:10:25.316  Status: zigate: (zigate) [-] NEW OBJECT: 45c1 Simple Descriptor Response EP: 0xf2 LQI: 73
2022-01-28 09:10:25.316  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 ProfileID a1e0
2022-01-28 09:10:25.316  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 ZDeviceID 0061
2022-01-28 09:10:25.316  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 Application Version 0001
2022-01-28 09:10:25.316  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 Cluster IN Count: 00
2022-01-28 09:10:25.316  Status: zigate: (zigate) [-]    NEW OBJECT: 45c1 Cluster OUT Count: 01
2022-01-28 09:10:25.316  Status: zigate: (zigate) [-]       NEW OBJECT: 45c1 Cluster Out 1: 0021
2022-01-28 09:10:28.070  zigate: (zigate) Request Basic  Manufacturer via Read Attribute request: 0004
2022-01-28 09:10:28.071  zigate: (zigate) EP: {'01': {'0000': {}, '0001': {}, '0003': {}, '0004': {}, '0500': {}, '0502': {}, '0b05': {}, '0019': {}}, 'f2': {'0021': {}}}
2022-01-28 09:10:28.071  Status: zigate: (zigate) [None] NEW OBJECT: 45c1 Request Node Descriptor
2022-01-28 09:10:28.072  zigate: (zigate) zdp_node_descriptor_request 45c1
2022-01-28 09:10:33.088  Status: zigate: (zigate) [1] NEW OBJECT: 45c1 Model Name: WarningDevice-EF-3.0
2022-01-28 09:10:33.090  zigate: (zigate) EP: {'01': {'0000': {'0004': 'HEIMAN', '0005': 'WarningDevice-EF-3.0'}, '0001': {}, '0003': {}, '0004': {}, '0500': {}, '0502': {}, '0b05': {}, '0019': {}}, 'f2': {'0021': {}}}
2022-01-28 09:10:38.106  Status: zigate: (zigate) [2] NEW OBJECT: 45c1 Model Name: WarningDevice-EF-3.0
2022-01-28 09:10:38.110  zigate: (zigate) EP: {'01': {'0000': {'0004': 'HEIMAN', '0005': 'WarningDevice-EF-3.0'}, '0001': {}, '0003': {}, '0004': {}, '0500': {}, '0502': {}, '0b05': {}, '0019': {}}, 'f2': {'0021': {}}}
2022-01-28 09:10:38.169  zigate: (zigate) WARNING - send_zigatecmd : [38] 0100 0245c10101000100000000010035 45c1 ZigateQueue: 16
2022-01-28 09:10:38.170  zigate: (zigate) WARNING - send_zigatecmd : [39] 0100 0245c10101001900000000010001 45c1 ZigateQueue: 17
2022-01-28 09:10:38.171  zigate: (zigate) WARNING - send_zigatecmd : [40] 0100 0245c10101001900000000010002 45c1 ZigateQueue: 18
2022-01-28 09:10:38.171  zigate: (zigate) WARNING - send_zigatecmd : [41] 0100 0245c10101001900000000010003 45c1 ZigateQueue: 19
2022-01-28 09:10:38.172  zigate: (zigate) WARNING - send_zigatecmd : [42] 0100 0245c10101001900000000010004 45c1 ZigateQueue: 20
2022-01-28 09:10:38.172  zigate: (zigate) WARNING - send_zigatecmd : [43] 0100 0245c10101001900000000010005 45c1 ZigateQueue: 21
2022-01-28 09:10:38.174  zigate: (zigate) WARNING - send_zigatecmd : [44] 0100 0245c10101001900000000010006 45c1 ZigateQueue: 22
2022-01-28 09:10:38.174  zigate: (zigate) WARNING - send_zigatecmd : [45] 0100 0245c10101001900000000010007 45c1 ZigateQueue: 23
2022-01-28 09:10:38.175  zigate: (zigate) WARNING - send_zigatecmd : [46] 0100 0245c10101001900000000010008 45c1 ZigateQueue: 24
2022-01-28 09:10:38.175  zigate: (zigate) WARNING - send_zigatecmd : [47] 0100 0245c10101001900000000010009 45c1 ZigateQueue: 25
2022-01-28 09:10:38.176  zigate: (zigate) WARNING - send_zigatecmd : [48] 0100 0245c1010100190000000001000a 45c1 ZigateQueue: 26
