[Résolu] PB inter sans fils Legrand-Netatmo
pipiche
Re: PB inter sans fils Legrand-Netatmo
Message par pipiche »
Tu peux attacher un fichier
Wiki ici
chat sur Keybase.io
Jihem
Message par Jihem »
la suite
2 appuis courts
2023-12-08 19:20:25,154 INFO    :b'ZigateRead - MsgType: 8000,  Data: 00000014008d0000, LQI: 0'
2023-12-08 19:20:25,155 INFO    :b'ZigateRead - MsgType: 8014,  Data: 00, LQI: 0'
2023-12-08 19:20:25,155 INFO    :b'Decode8014 - Permit Join status: False'
2023-12-08 19:20:25,156 INFO    :b"---> self.permitTojoin['Starttime']: 1702059625"
2023-12-08 19:20:25,156 INFO    :b"---> self.permitTojoin['Duration']: 0"
2023-12-08 19:20:25,157 INFO    :b'---> Current time                  : 1702059625'
2023-12-08 19:20:25,157 INFO    :b"---> self.Ping['Permit']  (prev)   : Off"
2023-12-08 19:20:25,158 INFO    :b"---> self.Ping['Permit']  (new )   : Off"
2023-12-08 19:20:25,159 INFO    :b'---> _to_notify                    : False'
2023-12-08 19:20:25,159 INFO    :b'Ping - received'
2023-12-08 19:20:50,336 INFO    :b'ZigateRead - MsgType: 8102,  Data: 3d475e010b04050b002900020000, LQI: 48'
2023-12-08 19:20:50,338 INFO    :b'Decode8102 - Attribute Reports: [475e:01] MsgSQN: 3d ClusterID: 0b04 AttributeID: 050b Status: 00 Type: 29 Size: 0002 ClusterData: >0000<'
2023-12-08 19:20:50,341 INFO    :b'scan_attribute_reponse - Sqn: 3d i_sqn: None Nwkid: 475e Ep: 01 Cluster: 0b04 MsgData: 3d475e010b04050b002900020000 Type: 8102'
2023-12-08 19:20:50,343 INFO    :b'scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [475e:01] ClusterID: 0b04 MsgSQN: 3d, i_sqn: None, AttributeID: 050b Status: 00 Type: 29 Size: 0002 ClusterData: >0000<'
2023-12-08 19:20:50,348 INFO    :b'Decode8102 - LQI:  48 Received Cluster:0b04 Attribute: 050b Value: 0000 from (475e/01)'
2023-12-08 19:20:50,350 INFO    :b'ReadCluster - 0b04 - 475e/01 AttrId: 050b AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 0000'
2023-12-08 19:20:50,351 INFO    :b"is_generic_zcl_cluster 0b04/050b and definition {'Enabled': True, 'Name': 'ActivePower', 'DataType': '29', 'Range': [-32768, 32768], 'Acc': 'R', 'Default': '0', 'Mandatory': False, 'EvalFunc': 'compute_electrical_measurement_conso', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:20:50,352 INFO    :b'Foundation Cluster - Nwkid: 475e Ep: 01 Cluster: 0b04 Attribute: 050b Type: 29 Data: 0000 Source: 8102'
2023-12-08 19:20:50,352 INFO    :b'compute_attribute_value - _decoding_value: None  value: 0'
2023-12-08 19:20:50,353 INFO    :b"compute_attribute_value - _function: compute_electrical_measurement_conso FUNCTION_MODULE: {'compute_metering_conso': <function compute_metering_conso at 0xec0487c0>, 'compute_electrical_measurement_conso': <function compute_electrical_measurement_conso at 0xec048808>, 'current_position_lift_percent': <function CurrentPositionLiftPercentage at 0xec048850>, 'legrand_operating_time': <function legrand_operating_time at 0xec036f10>, 'konke_onoff': <function konke_onoff at 0xec036ec8>, 'chameleon_stge': <function chameleon_stge at 0xec036c88>}"
2023-12-08 19:20:50,354 INFO    :b"compute_electrical_measurement_conso - 475e/01 0b04 050b 0 <class 'int'>"
2023-12-08 19:20:50,355 INFO    :b'compute_electrical_measurement_conso - 475e/01 Multiplier: 1 , Divisor: 1 , raw: 0 result: 0.0'
2023-12-08 19:20:50,355 INFO    :b'---> Data Action: check_store_value'
2023-12-08 19:20:50,356 INFO    :b'---> Data Action: upd_domo_device'
2023-12-08 19:20:50,357 INFO    :b'action_majdomodevice - 475e/01 0b04 050b Connected outlet 0.0'
