Problème liaison Edomoticz
Forum dédié au protocole MQTT : fonctionnement, intégration ...
Pour les questions concernant le plugin de FlyingDomotic, merci d'utiliser le sous-forum dédié.
UnseenThreat
Re: Problème liaison Edomoticz
Message par UnseenThreat »
Bonjour, problème de 401 réglé il suffisait pour ma par de changer le port domoticz dans la config Homebridge car port diffèrent depuis certaine MAJ de Domoticz.
Par contre j'ai un soucis homebridge ne trouve pas mes accessoire ( 2 prise Tasmota ) je peux les commander dans domoticz, mais 0 accessoires dans la section Accessoires de Homebridge.
[31/12/2023, 12:35:02] Homebridge v1.7.0 (HAP v0.11.1) (Homebridge Studio) is running on port 51550.
[31/12/2023, 12:37:12] [Homebridge UI] Changes to config.json saved.
[31/12/2023, 12:37:13] [Homebridge UI] Homebridge restart request received
[31/12/2023, 12:37:13] [Homebridge UI] UI / Bridge settings have not changed; only restarting Homebridge process
[31/12/2023, 12:37:13] [Homebridge UI] Sending SIGTERM to Homebridge
[31/12/2023, 12:37:13] Got SIGTERM, shutting down Homebridge...
[31/12/2023, 12:37:18] [HB Supervisor] Homebridge Process Ended. Code: 143, Signal: null
[31/12/2023, 12:37:23] [HB Supervisor] Restarting Homebridge...
[31/12/2023, 12:37:23] [HB Supervisor] Starting Homebridge with extra flags: -I -P /var/lib/homebridge/node_modules --strict-plugin-resolution
[31/12/2023, 12:37:23] [HB Supervisor] Started Homebridge v1.7.0 with PID: 150129
[31/12/2023, 12:37:24] Loaded config.json with 0 accessories and 2 platforms.
[31/12/2023, 12:37:24] Loaded 0 cached accessories from cachedAccessories.
[31/12/2023, 12:37:24] ---
[31/12/2023, 12:37:25] Loaded plugin: homebridge-alexa@0.6.8
[31/12/2023, 12:37:25] Registering platform 'homebridge-alexa.Alexa'
[31/12/2023, 12:37:25] ---
[31/12/2023, 12:37:26] Loaded plugin: homebridge-edomoticz@2.1.47
[31/12/2023, 12:37:26] Registering platform 'homebridge-edomoticz.eDomoticz'
[31/12/2023, 12:37:26] ---
[31/12/2023, 12:37:26] Loading 2 platforms...
[31/12/2023, 12:37:26] [Domoticz] Initializing eDomoticz platform...
[31/12/2023, 12:37:26] [Domoticz] synchronizeAccessories in progress...
Setup Payload:
X-HM://0024OWYOGJVMU
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
    │ 738-75-344 │
[31/12/2023, 12:37:26] Homebridge v1.7.0 (HAP v0.11.1) (Homebridge Studio) is running on port 51550.
