Nouveau firmware rflink R35
patoche
Message par patoche »
Gros travail de la stunt team
R35: - Added: Full A OK Controller/Motor support
- Added: Brel motor support
- Added: Krippl temperature/humidity sensor support
- Added: Elro DB270 doorbell
- Added: InoValley SM302 Temperature&Humidity sensor (Thanks: Pirion)
- Added: EZ6 Temperature&Humidity sensor
- Added: Alecto SA30 & SA33 Smoke Alarm
- Added: Xiron RS8751E3 Weather sensor
- Added: LightwaveRF (initial support, testers needed)
- Added: support for Oregon sensor simulator
- Fixed: Oregon OWL CM119, CM160, CM180
- Fixed: Oregon UV800 uv index value
- Fixed: Corrected WH440 temperature values
- Fixed: Improved Philips SBC
- Fixed: Improved Chacon EMW200
- Fixed: Improved FA500 false positive detection
- Fixed: Removed a slash in the UPM/Esic name
- Fixed: Mertik transmit improved
- Fixed: Optimized the Auriol/Xiron plugin
- Fixed: LaCrosse negative temperatures and extended allowed pulse range (Thanks: VeryBitter)
- Fixed: Alecto v1 Windspeed value
- Fixed: Improved Otio remote signal handling
- Fixed: corrected WH2 handling for Tesa WH1150 sensor (Thanks: Pirion)
- Fixed: Lacrosse rain - wind needs some more work (Thanks: Arie)
- Tested: tested and working: Lidl / Libra TR502MSV switches
- Tested: tested and working: Avidsen door contact 102539
http://sourceforge.net/projects/rflink/files/
RPI2 OSMC + domoticz + Rfx 433e + chacon dio, teleinfo 433 via arduino nano, sonde T° innovaley et TFA 303139, sonde T° piscine DIY 433 oregon, OWL 180, RPI zero W + camera
deennoo
Re: Nouveau firmware rflink R35
Message par deennoo »
Super !!
Il va falloir vite essayer cela !
Xylème
Message par Xylème »
Salut
Je n'arrive à mettre à jour le firmware de mon rflink.
Etant sous osx, pour l'installation j'avais utilisé la méthode avrdude décrite ici.
J'ai voulu répéter la procédure pour faire la MAJ R35 mais j'ai cette erreur :
 Programmer Type : STK500V2
         Description     : Atmel STK500
         Programmer Model: Unknown
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Une autre personne en parle sur le fil du forum domoticz.com mais aucune réponse n'est apportée...
J'ai essayé de stopper le serveur domoticz avant de lancer le process mais ça ne change rien...
Une idée ?
Xylème
J'ai réussi à faire la mise à jour grâce à cette procédure :
On OS X you can do it as follows:
Download the Arduino App from https://www.arduino.cc and install it.
Open a terminal session.
From the directory where the Arduino App is located run the commands below whereby replacing /dev/cu.usbmodem411 and RFLink_v1-2/RFLink.cpp.hex with your own values.
Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -v -p atmega2560 -c stk500 -P /dev/cu.usbmodem411 -b 115200 -D -U flash:w:RFLink_v1-2/RFLink.cpp.hex:i -C Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf
