2022-08-09 20:40:17.337 Status: Zigbee: Stop directive received.
2022-08-09 20:40:17.338 Zigbee: onStop()
2022-08-09 20:40:17.340 Status: Zigbee: Shuting down co-routine
2022-08-09 20:40:17.340 Status: Zigbee: ZigpyTransport: thread_processing_and_sending Thread stop.
2022-08-09 20:40:19.356 Zigbee: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-08-09 20:40:19.357 Zigbee: is_domoticz_db_available: True
2022-08-09 20:40:19.357 Status: Zigbee: Statistics on message
2022-08-09 20:40:19.357 Status: Zigbee: PDM load(s) : 0
2022-08-09 20:40:19.357 Status: Zigbee: ZiGate reacting time
2022-08-09 20:40:19.357 Status: Zigbee: Max : 0 sec
2022-08-09 20:40:19.357 Status: Zigbee: Average : 0 sec
2022-08-09 20:40:19.357 Status: Zigbee: ZiGate processing time on Rx
2022-08-09 20:40:19.357 Status: Zigbee: Sent:
2022-08-09 20:40:19.357 Status: Zigbee: TX commands : 11
2022-08-09 20:40:19.357 Status: Zigbee: Max Load (Queue) : 1
2022-08-09 20:40:19.357 Status: Zigbee: Max aPDU (Queue) : 0
2022-08-09 20:40:19.357 Status: Zigbee: Max nPDU (Queue) : 0
2022-08-09 20:40:19.357 Status: Zigbee: TX failed : 0 (0.0%)
2022-08-09 20:40:19.357 Status: Zigbee: TX timeout : 0 (0.0%)
2022-08-09 20:40:19.357 Status: Zigbee: TX data timeout : 0 (0.0%)
2022-08-09 20:40:19.357 Status: Zigbee: TX reTransmit : 0 (0.0%)
2022-08-09 20:40:19.357 Status: Zigbee: TX APS Failure : 0 (0.0%)
2022-08-09 20:40:19.357 Status: Zigbee: TX APS Ack : 3 (27.27%)
2022-08-09 20:40:19.357 Status: Zigbee: TX APS Nck : 0 (0.0%)
2022-08-09 20:40:19.357 Status: Zigbee: Received:
2022-08-09 20:40:19.357 Status: Zigbee: RX frame : 66
2022-08-09 20:40:19.357 Status: Zigbee: RX crc errors : 0 (0.0%)
2022-08-09 20:40:19.357 Status: Zigbee: RX lentgh errors : 0 (0.0%)
2022-08-09 20:40:19.357 Status: Zigbee: RX clusters : 8
2022-08-09 20:40:19.357 Status: Zigbee: RX clusters KO : 0
2022-08-09 20:40:19.357 Status: Zigbee: Operating time : 0 Hours 4 Mins 45 Secs
2022-08-09 20:40:19.359 Zigbee: logging_thread - ended
2022-08-09 20:40:19.363 Zigbee: Logging Thread shutdown
2022-08-09 20:40:19.363 Zigbee: onStop called (6) Close Logging Management
2022-08-09 20:40:19.492 Error: (FindModule) Domoticz/DomoticzEx modules not found in interpreter.
2022-08-09 20:40:19.519 Status: Zigbee: Exiting work loop.
2022-08-09 20:40:19.542 Status: Zigbee: Stopping threads.
2022-08-09 20:40:19.543 Status: Zigbee: Stopped.
2022-08-09 20:40:19.543 Zigbee: Worker thread started.
2022-08-09 20:40:19.543 Status: Zigbee: Started.
2022-08-09 20:40:19.543 Status: Zigbee: Entering work loop.
2022-08-09 20:40:20.205 Status: Zigbee: Initialized version 6.2, author 'pipiche38'
2022-08-09 20:40:20.207 Zigbee: Zigbee for Domoticz plugin started!