2022-01-28 09:10:38.177  zigate: (zigate) WARNING - send_zigatecmd : [49] 0100 0245c10101050200000000010000 45c1 ZigateQueue: 27
2022-01-28 09:10:38.185  zigate: (zigate) WARNING - send_zigatecmd : [50] 0100 0245c10101000000000000010004 45c1 ZigateQueue: 28
2022-01-28 09:10:38.186  zigate: (zigate) WARNING - send_zigatecmd : [51] 0100 0245c10101000000000000010005 45c1 ZigateQueue: 29
2022-01-28 09:10:38.186  zigate: (zigate) WARNING - send_zigatecmd : [52] 0100 0245c10101000000000000010000 45c1 ZigateQueue: 30
2022-01-28 09:10:38.187  zigate: (zigate) WARNING - send_zigatecmd : [53] 0100 0245c10101000000000000010001 45c1 ZigateQueue: 31
2022-01-28 09:10:38.187  zigate: (zigate) WARNING - send_zigatecmd : [54] 0100 0245c10101000000000000010002 45c1 ZigateQueue: 32
2022-01-28 09:10:38.188  zigate: (zigate) WARNING - send_zigatecmd : [55] 0100 0245c10101000000000000010003 45c1 ZigateQueue: 33
2022-01-28 09:10:38.189  zigate: (zigate) WARNING - send_zigatecmd : [56] 0100 0245c10101000000000000010006 45c1 ZigateQueue: 34
2022-01-28 09:10:38.194  zigate: (zigate) WARNING - send_zigatecmd : [57] 0100 0245c10101000000000000010007 45c1 ZigateQueue: 35
2022-01-28 09:10:38.195  zigate: (zigate) WARNING - send_zigatecmd : [58] 0100 0245c1010100000000000001000a 45c1 ZigateQueue: 36
2022-01-28 09:10:38.196  zigate: (zigate) WARNING - send_zigatecmd : [59] 0100 0245c1010100000000000001000f 45c1 ZigateQueue: 37
2022-01-28 09:10:38.196  zigate: (zigate) WARNING - send_zigatecmd : [60] 0100 0245c10101000000000000010010 45c1 ZigateQueue: 38
2022-01-28 09:10:38.197  zigate: (zigate) WARNING - send_zigatecmd : [61] 0100 0245c10101000000000000010015 45c1 ZigateQueue: 39
2022-01-28 09:10:38.197  zigate: (zigate) WARNING - send_zigatecmd : [62] 0100 0245c10101000000000000014000 45c1 ZigateQueue: 40
2022-01-28 09:10:38.198  zigate: (zigate) WARNING - send_zigatecmd : [63] 0100 0245c1010100000000000001f000 45c1 ZigateQueue: 41
2022-01-28 09:10:38.198  Status: zigate: (zigate) [2] NEW OBJECT: 45c1 0x8043 - IAS Zone controler setting
2022-01-28 09:10:38.201  Status: zigate: (zigate) [2] NEW OBJECT: 45c1 0x8043 - IAS WD enrolment
2022-01-28 09:10:38.202  zigate: (zigate) WARNING - send_zigatecmd : [66] 45c1               0140 None ZigateQueue: 44
2022-01-28 09:10:38.202  zigate: (zigate) WARNING - send_zigatecmd : [None] 45c1               0140 None ZigateQueue: 44
2022-01-28 09:10:38.203  zigate: (zigate) WARNING - send_zigatecmd : [None] 45c1               0140 None ZigateQueue: 44
2022-01-28 09:10:38.204  zigate: (zigate) WARNING - send_zigatecmd : [None] 45c1               0140 None ZigateQueue: 44
2022-01-28 09:10:38.210  zigate: (zigate) WARNING - send_zigatecmd : [67] 0530 0245c10000003300000200020100 None ZigateQueue: 45
2022-01-28 09:10:38.212  zigate: (zigate) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2022-01-28 09:10:38.212  zigate: (zigate) is_domoticz_db_available: True
2022-01-28 09:10:38.357  Error: zigate: (zigate) Decode8000 - PacketType: 45c1 TypeSqn: 00 sqn_app: 00 sqn_aps: da Status: [Unhandled Command]
2022-01-28 09:10:44.799  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_Voltage-847127fffead4501-01) 0:41.0;41.0
Apres quelques tests raproché le widget passe en rouge.
