Conbee2 & Wizer CCTFR6400 "optimisé" mais non fonctionnel
Re: Conbee2 & Wizer CCTFR6400 "optimisé" mais non fonctionnel
et tu as bien activer le parametre Wiser 2 ?
peux-tu activer le debug Schneider
le cas echeant, peux-tu relancer le plugin et ensuite me faire parvenir les logs ?
et oui je confirme que la date d'appairage est: Friday, August 4, 2023 11:33:24.339 AM GMT+02:00 DST
je reproduis le problème avec une ConBee II et ce firmware.
Donc laisses moi jeter un oeil
je viens d'activer wiser2, redemarrage du plugin, activation du debug Scheinder et redemarrage du plugin.
log du demarrage :
Pas de changement dans Domoticz
log du demarrage :
2023-08-04 14:34:43.692 Status: Z4D: Initialized version 7.1, author 'pipiche38'
2023-08-04 14:34:43.751 Status: Z4D: Zigbee for Domoticz plugin starting
2023-08-04 14:34:43.752 Status: Z4D: Z4D plugin requires python3 3.8 or above and you are running 3.9
2023-08-04 14:34:43.753 Status: Z4D: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-08-04 14:35:00.014 Z4D: load PluginConf
2023-08-04 14:35:00.036 Z4D: Loading PluginConf - from Domoticz sqlite Db
2023-08-04 14:35:00.039 Z4D: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-08.json timestamp is 1691152420.8085272
2023-08-04 14:35:00.039 Z4D: Dz PluginConf is older than Json Dz: 0 Json: 1691152420.8085272
2023-08-04 14:35:00.072 Z4D: Installing plugin custom page /home/pi/domoticz/www/templates/Z4D.html
2023-08-04 14:35:00.079 Z4D: Starting LoggingManagement thread
2023-08-04 14:35:00.081 Z4D: zigpy_login_mode(30)
2023-08-04 14:35:00.116 Z4D: start_logging_thread
2023-08-04 14:35:00.120 Z4D: logging_thread - listening
2023-08-04 14:35:00.061 Status: Z4D: PluginAnalytics set to 1
2023-08-04 14:35:00.061 Status: Z4D: Wiser2 set to 1
2023-08-04 14:35:00.062 Status: Z4D: autoRestore set to 0
2023-08-04 14:35:00.062 Status: Z4D: checkFirmwareAgainstZigbeeOTARepository set to 0
2023-08-04 14:35:00.063 Status: Z4D: blueLedOnOff set to 0
2023-08-04 14:35:00.063 Status: Z4D: channel set to 15
2023-08-04 14:35:00.064 Status: Z4D: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-08.json
2023-08-04 14:35:00.064 Status: Z4D: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2023-08-04 14:35:00.064 Status: Z4D: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2023-08-04 14:35:00.064 Status: Z4D: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data
2023-08-04 14:35:00.065 Status: Z4D: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf
2023-08-04 14:35:00.065 Status: Z4D: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2023-08-04 14:35:00.065 Status: Z4D: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports
2023-08-04 14:35:00.066 Status: Z4D: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www
2023-08-04 14:35:00.066 Status: Z4D: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs
2023-08-04 14:35:00.066 Status: Z4D: logDeviceUpdate set to 0
2023-08-04 14:35:00.067 Status: Z4D: Schneider set to 1
2023-08-04 14:35:00.068 Status: Z4D: ControllerInRawMode set to True
2023-08-04 14:35:00.068 Status: Z4D: expJsonDatabase set to 0
2023-08-04 14:35:00.069 Status: Z4D: ControllerInRawMode set to True
2023-08-04 14:35:00.123 Status: Z4D: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_08.log
2023-08-04 14:35:00.316 Status: Z4D: Zigbee for Domoticz (z4d) plugin stable7-7.1.001 started
2023-08-04 14:35:01.126 Status: Z4D: Loading ZCL Cluster definitions
2023-08-04 14:35:01.171 Status: Z4D: - ZCL Cluster 0000 - (V1) Basic loaded
