C'est le drame.
soudainement je ne peux plus controler mes prises connectées.
J'ai la PiZigate sous forme de carte sur un Raspberry Pi 2B sous Raspbian 10 buster kernel 5.10.103depuis plusieurs années.
Log Domoticz
2023-12-31 15:37:34.238 Error: PiZigate: APS Failure , Command: 0x0100:Read Attribute request for (....) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2023-12-31 15:37:34.364 Error: PiZigate: APS Failure , Command: 0x0100:Read Attribute request for (....) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2023-12-31 15:37:39.199 Error: PiZigate: APS Failure , Command: 0x0100:Read Attribute request for (....) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2023-12-31 15:37:44.182 PiZigate: _errorMgt - Give a chance of APS recovery for df18/7cb03eaa0a090083 on command 0100
2023-12-31 15:37:44.286 PiZigate: _errorMgt - Give a chance of APS recovery for 9c16/7cb03eaa0a02270e on command 0100
2023-12-31 15:37:49.198 Error: PiZigate: APS Failure , Command: 0x0100:Read Attribute request for for (....) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2023-12-31 15:37:54.286 PiZigate: _errorMgt - Give a chance of APS recovery for 8a72/7cb03eaa0a027ed3 on command 0100
2023-12-31 15:37:54.182 Error: PiZigate: APS Failure , Command: 0x0100:Read Attribute request for for (....) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )La Pizigate est en lumière bleu fixe
~/ ./PiZiGate_test /dev/ttyAMA0
Searching /dev/ttyAMA0...
sh: 1: lsof: not found
+ Port : /dev/ttyAMA0 is not used
Verif GPIOs ...
+ GPIO 0 (RESET) --> OK
+ GPIO 2 (FLASH) --> OK
Config GPIOs ...
Opening : /dev/ttyAMA0 ...
+ /dev/ttyAMA0 opened --> OK
- No packet received - size sent : 11 - error : 11Code : Tout sélectionner
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Oct 11 2023, 09:51:27) [GCC 8.3.0]J'ai un backup de carte SD au 1er octobre, peut etre dois je voir si ca refonctionnerait avec un retour en arrière ?