2023-12-08 19:20:50,358 INFO    :b'     _majdomo_formater: None'
2023-12-08 19:20:50,358 INFO    :b'get_device_config_param: 475e Config: disableBinaryInputCluster'
2023-12-08 19:20:50,359 INFO    :b'     _majdomo_cluster: None'
2023-12-08 19:20:50,360 INFO    :b'     _majdomo_attribute: None'
2023-12-08 19:20:50,365 INFO    :b'UpdateDevice - (zigbee - Connected outlet_Power-000474000009e10d-01) 0.0:0.0'
2023-12-08 19:20:50,386 INFO    :b'UpdateDevice - (zigbee - Connected outlet_Meter-000474000009e10d-01) 0:0.0;'
2023-12-08 19:20:50,391 INFO    :b'ZigateRead - MsgType: 8102,  Data: 3e475e01000600000010000100, LQI: 49'
2023-12-08 19:20:50,393 INFO    :b'Decode8102 - Attribute Reports: [475e:01] MsgSQN: 3e ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:20:50,396 INFO    :b'scan_attribute_reponse - Sqn: 3e i_sqn: None Nwkid: 475e Ep: 01 Cluster: 0006 MsgData: 3e475e01000600000010000100 Type: 8102'
2023-12-08 19:20:50,398 INFO    :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [475e:01] ClusterID: 0006 MsgSQN: 3e, i_sqn: None, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:20:50,404 INFO    :b'Decode8102 - LQI:  49 Received Cluster:0006 Attribute: 0000 Value:   00 from (475e/01)'
2023-12-08 19:20:50,406 INFO    :b'ReadCluster - 0006 - 475e/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00'
2023-12-08 19:20:50,407 INFO    :b"is_generic_zcl_cluster 0006/0000 and definition {'Enabled': True, 'Name': 'OnOff', 'DataType': '10', 'Acc': 'RPS', 'Default': '0', 'Mandatory': True, 'DomoClusterType': 'Switch', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:20:50,408 INFO    :b'Foundation Cluster - Nwkid: 475e Ep: 01 Cluster: 0006 Attribute: 0000 Type: 10 Data: 00 Source: 8102'
2023-12-08 19:20:50,408 INFO    :b'compute_attribute_value - _decoding_value: None  value: 00'
2023-12-08 19:20:50,409 INFO    :b'---> Data Action: check_store_value'
2023-12-08 19:20:50,409 INFO    :b'---> Data Action: upd_domo_device'
2023-12-08 19:20:50,410 INFO    :b'action_majdomodevice - 475e/01 0006 0000 Connected outlet 00'
2023-12-08 19:20:50,411 INFO    :b'     _majdomo_formater: None'
2023-12-08 19:20:50,411 INFO    :b'get_device_config_param: 475e Config: disableBinaryInputCluster'
2023-12-08 19:20:50,412 INFO    :b'     _majdomo_cluster: None'
2023-12-08 19:20:50,412 INFO    :b'     _majdomo_attribute: None'
2023-12-08 19:21:14,565 INFO    :b'ZigateRead - MsgType: 8102,  Data: 328f2e010008001100200001bd, LQI: 83'
2023-12-08 19:21:14,568 INFO    :b'Decode8102 - Attribute Reports: [8f2e:01] MsgSQN: 32 ClusterID: 0008 AttributeID: 0011 Status: 00 Type: 20 Size: 0001 ClusterData: >bd<'
2023-12-08 19:21:14,571 INFO    :b'scan_attribute_reponse - Sqn: 32 i_sqn: None Nwkid: 8f2e Ep: 01 Cluster: 0008 MsgData: 328f2e010008001100200001bd Type: 8102'
2023-12-08 19:21:14,571 INFO    :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [8f2e:01] ClusterID: 0008 MsgSQN: 32, i_sqn: None, AttributeID: 0011 Status: 00 Type: 20 Size: 0001 ClusterData: >bd<'
2023-12-08 19:21:14,572 INFO    :b'Decode8102 - LQI:  83 Received Cluster:0008 Attribute: 0011 Value:   bd from (8f2e/01)'
2023-12-08 19:21:14,573 INFO    :b'ReadCluster - 0008 - 8f2e/01 AttrId: 0011 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: bd'
2023-12-08 19:21:14,573 INFO    :b'ReadCluster - ClusterID: 0008 Addr: 8f2e MsgAttrID: 0011 MsgAttType: 20 MsgAttSize: 0001 MsgClusterData: bd'