2023-08-04 14:35:01.191 Status: Z4D: - ZCL Cluster 0001 - (V1) Power loaded
2023-08-04 14:35:01.211 Status: Z4D: - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2023-08-04 14:35:01.220 Status: Z4D: - ZCL Cluster 0003 - (V1) Identify loaded
2023-08-04 14:35:01.233 Status: Z4D: - ZCL Cluster 0004 - (V1) Groups loaded
2023-08-04 14:35:01.251 Status: Z4D: - ZCL Cluster 0005 - (V1) Scenes loaded
2023-08-04 14:35:01.265 Status: Z4D: - ZCL Cluster 0006 - (V1) On/Off loaded
2023-08-04 14:35:01.281 Status: Z4D: - ZCL Cluster 0008 - (V1) Level loaded
2023-08-04 14:35:01.306 Status: Z4D: - ZCL Cluster 0009 - (V1) Alarms loaded
2023-08-04 14:35:01.319 Status: Z4D: - ZCL Cluster 000a - (V1) Time loaded
2023-08-04 14:35:01.323 Status: Z4D: - ZCL Cluster 000d - (V1) Analog Output loaded
2023-08-04 14:35:01.361 Status: Z4D: - ZCL Cluster 000f - (V1) Binary Input loaded
2023-08-04 14:35:01.365 Status: Z4D: - ZCL Cluster 0013 - (V1) Multistate Output loaded
2023-08-04 14:35:01.385 Status: Z4D: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-08-04 14:35:01.403 Status: Z4D: - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-08-04 14:35:01.410 Status: Z4D: - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-08-04 14:35:01.429 Status: Z4D: - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-08-04 14:35:01.461 Status: Z4D: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-08-04 14:35:01.473 Status: Z4D: - ZCL Cluster 0300 - (V1) Color Control loaded
2023-08-04 14:35:01.501 Status: Z4D: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-08-04 14:35:01.505 Status: Z4D: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-08-04 14:35:01.536 Status: Z4D: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-08-04 14:35:01.541 Status: Z4D: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-08-04 14:35:01.545 Status: Z4D: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-08-04 14:35:01.565 Status: Z4D: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-08-04 14:35:01.662 Status: Z4D: - ZCL Cluster 0700 - (V1) Price loaded
2023-08-04 14:35:01.703 Status: Z4D: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-08-04 14:35:01.714 Status: Z4D: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-08-04 14:35:01.752 Status: Z4D: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-08-04 14:35:01.777 Status: Z4D: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-08-04 14:35:01.800 Status: Z4D: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-08-04 14:35:01.805 Status: Z4D: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-08-04 14:35:01.833 Status: Z4D: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-08-04 14:35:01.857 Status: Z4D: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-08-04 14:35:01.862 Status: Z4D: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-08-04 14:35:01.950 Status: Z4D: DeviceConf loaded - 16 confs loaded
2023-08-04 14:35:02.026 Status: Z4D: Local-Device conf loaded - 21 confs loaded
2023-08-04 14:35:06.130 Status: Z4D: Certified Devices loaded - 500 confs loaded
2023-08-04 14:35:06.134 Status: Z4D: load ListOfDevice
2023-08-04 14:35:06.754 Status: Z4D: 5 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-8.txt
2023-08-04 14:35:06.987 Status: Z4D: Transport mode: ZigpydeCONZ
2023-08-04 14:35:25.303 Status: Z4D: Start Zigpy Transport on deCONZ
2023-08-04 14:35:25.364 Status: Z4D: Starting radio deCONZ port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2669869-if00
2023-08-04 14:35:25.402 Status: Z4D: ZigpyTransport: thread_processing_and_sending Thread start.
