[Résolu] Ajout matériel - Compteur énergie "Zigbee Smart Meter with CT"
Jempi57
Message par Jempi57 »
Domoticz :
Version: 2023.1
Build Hash: f9b9ac774
Compile Date: 2023-02-14 15:06:40
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
Plugin Z4D:
stable6-6.3.013.
Bullsays à jour. Je ne suis pas sur la branche dev du plugin, ça ne fonctionne pas.
{"PluginInfos":{"HardwareID":3,"HomeFolder":"/home/pi/domoticz/plugins/Domoticz-Zigbee/",
"StartupFolder":"/home/pi/domoticz/","UserDataFolder":"/home/pi/domoticz/","WebRoot":"",
"Database":"/home/pi/domoticz/domoticz.db","Language":"fr","Version":"6.3",
"Author":"pipiche38","Name":"Compteur","Address":"0.0.0.0","Port":"9999","SerialPort":
"/dev/ttyAMA0","Key":"Zigate","Mode1":"V2","Mode2":"PI","Mode3":"False","Mode4":"9440","Mode6":"2","DomoticzVersion":"2023.1","DomoticzHash":"f9b9ac774","DomoticzBuildTime":"2023-02-14
15:06:40","PluginBranch":"stable6","PluginVersion":"6.3.013","TimeStamp":1684844701,"available":"6.3.012","available-firmMajor":"05","available-firmMinor":"0321","FirmwareVersion":"0321","FirmwareUpdate":false,"PluginUpdate":false,"LogLevel":7,"Zigpy":false,"CoordinatorModel":
"ZiGate+ (V2)","CoordinatorFirmwareVersion":"0321","DisplayFirmwareVersion"
:"Zigate - 0321","CoordinatorIEEE":"00158d0005d2a072","NetworkSize":"Total: 1 | Routers: 1 | End Devices: 0","NetworkDevices":{"1037":{"LiXee":["ZLinky_TIC-historique-mono"]}}},"Analytics":1,"Device":{"Version":"3","ZDeviceName":"","Status":"UNKNOW","SQN":"61","Ep":{"01":{"0000":{"0004":"_TZE204_cjbofhxw","0005":"TS0601","0001":"70","ffe2":"31","ffe4":"0","ffdf":"+f+\u0012+\u0012"},"0004":{},"0005":{},"ef00":{},"0019":{},"000a":{}}},"Heartbeat":"19","RIA":"4","LQI":28,"Battery":{},"Model":"TS0601","ForceAckCommands":
[],"MacCapa":"8e","IEEE":"70ac08fffed04e16","Type":{},"ProfileID":"0104","ZDeviceID":"0051","App Version":"70","Attributes List":{},"DeviceType":"FFD","HW Version":"","Last Cmds":
[[14,"02","fef8","0100","01010000000000000200040005"]],"LogicalType":"Router","Manufacturer":"1002","Manufacturer Name":"_TZE204_cjbofhxw","NbEp":"1","PowerSource":"Main","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":1684844622,"iSQN":{"0004":14,"0005":14},"Attributes":
{"0004":"00","0005":"00","0001":"00","ffe2":"00","ffe4":"00","ffdf":"00"}
,"ZigateRequest":{}}}}},"ReceiveOnIdle":"On","Stack Version":"","Stamp":{"time":1684844699.1876864,"Time":"2023-05-23 14:24:59","MsgType":"8011","LastSeen":1684844699},"ZCL Version":"","Health":"Live","Capability":
["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"ZDPSQN":"00","RollingLQI":[26,27,27,30,30,28,28,29,29,28,28],"Epv2":{"01":{"ClusterIn":{"0000":{},"0004":{},"0005":{},"ef00":{}},"ClusterOut":{"0019":{},"000a":{}},"ProfileID":"0104","ZDeviceID":"0051"}},"WriteAttributes":{"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":
{}}}}},"ZDeviceVersion":"0001","ConfigSource":"8043","PairingInProgress":
true,"_rawNodeDescriptor":"1002005200522c00008e524001","Max Buffer Size":"52","Max Rx":"0052","Max Tx":"0052","macapa":"8e","bitfield":"4001","server_mask":"2c00","descriptor_capability":"00","Tuya":{"TUYA_MCU_VERSION_RSP":"40"},"SQN_000a":"4b"}}
Log à l'appairage:
2023-05-23 14:23:30.515 Status: Compteur: [None] NEW OBJECT: fef8 None
2023-05-23 14:23:30.764 Status: Compteur: [-] NEW OBJECT: fef8 Active Endpoint Response Ep: 01 LQI: 32