2023-12-08 19:21:14,574 INFO    :b'ReadCluster - ClusterId=0008 - 8f2e/01 On Level : bd'
2023-12-08 19:21:14,616 INFO    :b'ZigateRead - MsgType: 8102,  Data: 338f2e01000600000010000100, LQI: 84'
2023-12-08 19:21:14,619 INFO    :b'Decode8102 - Attribute Reports: [8f2e:01] MsgSQN: 33 ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:14,624 INFO    :b'scan_attribute_reponse - Sqn: 33 i_sqn: None Nwkid: 8f2e Ep: 01 Cluster: 0006 MsgData: 338f2e01000600000010000100 Type: 8102'
2023-12-08 19:21:14,624 INFO    :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [8f2e:01] ClusterID: 0006 MsgSQN: 33, i_sqn: None, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:14,625 INFO    :b'Decode8102 - LQI:  84 Received Cluster:0006 Attribute: 0000 Value:   00 from (8f2e/01)'
2023-12-08 19:21:14,626 INFO    :b'ReadCluster - 0006 - 8f2e/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00'
2023-12-08 19:21:14,626 INFO    :b"is_generic_zcl_cluster 0006/0000 and definition {'Enabled': True, 'Name': 'OnOff', 'DataType': '10', 'Acc': 'RPS', 'Default': '0', 'Mandatory': True, 'DomoClusterType': 'Switch', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:14,627 INFO    :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0006 Attribute: 0000 Type: 10 Data: 00 Source: 8102'
2023-12-08 19:21:14,627 INFO    :b'compute_attribute_value - _decoding_value: None  value: 00'
2023-12-08 19:21:14,628 INFO    :b'---> Data Action: check_store_value'
2023-12-08 19:21:14,628 INFO    :b'---> Data Action: upd_domo_device'
2023-12-08 19:21:14,629 INFO    :b'action_majdomodevice - 8f2e/01 0006 0000 Dimmer switch wo neutral 00'
2023-12-08 19:21:14,629 INFO    :b'     _majdomo_formater: None'
2023-12-08 19:21:14,630 INFO    :b'get_device_config_param: 8f2e Config: disableBinaryInputCluster'
2023-12-08 19:21:14,630 INFO    :b'     _majdomo_cluster: None'
2023-12-08 19:21:14,631 INFO    :b'     _majdomo_attribute: None'
2023-12-08 19:21:16,549 INFO    :b'ZigateRead - MsgType: 8102,  Data: 348f2e01000800000020000100, LQI: 86'
2023-12-08 19:21:16,552 INFO    :b'Decode8102 - Attribute Reports: [8f2e:01] MsgSQN: 34 ClusterID: 0008 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:16,557 INFO    :b'scan_attribute_reponse - Sqn: 34 i_sqn: None Nwkid: 8f2e Ep: 01 Cluster: 0008 MsgData: 348f2e01000800000020000100 Type: 8102'
2023-12-08 19:21:16,558 INFO    :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [8f2e:01] ClusterID: 0008 MsgSQN: 34, i_sqn: None, AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:16,559 INFO    :b'Decode8102 - LQI:  86 Received Cluster:0008 Attribute: 0000 Value:   00 from (8f2e/01)'
2023-12-08 19:21:16,560 INFO    :b'ReadCluster - 0008 - 8f2e/01 AttrId: 0000 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00'
2023-12-08 19:21:16,560 INFO    :b"is_generic_zcl_cluster 0008/0000 and definition {'Enabled': True, 'Name': 'CurrentLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RPS', 'Default': 'ff', 'Mandatory': True, 'DomoClusterType': 'LvlControl', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:16,561 INFO    :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0008 Attribute: 0000 Type: 20 Data: 00 Source: 8102'
2023-12-08 19:21:16,562 INFO    :b'compute_attribute_value - _decoding_value: None  value: 0'
2023-12-08 19:21:16,562 INFO    :b'---> Data Action: check_store_value'
2023-12-08 19:21:16,563 INFO    :b'---> Data Action: upd_domo_device'
2023-12-08 19:21:16,563 INFO    :b'action_majdomodevice - 8f2e/01 0008 0000 Dimmer switch wo neutral 0'