2023-08-04 14:35:25.418 Status: Z4D: Start Web Server connection
2023-08-04 14:35:26.232 Status: Z4D: Web backend for Web User Interface started on port: 9440
2023-08-04 14:35:26.278 Status: Z4D: Plugin looks to upgrade the Certified Device package
2023-08-04 14:35:26.392 Status: Z4D: Started radio deCONZ port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2669869-if00
2023-08-04 14:35:31.795 Status: Z4D: Adding Wiser2 Endpoint 0x3
2023-08-04 14:35:36.770 Status: Z4D: deConz Radio manufacturer: dresden elektronik
2023-08-04 14:35:36.784 Status: Z4D: deConz Radio board model: ConBee II
2023-08-04 14:35:36.847 Status: Z4D: deConz Radio version: 0x26790700
2023-08-04 14:35:36.908 Status: Z4D: Network settings
2023-08-04 14:35:36.917 Status: Z4D: Device IEEE: 00:21:2e:ff:ff:09:7f:a1
2023-08-04 14:35:36.967 Status: Z4D: Device NWK: 0x0000
2023-08-04 14:35:36.972 Status: Z4D: Network Update Id: 0x0000
2023-08-04 14:35:37.012 Status: Z4D: PAN ID: 0x6CFF
2023-08-04 14:35:37.045 Status: Z4D: Extended PAN ID: 34:85:e9:ed:6b:f9:f3:79
2023-08-04 14:35:37.068 Status: Z4D: Channel: 15
2023-08-04 14:35:37.165 Status: Z4D: ConBee II
2023-08-04 14:35:37.201 Status: Z4D: Installer Version Number: 0x26790700
2023-08-04 14:35:37.206 Status: Z4D: Branch Version: ==> ConBee II <==
2023-08-04 14:35:37.424 Status: Z4D: Zigbee Coordinator ieee: 00212effff097fa1 , short addr: 0000
2023-08-04 14:35:37.451 Status: Z4D: Network state UP, PANID: 6cff extPANID: 0x3485e9ed6bf9f379 Channel: 15
2023-08-04 14:35:42.010 Error: Z4D hardware (8) thread seems to have ended unexpectedly
2023-08-04 14:35:56.017 Error: Z4D hardware (8) thread seems to have ended unexpectedly
2023-08-04 14:36:10.024 Error: Z4D hardware (8) thread seems to have ended unexpectedly
2023-08-04 14:36:18.816 Error: Z4D: ReadCluster - Error/unknow 8247/01 Cluster: 0b05 Attribute: e001 Status: 00 DataType: 21 DataSize: 0002 Data: 0000
2023-08-04 14:36:24.034 Error: Z4D hardware (8) thread seems to have ended unexpectedly
2023-08-04 14:36:38.041 Error: Z4D hardware (8) thread seems to have ended unexpectedly
2023-08-04 14:36:52.049 Error: Z4D hardware (8) thread seems to have ended unexpectedly
2023-08-04 14:37:06.862 Status: Z4D: Domoticz Widgets usage is at 5.9 % (240 units free)
2023-08-04 14:37:06.058 Error: Z4D hardware (8) thread seems to have ended unexpectedly
2023-08-04 14:37:15.104 Status: Z4D: Request Disabling Accepting new Hardware
2023-08-04 14:37:18.933 Error: Z4D: ReadCluster - Error/unknow 8247/01 Cluster: 0b05 Attribute: e001 Status: 00 DataType: 21 DataSize: 0002 Data: 0000
2023-08-04 14:37:22.943 Status: Z4D: coordinator set to Certification : 1/CE -> CE
2023-08-04 14:37:22.960 Status: Z4D: ota_scan_folder Following Firmware have been loaded
2023-08-04 14:37:22.968 Status: Z4D: Plugin with Zigpy, Coordinator ConBee II firmware deCONZ - 0x26790700 correctly initialized
© 2012-2023 DoRPI 2 -> Bullseye Lite
DomoticZ -> 2024.7
RFXCom 433E -> Pro1 1041
DongleP - Z-Stack 3.30+ (build 20240710) /Z4D 7.1.025 [7.489]
CC1101 433Mhz "Itron EverBlue Cyble"
PiTInfo v1.4
USB->ùSD = Rpi-clones
DomoticZ -> 2024.7
PiTInfo v1.4
il faudrait que tu fasses une mise à jour depuis le repertoire du plugin
coté Domoticz/plugin, tu supprimes les widgets relatives a ce device, tu restart le plugin pour qu'il charge les dernier modules [2.81] tu vérifies que tu n'as pas le device dans le plugin
et tu refais l'appairage
sudo python3 -m pip --no-input install -r requirements.txt --ignore-requires-python --upgradecoté Domoticz/plugin, tu supprimes les widgets relatives a ce device, tu restart le plugin pour qu'il charge les dernier modules [2.81] tu vérifies que tu n'as pas le device dans le plugin
Wiki ici
chat sur Keybase.io
Wiki ici
chat sur Keybase.io
Je comprend pas, impossible d'appairer directement sur la Conbee... (j'avais déjà bien galéré avant la maj du Conbee)
Appairage depuis la prise en 1 seconde.
