J'ai des vannes citées dans le titre qui fonctionnent bien mais je voudrais retoucher la compensation ; la sonde intégrée étant sur la vanne.
Type dans le plugin :
TS0601-_TZE200_b6wax7g0
Cela dit, impossible de changer le paramètre : Temperature compensation aussi bien sur la vanne que dans le plugin.
Sur la vanne, je vais dans le param A1, je change à -2 par exemple et ça revient à 00 systématiquement.
Dans le plugin, j'ai ça :
{ 'BRT100WindowsDetection': 1, 'BRT100ChildLock': 0, 'BRT100BoostDuration': 300, 'BRT100Calibration': 0, 'BRT100SetpointEco': 18, 'BRT100MaxSetpoint': 30, 'BRT100MinSetpoint': 3}
Objet raw pour exemple :
Version: "3"
ZDeviceName: "Vanne bureau"
Status: "inDB"
SQN: "51"
Ep: Object {"01":{"0000":{"0004":"_TZE200_b6wax7g0","0005":"TS0601","0001":64,"ffe2":31,"ffe4":0,"0000":3,"0007":3,"fffe":0,"ffdf":"L,-\u0011"},"0004":{},"0005":{},"ef00":{},"000a":{},"0019":{},"Type":"ThermoMode_4/Temp/ThermoSetpoint/Valve/Door","ClusterType":{"140":"ThermoMode_4","141":"Temp","142":"ThermoSetpoint","143":"Valve","144":"Door"},"0201":{"0012":210},"0402":{"0000":23},"0001":{"0000":88}}}
Heartbeat: "12278"
RIA: "0"
LQI: 255
Battery: 88
Model: "TS0601-_TZE200_b6wax7g0"
ForceAckCommands: Array[0] []
MacCapa: "80"
IEEE: "84fd27fffea65702"
Type: "ThermoMode_4/Temp/ThermoSetpoint/Valve/Door"
ProfileID: "0104"
ZDeviceID: "0051"
App Version: 64
Attributes List: Object {}
DeviceType: "RFD"
HW Version: ""
Last Cmds: Array[0] []
LogicalType: "End Device"
Manufacturer: "1002"
Manufacturer Name: "_TZE200_b6wax7g0"
NbEp: "1"
PowerSource: "Battery"
ReadAttributes: Object {"Ep":{"01":{"0402":{"TimeStamp":"29/07/2023 18:39:24","iSQN":{"0000":"27","0001":"27","0002":"27","0003":"28","fffd":"28","fffe":"28"},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":"29/07/2023 18:39:24","iSQN":{"0000":"29","0001":"29","0010":"29","0011":"2a","0012":"2a","0013":"2a","0020":"2b","0021":"2b","0030":"2b","0031":"2c","0032":"2c","0033":"2c","0034":"2d","0035":"2d","0036":"2d","0037":"2e","0038":"2e","0039":"2e","003a":"2f","003b":"2f","003c":"2f","003d":"30","003e":"30","fffd":"30","fffe":"31"},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":"29/07/2023 18:39:24","iSQN":{"0000":"32","0001":"32","0002":"32","0003":"33","0004":"33","0005":"33","0006":"34","0007":"34","0008":"34","0009":"35","000a":"35","fffd":"35","fffe":"36"},"Attributes":{},"ZigateRequest":{}},"0201":{"TimeStamp":"29/07/2023 18:39:24","iSQN":{"0000":"37","0008":"37","0010":"37","0011":"38","0012":"38","0014":"38","0015":"39","0016":"39","001b":"39","001c":"3a","001f":"3a","fd00":"3a"},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":"08/01/2024 14:09:19","iSQN":{"0004":"3b","0000":"3b","0001":"3b","0005":"3c","0007":"3c","fffe":"3c"},"Attributes":{"0001":"00","ffe2":"00","ffe4":"00","ffdf":"00","0004":"00","0005":"00"},"ZigateRequest":{}}}}}
ReceiveOnIdle: ""
Stack Version: ""
Stamp: Object {"time":1704724553.8644423,"Time":"2024-01-08 15:35:53","MsgType":"8011","LastSeen":"08/01/2024 15:35:53"}
ZCL Version: 3
Health: "Live"
Max Rx: "0052"