2023-12-08 19:21:16,564 INFO    :b'     _majdomo_formater: None'
2023-12-08 19:21:16,565 INFO    :b'get_device_config_param: 8f2e Config: disableBinaryInputCluster'
2023-12-08 19:21:16,565 INFO    :b'     _majdomo_cluster: None'
2023-12-08 19:21:16,566 INFO    :b'     _majdomo_attribute: None'
2023-12-08 19:21:26,351 INFO    :b'zcl_decoders Zcl.ddr: 0 GlobalCommand: False Sqn: 01 ManufCode: 1021 Command: 09 Data: 9181c4000074040001 Payload: 05211001099181c4000074040001'
2023-12-08 19:21:26,353 INFO    :b'zcl_decoders Unknown Command: 09 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c4000074040001 - GlobalCommand: False, Sqn: 01, ManufacturerCode: 1021'
2023-12-08 19:21:26,356 INFO    :b'ZigateRead - MsgType: 8002,  Data: 000104fc010101022c2f02000005211001099181c4000074040001, LQI: 81'
2023-12-08 19:21:26,357 INFO    :b'zcl_decoders Zcl.ddr: 0 GlobalCommand: False Sqn: 01 ManufCode: 1021 Command: 09 Data: 9181c4000074040001 Payload: 05211001099181c4000074040001'
2023-12-08 19:21:26,358 INFO    :b'zcl_decoders Unknown Command: 09 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c4000074040001 - GlobalCommand: False, Sqn: 01, ManufacturerCode: 1021'
2023-12-08 19:21:26,359 INFO    :b'Reception Data indication, Source Address: 2c2f Destination Address: 0000 ProfilID: 0104 ClusterID: fc01 Message Payload: 05211001099181c4000074040001'
2023-12-08 19:21:26,360 INFO    :b'legrandReadRawAPS - Nwkid: 2c2f Ep: 01, Cluster: fc01, dstNwkid: 0000, dstEp: 01, Payload: 05211001099181c4000074040001'
2023-12-08 19:21:26,361 INFO    :b' NwkId: 2c2f/01 Cluster: fc01 Command: 09 Data: 9181c4000074040001'
2023-12-08 19:21:26,361 INFO    :b'---> Decoding cmd 0x09 Ieee: 4740000c48191 leftright: 01'
2023-12-08 19:21:26,362 INFO    :b'assign_group_membership_to_legrand_remote 2c2f lefright: 01'
2023-12-08 19:21:26,404 INFO    :b'zcl_decoders Zcl.ddr: 1 GlobalCommand: False Sqn: 02 ManufCode: 1021 Command: 05 Data: 9181c40000740400 Payload: 15211002059181c40000740400'
2023-12-08 19:21:26,406 INFO    :b'zcl_decoders Unknown Command: 05 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c40000740400 - GlobalCommand: False, Sqn: 02, ManufacturerCode: 1021'
2023-12-08 19:21:26,408 INFO    :b'ZigateRead - MsgType: 8002,  Data: 000104fc010101022c2f02000015211002059181c40000740400, LQI: 81'
2023-12-08 19:21:26,410 INFO    :b'zcl_decoders Zcl.ddr: 1 GlobalCommand: False Sqn: 02 ManufCode: 1021 Command: 05 Data: 9181c40000740400 Payload: 15211002059181c40000740400'
2023-12-08 19:21:26,411 INFO    :b'zcl_decoders Unknown Command: 05 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c40000740400 - GlobalCommand: False, Sqn: 02, ManufacturerCode: 1021'
2023-12-08 19:21:26,411 INFO    :b'Reception Data indication, Source Address: 2c2f Destination Address: 0000 ProfilID: 0104 ClusterID: fc01 Message Payload: 15211002059181c40000740400'
2023-12-08 19:21:26,412 INFO    :b'legrandReadRawAPS - Nwkid: 2c2f Ep: 01, Cluster: fc01, dstNwkid: 0000, dstEp: 01, Payload: 15211002059181c40000740400'
2023-12-08 19:21:26,413 INFO    :b' NwkId: 2c2f/01 Cluster: fc01 Command: 05 Data: 9181c40000740400'
2023-12-08 19:21:26,560 INFO    :b'zcl_decoders Zcl.ddr: 1 GlobalCommand: True Sqn: 03 ManufCode: None Command: 0a Data: 55001000 Payload: 18030a55001000'
2023-12-08 19:21:26,561 INFO    :b'zcl_decoders Sqn: 3/03 ManufCode: None Command: 0a Data: 55001000 '
2023-12-08 19:21:26,563 INFO    :b'buildframe_report_attribute_response - 2c2f 01 000f Data: 55001000'
