#!/bin/bash
# LOCAL/FTP/SCP/MAIL PARAMETERS
SERVER="192.168.1.250" # IP of Network disk, used for ftp
USERNAME="xxx" # FTP username of Network disk used for ftp
PASSWORD="xxxx" # FTP password of Network disk used for ftp
DESTDIR="/Raspberry" # used for temorarily storage
DOMO_IP="192.168.1.251" # Domoticz IP
DOMO_PORT="8080" # Domoticz port
### END OF USER CONFIGURABLE PARAMETERS
TIMESTAMP=`/bin/date +%Y%m%d%H%M%S`
BACKUPFILE="domoticz_$TIMESTAMP.db" # backups will be named "domoticz_YYYYMMDDHHMMSS.db.gz"
BACKUPFILEGZ="$BACKUPFILE".gz
### create backup, ZIP it and start Domoticz again
/usr/bin/curl -s http://$DOMO_IP:$DOMO_PORT/backupdatabase.php > /tmp/$BACKUPFILE
gzip -9 /tmp/$BACKUPFILE
### Send to Network disk through FTP
curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/media/hdd/Domoticz_backup/"
### Remove temp backup file
/bin/rm /tmp/$BACKUPFILEGZ
### Done!
* Expire in 0 ms for 6 (transfer 0x16c9960)
* Trying 192.168.1.250...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0x16c9960)
* Connected to 192.168.1.250 (192.168.1.250) port 21 (#0)
< 220 Nas_home FTP server ready.
> USER xxxx
< 331 Password required for admin.
> PASS xxxx
< 230 User admin logged in.
> PWD
< 257 "/" is current directory.
* Entry path is '/'
> CWD media
* ftp_perform ends with SECONDARY: 0
< 550 No such file or directory.
* Server denied you to change to the given directory
* Uploaded unaligned file size (0 out of 109 bytes)
* Connection #0 to host 192.168.1.250 left intact
Apparement il n'arrive pas a écrire dans le répertoire pourtant celui à les doits en écriture
Je n'ai pas de commande sous la main. Je pense que tu devrais en trouver sur Internet en fonction de ton OS.
Cela devrait t'aider à déterminer si la configuration du NAS est bonne ou pas.
# get a list of files and dates from ftp and remove files older than ndays
ftpsite="sftp -b- -oPort=22 $USERNAME@$SERVER"
putdir=$DESTDIRNAS
ndays=19
# work out our cutoff date
MM=`date --date="$ndays days ago" +%b`
DD=`date --date="$ndays days ago" +%d`
TT=`date --date="$ndays days ago" +%s`
echo removing files older than $MM $DD
# get directory listing from remote source
echo "
cd $putdir
ls -l
"|$ftpsite >dirlist
# skip first three and last line, ftp command echo
listing="`tail -n+4 dirlist|head -n-1`"
lista=( $listing )
# loop over our files
for ((FNO=0; FNO<${#lista[@]}; FNO+=9));do
# month (element 5), day (element 6) and filename (element 8)
# echo Date ${lista[`expr $FNO+5`]} ${lista[`expr $FNO+6`]} File: ${lista[`expr $FNO+8`]}
fdate="${lista[`expr $FNO+5`]} ${lista[`expr $FNO+6`]} ${lista[`expr $FNO+7`]}"
sdate=`date --date="$fdate" +%s`
# check the date stamp
if [ $sdate -lt $TT ]
then
# Remove this file
echo "$MM $DD: Removing ${lista[`expr $FNO+5`]} / ${lista[`expr $FNO+6`]} / ${lista[`expr $FNO+8`]}"
$ftpsite <<EOMYF2
cd $putdir
rm ${lista[`expr $FNO+8`]}
quit
EOMYF2
fi
done
J'ai le message d'erreur suivant sur cette partie du script:
Tu peux nous mettre ton script domoticz_backup.sh en entier. Il semblerait que tu aies une erreur avec une "(" à la ligne 52. Et il n'y a que 44 lignes dans le code que tu as passé.
#!/bin/bash
SERVER="192.168.1.250" # IP of Synology NAS, used for ftp
USERNAME="xxxx" # FTP username of Network disk used for ftp
DESTDIR="/tmp" # used for temorarily storage
DESTDIRNAS="/Raspberry/rasphome/Sauvegarde/Database Domoticz/" # Path to your Synology NAS backup folder
### Create backup and ZIP it
tar -zcvf /tmp/domoticz_scripts_$TIMESTAMP.tar.gz /home/pi/domoticz/scripts/
curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/$DESTDIRNAS"
curl -s --disable-epsv -v -T"/tmp/domoticz_scripts_$TIMESTAMP.tar.gz" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/$DESTDIRNAS"
/bin/rm /tmp/domoticz_scripts_$TIMESTAMP.tar.gz
putdir=$DESTDIRNAS
ndays=19
echo "
cd $putdir
ls -l
"|$ftpsite >dirlist
lista=( $listing )
then
# Remove this file
$ftpsite <<EOMYF2
cd $putdir
quit
EOMYF2
fi
done
### Done!
