J'ai créer une passerelle ZiGate-Ethernet en connectant ma PiZiGate+ a mon raspberry PI2 en suivant le tuto suivant https://zigate.fr/documentation/creer-u ... pberry-pi/.
J'ai mis à jour aussi ce mation le firmware de la pizigate avec la derniére version disponible 03a0.
J'ai configurer le plugin Zigbeefordomoticz pour utiliser la zigate-Ethernet,
Voici le log
2023-02-26 12:39:00.723 Zigbee: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-02.json timestamp is 1677410993.869133
2023-02-26 12:39:00.724 Zigbee: Dz PluginConf is older than Json Dz: 0 Json: 1677410993.869133
2023-02-26 12:39:00.727 Zigbee: Installing plugin custom page /home/pi/domoticz/www/templates/Zigbee.html
2023-02-26 12:39:00.728 Zigbee: Starting LoggingManagement thread
2023-02-26 12:39:00.735 Zigbee: start_logging_thread
2023-02-26 12:39:00.736 Zigbee: logging_thread - listening
2023-02-26 12:39:00.423 Status: Zigbee: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-02-26 12:39:00.726 Status: Zigbee: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-02.json
2023-02-26 12:39:00.726 Status: Zigbee: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2023-02-26 12:39:00.726 Status: Zigbee: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2023-02-26 12:39:00.726 Status: Zigbee: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2023-02-26 12:39:00.726 Status: Zigbee: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2023-02-26 12:39:00.726 Status: Zigbee: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2023-02-26 12:39:00.727 Status: Zigbee: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2023-02-26 12:39:00.727 Status: Zigbee: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2023-02-26 12:39:00.727 Status: Zigbee: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2023-02-26 12:39:00.736 Status: Zigbee: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_02.log
2023-02-26 12:39:00.756 Status: Zigbee: Zigbee for Domoticz (z4d) plugin stable6-6.3.010 started
2023-02-26 12:39:00.864 Status: Zigbee: DeviceConf loaded - 17 confs loaded
2023-02-26 12:39:00.788 Error: Zigbee: Urlopen to http://127.0.0.1:8080/json.htm?type=hardware rejected. Error: HTTP Error 401: Unauthorized
2023-02-26 12:39:00.822 Error: Zigbee: Urlopen to http://127.0.0.1:8080/json.htm?type=hardware rejected. Error: HTTP Error 401: Unauthorized
2023-02-26 12:39:01.435 Status: Zigbee: DeviceConf loaded - 424 confs loaded
2023-02-26 12:39:01.438 Status: Zigbee: load ListOfDevice
2023-02-26 12:39:01.440 Status: Zigbee: 0 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-2.txt
2023-02-26 12:39:01.449 Status: Zigbee: Transport mode: V2-Wifi
2023-02-26 12:39:01.513 Status: Zigbee: ZigateTransport: TCPIP Connection open: <socket.socket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('192.168.5.200', 51460), raddr=('192.168.5.248', 9999)>
2023-02-26 12:39:02.518 Status: Zigbee: ZigateTransport: writer_thread Thread start.
2023-02-26 12:39:02.524 Status: Zigbee: ZigateTransport: thread_processing_and_sending Thread start.
2023-02-26 12:39:02.528 Status: Zigbee: Start Web Server connection
2023-02-26 12:39:02.609 Status: Zigbee: Web backend for Web User Interface started on port: 9440
2023-02-26 12:39:02.610 Status: Zigbee: Domoticz Widgets usage is at 1.2 % (252 units free)
2023-02-26 12:39:11.157 Status: Zigbee: ==> Transport Mode switch to full mode
2023-02-26 12:39:11.161 Status: Zigbee: ZiGate+ (V2)
2023-02-26 12:39:11.162 Status: Zigbee: Installer Version Number: 03a0
2023-02-26 12:39:11.163 Status: Zigbee: Branch Version: ==> Production <==
2023-02-26 12:39:16.092 Status: Zigbee: Erase coordinator PDM
2023-02-26 12:39:16.528 Status: Zigbee: ZiGate PDM loaded
2023-02-26 12:39:16.532 Status: Zigbee: 'Factory new' Restart status: STARTUP
2023-02-26 12:39:21.207 Status: Zigbee: ZiGate+ (V2)
2023-02-26 12:39:21.211 Status: Zigbee: Installer Version Number: 03a0
2023-02-26 12:39:21.212 Status: Zigbee: Branch Version: ==> Production <==
2023-02-26 12:39:31.081 Status: Zigbee: ZigateConf - Setting extPANID : 0x0000000000000000
2023-02-26 12:39:31.083 Status: Zigbee: ZigateConf setting Channel(s) to: 0
2023-02-26 12:39:31.084 Status: Zigbee: setChannel - Channel set to : 00000000
2023-02-26 12:39:31.086 Status: Zigbee: Force ZiGate to Normal mode
2023-02-26 12:39:31.087 Status: Zigbee: Start network
2023-02-26 12:39:31.089 Status: Zigbee: Set Zigate as a TimeServer
2023-02-26 12:39:35.880 Status: Zigbee: Accepting new Hardware: Disable (Off)
2023-02-26 12:39:36.030 Error: Zigbee: Coordinator not correctly initialized
2023-02-26 12:39:36.234 Error: Zigbee: Coordinator not correctly initialized
2023-02-26 12:39:40.193 Zigbee: Decode8024: Status: 01
2023-02-26 12:39:40.193 Status: Zigbee: Updating Channel in Plugin Configuration from: 0 to: 11
2023-02-26 12:39:40.196 Status: Zigbee: Start Network - Formed new network
2023-02-26 12:39:40.200 Status: Zigbee: Coordinator details IEEE: 00158d00095202d6, NetworkID: 0000, Channel: 11, Status: 01: Success
2023-02-26 12:39:41.112 Status: Zigbee: Request Disabling Accepting new Hardware
2023-02-26 12:39:41.721 Status: Zigbee: Accepting new Hardware: Disable (Off)
2023-02-26 12:39:46.069 Zigbee: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 2, 'name': 'Zigbee', 'address': '192.168.5.248', 'port': '9999', 'serialport': '/dev/ttyAMA0', 'Mode1': 'V2', 'Mode2': 'Wifi', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '2', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-02-26 12:39:46.071 Status: Zigbee: Plugin Restart command : http://127.0.0.1:8080/json.htm?type=command¶m=updatehardware&htype=94&idx=2&name=Zigbee&address=192.168.5.248&port=9999&serialport=%2Fdev%2FttyAMA0&Mode1=V2&Mode2=Wifi&Mode3=False&Mode4=9440&Mode5=http%3A%2F%2F127.0.0.1%3A8080&Mode6=2&extra=Zigate&enabled=true&datatimeout=0&loglevel=7
2023-02-26 12:39:46.113 Status: Zigbee: coordinator set to Certification : 1/CE -> CE
2023-02-26 12:39:46.735 Status: Zigbee: ota_scan_folder Following Firmware have been loaded
2023-02-26 12:39:46.736 Status: Zigbee: Plugin with Zigate+, firmware 03a0 correctly initialized
2023-02-26 12:39:46.080 Error: Zigbee: WARNING: Firmware 03a0 is not yet supportedReflasher la Pizigate+ avec le firmware de la version précédente au 03a0?
Philippe.