2023-12-08 19:21:26,564 INFO    :b'ZigateRead - MsgType: 8102,  Data: 032c2f01000f00550010000100, LQI: 81'
2023-12-08 19:21:26,570 INFO    :b'Decode8102 - Attribute Reports: [2c2f:01] MsgSQN: 03 ClusterID: 000f AttributeID: 0055 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:26,572 INFO    :b'scan_attribute_reponse - Sqn: 03 i_sqn: 13 Nwkid: 2c2f Ep: 01 Cluster: 000f MsgData: 032c2f01000f00550010000100 Type: 8102'
2023-12-08 19:21:26,572 INFO    :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [2c2f:01] ClusterID: 000f MsgSQN: 03, i_sqn: 13, AttributeID: 0055 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:26,573 INFO    :b'Decode8102 - LQI:  81 Received Cluster:000f Attribute: 0055 Value:   00 from (2c2f/01)'
2023-12-08 19:21:26,574 INFO    :b'ReadCluster - 000f - 2c2f/01 AttrId: 0055 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00'
2023-12-08 19:21:26,574 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,575 INFO    :b'Foundation Cluster - Nwkid: 2c2f Ep: 01 Cluster: 000f Attribute: 0055 Type: 10 Data: 00 Source: 8102'
2023-12-08 19:21:26,576 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,577 INFO    :b"is_cluster_specific_config 000f and definition {'Attributes': {'0055': {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}, 'f000': {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}}}"
2023-12-08 19:21:26,577 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,578 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,579 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,580 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,581 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,582 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,583 INFO    :b'compute_attribute_value - _decoding_value: None  value: 00'
2023-12-08 19:21:26,583 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,584 INFO    :b'---> Data Action: check_store_value'
2023-12-08 19:21:26,584 INFO    :b'---> Data Action: upd_domo_device'
2023-12-08 19:21:26,586 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,587 INFO    :b'action_majdomodevice - 2c2f/01 000f 0055 Remote switch 00'
2023-12-08 19:21:26,588 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,588 INFO    :b'     _majdomo_formater: None'
2023-12-08 19:21:26,589 INFO    :b'get_device_config_param: 2c2f Config: disableBinaryInputCluster'
2023-12-08 19:21:26,589 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,590 INFO    :b'     _majdomo_cluster: 0006'
2023-12-08 19:21:26,591 INFO    :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,591 INFO    :b'     _majdomo_attribute: None'
2023-12-08 19:21:26,594 INFO    :b'UpdateDevice - (zigbee - Remote switch_LegrandSelector-0004740000c48191-01) 0:00'
2023-12-08 19:21:26,663 INFO    :b'ZigateRead - MsgType: 8102,  Data: 1b04cc01010200080020000164, LQI: 83'
2023-12-08 19:21:26,665 INFO    :b'Decode8102 - Attribute Reports: [04cc:01] MsgSQN: 1b ClusterID: 0102 AttributeID: 0008 Status: 00 Type: 20 Size: 0001 ClusterData: >64<'
2023-12-08 19:21:26,670 INFO    :b'scan_attribute_reponse - Sqn: 1b i_sqn: None Nwkid: 04cc Ep: 01 Cluster: 0102 MsgData: 1b04cc01010200080020000164 Type: 8102'
2023-12-08 19:21:26,671 INFO    :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [04cc:01] ClusterID: 0102 MsgSQN: 1b, i_sqn: None, AttributeID: 0008 Status: 00 Type: 20 Size: 0001 ClusterData: >64<'
