[Fermé] OSRAM/LEDVANCE lampe impossible to pair après suppression
pouilld
Message par pouilld »
Description du problème.
Après avoir effectué un premier pairing (ou la lampe a été correctement reconnue), j'ai été amené à la supprimer (domoticz et plugin).
Depuis cette suppression, il n'est plus possible de refaire le pairing de cette ampoule après avoir effectué plusieurs reset de la lampe et avoir tenté de refaire un pairing après avolir sélectionné le mode reset pour cet objet.
Le pairing échoue avec un message d'erreur (UNKNOWn) voit log.
Short id:0746
IEEE: 7cb03eaa0a040691
Model: OSRAM(LEDVANCE) Smart+ standard dimmable 8,5W E27
Version de Domoticz
2020.2
Build Hash: eea9db734
Build Date: 2022-11-05 13:05:35
Version du plugin 6.3.008
Plugin:2022-11-05 13:05:35
Firmware: ZIGATE 0321
Branche du plugin stable
Système sur lequel tourne Domoticz avec le plugin RPI3B+,
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
{"Version":"3","ZDeviceName":"","Status":"UNKNOW","SQN":"","Ep":{},"Heartbeat":"447","RIA":"6","LQI":{},"Battery":{},"Model":"","ForceAckCommands":[],"MacCapa":"8e","IEEE":"7cb03eaa0a040691","Type":{},"ProfileID":{},"ZDeviceID":{},"App Version":"","Attributes List":{},"DeviceType":"FFD","HW Version":"","Last Cmds":[],"LogicalType":"Router","Manufacturer":"","Manufacturer Name":"","NbEp":"","PowerSource":"Main","ReadAttributes":{},"ReceiveOnIdle":"","Stack Version":"","Stamp":{"time":1674062219.4275863,"Time":"2023-01-18 18:16:59","MsgType":" 4d","LastSeen":1674062219},"ZCL Version":"","Health":"Not Reachable","Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"PairingInProgress":true,"ConsistencyCheck":"Bad Pairing"}
PLUGIN LOG
2023-01-18 18:13:04,161 INFO : [ZiGateSerial_26 15523] ==> Transport Mode switch to full mode
2023-01-18 18:13:04,164 INFO : [ZiGateForwarder_26 15525] ZiGate+ (V2)
2023-01-18 18:13:04,164 INFO : [ZiGateForwarder_26 15525] Installer Version Number: 0321
2023-01-18 18:13:04,165 INFO : [ZiGateForwarder_26 15525] Branch Version: ==> Production <==
2023-01-18 18:13:14,222 INFO : [ZiGateForwarder_26 15525] Zigbee Coordinator ieee: 00158d0005bea75c , short addr: 0000
2023-01-18 18:13:14,223 INFO : [ZiGateForwarder_26 15525] Network state UP, PANID: a0cf extPANID: 0x6a84631bbeb0213e Channel: 11
2023-01-18 18:13:19,112 INFO : [ MainThread 15510] Request Disabling Accepting new Hardware
2023-01-18 18:13:19,611 INFO : [ZiGateForwarder_26 15525] Accepting new Hardware: Disable (Off)
2023-01-18 18:13:19,716 INFO : [ZiGateForwarder_26 15525] Number of devices recently active in Zigate = 3
2023-01-18 18:13:19,717 INFO : [ZiGateForwarder_26 15525] [00] DevID: 14 Network addr: 8860 IEEE: 00124b002450ea86 LQI: 042 power: 01 Model: ZB-CL01 ( Lampe buffet )
2023-01-18 18:13:19,718 INFO : [ZiGateForwarder_26 15525] [01] DevID: 15 Network addr: 0746 IEEE: 7cb03eaa0a040691 LQI: 079 power: 01 not found in plugin database!