2022-08-09 20:40:20.208 Status: Zigbee: Checking Python modules /home/laurent/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2022-08-09 20:40:20.628 Zigbee: load PluginConf
2022-08-09 20:40:20.629 Zigbee: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-08-09 20:40:20.629 Zigbee: is_domoticz_db_available: True
2022-08-09 20:40:20.629 Zigbee: /home/laurent/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-05.json timestamp is 1659965721.8738413
2022-08-09 20:40:20.629 Zigbee: Dz PluginConf is older than Json Dz: 0 Json: 1659965721.8738413
2022-08-09 20:40:20.630 Zigbee: is_domoticz_db_available: True
2022-08-09 20:40:20.630 Status: Zigbee: PluginAnalytics set to 1
2022-08-09 20:40:20.630 Status: Zigbee: channel set to 24
2022-08-09 20:40:20.630 Status: Zigbee: filename set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-05.json
2022-08-09 20:40:20.630 Status: Zigbee: pluginHome set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/
2022-08-09 20:40:20.630 Status: Zigbee: homedirectory set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/
2022-08-09 20:40:20.630 Status: Zigbee: pluginData set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/Data/
2022-08-09 20:40:20.630 Status: Zigbee: pluginConfig set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-08-09 20:40:20.630 Status: Zigbee: pluginOTAFirmware set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-08-09 20:40:20.630 Status: Zigbee: pluginReports set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-08-09 20:40:20.630 Status: Zigbee: pluginWWW set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/www/
2022-08-09 20:40:20.630 Status: Zigbee: pluginLogs set to /home/laurent/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-08-09 20:40:20.630 Status: Zigbee: ControllerInRawMode set to True
2022-08-09 20:40:20.630 Zigbee: Installing plugin custom page /home/laurent/domoticz/www/templates/Zigbee.html
2022-08-09 20:40:20.630 Zigbee: Starting LoggingManagement thread
2022-08-09 20:40:20.631 Zigbee: start_logging_thread
2022-08-09 20:40:20.631 Zigbee: logging_thread - listening
2022-08-09 20:40:20.631 Status: Zigbee: Please watch plugin log into /home/laurent/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_05.log
2022-08-09 20:40:20.635 Status: Zigbee: Zigate plugin stable6-6.1.005 started
2022-08-09 20:40:20.650 Status: Zigbee: DeviceConf loaded - 22 confs loaded
2022-08-09 20:40:20.828 Zigbee: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-08-09 20:40:20.828 Zigbee: is_domoticz_db_available: True
2022-08-09 20:40:20.829 Status: Zigbee: DeviceConf loaded - 344 confs loaded
2022-08-09 20:40:20.835 Status: Zigbee: load ListOfDevice
2022-08-09 20:40:20.842 Error: Zigbee: Not Loading 074c as Status: UNKNOW
2022-08-09 20:40:20.846 Zigbee: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-08-09 20:40:20.846 Zigbee: is_domoticz_db_available: True
2022-08-09 20:40:20.847 Status: Zigbee: 2 Entries loaded from /home/laurent/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-5.txt
2022-08-09 20:40:20.848 Error: Zigbee: checkListOfDevice2Devices - Séjour - 00124b00251cc707 not found in Plugin Database
2022-08-09 20:40:20.850 Error: Zigbee: checkListOfDevice2Devices - Télécommande - 8cf681fffef2512f not found in Plugin Database
2022-08-09 20:40:20.853 Error: Zigbee: checkListOfDevice2Devices - Chambre - 00124b0022cf0a12 not found in Plugin Database
2022-08-09 20:40:20.862 Error: Zigbee: checkListOfDevice2Devices - Chambre SE - 00124b0022cf0924 not found in Plugin Database
2022-08-09 20:40:20.865 Error: Zigbee: checkListOfDevice2Devices - Salle d'eau - 00124b0022cf0973 not found in Plugin Database
2022-08-09 20:40:20.875 Error: Zigbee: checkListOfDevice2Devices - Détecteur fumée RDC - 84fd27fffe0682a6 not found in Plugin Database
2022-08-09 20:40:20.878 Error: Zigbee: checkListOfDevice2Devices - Détecteur fumée étage - 804b50fffeff0d0b not found in Plugin Database
2022-08-09 20:40:20.881 Error: Zigbee: checkListOfDevice2Devices - Buanderie - 00124b002518fdfb not found in Plugin Database
2022-08-09 20:40:20.892 Error: Zigbee: checkListOfDevice2Devices - Salle de bain - 00124b0025118c6a not found in Plugin Database
2022-08-09 20:40:20.895 Status: Zigbee: Transport mode: ZigpyZNP
2022-08-09 20:40:21.691 Zigbee: Start Zigpy Transport on ZNP
2022-08-09 20:40:21.697 Status: Zigbee: ZigpyTransport: thread_processing_and_sending Thread start.