Voici le log du test :
2022-01-28 09:10:56.517  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_Door-847127fffead4501-01) 0:Closed
2022-01-28 09:11:04.835  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_Voltage-847127fffead4501-01 -> True from 0:41.0;41.0
2022-01-28 09:11:04.840  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_Door-847127fffead4501-01 -> True from 0:Closed
2022-01-28 09:11:04.845  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01 -> True from 0:
2022-01-28 09:11:04.852  zigate: (zigate) Receive NACK from 45c1 clusterId: 8033 Status: a7
2022-01-28 09:11:25.017  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_Voltage-847127fffead4501-01 -> False from 0:41.0;41.0
2022-01-28 09:11:25.021  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_Door-847127fffead4501-01 -> False from 0:Closed
2022-01-28 09:11:25.026  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01 -> False from 0:
2022-01-28 09:11:41.511  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_Door-847127fffead4501-01) 0:Closed
2022-01-28 09:13:07.661  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:07.694  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 1:10
2022-01-28 09:13:10.517  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:10.557  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 0:Off
2022-01-28 09:13:11.734  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:11.774  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 1:10
2022-01-28 09:13:13.268  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:13.291  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 0:Off
2022-01-28 09:13:15.670  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:15.709  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 1:10
2022-01-28 09:13:17.029  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:17.068  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 0:Off
2022-01-28 09:13:21.059  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:21.091  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 1:10
2022-01-28 09:13:22.880  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:22.908  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 1:20
2022-01-28 09:13:27.561  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:27.583  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 0:Off
2022-01-28 09:13:31.628  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:31.655  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 1:30
2022-01-28 09:13:33.637  Status: User: Admin (IP: 192.168.1.2) initiated a switch command (156/zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01/Set Level)
2022-01-28 09:13:33.679  zigate: (zigate) UpdateDevice - (zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01) 0:Off
2022-01-28 09:13:38.115  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_Voltage-847127fffead4501-01 -> True from 0:41.0;41.0
2022-01-28 09:13:38.118  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_Door-847127fffead4501-01 -> True from 0:Closed
2022-01-28 09:13:38.126  zigate: (zigate) timeout_widget unit zigate - WarningDevice-EF-3.0_AlarmWD-847127fffead4501-01 -> True from 0:Off
2022-01-28 09:13:38.136  zigate: (zigate) Receive NACK from 45c1 clusterId: 0502 Status: a7
2022-01-28 09:13:44.594  zigate: (zigate) Receive NACK from 45c1 clusterId: 0502 Status: a7
Voici le retour de l'interface web :
Merci d'avance.
pipiche
Ton cas, semble indiquer que la sirène quitte le réseau lors de l'appairage ou a la fin de l'appairage
Il faut savoir que quand tu fais le reset de la sirène il faut en fonction de la situation
la supprimer d'un réseau existant puis l'appairer ou l'appairer directement
Pour l'appairage il faut reset 4 secondes appuyé pour que le voyant vert se mette a clignoter
Pour le de-appairage il faut reset 8 à 10 secondes
Pour partir d'une situation clean peux-tu
1/ arrêter le plugin et/ou Domoticz
2/ retirer la clef Zigate
3/ faire un reset de la sirène. Rester appuyer jusqu'au clignotement vert
- normalement tu devrais avoir à appuyer uniquement 4 secondes avant que ca clignote (puisqu'elle est censé ne plus être appairée)
4/ attendre l’arrêt du clignotement
5/ rebrancher la clef, relancer domoticz et le plugin
5/ supprimer les widgets de domoticz (vérifier que c'est bien supprimé du Plugin via le WebUI)
5/ Mettre la Zigate en appairage
6/ Faire un reset ( 4s )
Si problème, peux-tu joindre le fichier de log et pas simplement un extract. merci
thanks
Merci encore une fois pour ton aide.
Tous semble marcher correctement maintenant et je penses que mon erreur vient que j’appuyai 10 secondes sur le bouton comme expliquer sur le site de zigate : https://zigate.fr/le-materiel-compatibl ... rneheiman/
Petites question annexe, puis-je utiliser un autre channel que le 11, comme par exemple le 20 pour limiter les interférences en wifi ou cela provoque une instabilité quelconque ?
Je ferais un retour ce soir car je vais tester durant l'ensemble de la journée pour voir si tout est ok.
pipiche
je te recommande le Wiki qui a pas mal d'information
https://github.com/zigbeefordomoticz/wi ... -ZigBee.md
Modération
Si le sujet est terminé, merci de bien vouloir modifier le premier message de cette discussion pour indiquer [Résolu] dans le titre du sujet. Comment faire ? Voir le sujet [A lire avant de poster] Guide pour bien formuler une demande.
thanks
Re: [Résolu] Smart Siren timeout
Un grand merci a toi pipiche pour ton aide au top :)
