Alors je fais la manip pour mettre à jour le plugin de mon zigate+ et la c'est la galère qui commence.
le module python cryptography ne veut pas s'installer (un problème avec rustc ???) pas grave, j'installe une version ultérieure puis je rafais les manips de maj du plugin,la ça passe, il n'y a plus d'erreurs. Mais dans les logs de DZ (après 1000 restart/reboot manuel) j'ai toujours ce message qui apparait au demmarage
2022-10-09 11:50:20.136 Error: Zigate: Looks like click python module is not installed. Make sure to install the required python3 module
2022-10-09 11:50:20.136 Error: Zigate: Use the command:
2022-10-09 11:50:20.136 Error: Zigate: sudo pip3 install -r requirements.txtEnsuite régulièrement je plugin me dit :
2022-10-09 11:44:00.385 Error: Zigate: 'onCommand' failed 'AttributeError':''NoneType' object has no attribute 'logging''.
2022-10-09 11:44:00.386 Error: Zigate: Exception traceback:
2022-10-09 11:44:00.386 Error: Zigate: ----> Line 1763 in '/root/domoticz/plugins/Domoticz-Zigate/plugin.py', function onCommand
2022-10-09 11:44:00.386 Error: Zigate: ----> Line 925 in '/root/domoticz/plugins/Domoticz-Zigate/plugin.py', function onCommandLe gui zigbee n'est pas accessible.
Après un sudo pip3 install -r requirements.txt
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 1)) (3.8.1)
Requirement already satisfied: aiosignal in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 2)) (1.2.0)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 3)) (0.17.0)
Requirement already satisfied: async-timeout in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 4)) (4.0.2)
Requirement already satisfied: attrs in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 5)) (21.4.0)
Requirement already satisfied: charset-normalizer in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 6)) (2.0.10)
Requirement already satisfied: click in /root/.local/lib/python3.7/site-packages (from -r requirements.txt (line 7)) (8.0.1)
Requirement already satisfied: click-log>=0.2.1 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 8)) (0.4.0)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 9)) (1.1)
Requirement already satisfied: coloredlogs in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 10)) (15.0.1)
Requirement already satisfied: jsonschema in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 11)) (4.16.0)
Requirement already satisfied: frozenlist in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 13)) (1.2.0)
Requirement already satisfied: multidict in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 14)) (5.2.0)
Requirement already satisfied: pure-pcapy3 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 15)) (1.0.1)
Requirement already satisfied: pyserial==3.5 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 16)) (3.5)
Requirement already satisfied: pyserial-asyncio!=0.5 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 17)) (0.6)
Requirement already satisfied: pyusb==1.2.1 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 18)) (1.2.1)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 19)) (4.0.1)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 20)) (0.12.2)
Requirement already satisfied: yarl in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 21)) (1.7.2)
Requirement already satisfied: cryptography in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 22)) (3.3.1)
Requirement already satisfied: asynctest==0.13.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 1)) (0.13.0)
Requirement already satisfied: importlib-metadata in /root/.local/lib/python3.7/site-packages (from click->-r requirements.txt (line 7)) (4.5.0)
Requirement already satisfied: humanfriendly>=9.1 in /usr/local/lib/python3.7/dist-packages (from coloredlogs->-r requirements.txt (line 10)) (10.0)
Requirement already satisfied: pkgutil-resolve-name>=1.3.10 in /usr/local/lib/python3.7/dist-packages (from jsonschema->-r requirements.txt (line 11)) (1.3.10)
Requirement already satisfied: importlib-resources>=1.4.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->-r requirements.txt (line 11)) (5.10.0)
Requirement already satisfied: pyrsistent!=0.17.0,!=0.17.1,!=0.17.2,>=0.14.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->-r requirements.txt (line 11)) (0.18.1)
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (from pure-pcapy3->-r requirements.txt (line 15)) (65.4.1)
Requirement already satisfied: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl->-r requirements.txt (line 21)) (3.3)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.7/dist-packages (from cryptography->-r requirements.txt (line 22)) (1.15.1)
Requirement already satisfied: six>=1.4.1 in /root/.local/lib/python3.7/site-packages (from cryptography->-r requirements.txt (line 22)) (1.16.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.12->cryptography->-r requirements.txt (line 22)) (2.21)
Requirement already satisfied: zipp>=3.1.0 in /root/.local/lib/python3.7/site-packages (from importlib-resources>=1.4.0->jsonschema->-r requirements.txt (line 11)) (3.4.1)
remote: Enumerating objects: 4, done.
remote: Counting objects: 100% (4/4), done.
remote: Total 4 (delta 1), reused 4 (delta 1), pack-reused 0
Dépaquetage des objets: 100% (4/4), fait.
Depuis https://github.com/zigbeefordomoticz/Domoticz-Zigbee
aaaaf451..84f0b571 beta6 -> origin/beta6
* [nouvelle étiquette] beta6-6.2.181 -> beta6-6.2.181
Fetching submodule external/bellows
Fetching submodule external/dnspython
Fetching submodule external/pyserial
Fetching submodule external/zigpy
Fetching submodule external/zigpy-deconz
Fetching submodule external/zigpy-zigate
Fetching submodule external/zigpy-znp
Déjà à jour.Cordialement
Frederic