2022-08-09 20:40:21.697 Status: Zigbee: Start Web Server connection
2022-08-09 20:40:21.706 Status: Zigbee: Web backend for Web User Interface started on port: 9440
2022-08-09 20:40:29.835 Status: Zigbee: Accepting new Hardware: Disable (Off)
2022-08-09 20:40:30.827 Error: EventSystem: Warning!, lua script Capteur d'ouverture garage has been running for more than 10 seconds
2022-08-09 20:40:34.382 Status: Zigbee: Device Annoucement: NwkId: aa9d Ieee: 00124b0022cf0b7b MacCap: 80
2022-08-09 20:40:39.528 Météo: Temp + Humidity + Baro (Météo)
2022-08-09 20:40:39.530 Météo: Wind (Vent/Température)
2022-08-09 20:40:39.533 Météo: Rain (Pluie)
2022-08-09 20:40:41.363 Status: Zigbee: Number of devices recently active in Zigate = 0
2022-08-09 20:40:41.363 Status: Zigbee: CC1352/CC2652, Z-Stack 3.30+ (znp)
2022-08-09 20:40:41.363 Status: Zigbee: Installer Version Number: 0708
2022-08-09 20:40:41.364 Status: Zigbee: Branch Version: ==> CC1352/CC2652, Z-Stack 3.30+ (znp) <==
2022-08-09 20:40:41.368 Status: Zigbee: Zigbee Coordinator ieee: 00124b00257cafd2 , short addr: 0000
2022-08-09 20:40:41.368 Status: Zigbee: Network state UP, PANID: 7ee7 extPANID: 0xe4e2a5a4516ef948 Channel: 24
2022-08-09 20:40:50.070 Status: Zigbee: Request Disabling Accepting new Hardware
2022-08-09 20:40:50.137 Status: Zigbee: Accepting new Hardware: Disable (Off)
2022-08-09 20:40:55.088 Status: Zigbee: Zigate set to Certification : 1/CE -> CE
2022-08-09 20:40:55.090 Status: Zigbee: Plugin with Zigpy, Coordinator CC1352/CC2652, Z-Stack 3.30+ (znp) firmware Znp - (....0708) correctly initialized
2022-08-09 20:41:00.127 Error: Zigbee: processNotinDBDevices - Devices already exist. Salle TV with {'Version': '3', 'ZDeviceName': '', 'Status': '0043', 'SQN': 'fb', 'Ep': {'01': {'0000': {'0004': 'eWeLink', '0005': 'TH01'}, '0001': {'0020': 29, '0021': 190}, '0003': {}, '0402': {'0000': 2616}, '0405': {}, 'Type': 'Temp/Humi'}}, 'Heartbeat': '2111', 'RIA': '6', 'LQI': 60, 'Battery': 190.0, 'Model': 'TH01', 'ForceAckCommands': [], 'MacCapa': '80', 'IEEE': '00124b0022cf0b7b', 'Type': '', 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'End Device', 'Manufacturer': '0000', 'Manufacturer Name': 'eWeLink', 'NbEp': '1', 'PowerSource': 'Battery', 'ReadAttributes': {'Ep': {'01': {'0001': {'TimeStamp': 1659966635, 'iSQN': {}, 'Attributes': {'0020': '00', '0021': '00'}, 'ZigateRequest': {}}, '0000': {'TimeStamp': 1659966636, 'iSQN': {'0004': '00', '0005': '01'}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}, '0402': {'TimeStamp': 1660070390, 'iSQN': {}, 'Attributes': {'0000': '00'}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': 'Off', 'Stack Version': '', 'Stamp': {'time': 1660070434.3893442, 'Time': '2022-08-09 20:40:34', 'MsgType': ' 4d', 'LastSeen': 1660070434}, 'ZCL Version': '', 'Health': 'Live', 'ConfigSource': 'DeviceConf', 'Epv2': {'01': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}}, 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'BatteryUpdateTime': 1659966635, 'ConsistencyCheck': '', 'PairingInProgress': True}
2022-08-09 20:41:00.128 Error: Zigbee: processNotinDBDevices - Please cross check the consistency of the Domoticz and Plugin database.