2023-05-23 14:23:30.773 Status: Compteur: [-] NEW OBJECT: fef8 Request Simple Descriptor for Ep: 01
2023-05-23 14:23:30.998 Status: Compteur: [-] NEW OBJECT: fef8 Simple Descriptor Response EP: 0x01 LQI: 35
2023-05-23 14:23:30.998 Status: Compteur: [-] NEW OBJECT: fef8 ProfileID 0104
2023-05-23 14:23:30.999 Status: Compteur: [-] NEW OBJECT: fef8 ZDeviceID 0051
2023-05-23 14:23:31.000 Status: Compteur: [-] NEW OBJECT: fef8 Application Version 0001
2023-05-23 14:23:31.001 Status: Compteur: [-] NEW OBJECT: fef8 Cluster IN Count: 04
2023-05-23 14:23:31.002 Status: Compteur: [-] NEW OBJECT: fef8 Cluster In 1: 0000 (Basic)
2023-05-23 14:23:31.002 Status: Compteur: [-] NEW OBJECT: fef8 Cluster In 2: 0004 (Groups)
2023-05-23 14:23:31.003 Status: Compteur: [-] NEW OBJECT: fef8 Cluster In 3: 0005 (Scenes)
2023-05-23 14:23:31.004 Status: Compteur: [-] NEW OBJECT: fef8 Cluster In 4: ef00
2023-05-23 14:23:31.005 Status: Compteur: [-] NEW OBJECT: fef8 Cluster OUT Count: 02
2023-05-23 14:23:31.005 Status: Compteur: [-] NEW OBJECT: fef8 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2023-05-23 14:23:31.006 Status: Compteur: [-] NEW OBJECT: fef8 Cluster Out 2: 000a (Time)
2023-05-23 14:23:31.105 Status: Compteur: [0] NEW OBJECT: fef8 Model Name: TS0601
2023-05-23 14:23:31.107 Status: Compteur: [0] NEW OBJECT: fef8 Manufacturer Name: _TZE204_cjbofhxw
2023-05-23 14:23:31.109 Status: Compteur: [None] NEW OBJECT: fef8 Request Node Descriptor
2023-05-23 14:23:32.977 Compteur: Assisted Pairing: Polling: ['fef8']
2023-05-23 14:23:32.977 Compteur: --> New device: fef8
2023-05-23 14:23:36.097 Status: Compteur: [1] NEW OBJECT: fef8 Model Name: TS0601
2023-05-23 14:23:36.099 Status: Compteur: [1] NEW OBJECT: fef8 Manufacturer Name: _TZE204_cjbofhxw
2023-05-23 14:23:41.068 Status: Compteur: [2] NEW OBJECT: fef8 Model Name: TS0601
2023-05-23 14:23:41.069 Status: Compteur: [2] NEW OBJECT: fef8 Manufacturer Name: _TZE204_cjbofhxw
2023-05-23 14:23:42.974 Compteur: Assisted Pairing: Polling: ['fef8']
2023-05-23 14:23:42.974 Compteur: --> New device: fef8
2023-05-23 14:23:46.098 Status: Compteur: [3] NEW OBJECT: fef8 Model Name: TS0601
2023-05-23 14:23:46.104 Status: Compteur: [3] NEW OBJECT: fef8 Manufacturer Name: _TZE204_cjbofhxw
2023-05-23 14:23:46.096 Error: Compteur: processNotinDBDevices - Creat Domo Device Failed !!! for fef8 status: 8043
2023-05-23 14:23:53.813 Compteur: Assisted Pairing: Polling: ['fef8']
2023-05-23 14:23:53.813 Compteur: --> New device: fef8
2023-05-23 14:23:53.813 Compteur: --> UNKNOW , removed fef8 from List
2023-05-23 14:23:53.813 Compteur: ------> New Cluster: {'ClusterId': '0000', 'ClusterDesc': 'Basic'}
2023-05-23 14:23:53.813 Compteur: ------> New Cluster: {'ClusterId': '0004', 'ClusterDesc': 'Groups'}
2023-05-23 14:23:53.813 Compteur: ------> New Cluster: {'ClusterId': '0005', 'ClusterDesc': 'Scenes'}
2023-05-23 14:23:53.813 Compteur: ------> New Cluster: {'ClusterId': 'ef00', 'ClusterDesc': 'Unknown'}
2023-05-23 14:23:53.813 Compteur: ------> New Cluster: {'ClusterId': '0019', 'ClusterDesc': 'Over-the-Air Upgrade'}
2023-05-23 14:23:53.813 Compteur: ------> New Cluster: {'ClusterId': '000a', 'ClusterDesc': 'Time'}