2023-01-18 18:13:19,719 INFO : [ZiGateForwarder_26 15525] [02] DevID: 16 Network addr: b8ea IEEE: 00158d0002506165 LQI: 056 power: 01 Model: Dimmablelight ( Lampadaire salon )
2023-01-18 18:13:24,073 INFO : [ MainThread 15510] Switch Blue Led On
2023-01-18 18:13:24,079 INFO : [ MainThread 15510] coordinator set to Certification : 1/CE -> CE
2023-01-18 18:13:25,108 INFO : [ MainThread 15510] ota_scan_folder Following Firmware have been loaded
2023-01-18 18:13:25,110 INFO : [ MainThread 15510] We have detected a working device Lampe buffet (8860) Model: ZB-CL01 not optimized with the plugin.
2023-01-18 18:13:25,111 INFO : [ MainThread 15510]
2023-01-18 18:13:25,111 INFO : [ MainThread 15510] --- Please follow the link https://zigbeefordomoticz.github.io/wik ... evice.html
2023-01-18 18:13:25,112 INFO : [ MainThread 15510] --- Thanks the Zigbee for Domoticz plugin team
2023-01-18 18:13:25,114 INFO : [ MainThread 15510]
2023-01-18 18:13:25,115 INFO : [ MainThread 15510] We have detected a working device Lampadaire salon (b8ea) Model: Dimmablelight not optimized with the plugin.
2023-01-18 18:13:25,116 INFO : [ MainThread 15510]
2023-01-18 18:13:25,116 INFO : [ MainThread 15510] --- Please follow the link https://zigbeefordomoticz.github.io/wik ... evice.html
2023-01-18 18:13:25,117 INFO : [ MainThread 15510] --- Thanks the Zigbee for Domoticz plugin team
2023-01-18 18:13:25,118 INFO : [ MainThread 15510]
2023-01-18 18:13:25,119 INFO : [ MainThread 15510] Plugin with Zigate+, firmware 0321 correctly initialized
2023-01-18 18:15:49,662 INFO : [ MainThread 15510] Request Accepting new Hardware for 240 seconds
2023-01-18 18:15:49,858 INFO : [ZiGateForwarder_26 15525] Accepting new Hardware: Enable (On)
2023-01-18 18:16:13,890 INFO : [ZiGateForwarder_26 15525] --> Adding device 0746 in self.DevicesInPairingMode
2023-01-18 18:16:13,893 INFO : [ZiGateForwarder_26 15525] --> ['0746']
2023-01-18 18:16:13,893 INFO : [ZiGateForwarder_26 15525] [None] NEW OBJECT: 0746 None
2023-01-18 18:16:20,415 INFO : [ZiGateForwarder_26 15525] Receive NACK from 0746 clusterId: 0005 Status: a7
2023-01-18 18:16:21,429 INFO : [ZiGateForwarder_26 15525] Device Annoucement: NwkId: 0746 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-18 18:16:21,441 INFO : [ZiGateForwarder_26 15525] Forcing a check of configure reporting after Device Annoucement on Main Powered device 0746
2023-01-18 18:16:27,628 INFO : [ZiGateForwarder_26 15525] Device Annoucement: NwkId: 0746 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-18 18:16:27,629 INFO : [ZiGateForwarder_26 15525] Forcing a check of configure reporting after Device Annoucement on Main Powered device 0746
2023-01-18 18:16:33,682 INFO : [ZiGateForwarder_26 15525] Device Annoucement: NwkId: 0746 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-18 18:16:33,684 INFO : [ZiGateForwarder_26 15525] Forcing a check of configure reporting after Device Annoucement on Main Powered device 0746
2023-01-18 18:16:39,581 INFO : [ZiGateForwarder_26 15525] Device Annoucement: NwkId: 0746 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-18 18:16:39,582 INFO : [ZiGateForwarder_26 15525] Forcing a check of configure reporting after Device Annoucement on Main Powered device 0746
2023-01-18 18:16:44,809 INFO : [ZiGateForwarder_26 15525] Device Annoucement: NwkId: 0746 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-18 18:16:44,822 INFO : [ZiGateForwarder_26 15525] Forcing a check of configure reporting after Device Annoucement on Main Powered device 0746
2023-01-18 18:16:57,218 INFO : [ZiGateForwarder_26 15525] Receive NACK from 0746 clusterId: 8006 Status: a7
2023-01-18 18:16:59,429 INFO : [ZiGateForwarder_26 15525] Device Annoucement: NwkId: 0746 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-18 18:16:59,430 INFO : [ZiGateForwarder_26 15525] Forcing a check of configure reporting after Device Annoucement on Main Powered device 0746
2023-01-18 18:17:11,329 INFO : [ZiGateForwarder_26 15525] Receive NACK from 0746 clusterId: 8006 Status: a7
2023-01-18 18:18:43,029 INFO : [ MainThread 15510] Request Disabling Accepting new Hardware
Dernière modification par Keros le 13 avr. 2023, 22:42, modifié 1 fois.