Z4D - Wiser2-Thermostat (temp + Humi)
Z4D - Wiser2-Thermostat_Humi-f082c0fffefc2ed3-01
Z4D - Wiser2-Thermostat_Temp-f082c0fffefc2ed3-01
Z4D - Wiser2-Thermostat_ThermoSetpoint-f082c0fffefc2ed3-01
Z4D - Wiser2-Thermostat_Valve-f082c0fffefc2ed3-01
Tout fonctionne!!!! (depuis le plugin et domoticz)
Un grand MERCI!!!!!!!!!!
si besoin
si besoin
DomoticZ -> 2024.7
PiTInfo v1.4
DomoticZ -> 2024.7
PiTInfo v1.4
Re: [Résolu] Conbee2 & Wizer CCTFR6400 "optimisé" mais non fonctionnel
super !!!
Wiki ici
chat sur Keybase.io
Wiki ici
chat sur Keybase.io
Je viens de bosser sur ce device, car je n'étais pas satisfait de la gestion du mode boost.Bibi49 a écrit : 04 août 2023, 15:43 Je comprend pas, impossible d'appairer directement sur la Conbee... (j'avais déjà bien galéré avant la maj du Conbee)
si besoin export (1).json
cela devrait arriver avec la version 7.1.021
dis moi si ca t'intéresse de valider en amont
Wiki ici
chat sur Keybase.io
Wiki ici
chat sur Keybase.io
Bonsoir Pipiche,
Ce model n'est pas facilement accessible (plus de 100km allé)
Je peux essayer de récupérer un thermomètre et un actionneur pour le tester sur mon Domoticz en signature pour ce week-end.
Je suis OK pour installer une version dev si besoin.
Je regarderais demain comment fonctionne ce mode boost sur la box wiser du boulot.
Bonne soirée
Bonne soirée
DomoticZ -> 2024.7
PiTInfo v1.4
DomoticZ -> 2024.7
PiTInfo v1.4
merci pour ton aide, et ta réactivité. mais si pas possible , pas de soucis
git pull
git checkout wiser2-thermostat-enhancement
git pull
Wiki ici
chat sur Keybase.io
Wiki ici
chat sur Keybase.io
Bonjour Pipiche,
J'ai une impression d'impatience de ta pars
J'ai installer "wiser2-thermostat-enhancement", durant l'installation, un "Warning" :
Suite a l'appairage, je te joins les logs "non optimisé", "raw" et "log du plugin"
Le CCTFR6700 n'est pas optimisé. il peut être soit en mode "relais" ou "fil pilotes" une sortie est prévu en option pour une sonde Th deporté.
Pour info, il n'y a pas de charge en sorti (j'ai juste emprunté le 6700 sans le convecteur)
le CCTFR6400 mode boost = 30m, 1h, 2h, 3h, arret.
Je laisse tourner, et au besoin, ce soir je t'envoi d'autres logs.
Je serais de retour vers 17h15.
Edit
le 6700 est en fw 1.8.12 (dernier en date)
le 6400 est en fw 0.60.3 (dernier en date)
le plugin Z4D m'affiche 7.1.020 [5.368]
Edit 2
Ajout errors.json
Bon courrage.
Using cached https://www.piwheels.org/simple/dnspython/dnspython-2.6.1-py3-none-any.whl (307 kB)
Requirement already satisfied: z4d-certified-devices in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 5)) (5.368)
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))': /simple/z4d-certified-devices/
Collecting z4d-certified-devices
Using cached https://www.piwheels.org/simple/z4d-certified-devices/z4d_certified_devices-5.368-py3-none-any.whl (430 kB)
Edit
Edit 2
Ajout errors.json
Bon courrage.
- Pièces jointes
errors.json- (147.79 Kio) Téléchargé 59 fois
_PluginZigbee_08.log- (39.6 Mio) Téléchargé 64 fois
exportobjetraw.json- (68.16 Kio) Téléchargé 56 fois
exportnonoptimise.json- (17.25 Kio) Téléchargé 60 fois
DomoticZ -> 2024.7
PiTInfo v1.4
DomoticZ -> 2024.7
PiTInfo v1.4
