Aile
Messages : 157 Inscription : 27 janv. 2022, 12:18
Message
par Aile » 22 oct. 2022, 14:21
Super ! Les erreurs ont disparu
J'en profite pour poser une question : dans mon fichier DeviceList-5.txt, il y a des périphériques qui n'existent pas :
2022-10-22 12:48:40.052 Status: Zigbee: [04] DevID: 00 Network addr: 3c7f IEEE: 00124b0022cf0924 LQI: 000 power: ff Model: TH01 ( T° Buanderie annexe )
2022-10-22 12:48:40.052 Status: Zigbee: [05] DevID: 00 Network addr: 8e7c IEEE: 8cf681fffef2512f LQI: 000 power: ff Model: RC-EF-3.0 ( Télécommande )
2022-10-22 12:48:40.052 Status: Zigbee: [06] DevID: 00 Network addr: 8cf6 IEEE: 81fffef2512f8e7c LQI: 000 power: ff not found in plugin database!
2022-10-22 12:48:40.052 Status: Zigbee: [07] DevID: 00 Network addr: 1859 IEEE: 84fd27fffe0682a6 LQI: 000 power: ff Model: SmokeSensor-EF-3.0 ( Détecteur RDC )
2022-10-22 12:48:40.052 Status: Zigbee: [08] DevID: 00 Network addr: 20e0 IEEE: 50325ffffe305d1b LQI: 000 power: ff Model: TS011F ( Prise étage )
2022-10-22 12:48:40.052 Status: Zigbee: [09] DevID: 00 Network addr: 0ac7 IEEE: 804b50fffeff0d0b LQI: 000 power: ff Model: SmokeSensor-EF-3.0 ( Détecteur étage )
2022-10-22 12:48:40.052 Status: Zigbee: [10] DevID: 00 Network addr: 804b IEEE: 50fffeff0d0b0ac7 LQI: 000 power: ff not found in plugin database!
2022-10-22 12:48:40.052 Status: Zigbee: [11] DevID: 00 Network addr: 8eda IEEE: 00124b0025118c6a LQI: 000 power: ff Model: TH01 ( Salle de bain )
2022-10-22 12:48:40.052 Status: Zigbee: [12] DevID: 00 Network addr: 0012 IEEE: 4b002518fdfb95b6 LQI: 000 power: ff not found in plugin database!
2022-10-22 12:48:40.052 Status: Zigbee: [13] DevID: 00 Network addr: 84fd IEEE: 27fffe0682a61859 LQI: 000 power: ff not found in plugin database!
2022-10-22 12:48:40.052 Status: Zigbee: [14] DevID: 00 Network addr: 4b55 IEEE: 00124b0022cf0b7b LQI: 000 power: ff Model: TH01 ( Salon TV )
2022-10-22 12:48:40.052 Status: Zigbee: [15] DevID: 00 Network addr: f918 IEEE: 50325ffffe2ce394 LQI: 000 power: ff Model: TS011F ( Prise bureau )
2022-10-22 12:48:40.067 Status: Zigbee: [16] DevID: 00 Network addr: 162f IEEE: 50325ffffe531ca6 LQI: 000 power: ff Model: TS011F ( Prise Annexe )
2022-10-22 12:48:40.067 Status: Zigbee: Network state UP, PANID: 7ee7 extPANID: 0xe4e2a5a4516ef948 Channel: 24
Puis-je supprimer ces périphériques dans le fichier DeviceList-5.txt ?
NUC Celeron 1037U / Win 10 Pro
EcoCompteur Legrand
RFLink Nodo : capteurs T° Alecto / capteurs présence EV1527
Clef Sonoff Zigbee 3.0 : capteurs T° Sonoff / capteurs présence Lidl / Détecteurs fumée Heiman
BroadLink : pilotage clim
Shelly 1
pipiche
Messages : 4677 Inscription : 04 avr. 2018, 16:16
Contact :
Message
par pipiche » 22 oct. 2022, 14:26
je te recommande de ne pas modifier le fichier DeviceList directement.
Dans ce logs, le message :
Indique simplement qu'on a trouvé une référence d'un device dans le coordinateur mais il n'y a pas de trace dans le Plugin. A priori un device qui a été appairé et qui a été supprimé du plugin.
Donc y-a rien qui me dérange ici
Aile
Message
par Aile » 22 oct. 2022, 14:49
Ok, mais c'est un peu curieux car je n'ai supprimé aucun périphérique et tous mes périphériques sont présents dans le plugin.
Sauf erreur, un périphérique garde toujours le même identifiant ?
Est-ce qu'on peut supprimer ces périphériques dans le coordinateur ?
EcoCompteur Legrand
Shelly 1
pipiche
Contact :
Message
par pipiche » 22 oct. 2022, 15:00
est-ce que ce device 81fffef2512f8e7c existe dans le Domoticz ?
Est-ce que la clef etait utilisée avant ?
Aile
Message
par Aile » 22 oct. 2022, 15:03
Ben non...
Et la clef est neuve !
EcoCompteur Legrand
Shelly 1
pipiche
Contact :
Message
par pipiche » 22 oct. 2022, 15:26
c'est bizarre, effectivement.
Donc pour la question peut-on les supprimer, non sans faire un Erase complet
Pour moi c'est pas genant.
J'essaies de pousser l"update sur la branche stable d'ici la fin du week-end ..
Aile
Message
par Aile » 22 oct. 2022, 15:30
Pas grave...
Sans doute que cette clef avait déjà été utilisée, puis rendue au fournisseur.
Je marque le sujet comme résolu.
Dernière question : tu as modifié le plugin pour supprimer ces erreurs ?
Merci encore !
EcoCompteur Legrand
Shelly 1
pipiche
Contact :
Message
par pipiche » 23 oct. 2022, 19:32
si tu souhaites rebasculer sur la stable6 , c'est possible en faisant
Après quoi tu relances le plugin et tu devrais te retrouver sur la 6.3.002
Si vous appréciez ce que je fais, vous pouvez contribuer par un don
Paypal , ce qui me permettra notamment l'achat d’équipements et de les tester/valider pour le plugin.
Wiki
ici
chat sur Keybase.io