Raison : Fermeture du sujet car sans réponses
pipiche
Re: OSRAM/LEDVANCE lampe impossible to pair après suppression
Message par pipiche »
bonsoir
(1) est-que qu'il y a des widgets pour cette lampe dans Domoticz ?
(2) est-ce que cette lampe est connue du plugin ? quand tu vas dans Liste des equipements est-ce qu'elle est listée ? si oui quel est le status ?
pouilld
Mercin pour votre réponse.
1) lors du pairing initial, les devices avaient été correctement crées dans Domoticz
2) lors de la nouvelle tentative de pairing l'objet est vrée dans le plugin (UNKNOWN) mais aucun device correspondant dans Domoticz.
Merci pour votre aide.
pipiche
Etrange.
relances le plugin
actives le debugPairing via le WebUI du plugin menu Tools> Debug > Avancé
puis fais un appairage,-,assures-toi d'etre à coté de la zigate pour avoir toute les chances d'un appairage
et attaches ici, les logs Domoticz ainsi que les logs du plugin qui se trouvent dans Logs/PluginZigbee-xx.log
PS/ merci de ne pas dupliquer les posts ici et sur le github. Les problèmes sont a etre qualifié reglé ici, et si il y a un bug de fonctionnement ou réellement un device non certifié il faut utiliser le github.
merci d'avance
Wiki ici
chat sur Keybase.io
pouilld
Après avoir effectué un reset hardware de la zigate V2 (via DK6programmer) et relancé le plugin je suis maintenant dans une situation ou j'ai des objets (Led ikea, IAS sirène,...) qui se sont créés automatiquement dans le plugin (mais pas dans domoticz).
il n'est pas possible de supprimer ces objets (pas d'icone "delete") qui sont persistants malgré une réinstallation complète du plugin.
Je vais donc tenter de repartir de zero;
- installation PI OS bulleye
- installation Domoticz
- réinitialisation ZIgate avec remise à zero et effacment des données (appairages compris)
- installation du plugin
- essai d'appairage des objets
pipiche
Cela me surprend beaucoup.
peux-tu faire un screen shoot que je puisse voir ?
j'aimerai également les logs du plugin Logs/PluginZigbee-xx.log
Si il n'y a aucun widget coté Domoticz, tu dois etre en mesure de supprimer, les choses.
Au pire je te donnerais une astuce pour éviter de tout reinstaler
pouilld
Après réinstallation du plugin et réinitialisation complète de la ZigateV2 (réinstallation firmware version 321 et effacement complet des données) j'ai retrouvé un fonctionnement "normale" du plugin et pu refaire le pairing de plusieurs objets.
Par contre, je suis toujours dans l'impossibilité d'effectuer le pairing avec une ampoule OSRAM que j'avais pu effectuer initialement sur mon système de test.
Description de cette ampoule: OSRAM SMART+ ZB CLA60 60 8.5 W E27 SMART+ Classic Dimmable | Classic candle shape with ZigBee technology
Je vous joins comme demandé la log du plugin avec (option debug pairing activée) ainsi que la log Domoticz.