2023-12-08 19:21:26,672 INFO    :b'Decode8102 - LQI:  83 Received Cluster:0102 Attribute: 0008 Value:   64 from (04cc/01)'
2023-12-08 19:21:26,672 INFO    :b'ReadCluster - 0102 - 04cc/01 AttrId: 0008 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 64'
2023-12-08 19:21:26,673 INFO    :b"is_generic_zcl_cluster 0102/0008 and definition {'Enabled': True, 'Name': 'CurrentPositionLiftPercentage', 'DataType': '20', 'Range': [0, 100], 'Acc': 'R', 'Mandatory': False, 'DomoDeviceFormat': 'strhex', 'EvalFunc': 'current_position_lift_percent', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,673 INFO    :b'Foundation Cluster - Nwkid: 04cc Ep: 01 Cluster: 0102 Attribute: 0008 Type: 20 Data: 64 Source: 8102'
2023-12-08 19:21:26,674 INFO    :b'compute_attribute_value - _decoding_value: None  value: 100'
2023-12-08 19:21:26,674 INFO    :b"compute_attribute_value - _function: current_position_lift_percent FUNCTION_MODULE: {'compute_metering_conso': <function compute_metering_conso at 0xec0487c0>, 'compute_electrical_measurement_conso': <function compute_electrical_measurement_conso at 0xec048808>, 'current_position_lift_percent': <function CurrentPositionLiftPercentage at 0xec048850>, 'legrand_operating_time': <function legrand_operating_time at 0xec036f10>, 'konke_onoff': <function konke_onoff at 0xec036ec8>, 'chameleon_stge': <function chameleon_stge at 0xec036c88>}"
2023-12-08 19:21:26,675 INFO    :b'CurrentPositionLiftPercentage - 0102 - 04cc/01 - Shutter after correction value: 100'
2023-12-08 19:21:26,675 INFO    :b'---> Data Action: check_store_value'
2023-12-08 19:21:26,676 INFO    :b'---> Data Action: upd_domo_device'
2023-12-08 19:21:26,676 INFO    :b'action_majdomodevice - 04cc/01 0102 0008 Shutter switch with neutral 100'
2023-12-08 19:21:26,677 INFO    :b'     _majdomo_formater: strhex'
2023-12-08 19:21:26,677 INFO    :b'get_device_config_param: 04cc Config: disableBinaryInputCluster'
2023-12-08 19:21:26,678 INFO    :b'get_device_config_param: 04cc Config: disableBinaryInputCluster return 0'
2023-12-08 19:21:26,678 INFO    :b'     _majdomo_cluster: None'
2023-12-08 19:21:26,679 INFO    :b'     _majdomo_attribute: None'
2023-12-08 19:21:26,765 INFO    :b'ZigateRead - MsgType: 004d,  Data: 2c2f0004740000c4819180, LQI: 81'
2023-12-08 19:21:26,769 INFO    :b'ZigateRead - MsgType: 8011,  Data: 002c2f01fc018e, LQI: 0'
2023-12-08 19:21:26,817 INFO    :b'ZigateRead - MsgType: 8011,  Data: 002c2f01fc018f, LQI: 0'
export.json
(166.1 Kio) Téléchargé 59 fois
merci de ton aide et bonne soirée
Hard:Raspberry Pi4 + SSD Arduino Tablette murale Archos
Soft: Domoticz WireGuard vpn Homebridge Tradfri Ikea
Devices:[/colore]Rfxtrx433 DI-O Chacon Sonoff touch Anémomètre, pluviometre, sondes Orégon, capteurs humidité Miflora, téléinfo
pipiche
j'ai une piste ..
Wiki ici
chat sur Keybase.io
pipiche
première chose, on reçoit bien l'évènement lié à l'appui bref, par contre celui-ci n'est pas le meme que avec les versions précédentes de la remote. Je pense que c'est l'implémentation toggle qu'ils ont ajouté
Et du coup il y a un bug qui fait que l'évènement n'est pas correctement interprété
Tu peux désactiver les debugs
Input
Cluster
zclDecoder
Legrand
il faudrait que tu passes sur branche spécifique
git pull
git checkout device/remote-legrand-toggle
sudo python3 -m pip install -r requirements --upgrade
restart du plugin, puis tu re-essayes
au cas ou, retour arriere
git checkout stable7
Wiki ici
chat sur Keybase.io
Jihem
Message par Jihem »
Aucune résultat sur la remote... hélas.