2022-08-09 20:41:00.129 Status: Zigbee: [6] NEW OBJECT: aa9d Model Name: TH01
2022-08-09 20:41:00.129 Status: Zigbee: [6] NEW OBJECT: aa9d Manufacturer Name: eWeLink
2022-08-09 20:41:05.102 Error: Zigbee: processNotinDBDevices - Devices already exist. Salle TV with {'Version': '3', 'ZDeviceName': '', 'Status': '0043', 'SQN': 'fb', 'Ep': {'01': {'0000': {'0004': 'eWeLink', '0005': 'TH01'}, '0001': {'0020': 29, '0021': 190}, '0003': {}, '0402': {'0000': 2616}, '0405': {}, 'Type': 'Temp/Humi'}}, 'Heartbeat': '2112', 'RIA': '6', 'LQI': 60, 'Battery': 190.0, 'Model': 'TH01', 'ForceAckCommands': [], 'MacCapa': '80', 'IEEE': '00124b0022cf0b7b', 'Type': '', 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'End Device', 'Manufacturer': '0000', 'Manufacturer Name': 'eWeLink', 'NbEp': '1', 'PowerSource': 'Battery', 'ReadAttributes': {'Ep': {'01': {'0001': {'TimeStamp': 1659966635, 'iSQN': {}, 'Attributes': {'0020': '00', '0021': '00'}, 'ZigateRequest': {}}, '0000': {'TimeStamp': 1659966636, 'iSQN': {'0004': '00', '0005': '01'}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}, '0402': {'TimeStamp': 1660070390, 'iSQN': {}, 'Attributes': {'0000': '00'}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': 'Off', 'Stack Version': '', 'Stamp': {'time': 1660070434.3893442, 'Time': '2022-08-09 20:40:34', 'MsgType': ' 4d', 'LastSeen': 1660070434}, 'ZCL Version': '', 'Health': 'Live', 'ConfigSource': 'DeviceConf', 'Epv2': {'01': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}}, 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'BatteryUpdateTime': 1659966635, 'ConsistencyCheck': '', 'PairingInProgress': True}
2022-08-09 20:41:05.102 Error: Zigbee: processNotinDBDevices - Please cross check the consistency of the Domoticz and Plugin database.
2022-08-09 20:41:05.104 Status: Zigbee: [6] NEW OBJECT: aa9d Model Name: TH01
2022-08-09 20:41:05.104 Status: Zigbee: [6] NEW OBJECT: aa9d Manufacturer Name: eWeLink
2022-08-09 20:41:10.073 Error: Zigbee: processNotinDBDevices - Devices already exist. Salle TV with {'Version': '3', 'ZDeviceName': '', 'Status': '0043', 'SQN': 'fb', 'Ep': {'01': {'0000': {'0004': 'eWeLink', '0005': 'TH01'}, '0001': {'0020': 29, '0021': 190}, '0003': {}, '0402': {'0000': 2616}, '0405': {}, 'Type': 'Temp/Humi'}}, 'Heartbeat': '2113', 'RIA': '6', 'LQI': 60, 'Battery': 190.0, 'Model': 'TH01', 'ForceAckCommands': [], 'MacCapa': '80', 'IEEE': '00124b0022cf0b7b', 'Type': '', 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'End Device', 'Manufacturer': '0000', 'Manufacturer Name': 'eWeLink', 'NbEp': '1', 'PowerSource': 'Battery', 'ReadAttributes': {'Ep': {'01': {'0001': {'TimeStamp': 1659966635, 'iSQN': {}, 'Attributes': {'0020': '00', '0021': '00'}, 'ZigateRequest': {}}, '0000': {'TimeStamp': 1659966636, 'iSQN': {'0004': '00', '0005': '01'}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}, '0402': {'TimeStamp': 1660070390, 'iSQN': {}, 'Attributes': {'0000': '00'}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': 'Off', 'Stack Version': '', 'Stamp': {'time': 1660070434.3893442, 'Time': '2022-08-09 20:40:34', 'MsgType': ' 4d', 'LastSeen': 1660070434}, 'ZCL Version': '', 'Health': 'Live', 'ConfigSource': 'DeviceConf', 'Epv2': {'01': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}}, 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'BatteryUpdateTime': 1659966635, 'ConsistencyCheck': '', 'PairingInProgress': True}
2022-08-09 20:41:10.073 Error: Zigbee: processNotinDBDevices - Please cross check the consistency of the Domoticz and Plugin database.