Log Plugin
2023-01-20 09:00:30,311 INFO : [ZiGateForwarder_26 9954] Remove Device cmd statusSuccess
2023-01-20 09:12:42,425 INFO : [ MainThread 9950] Request Accepting new Hardware for 240 seconds
2023-01-20 09:12:42,624 INFO : [ZiGateForwarder_26 9954] Accepting new Hardware: Enable (On)
2023-01-20 09:12:59,942 INFO : [ZiGateForwarder_26 9954] --> Adding device 2fd7 in self.DevicesInPairingMode
2023-01-20 09:12:59,944 INFO : [ZiGateForwarder_26 9954] --> ['2fd7']
2023-01-20 09:12:59,945 DEBUG : [ZiGateForwarder_26 9954] interview_state_004d - NWKID: 2fd7, Status: None, RIA: None,
2023-01-20 09:12:59,945 INFO : [ZiGateForwarder_26 9954] [None] NEW OBJECT: 2fd7 None
2023-01-20 09:13:04,106 DEBUG : [ MainThread 9950] processNotinDBDevices - NWKID: 2fd7, Status: 0045, RIA: 0, HB_: 1
2023-01-20 09:13:04,107 DEBUG : [ MainThread 9950] [0] NEW OBJECT: 2fd7 Model Name: knownModel: False status: 0045
2023-01-20 09:13:04,229 INFO : [ZiGateForwarder_26 9954] Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:04,245 INFO : [ZiGateForwarder_26 9954] Forcing a check of configure reporting after Device Annoucement on Main Powered device 2fd7
2023-01-20 09:13:06,419 INFO : [ZiGateForwarder_26 9954] Receive NACK from 2fd7 clusterId: 0005 Status: a7
2023-01-20 09:13:09,099 DEBUG : [ MainThread 9950] processNotinDBDevices - NWKID: 2fd7, Status: 0045, RIA: 1, HB_: 1
2023-01-20 09:13:09,101 DEBUG : [ MainThread 9950] [1] NEW OBJECT: 2fd7 Model Name: knownModel: False status: 0045
2023-01-20 09:13:10,457 INFO : [ZiGateForwarder_26 9954] Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:10,459 INFO : [ZiGateForwarder_26 9954] Forcing a check of configure reporting after Device Annoucement on Main Powered device 2fd7
2023-01-20 09:13:14,081 DEBUG : [ MainThread 9950] processNotinDBDevices - NWKID: 2fd7, Status: 0045, RIA: 2, HB_: 1
2023-01-20 09:13:14,082 DEBUG : [ MainThread 9950] [2] NEW OBJECT: 2fd7 Model Name: knownModel: False status: 0045
2023-01-20 09:13:16,236 INFO : [ZiGateForwarder_26 9954] Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:16,237 INFO : [ZiGateForwarder_26 9954] Forcing a check of configure reporting after Device Annoucement on Main Powered device 2fd7
2023-01-20 09:13:19,091 DEBUG : [ MainThread 9950] processNotinDBDevices - NWKID: 2fd7, Status: 0045, RIA: 3, HB_: 1
2023-01-20 09:13:19,091 DEBUG : [ MainThread 9950] [3] NEW OBJECT: 2fd7 Model Name: knownModel: False status: 0045
2023-01-20 09:13:21,621 INFO : [ZiGateForwarder_26 9954] Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:21,622 INFO : [ZiGateForwarder_26 9954] Forcing a check of configure reporting after Device Annoucement on Main Powered device 2fd7
2023-01-20 09:13:24,108 DEBUG : [ MainThread 9950] processNotinDBDevices - NWKID: 2fd7, Status: 0045, RIA: 4, HB_: 1
2023-01-20 09:13:24,110 DEBUG : [ MainThread 9950] [4] NEW OBJECT: 2fd7 Model Name: knownModel: False status: 0045
2023-01-20 09:13:29,072 DEBUG : [ MainThread 9950] processNotinDBDevices - NWKID: 2fd7, Status: 0045, RIA: 5, HB_: 2
2023-01-20 09:13:29,073 DEBUG : [ MainThread 9950] [5] NEW OBJECT: 2fd7 Model Name: knownModel: False status: 0045
2023-01-20 09:13:32,594 INFO : [ZiGateForwarder_26 9954] Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:32,596 INFO : [ZiGateForwarder_26 9954] Forcing a check of configure reporting after Device Annoucement on Main Powered device 2fd7