Je pense avoir fait la bonne manip
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ git checkout device/remotegrand-toggle
Déjà sur 'device/remote-legrand-toggle'
Votre branche est à jour avec 'origin/device/remote-legrand-toggle'.
par contre l'interrupteur filaire est passé en mode 'toggle' alors qu'il fonctionnait en mode 'On-Off'
j'ai des erreurs dans Domoticz
 2023-12-09 09:42:58.398 Error: zigbee: Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: 7e Status: [06]
  2023-12-09 09:43:08.772 Error: zigbee: ------> Auto Update (Power 00) not found in SWITCH_SELECTORS
2023-12-09 09:43:08.947 Error: zigbee: ------> Auto Update (Meter 00) not found in SWITCH_SELECTORS
 2023-12-09 09:45:21.034 Error: zigbee: ReadCluster - Error/unknow 04cc/01 Cluster: 0102 Attribute: f000 Status: 00 DataType: 20 DataSize: 0001 Data: 64
un appui simple donne:
23-12-09 10:02:31,818 INFO    :b"is_generic_zcl_cluster 0006/4003 and definition {'Enabled': True, 'Name': 'StartUpOnOff', 'DataType': '30', 'Acc': 'RW', 'Default': '0', 'Mandatory': False, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:31,818 INFO    :b'Foundation Cluster - Nwkid: 475e Ep: 01 Cluster: 0006 Attribute: 4003 Type: 30 Data: ff Source: 8100'
2023-12-09 10:02:31,819 INFO    :b'compute_attribute_value - _decoding_value: None  value: 255'
2023-12-09 10:02:31,819 INFO    :b'---> Data Action: check_store_value'
2023-12-09 10:02:32,306 INFO    :b"is_generic_zcl_cluster 0006/4003 and definition {'Enabled': True, 'Name': 'StartUpOnOff', 'DataType': '30', 'Acc': 'RW', 'Default': '0', 'Mandatory': False, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:32,307 INFO    :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0006 Attribute: 4003 Type: 30 Data: ff Source: 8100'
2023-12-09 10:02:32,308 INFO    :b'compute_attribute_value - _decoding_value: None  value: 255'
2023-12-09 10:02:32,308 INFO    :b'---> Data Action: check_store_value'
2023-12-09 10:02:32,586 INFO    :b"is_generic_zcl_cluster 0301/0011 and definition {'Enabled': True, 'Name': 'MaxLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RW', 'Default': 0, 'Mandatory': True, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:32,587 INFO    :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0301 Attribute: 0011 Type: 20 Data: fe Source: 8100'
2023-12-09 10:02:32,587 INFO    :b'compute_attribute_value - _decoding_value: None  value: 254'
2023-12-09 10:02:32,588 INFO    :b'---> Data Action: check_store_value'
2023-12-09 10:02:32,875 INFO    :b"is_generic_zcl_cluster 0301/0010 and definition {'Enabled': True, 'Name': 'MinLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RW', 'Default': 0, 'Mandatory': True, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:32,875 INFO    :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0301 Attribute: 0010 Type: 20 Data: 01 Source: 8100'
2023-12-09 10:02:32,876 INFO    :b'compute_attribute_value - _decoding_value: None  value: 1'
2023-12-09 10:02:32,877 INFO    :b'---> Data Action: check_store_value'
2023-12-09 10:02:33,053 INFO    :b"is_generic_zcl_cluster 0006/4003 and definition {'Enabled': True, 'Name': 'StartUpOnOff', 'DataType': '30', 'Acc': 'RW', 'Default': '0', 'Mandatory': False, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:33,053 INFO    :b'Foundation Cluster - Nwkid: 2492 Ep: 01 Cluster: 0006 Attribute: 4003 Type: 30 Data: ff Source: 8100'
2023-12-09 10:02:33,054 INFO    :b'compute_attribute_value - _decoding_value: None  value: 255'
2023-12-09 10:02:33,055 INFO    :b'---> Data Action: check_store_value'
2023-12-09 10:02:33,341 INFO    :b"is_generic_zcl_cluster 0301/0011 and definition {'Enabled': True, 'Name': 'MaxLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RW', 'Default': 0, 'Mandatory': True, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:33,342 INFO    :b'Foundation Cluster - Nwkid: 2492 Ep: 01 Cluster: 0301 Attribute: 0011 Type: 20 Data: fe Source: 8100'
2023-12-09 10:02:33,343 INFO    :b'compute_attribute_value - _decoding_value: None  value: 254'