WriteAttributes: Object {"Ep":{"01":{"0000":{"TimeStamp":"29/07/2023 18:39:24","iSQN":{"ffde":"3d"},"Attributes":{"ffde":"00"},"ZigateRequest":{"ffde":{"Status":"fullfilled","DataType":"20","EPin":"01","EPout":"01","manuf_id":"0000","manuf_spec":"00","data":"13","ackIsDisabled":false}}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0005":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"ef00":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"000a":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0201":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0402":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
Max Tx: "0052"
Max Buffer Size: "52"
Capability: Array[3] ["Reduced-Function Device","Standard security","NwkAddr should be allocated"]
Tuya: Object {"TUYA_MCU_VERSION_RSP":"40","BRTMode":"Manual","SetPoint":"00000015","Temperature":"000000e6","RapidHeating":"00","UnknowDp_0x05_Dt_0x02":"00000000","UnknowDp_0x07_Dt_0x04":"01","OpenWindowDetection":"01","OpenWindow":"00","ChildLock":"00","BatteryStatus":"00000058","Schedule":{"Monday Friday":{"Period1":{"Start":"0600","Setpoint":40},"Period2":{"Start":"0b1e","Setpoint":42},"Period3":{"Start":"0d1e","Setpoint":44},"Period4":{"Start":"111e","Setpoint":46}},"Saturday":{"Period1":{"Start":"0600","Setpoint":48},"Period2":{"Start":"0c00","Setpoint":46},"Period3":{"Start":"0e1e","Setpoint":44},"Period4":{"Start":"111e","Setpoint":42}},"Sunday":{"Period1":{"Start":"0600","Setpoint":38},"Period2":{"Start":"0c1e","Setpoint":40},"Period3":{"Start":"0e1e","Setpoint":42},"Period4":{"Start":"121e","Setpoint":40}}},"BoostTime":"0000012c","ValvePosition":"00000000","Calibration":"00000000","TemporaryAway":"00","EcoTemp":"00000012","MaxSetpoint":"0000001e","MinSetpoint":"00000003","TuyaTransactionId":95}
macapa: "80"
bitfield: "4002"
Bind: Object {"01":{"0019":{"Target":"0000","Stamp":"29/07/2023 18:39:29","Phase":"binded","Status":"00","i_sqn":"04"},"ef00":{"Target":"0000","Stamp":"29/07/2023 18:39:29","Phase":"binded","Status":"00","i_sqn":"05"}}}
Epv2: Object {"01":{"ClusterIn":{"0000":{},"0004":{},"0005":{},"ef00":{}},"ClusterOut":{"0019":{},"000a":{}},"ProfileID":"0104","ZDeviceID":"0051"}}
_rawNodeDescriptor: "1002005200522c000080524002"
BindingTable: Object {"SQN":0,"Status":"Success","TimeStamp":"29/07/2023 18:39:30","BindingTableSize":2,"Devices":[{"84fd27fffea65702":{"sourceEp":"01","Cluster":"0019","targetIEEE":"00212effff08522e","targetNickName":"Zigbee Coordinator","targetEp":"01"}},{"84fd27fffea65702":{"sourceEp":"01","Cluster":"ef00","targetIEEE":"00212effff08522e","targetNickName":"Zigbee Coordinator","targetEp":"01"}}]}
Param: Object {"Disabled":0,"BRT100WindowsDetection":1,"BRT100ChildLock":0,"BRT100BoostDuration":300,"BRT100Calibration":0,"BRT100SetpointEco":18,"BRT100MaxSetpoint":30,"BRT100MinSetpoint":3}
descriptor_capability: "00"
server_mask: "2c00"
ConfigSource: "DeviceConf"
CertifiedDevice: true
CheckParam: false
ConsistencyCheck: "ok"
ZCLSQN: "11"
ZCL-IN-SQN: Object {"ef00":"51","0000":"48","000a":"49"}
RollingLQI: Array[11] [255,255,255,255,255,255,255,255,255,255,255]
SQN_000a: "49"
NwkID: "32f7"
