[Fermé] Nouvelle Installation avec SONOFF Zigbee 3.0 USB Dongle Plus V2
marc_bzh
Message par marc_bzh »
Bonjour , je viens de faire une installation avec une clé SONOFF Zigbee 3.0 USB Dongle Plus V2
sur Domoticz version 2022
Version: 2022.2
Build Hash: eea9db734
Compile Date: 2022-11-05 13:05:35
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
J'ai un message d'erreur dans les logs de l'interface du plugin sans que cela soit un problème pour le fonctionnement
Ci-joint les logs
{"0":{"0":{"Time":"10/12/2022 16:14:26","Module":"Input","nwkid":"None","PluginHealth":"Startup","message":"Untested Zigbee adapater model, please report to the Zigbee for Domoticz team","PermitToJoin":{"Duration":0,"Starttime":1670685273},"Thread":"ZigpyForwarder_8"},"LastLog":0,"StartTime":"10/12/2022 16:14:22","FirmwareVersion":"1030","FirmwareMajorVersion":"06","PluginVersion":"stable6-6.3.007"},"1":{"0":{"Time":"10/12/2022 16:14:52","Module":"Input","nwkid":"None","PluginHealth":"Startup","message":"Untested Zigbee adapater model, please report to the Zigbee for Domoticz team","PermitToJoin":{"Duration":240,"Starttime":1670685801},"Thread":"ZigpyForwarder_8"},"1":{"Time":"10/12/2022 16:15:08","Module":"Input","nwkid":"None","PluginHealth":"Startup","message":"Decode 8041 - Receive an IEEE: 00158d0005d2a6a5 with a NwkId: 02c1, seems not known by the plugin","PermitToJoin":{"Duration":240,"Starttime":1670685801},"Thread":"ZigpyForwarder_8"},"2":{"Time":"10/12/2022 16:22:20","Module":"Input","nwkid":"None","PluginHealth":"Ready","message":"Decode 8041 - Receive an IEEE: 00158d000700776f with a NwkId: 6bda, seems not known by the plugin","PermitToJoin":{"Duration":240,"Starttime":1670685801},"Thread":"ZigpyForwarder_8"},"LastLog":2,"StartTime":"10/12/2022 16:14:49","FirmwareVersion":"1030","FirmwareMajorVersion":"06","PluginVersion":["stable6-6.3.007"]},"LastLog":1}
Re: Nouvelle Installation avec SONOFF Zigbee 3.0 USB Dongle Plus V2
Nous avons regroupé dans le sujet [A lire avant de poster] Guide pour bien formuler une demande une première liste d’informations qui nous sont utiles pour commencer à analyser les demandes. En complétant tes informations, nous pourrons t’apporter plus rapidement des réponses pertinentes. Merci.
pipiche
Message par pipiche »
est-ce un Dongle SonOff P ou E.
Je pense que c'est une E, et effectivement SonOff n'a pas renseigné une information.
Mais pas de soucis, ca doit fonctionner
marc_bzh
Bonjour désolé du retard pour ma réponse c'est bien la version E
Quelques lignes des logs Domoticz , j'ai des plantages mais ça fonctionne correctement dans l'ensemble
2022-12-18 09:24:32.895 Status: ZigbeeForDomoticz: Device NWK: 0x0000
2022-12-18 09:24:32.899 Status: ZigbeeForDomoticz: Installer Version Number: 1030
2022-12-18 09:24:32.899 Status: ZigbeeForDomoticz: Branch Version: ==> Unknown Silicon Labs <==
2022-12-18 09:24:32.907 Status: ZigbeeForDomoticz: Zigbee Coordinator ieee: 84b4dbfffef16124 , short addr: 0000
2022-12-18 09:24:32.908 Status: ZigbeeForDomoticz: Network state UP, PANID: 136f extPANID: 0x4447737f9a9d5b4c Channel: 15
2022-12-18 09:24:32.896 Error: ZigbeeForDomoticz: Untested Zigbee adapater model, please report to the Zigbee for Domoticz team
2022-12-18 09:24:38.525 Status: Incoming connection from: 192.168.31.92
2022-12-18 09:24:39.068 Status: ZigbeeForDomoticz: Request Disabling Accepting new Hardware
2022-12-18 09:24:44.082 Status: ZigbeeForDomoticz: coordinator set to Certification : 1/CE -> CE
2022-12-18 09:24:44.968 Status: ZigbeeForDomoticz: ota_scan_folder Following Firmware have been loaded
2022-12-18 09:24:44.969 Status: ZigbeeForDomoticz: Plugin with Zigpy, Coordinator Unknown Silicon Labs firmware UNK - 1030 correctly initialized
PluginZigbee_Domoticz.log.zip
Logs Plugin et Domoticz
(11.16 Kio) Téléchargé 62 fois
pipiche
Donc pas de soucis
marc_bzh
J'ai la page personnalisé qui n'affiche rien pour info
Le WebUI est fonctionnel quand tu essayes d'y aller directement https://zigbeefordomoticz.github.io/wik ... ation.html
pipiche
qu'est-ce qu'il y a dans les logs de Domoticz lors du lancement du plugin
qu'est-ce qu'il y a dans les logs du plugin ? Domoticz-Zigbee/Logs/PluginZigee-xx.log ?
