Ok pour l'info qui ne remonte pas sur la trame TIC... on attend le premier jour blanc ou rouge pour voir si ça bouge !!
Et aussi ok pour le script pour la couleur du jour et du lendemain qui est déjà installé depuis pas mal de temps
A bientôt.
http://127.0.0.1:8080/json.htm?type=command¶m=setactivetimerplan&ActiveTimerPlan=1Code : Tout sélectionner
-- Title: script_time_tempoMgt.lua
-- This script manage tempo next-day "color" data retrieve from electricity provider,
-- timer plan switch to/from "red" days and warnings if next day 'color' was
-- not updated since more than 24h.
-- During "red" days, a warning is sent during high price hours (06h00/22h00) if
-- 10mn average power (computed in devMeanPwrVrtSen virtual power-meter) exceed a threshold.
-- Changelog:
-- 2023/10/15 : Creation
-- 2023/10/21 : Merge tempo update from all_time script.
-- 2023/10/28 : Extend next day color check max boundary from 14h00->16h00.
-- 2023/10/28 : Add tempoJ user var mgt + mean power drain alert for red days.
-- 2023/11/03 : Removed tempoName Idx explicit setting (use otherdevices_idx).
-- 2023/11/07 : Move mean power drain alert for red days in device script after
-- virtual power meter update changed to allow events triger...
-- 2023/11/28 : Add remaining days count for each price/color.
-- 2023/11/30 : Update tempoVarJ <- tempoVarJ1 at switch from red hours time, for
-- tempoVarJ being valid before daily tempo update hour.
-- Global settings
emailNotifyAlarm = 'TOTO@gmail.com'
-- Editable settings :
-- TEMPO current/next day "colors" update settings : (tempoName = virtual text switch name),
-- updates check time range must not cross midnight and be ordered (hCheck1 < hCheck2).
jsonLibPath = '/home/domo/domoticz/scripts/lua/JSON.lua' -- UPDATE USER NAME IN PATH !!!
hCheck1 = 11 -- Begin hour for updates check (should be done ~11h00)
hCheck2 = 16 -- End hour for updates check
tempoName = 'Tempo'
-- toTimPlans table string indexes must match names in timer-plan switching device timerPlanSw
-- and index a secondary table that contains 2 values with:
-- 1) Boolean : Define which timer-plan, if currently active, will trigger a "red day(s)" switch.
-- 2) Integer : Must match name level in selector definition.
-- => So we get decision/level data using toTimPlans.Norm[2] or, if VAR contains any
-- index string, toTimPlans[VAR][1] ('.' notation does not work for variables).
tempoVarJ = 'tempoJ' -- User variable that store current day color.
tempoVarJ1 = 'tempoJ1' -- User variable that store next day color for 6h00 timer plan switch.
timerPlanSw = 'PlanningActif'
toRedHour = 21 -- Switch to red timer-plan at 21h50.
toRedMin = 50
fromRedHour = 5 -- Switch from red timer-plan at 05h50.
fromRedMin = 50
toTimPlans = {['Off']={false, 0}, ['Norm']={true, 10}, ['Vacances']={false, 20}, ['VacancesM']={true, 30}, ['TempoR']={false, 40}}
-- Internal fct :
-- Get current script exec time & compute last 'device' or 'uservariable' update time.
local function timeLastUpdate(devOrVar, isUserVar)
t1 = os.time()
if (isUserVar == true) then
sT0 = uservariables_lastupdate[devOrVar]
sT0 = otherdevices_lastupdate[devOrVar]
-- Returns a date time like 2016-12-02 15:30:10
-- => Format as os.time & compute diff :
year = string.sub(sT0, 1, 4)
month = string.sub(sT0, 6, 7)
day = string.sub(sT0, 9, 10)
hour = string.sub(sT0, 12, 13)
minutes = string.sub(sT0, 15, 16)
seconds = string.sub(sT0, 18, 19)
t0 = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
tDiff = os.difftime(t1, t0)
return(tDiff)
-- Internal fct :
-- Get json answer EDF http/json API.
urlTempoColor='https://particulier.edf.fr/services/rest/referentiel/searchTempoStore?dateRelevant='
urlTempoCount='https://particulier.edf.fr/services/rest/referentiel/getNbTempoDays?TypeAlerte=TEMPO'
local function getUrlJson(url)
config = assert(io.popen('curl --retry 1 --connect-timeout 2 -m 4 \"'..url..'\"'))
tempo = config:read('*all')
config:close()
jsonOut = json:decode(tempo)
return(jsonOut)
-- MAIN --
time = os.date("*t")
-- TEMPO "COLOR" UPDATE:
-- Exec every 10mn in hereupper hours range until next day status is defined,
-- retrying while last update > range to handle tempory fails (EDF site unreachable...).