2023-01-20 09:13:34,019 INFO : [ZiGateForwarder_26 9954] Receive NACK from 2fd7 clusterId: 8006 Status: a7
2023-01-20 09:13:34,086 DEBUG : [ MainThread 9950] processNotinDBDevices - NWKID: 2fd7, Status: 0045, RIA: 6, HB_: 1
2023-01-20 09:13:34,087 DEBUG : [ MainThread 9950] [6] NEW OBJECT: 2fd7 Model Name: knownModel: False status: 0045
2023-01-20 09:13:34,088 DEBUG : [ MainThread 9950] interview_timeout - NWKID: 2fd7, Status: 0045, RIA: 6,
2023-01-20 09:13:45,911 INFO : [ZiGateForwarder_26 9954] Receive NACK from 2fd7 clusterId: 8006 Status: a7
2023-01-20 09:13:50,569 INFO : [ MainThread 9950] Request Disabling Accepting new Hardware
2023-01-20 09:13:50,749 INFO : [ZiGateForwarder_26 9954] Accepting new Hardware: Disable (Off)
Log Domoticz
2023-01-20 09:12:42.422 ZIGBEE: Enable Assisted pairing
2023-01-20 09:12:42.427 Status: ZIGBEE: Request Accepting new Hardware for 240 seconds
2023-01-20 09:12:42.475 ZIGBEE: Assisted Pairing: Polling: []
2023-01-20 09:12:42.475 ZIGBEE: --> Empty queue
2023-01-20 09:12:42.624 Status: ZIGBEE: Accepting new Hardware: Enable (On)
2023-01-20 09:12:48.572 DOMOEDF: General/kWh (St Bernard HC)
2023-01-20 09:12:48.592 DOMOEDF: General/kWh (St Bernard HP)
2023-01-20 09:12:48.618 DOMOEDF: P1 Smart Meter (St Bernard kWh total)
2023-01-20 09:12:48.629 DOMOEDF: Current (St Bernard courant)
2023-01-20 09:12:48.640 DOMOEDF: General/Percentage (St Bernard charge phase 1)
2023-01-20 09:12:48.650 DOMOEDF: General/Percentage (St Bernard charge phase 2)
2023-01-20 09:12:48.666 DOMOEDF: General/Percentage (St Bernard charge phase 3)
2023-01-20 09:12:52.507 ZIGBEE: Assisted Pairing: Polling: []
2023-01-20 09:12:52.508 ZIGBEE: --> Empty queue
2023-01-20 09:12:52.844 RFXCOM: Temp + Humidity (St Bernard T° Extérieure)
2023-01-20 09:12:54.920 RFXCOM: Temp + Humidity (St B T° sonde humidité sud)
2023-01-20 09:12:56.727 RFXCOM: Temp + Rain (St Bernard pluviomètre)
2023-01-20 09:12:59.946 Status: ZIGBEE: [None] NEW OBJECT: 2fd7 None
2023-01-20 09:13:01.005 RFXCOM: Temp (St Bernard chambre 1)
2023-01-20 09:13:02.490 ZIGBEE: Assisted Pairing: Polling: ['2fd7']
2023-01-20 09:13:02.490 ZIGBEE: --> New device: 2fd7
2023-01-20 09:13:04.229 Status: ZIGBEE: Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:06.122 AEOTEC ZW090: Temp (St Bernard T° Bureau)
2023-01-20 09:13:06.187 AEOTEC ZW090: General/Thermostat Operating State (St Bernard T° Bureau état)
2023-01-20 09:13:10.458 Status: ZIGBEE: Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:12.470 ZIGBEE: Assisted Pairing: Polling: ['2fd7']
2023-01-20 09:13:12.470 ZIGBEE: --> New device: 2fd7
2023-01-20 09:13:16.236 Status: ZIGBEE: Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:21.321 RFXCOM: Temp + Humidity (St Bernard T° Entrée)
2023-01-20 09:13:21.622 Status: ZIGBEE: Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:22.498 ZIGBEE: Assisted Pairing: Polling: ['2fd7']
2023-01-20 09:13:22.499 ZIGBEE: --> New device: 2fd7
2023-01-20 09:13:32.476 ZIGBEE: Assisted Pairing: Polling: ['2fd7']
2023-01-20 09:13:32.477 ZIGBEE: --> New device: 2fd7
2023-01-20 09:13:32.595 Status: ZIGBEE: Device Annoucement: NwkId: 2fd7 Ieee: 7cb03eaa0a040691 MacCap: 8e