2023-05-23 14:23:53.814 Compteur: ----> New Ep: {'Ep': '01', 'Clusters': [{'ClusterId': '0000', 'ClusterDesc': 'Basic'}, {'ClusterId': '0004', 'ClusterDesc': 'Groups'}, {'ClusterId': '0005', 'ClusterDesc': 'Scenes'}, {'ClusterId': 'ef00', 'ClusterDesc': 'Unknown'}, {'ClusterId': '0019', 'ClusterDesc': 'Over-the-Air Upgrade'}, {'ClusterId': '000a', 'ClusterDesc': 'Time'}]}
2023-05-23 14:23:53.814 Compteur: --> New Device: {'NwkId': 'fef8', 'ProvisionStatus': 'Failed', 'ProvisionStatusDesc': 'Failed', 'IEEE': '70ac08fffed04e16', 'ProfileId': '0104', 'ProfileIdDesc': 'ZHA', 'ZDeviceID': '0051', 'ZDeviceIDDesc': 'Unknow', 'Model': 'TS0601', 'PluginCertified': 'no', 'Ep': [{'Ep': '01', 'Clusters': [{'ClusterId': '0000', 'ClusterDesc': 'Basic'}, {'ClusterId': '0004', 'ClusterDesc': 'Groups'}, {'ClusterId': '0005', 'ClusterDesc': 'Scenes'}, {'ClusterId': 'ef00', 'ClusterDesc': 'Unknown'}, {'ClusterId': '0019', 'ClusterDesc': 'Over-the-Air Upgrade'}, {'ClusterId': '000a', 'ClusterDesc': 'Time'}]}]}
2023-05-23 14:24:03.341 Compteur: Assisted Pairing: Polling: []
2023-05-23 14:24:03.341 Compteur: --> Empty queue
2023-05-23 14:24:12.987 Compteur: Assisted Pairing: Polling: []
2023-05-23 14:24:12.987 Compteur: --> Empty queue
2023-05-23 14:24:22.987 Compteur: Assisted Pairing: Polling: []
2023-05-23 14:24:22.987 Compteur: --> Empty queue
2023-05-23 14:24:29.269 Compteur: Disable Assisted pairing
2023-05-23 14:24:29.279 Status: Compteur: Request Disabling Accepting new Hardware
2023-05-23 14:24:29.478 Status: Compteur: Accepting new Hardware: Disable (Off)
Que dois-je faire, merci d'avance.
PS: sur le commentaires du produit, il est indiqué que l'interface fonctionne aussi avec Zigbee2mqtt et je n'y arrive pas non plus.
Merci d'avance pour vos conseilles. JPB.
PS: Zigate ver 0321.
Dernière modification par Jempi57 le 23 mai 2023, 15:09, modifié 1 fois.
pipiche
Re: [Résolu] Ajout matériel - Compteur énergie "Zigbee Smart Meter with CT"
Message par pipiche »
Passes sur la branche de développement pour commencer
Wiki ici
chat sur Keybase.io
Jempi57
Bonjour, merci.
J'ai préféré demander.
Par contre, je ne comprends pas:
2023-05-23 16:22:30.697 Error: Compteur: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/ to /home/pi/domoticz/plugins/Domoticz-Zigbee is required, but no backward compatibility
2023-05-23 16:22:30.697 Error: Compteur: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data is required, but no backward compatibility
2023-05-23 16:22:30.698 Error: Compteur: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf is required, but no backward compatibility
2023-05-23 16:22:30.698 Error: Compteur: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware is required, but no backward compatibility
2023-05-23 16:22:30.698 Error: Compteur: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports is required, but no backward compatibility
2023-05-23 16:22:30.698 Error: Compteur: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/www/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/www is required, but no backward compatibility
2023-05-23 16:22:30.698 Error: Compteur: Updating path from /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/ to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs is required, but no backward compatibility
C'est tout bon pour le CT meter.
Modération
Merci de ne pas continuer d'autres sujets.
