[Résolu] Optimisation: Moes Vibration Sensor.
pipiche
Re: Optimisation: Moes Vibration Sensor.
Message par pipiche »
exact, je me suis loupé sur ce truc.
ca devrait etre mieux sur la branch wip-stable7.1.010
Wiki ici
chat sur Keybase.io
lost
Message par lost »
OK, je testerais ce soir après le boulot...
Pour éviter de bouger de la branche stable7 (et oublier d'en sortir plus tard!), je pense plutôt patcher la modif vu que c'est pas bien gros:
https://github.com/zigbeefordomoticz/Do ... 091b0d9178
pipiche
ca marche .
Wiki ici
chat sur Keybase.io
lost
Message par lost »
Bon, c'est pas mieux visiblement avec:
 2024-02-26 18:37:57.094 Error: Zi-Stick: Call to function 'onHeartbeat' failed, exception details:
2024-02-26 18:37:57.100 Error: Zi-Stick: Traceback (most recent call last):
2024-02-26 18:37:57.100 Error: Zi-Stick: File "/home/domo/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1543, in onHeartbeat
2024-02-26 18:37:57.100 Error: Zi-Stick: _plugin.onHeartbeat()
2024-02-26 18:37:57.100 Error: Zi-Stick: File "/home/domo/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 896, in onHeartbeat
2024-02-26 18:37:57.100 Error: Zi-Stick: processListOfDevices(self, Devices)
2024-02-26 18:37:57.100 Error: Zi-Stick: File "/home/domo/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 878, in processListOfDevices
2024-02-26 18:37:57.100 Error: Zi-Stick: processKnownDevices(self, Devices, NWKID)
2024-02-26 18:37:57.100 Error: Zi-Stick: File "/home/domo/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 613, in processKnownDevices
2024-02-26 18:37:57.100 Error: Zi-Stick: sanity_check_of_param(self, NWKID)
2024-02-26 18:37:57.100 Error: Zi-Stick: File "/home/domo/domoticz/plugins/Domoticz-Zigbee/Modules/paramDevice.py", line 108, in sanity_check_of_param
2024-02-26 18:37:57.100 Error: Zi-Stick: DEVICE_PARAMETERS[param](self, NwkId, value)
2024-02-26 18:37:57.100 Error: Zi-Stick: TypeError: ias_CurrentZoneSensitivityLevel() missing 1 required positional argument: 'value'
EDIT:
OK, j'avais pas vu que c'était splitté en 2 commit. En ajoutant ces modifs ça va mieux visiblement:
https://github.com/zigbeefordomoticz/Do ... 1cba2729ed
Merci et je confirmerais sur la durée + qq essais sensi dès que possible pour confirmer que tout fonctionne bien! Je ne sais pas si tu as idée de l'échelle utilisée. En zwave on avait un joli livret dans la boite avec les modules décrivant les paramètres (type/range etc...) et les commandes supportées dans le jeu du standard, bref toute l'info utile d'intégration, mais en Zigbee c'est nada hélas!
lost
Message par lost »
Bon, après qq jours pas de souci avec les modifs ci dessus patchées dans ma stable 7. Un peu difficile de juger de la sensi un peu au hasard, néanmoins.
Surtout que les infos qu'on trouve sont contradictoires entre un 0-50 ici:
https://www.zigbee2mqtt.io/devices/TS0210.html
et un 2-255 (NumberOfZoneSensitivityLevelsSupported) ici:
https://developer.tuya.com/en/docs/conn ... k6zvu1yd5f
A 20 le mouvement de la (lourde) serrure fait tilter, par contre les mouvements de la porte plus toujours (c'est pas un capteur d'ouverture, plus difficile de juger, mais si en ouvrant doucement avant cela pouvait parfois ne pas tilter avec sensi pas touchée, une fois à 20 sans précaution c'est déjà plus à tous les coups).
J'en resterais à 10 en sensi pour le moment. Les 5s de timeout semblent respectées, avec la fin de vibration: Pour ceux qui ne prennent en compte que les transitions des capteurs, attention donc à la régler assez bas sinon on loupe des détections de vibrations.
Incertitude aussi sur le moment de prise en compte des paramètres sur des capteurs sur pile 99.9% du temps en sommeil. En zwave, il y avait une procédure de réveil (généralement 3 appuis rapprochés sur le bouton d'association), en zigbee??? Rien trouvé de tel. J'ai donc à chaque fois déclenché une vibration avant de tenter de comparer ensuite.
pipiche
en zigbee, en général, il faut appuyer une fois sur le bouton, et l'objet se met en ecoute pendant quelques temps.
Avec les SonOff par exemple c'est le cas
Wiki ici
chat sur Keybase.io
lost
Message par lost »
Merci de la précision, sans être sûr j'avais en fait fait les deux (vibration + appui court vu qu'un long apparie sur ce capteur) donc les chgt de config avaient été prises en compte et les tests, même sans trop pouvoir étalonner avec ce type de capteur, me semblaient OK.
On va pouvoir mettre un résolu sur le fil!