2023-12-09 10:02:33,343 INFO    :b'---> Data Action: check_store_value'
2023-12-09 10:02:33,564 INFO    :b"is_generic_zcl_cluster 0301/0010 and definition {'Enabled': True, 'Name': 'MinLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RW', 'Default': 0, 'Mandatory': True, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:33,565 INFO    :b'Foundation Cluster - Nwkid: 2492 Ep: 01 Cluster: 0301 Attribute: 0010 Type: 20 Data: 01 Source: 8100'
2023-12-09 10:02:33,566 INFO    :b'compute_attribute_value - _decoding_value: None  value: 1'
2023-12-09 10:02:33,566 INFO    :b'---> Data Action: check_store_value'
2023-12-09 10:02:54,160 INFO    :b'zcl_decoders Unknown Command: 09 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c4000074040001 - GlobalCommand: False, Sqn: 00, ManufacturerCode: 1021'
2023-12-09 10:02:54,164 INFO    :b'zcl_decoders Unknown Command: 09 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c4000074040001 - GlobalCommand: False, Sqn: 00, ManufacturerCode: 1021'
2023-12-09 10:02:54,209 INFO    :b'zcl_decoders Unknown Command: 05 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c40000740400 - GlobalCommand: False, Sqn: 02, ManufacturerCode: 1021'
2023-12-09 10:02:54,211 INFO    :b'zcl_decoders Unknown Command: 05 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c40000740400 - GlobalCommand: False, Sqn: 02, ManufacturerCode: 1021'
2023-12-09 10:02:54,579 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,581 INFO    :b'Foundation Cluster - Nwkid: 2c2f Ep: 01 Cluster: 000f Attribute: f000 Type: 21 Data: 0001 Source: 8102'
2023-12-09 10:02:54,582 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,585 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,585 INFO    :b"is_cluster_specific_config 000f and definition {'Attributes': {'0055': {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}, 'f000': {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}}}"
2023-12-09 10:02:54,586 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,587 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,588 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,589 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,590 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,591 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,593 INFO    :b'compute_attribute_value - _decoding_value: None  value: 1'
2023-12-09 10:02:54,598 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,600 INFO    :b'---> Data Action: check_store_value'
2023-12-09 10:02:54,600 INFO    :b'---> Data Action: upd_domo_device'
2023-12-09 10:02:54,601 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,601 INFO    :b'action_majdomodevice - 2c2f/01 000f f000 Remote switch 1'
2023-12-09 10:02:54,602 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,602 INFO    :b'     _majdomo_formater: str_2digits'
2023-12-09 10:02:54,603 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,604 INFO    :b'     _majdomo_cluster: 0006'
2023-12-09 10:02:54,604 INFO    :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,605 INFO    :b'     _majdomo_attribute: 0000'
2023-12-09 10:02:54,607 ERROR   : [ZiGateForwarder_2] ------> Auto Update (LegrandSelector  1) not found in SWITCH_SELECTORS
pipiche
Merci de faire une mise à jour
git pull
et de relancer
Wiki ici
chat sur Keybase.io
Jihem
Message par Jihem »
BRAVO !!!!
Ça marche
Un grand merci
Bon Week-End
Jihem
Modération
Si le sujet est terminé, merci de bien vouloir modifier le premier message de cette discussion pour indiquer [Résolu] dans le titre du sujet. Comment faire ? Voir le sujet [A lire avant de poster] Guide pour bien formuler une demande.
pipiche
Jihem a écrit : 09 déc. 2023, 12:11 BRAVO !!!!
Ça marche
Un grand merci
Bon Week-End
Jihem
Ok, je met ca au propre, et je le bougerais sur une autre branche avant la release
Wiki ici
chat sur Keybase.io
pipiche
pourrais-tu refaire un test pour vérifier que ca fonctionne toujours correctement
git pull
restart du plugin
Wiki ici
chat sur Keybase.io
