la configuration :
DomoticZ 2023.1
RPI B+ Bullseye lite
RFXCom433E Pro2 1048
Conbee2 Z4D plugin 6.4.412 developp
WI-FI USB WIPI
USB->ùSD Rpi_clone
J'ai plusieurs erreurs dans les log de domoticz au démarrage :
2023-04-29 09:18:03.449 Error: Conbee2: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/ to /home/pi/domoticz/plugins/Domoticz-Zigbee is required, but no backward compatibility
2023-04-29 09:18:03.451 Error: Conbee2: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/ to /home/pi/domoticz/plugins/Domoticz-Zigbee is required, but no backward compatibility
2023-04-29 09:18:03.459 Error: Conbee2: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data is required, but no backward compatibility
2023-04-29 09:18:03.462 Error: Conbee2: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf is required, but no backward compatibility
2023-04-29 09:18:03.464 Error: Conbee2: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware is required, but no backward compatibility
2023-04-29 09:18:03.472 Error: Conbee2: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports is required, but no backward compatibility
2023-04-29 09:18:03.474 Error: Conbee2: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/www/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/www is required, but no backward compatibility
2023-04-29 09:18:03.476 Error: Conbee2: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs is required, but no backward compatibility
2023-04-29 09:18:34.598 Error: Conbee2 hardware (5) thread seems to have ended unexpectedlyCode : Tout sélectionner
2023-04-29 09:17:48.335 Status: Conbee2: Initialized version 6.4, author 'pipiche38'
2023-04-29 09:17:48.386 Status: Conbee2: Zigbee for Domoticz plugin started!
2023-04-29 09:17:48.386 Status: Conbee2: Python3 requires 3.8 or above and you are running 3.9
2023-04-29 09:17:48.389 Status: Conbee2: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-04-29 09:18:01.977 Status: Conbee2: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-04-29 09:18:03.478 Status: Conbee2: PluginAnalytics set to 1
2023-04-29 09:18:03.479 Status: Conbee2: checkFirmwareAgainstZigbeeOTARepository set to 0
2023-04-29 09:18:03.480 Status: Conbee2: channel set to 25
2023-04-29 09:18:03.481 Status: Conbee2: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-05.json
2023-04-29 09:18:03.481 Status: Conbee2: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2023-04-29 09:18:03.481 Status: Conbee2: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2023-04-29 09:18:03.481 Status: Conbee2: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2023-04-29 09:18:03.492 Status: Conbee2: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2023-04-29 09:18:03.492 Status: Conbee2: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2023-04-29 09:18:03.493 Status: Conbee2: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2023-04-29 09:18:03.493 Status: Conbee2: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2023-04-29 09:18:03.493 Status: Conbee2: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2023-04-29 09:18:03.494 Status: Conbee2: enablePluginLogging set to 0
2023-04-29 09:18:03.494 Status: Conbee2: logDeviceUpdate set to 0
2023-04-29 09:18:03.495 Status: Conbee2: NXPExtendedErrorCode set to 0
2023-04-29 09:18:03.496 Status: Conbee2: ControllerInRawMode set to True
2023-04-29 09:18:03.496 Status: Conbee2: expJsonDatabase set to 0
2023-04-29 09:18:03.497 Status: Conbee2: ControllerInRawMode set to True
2023-04-29 09:18:03.622 Status: Conbee2: Zigbee for Domoticz (z4d) plugin beta6-6.4.412 [Certified Devices: 2.54] started
2023-04-29 09:18:03.984 Status: Conbee2: Loading ZCL Cluster definitions
2023-04-29 09:18:04.005 Status: Conbee2: - ZCL Cluster 0000 - (V1) Basic loaded
2023-04-29 09:18:04.014 Status: Conbee2: - ZCL Cluster 0001 - (V1) Power loaded
2023-04-29 09:18:04.022 Status: Conbee2: - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2023-04-29 09:18:04.028 Status: Conbee2: - ZCL Cluster 0003 - (V1) Identify loaded
2023-04-29 09:18:04.035 Status: Conbee2: - ZCL Cluster 0004 - (V1) Groups loaded
2023-04-29 09:18:04.047 Status: Conbee2: - ZCL Cluster 0005 - (V1) Scenes loaded
2023-04-29 09:18:04.054 Status: Conbee2: - ZCL Cluster 0006 - (V1) On/Off loaded
2023-04-29 09:18:04.061 Status: Conbee2: - ZCL Cluster 0008 - (V1) Level loaded
2023-04-29 09:18:04.067 Status: Conbee2: - ZCL Cluster 0009 - (V1) Alarms loaded
2023-04-29 09:18:04.076 Status: Conbee2: - ZCL Cluster 000a - (V1) Time loaded
2023-04-29 09:18:04.083 Status: Conbee2: - ZCL Cluster 000f - (V1) Binary Input loaded
2023-04-29 09:18:04.091 Status: Conbee2: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-04-29 09:18:04.100 Status: Conbee2: - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-04-29 09:18:04.108 Status: Conbee2: - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-04-29 09:18:04.115 Status: Conbee2: - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-04-29 09:18:04.122 Status: Conbee2: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-04-29 09:18:04.131 Status: Conbee2: - ZCL Cluster 0300 - (V1) Color Control loaded