if ((time.min % 10 == 0) and (time.hour >= hCheck1) and (time.hour < hCheck2) and (timeLastUpdate(tempoName, false) > ((hCheck2 - hCheck1)*3600))) then
jsonLib = assert(loadfile(jsonLibPath))
json = (jsonLib)()
today = tostring(os.date("%Y-%m-%d"))
jsonTempo = getUrlJson(urlTempoColor..today)
--print(jsonTempo.couleurJourJ)
--print(jsonTempo.couleurJourJ1)
if (jsonTempo == nil) then
print("TEMPO : Warning, no data/color received ; Network issue?")
return
tempoJ = string.gsub(jsonTempo.couleurJourJ, "TEMPO_", "")
tempoJ1 = string.gsub(jsonTempo.couleurJourJ1, "TEMPO_", "")
dateDay = tostring(os.date("%A"))
dateNextDay = tostring(os.date('%A', (os.time()+ 86400)))
tempoText = dateDay..":"..tempoJ.." - "..dateNextDay..":"..tempoJ1
print("TEMPO : "..tempoText)
-- Only update when next day "color" is defined.
if (tempoJ1 ~= "NON_DEFINI") then
commandArray[#commandArray+1]={['Variable:'..tempoVarJ] = tempoJ}
commandArray[#commandArray+1]={['Variable:'..tempoVarJ1] = tempoJ1}
-- Get/add remaining days count information...
jsonTempo = getUrlJson(urlTempoCount)
--print(jsonTempo.PARAM_NB_J_BLEU)
--print(jsonTempo.PARAM_NB_J_BLANC)
--print(jsonTempo.PARAM_NB_J_ROUGE)
print("TEMPO : Warning, no data/count received ; Network issue?")
tempoText = tempoText..' ('..jsonTempo.PARAM_NB_J_BLEU..'/'..jsonTempo.PARAM_NB_J_BLANC..'/'..jsonTempo.PARAM_NB_J_ROUGE..')'
commandArray[#commandArray+1]={['UpdateDevice'] = otherdevices_idx[tempoName].."|0|"..tempoText}
-- Send notification mail if today or tomorrow prices are high...
if ((tempoJ1 ~= "BLEU") or (tempoJ ~= "BLEU")) then
commandArray[#commandArray+1]={['SendEmail'] = 'TEMPO Demain : '..tempoJ1..'#'..tempoText..'#'..emailNotifyAlarm}
print("TEMPO : Updated !")
-- Warn each hour (at HH:30", as Tempo update is usually done between 11:00 and 11:10),
-- during update hours range, if tempo status update did not work for more than 24h...
if ((time.min == 30) and (time.hour >= hCheck1) and (time.hour <= hCheck2)) then
local lastUpdVarT = timeLastUpdate(tempoVarJ1, true)
if (lastUpdVarT > 86400) then
print('ERROR : No TEMPO update since '..tostring(lastUpdVarT)..'s (>86400s/24h00).')
commandArray[#commandArray+1]={['SendEmail']='TEMPO Warning!#'..tempoVarJ1..' : Last Update > 24h ('..lastUpdVarT..'s)!!!#'..emailNotifyAlarm}
-- Need to switch to 'red' timerplan?
if ((time.hour == toRedHour) and (time.min == toRedMin)) then
if (uservariables[tempoVarJ1] == "ROUGE") and (toTimPlans[otherdevices[timerPlanSw]][1]) then
-- Switch current timer-plan to "TempoR"
print('Switch current timer-plan '..otherdevices[timerPlanSw]..' -> TempoR.')
commandArray[#commandArray+1]={[timerPlanSw]='Set Level: '..toTimPlans.TempoR[2]}
commandArray[#commandArray+1]={['SendEmail']='TEMPO Switch!#'..uservariables[tempoVarJ1]..' => TempoR!!!#'..emailNotifyAlarm}
-- Need to switch from 'red' timerplan?
if ((time.hour == fromRedHour) and (time.min == fromRedMin)) then
tempoJ1 = uservariables[tempoVarJ1]
if (tempoJ1 ~= "ROUGE") and (otherdevices[timerPlanSw] == "TempoR") then
-- Switch (back) "TempoR" timer-plan (always) to "Norm"
print('Switch current timer-plan '..otherdevices[timerPlanSw]..' -> Norm.')
commandArray[#commandArray+1]={[timerPlanSw]='Set Level: '..toTimPlans.Norm[2]}
commandArray[#commandArray+1]={['SendEmail']='TEMPO Switch!#'..uservariables[tempoVarJ1]..' => Norm!!!#'..emailNotifyAlarm}
-- Change tempoVarJ1 that is now tempoVarJ & may be used by tempoWarn script before daily refresh.
commandArray[#commandArray+1]={['Variable:'..tempoVarJ] = tempoJ1}
-- Title: script_device_tempoWarn.lua
-- This script warns if power drain during "red" days exceed a limit.