2023-01-20 09:13:34.082 Error: ZIGBEE: [6] NEW OBJECT: 2fd7 Not able to get all needed attributes on time
2023-01-20 09:13:34.082 Error: ZIGBEE: processNotinDB - not able to find response from 2fd7 stop process at 0045
2023-01-20 09:13:34.082 Error: ZIGBEE: processNotinDB - Collected Infos are : {'Version': '3', 'ZDeviceName': '', 'Status': 'UNKNOW', 'SQN': '', 'Ep': {}, 'Heartbeat': '1', 'RIA': '6', 'LQI': {}, 'Battery': {}, 'Model': '', 'ForceAckCommands': [], 'MacCapa': '8e', 'IEEE': '7cb03eaa0a040691', 'Type': {}, 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'FFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'Router', 'Manufacturer': '', 'Manufacturer Name': '', 'NbEp': '', 'PowerSource': 'Main', 'ReadAttributes': {}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'time': 1674202412.5912502, 'Time': '2023-01-20 09:13:32', 'MsgType': ' 4d', 'LastSeen': 1674202412}, 'ZCL Version': '', 'Health': 'Not Reachable', 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'PairingInProgress': True, 'ConsistencyCheck': 'Bad Pairing'}
2023-01-20 09:13:42.525 ZIGBEE: Assisted Pairing: Polling: ['2fd7']
2023-01-20 09:13:42.525 ZIGBEE: --> New device: 2fd7
2023-01-20 09:13:42.525 ZIGBEE: --> UNKNOW , removed 2fd7 from List
2023-01-20 09:13:42.525 ZIGBEE: --> New Device: {'NwkId': '2fd7', 'ProvisionStatus': 'Failed', 'ProvisionStatusDesc': 'Failed', 'IEEE': '7cb03eaa0a040691', 'ProfileId': '', 'ProfileIdDesc': 'Unknow', 'ZDeviceID': '', 'ZDeviceIDDesc': 'Unknow', 'Model': '', 'PluginCertified': 'Unknow', 'Ep': []}
2023-01-20 09:13:44.003 RFXCOM: Temp (St Bernard chambre 1)
2023-01-20 09:13:44.709 RFXCOM: Temp + Rain (St Bernard pluviomètre)
2023-01-20 09:13:50.564 ZIGBEE: Disable Assisted pairing
2023-01-20 09:13:50.569 Status: ZIGBEE: Request Disabling Accepting new Hardware
2023-01-20 09:13:50.750 Status: ZIGBEE: Accepting new Hardware: Disable (Off)
D.P.
pipiche
difficile de t'aider ici.
La lampe ne répond pas aux demandes d’interrogation du plugin.
Ce que je sais par experience c'est que les ampoules OSRAM sont des pietres routers zigbee. Peut-etre que celle-ci a un problème , et que le reset ne se passe pas bien , ou un truc comme ca.
Essayes de laisser le plugin en mode normal et
de faire un reset de l'ampoule par la procédure idouane.
de debrancher l'ampoule
puis de mettre le plugin en mode appairage
de rebrancher l'ampoule à proximité de la Zigate
si ca ne marche pas, je ne vois pas d'autre chose que de changer l'ampoule
pouilld
En complément d'information :
1) La lampe posant problème est référencée comme compatible sur le site
https://zigbee.blakadder.com/OSRAM_4058075816510.html
C'est bien le même code produit que celui posant problème acheté sur Amazon France : 4058075816510
2) Une ampoule du même fabricant OSRAM smart+ E14 5W code produit 4058075485150 ne pose pas problème lors du pairing (qui a pu être effectué plusieurs fois)
pipiche
du coup si tu n'as aucun problème avec une autre ampoule , je pense que c'est l'ampoule qu'il faut mettre en question.
Comme je disais la qualité des ampoules Osram est pas terrible, et notamment meme si compatible , ont une facheuse tendance à ne pas correctementn router , ce qui est un problème majeur dans le maillage du reseau zigbee
Wiki ici
chat sur Keybase.io