marc_bzh
Dans les logs du plugin j'ai ça :
2022-12-30 06:47:55,950 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 0180020032ff000104fcc0010102b50f0200001>
2022-12-30 06:55:34,374 INFO : [ZigpyCom_8 291063] Coordinator backup is available: /home/pi/domoticz/plugins/Domoticz-Zigbee/Data//Coordinator-08.backup
2022-12-30 07:01:26,932 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 0180020032ff000104fcc0010102b50f0200001>
2022-12-30 07:02:52,923 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 018002008cff000104fcc0010102b50f0200001>
2022-12-30 07:07:34,314 INFO : [ZigpyForwarder_8 291064] linky_device_conf 02c1 found Protocol Linky: 0
2022-12-30 07:53:51,117 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 018002008cff000104fcc0010102b50f0200001>
2022-12-30 08:07:34,340 INFO : [ZigpyForwarder_8 291064] linky_device_conf 02c1 found Protocol Linky: 0
2022-12-30 08:47:39,792 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 018002008cff000104fcc0010102b50f0200001>
2022-12-30 09:07:36,580 INFO : [ZigpyForwarder_8 291064] linky_device_conf 02c1 found Protocol Linky: 0
2022-12-30 09:40:01,753 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 0180020032ff000104fcc0010102b50f0200001>
2022-12-30 09:40:31,648 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 0180020032ff000104fcc0010102b50f0200001>
2022-12-30 09:41:05,372 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 018002008cff000104fcc0010102b50f0200001>
2022-12-30 09:47:37,078 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 0180020032ff000104fcc0010102b50f0200001>
2022-12-30 10:03:00,817 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 0180020032ff000104fcc0010102b50f0200001>
2022-12-30 10:07:34,278 INFO : [ZigpyForwarder_8 291064] linky_device_conf 02c1 found Protocol Linky: 0
2022-12-30 10:32:03,024 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 018002008cff000104fcc0010102b50f0200001>
2022-12-30 11:07:34,363 INFO : [ZigpyForwarder_8 291064] linky_device_conf 02c1 found Protocol Linky: 0
2022-12-30 11:24:09,172 INFO : [ZigpyForwarder_8 291064] decode8002_and_process unknown NwkId: b50f for ZCL frame 018002008cff000104fcc0010102b50f0200001>
2022-12-30 11:43:34,211 INFO : [MainThread 291048] *** A more recent plugin version is waiting for you on gitHub. You are on 6.3.007 and 6.3.008 is avail>
2022-12-30 11:43:34,414 INFO : [ZigpyCom_8 291063] Coordinator backup is available: /home/pi/domoticz/plugins/Domoticz-Zigbee/Data//Coordinator-08.backup
2022-12-30 12:07:35,588 INFO : [ZigpyForwarder_8 291064] linky_device_conf 02c1 found Protocol Linky: 0
pipiche
Il faudrait le fichier de log complet, pour voir ce qu'il se passe au lancement du plugin notamment
Et je te suggère également de mettre à jour le plugin. Comme indiqué il y a une version plus récente.
