ponjour
comme ennoncé dans le titre j ai des souci avec des module qui s allume seul et c' est un vrai casse tete
quelqu un a t il une idée pour m aider ?
voici les log de 2 de mes module qui ce r allume seul
1 module qubino dimmer
pourtant configuré en on/off et pas en dimmer
2023-04-05 02:52:27 Off zwave
2023-04-05 02:50:51 Set Level: 33 % zwave
2023-04-04 21:25:54 Off zwave
2023-04-04 21:24:38 Set Level: 33 % zwave
2023-04-04 20:26:35 Off zwave
2023-04-04 20:24:39 On zwave
2023-04-04 07:22:28 Off zwave
2023-04-04 07:21:13 Set Level: 33 % zwave
2023-04-04 05:22:04 Off zwave
2023-04-04 05:20:43 Set Level: 33 % zwave
2023-04-03 17:49:44 Off zwave
2023-04-03 17:48:00 Set Level: 33 % zwave
2023-04-03 16:44:12 Off zwave
2023-04-03 16:42:43 Set Level: 33 % zwave
2023-04-03 03:51:13 Off zwave
2023-04-03 03:49:28 Set Level: 33 % zwave
2023-04-03 00:35:07 Off zwave
2023-04-03 00:33:42 Set Level: 33 % zwave
2023-04-02 23:34:54 Off zwave
2023-04-02 23:33:28 Set Level: 33 % zwave
2023-04-02 08:17:11 Off zwave
2023-04-02 08:15:00 Set Level: 33 % zwave
2023-04-02 06:21:07 Off zwave
2023-04-02 06:19:33 Set Level: 33 % zwave
et 1 module double relais qubino
qui dés que j essais de l'éteindre , ce rallume
2023-04-05 14:29:31 On zwave
2023-04-05 14:29:30 Off user (IP: xxx.xxx.xxx.208 )
2023-04-05 14:29:28 On zwave
2023-04-05 14:29:27 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 14:29:21 On zwave
2023-04-05 14:29:16 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 14:28:43 On zwave
2023-04-05 14:28:42 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 14:00:15 On zwave
2023-04-05 14:00:08 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 14:00:07 On zwave
2023-04-05 14:00:05 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 14:00:03 On zwave
2023-04-05 14:00:02 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 13:56:48 On zwave
2023-04-05 13:56:46 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 13:56:44 On zwave
2023-04-05 13:56:42 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 13:56:40 On zwave
2023-04-05 13:56:39 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 13:56:39 On zwave
2023-04-05 13:56:38 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 13:56:38 On zwave
2023-04-05 13:56:37 Off user (IP: xxx.xxx.xxx.208)
2023-04-05 13:56:36 On zwave
help merci ( toujours en version 2022)
probleme de periferique qui se rallume seul
Re: probleme de periferique qui se rallume seul
Pour ton problème de périphériques, as-tu des scripts qui commandent ces modules ? Si oui, désactive-les tous pour voir si ton souci ne viendrait pas de là.
Qu'est-ce qui peut expliquer ce changement de comportement : tu as fait des mises à jour, des changements particuliers ?
Dernière modification par Keros le 05 avr. 2023, 22:04, modifié 1 fois.
Raison : Correction de la faute d'orthographe
C'est corrigé, merci
bonjour
non pas de script ,
pour la filtration c est un problème ponctuel quand j essais de l actionner hors réseau local
mais pour l éclairage parking c est arrivé après avoir voulue mettre une tempo de 5 min pour l éteindre
et depuis , elle s allume et s éteint toute seule mais ne s illumine pas puisque les LEDs ne sont pas dimmable et cela s active a 33% alors que le module n est pas configuré en dimmer ....
j ai essayé d exclure et de reinclure le module mais c est pareil ( sauf qu avant c était on off et maintenant 33% )
peut être les modules qubino qui dysfonctionnent ?...
non pas de script ,