2023-04-29 09:18:04.140 Status: Conbee2: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-04-29 09:18:04.147 Status: Conbee2: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-04-29 09:18:04.155 Status: Conbee2: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-04-29 09:18:04.163 Status: Conbee2: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-04-29 09:18:04.170 Status: Conbee2: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-04-29 09:18:04.179 Status: Conbee2: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-04-29 09:18:04.196 Status: Conbee2: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-04-29 09:18:04.204 Status: Conbee2: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-04-29 09:18:04.221 Status: Conbee2: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-04-29 09:18:04.232 Status: Conbee2: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-04-29 09:18:04.238 Status: Conbee2: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-04-29 09:18:04.245 Status: Conbee2: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-04-29 09:18:04.252 Status: Conbee2: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-04-29 09:18:04.259 Status: Conbee2: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-04-29 09:18:04.271 Status: Conbee2: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-04-29 09:18:04.315 Status: Conbee2: DeviceConf loaded - 16 confs loaded
2023-04-29 09:18:04.517 Status: Conbee2: Local-Device conf loaded - 28 confs loaded
2023-04-29 09:18:08.346 Status: Conbee2: Certified Devices loaded - 475 confs loaded
2023-04-29 09:18:08.347 Status: Conbee2: load ListOfDevice
2023-04-29 09:18:08.884 Status: Conbee2: 4 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-5.txt
2023-04-29 09:18:09.086 Status: Conbee2: Transport mode: ZigpydeCONZ
2023-04-29 09:18:26.844 Status: Conbee2: Start Zigpy Transport on deCONZ
2023-04-29 09:18:26.878 Status: Conbee2: Starting radio deCONZ port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2686713-if00
2023-04-29 09:18:26.888 Status: Conbee2: ZigpyTransport: thread_processing_and_sending Thread start.
2023-04-29 09:18:26.903 Status: Conbee2: Start Web Server connection
2023-04-29 09:18:27.945 Status: Conbee2: Web backend for Web User Interface started on port: 9440
2023-04-29 09:18:27.947 Status: Conbee2: Plugin looks to upgrade the Certified Device package
2023-04-29 09:18:28.134 Status: Conbee2: Started radio deCONZ port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2686713-if00
2023-04-29 09:18:36.816 Status: Conbee2: deConz Radio manufacturer: dresden elektronik
2023-04-29 09:18:36.818 Status: Conbee2: deConz Radio board model: ConBee II
2023-04-29 09:18:36.820 Status: Conbee2: deConz Radio version: 0x26780700
2023-04-29 09:18:36.850 Status: Conbee2: Network settings
2023-04-29 09:18:36.852 Status: Conbee2: Device IEEE: 00:21:2e:ff:ff:09:c1:6d
2023-04-29 09:18:36.857 Status: Conbee2: Device NWK: 0x0000
2023-04-29 09:18:36.874 Status: Conbee2: Network Update Id: 0x0000
2023-04-29 09:18:36.876 Status: Conbee2: PAN ID: 0xF85F
2023-04-29 09:18:36.877 Status: Conbee2: Extended PAN ID: 00:21:2e:ff:ff:09:c1:6d
2023-04-29 09:18:36.879 Status: Conbee2: Channel: 25
2023-04-29 09:18:36.964 Status: Conbee2: ConBee II
2023-04-29 09:18:37.003 Status: Conbee2: Installer Version Number: 0x26780700
2023-04-29 09:18:37.005 Status: Conbee2: Branch Version: ==> ConBee II <==
2023-04-29 09:18:37.257 Status: Conbee2: Zigbee Coordinator ieee: 00212effff09c16d , short addr: 0000
2023-04-29 09:18:37.258 Status: Conbee2: Network state UP, PANID: f85f extPANID: 0x00212effff09c16d Channel: 25
2023-04-29 09:18:48.605 Error: Conbee2 hardware (5) thread seems to have ended unexpectedly
2023-04-29 09:19:02.619 Error: Conbee2 hardware (5) thread seems to have ended unexpectedly
2023-04-29 09:19:16.626 Error: Conbee2 hardware (5) thread seems to have ended unexpectedly
2023-04-29 09:19:30.633 Error: Conbee2 hardware (5) thread seems to have ended unexpectedly
2023-04-29 09:19:44.644 Error: Conbee2 hardware (5) thread seems to have ended unexpectedly
2023-04-29 09:19:51.182 Status: Conbee2: Domoticz Widgets usage is at 3.9 % (245 units free)
2023-04-29 09:20:00.089 Status: Conbee2: Request Disabling Accepting new Hardware
2023-04-29 09:20:05.140 Status: Conbee2: coordinator set to Certification : 1/CE -> CE
2023-04-29 09:20:06.429 Status: Conbee2: ota_scan_folder Following Firmware have been loaded
2023-04-29 09:20:06.436 Status: Conbee2: Plugin with Zigpy, Coordinator ConBee II firmware deCONZ - 0x26780700 correctly initializedA mon niveau, tout fonctionne correctement donc aucune urgence : ça reste du facultatif.
Bon Week end