-- CAUTION: Virtual switches update from La does not trigger other "device" scripts
-- but this works using http/Json API, for instance:
-- curl 'http://127.0.1.1:8080/json.htm?type=command¶m=udevice&idx=706&svalue=280'
-- Changelog:
-- 2023/11/01 : Creation /don't work as expected as virtuel sensors update
-- through Lua does not trigger events/device scripts...
-- 2023/11/07 : OK after virtual meter update changed to allow event trig.
-- Global settings
tempoVarJ='tempoJ' -- User variable that store current day color.
SmartMeterSwitch='Relais Smart-Meter HP/HC Actif' -- 'Off' during high electricity price hours
devMeanPwrVrtSen='Puissance MOY' -- Virtual sensor type "usage/electricity" name.
warnMeanPower=1000
if (devicechanged[devMeanPwrVrtSen]) and (uservariables[tempoVarJ] == 'ROUGE') then
local curMeanPwr = tonumber(devicechanged[devMeanPwrVrtSen])
-- DEBUG:
--print(devMeanPwrVrtSen..' : '..tostring(curMeanPwr)..'W.')
-- Log on warn pwr figures during highest electricity price hours...
if (curMeanPwr > warnMeanPower) and (otherdevices[SmartMeterSwitch] == 'Off') then
print('TEMPO : Warning, '..devMeanPwrVrtSen..'/'..uservariables[tempoVarJ]..' : '..curMeanPwr..'W !!!')
commandArray[#commandArray+1]={['SendEmail']='TEMPO Pwr!#'..devMeanPwrVrtSen..'='..curMeanPwr..'W ('..uservariables[tempoVarJ]..')#'..emailNotifyAlarm}
2023-11-15 11:00:00.729 Status: LUA: TEMPO : Wednesday:BLEU - Thursday:NON_DEFINI
2023-11-15 11:02:05.949 Status: LUA: Puissance MOY : New time slice (after 603s) => Record Pmean=574.31W
2023-11-15 11:10:00.407 Status: LUA: TEMPO : Wednesday:BLEU - Thursday:BLEU
2023-11-15 11:10:00.407 Status: LUA: TEMPO : Updated !
JOURF 00 &
NJOURF+1 00 B
PJOURF+1 00004001 06004002 16004001 NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE 1
PPOINTE 00004003 06004004 16004003 NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE NONUTILE $
ADSC -------- 6
VTIC 02 J
DATE H231121222227 <
NGTF TEMPO F
LTARF HC BLEU ^
63ST G04828661 2
EASF02 002242798 E
EASF03 000000000 $
EASF04 000000000 %
EASF05 000000000 &
EASF06 000000000 '
EASF07 000000000 (
EASF08 000000000 )
EASF09 000000000 *
EASF10 000000000 "
EASD01 002491883 C
EASD02 002153922 9
EASD03 000093979 G
EASD04 000088877 I
IRMS1 001 /
URMS1 238 G
PREF 06 E
PCOUP 06 _
SINSTS 00339 U
15002002H231121103080 G2340 2
1213000 00344212T0000 00290 4
KMOY1 H231121222000 235 (
DPM1 231122060000 00 ^
FPM1 231123060000 00 !
MSG1 PAS DE MESSAGE <
PRM -------- H
RELAIS 001 C
NTARF 01 N
NJOURF 00 &
En bas de cette page:grostoto28 a écrit : 21 nov. 2023, 22:23 edit: en fait le signal n'est pas continu mais envoyé à 20h pile..
curl --retry 1 --connect-timeout 2 -m 4 "https://particulier.edf.fr/services/rest/referentiel/searchTempoStore?dateRelevant=2023-11-22"
{"couleurJourJ":"TEMPO_BLANC","couleurJourJ1":"NON_DEFINI"}Je pense plutôt qu'ils n'indiquent que les jours différents de bleu, car il n'y a eu que mercredi en blanc, ce jeudi est revenu bleu. Annoncé hier dans la plage horaire habituelle côté url EDF:Fred06 a écrit : 22 nov. 2023, 19:00 à croire que si la couleur du jour ne change pas, il n'y a pas d'info dans la trame...
2023-11-22 11:00:00.886 Status: LUA: TEMPO : Wednesday:BLANC - Thursday:NON_DEFINI
2023-11-22 11:10:00.686 Status: LUA: TEMPO : Wednesday:BLANC - Thursday:BLEU
2023-11-22 11:10:00.689 Status: LUA: TEMPO : Updated !
