Aprés avoir installé le plugin de FlyingDomotic pour faire de la translation MQTT vers domoticz https://github.com/FlyingDomotic/domoti ... me-ov-file
J'ai configuré un petit fichier json d'après ce que j'ai compris du plugin mais j'ai une erreur qui remonte dans les logs de Domoticz
2024-04-03 13:34:08.639 Error: MQTTMAPP: Error loading /home/patrice/domoticz/plugins/MqttMapper/MqttMapper.json - JSONDecodeError at line 243 of /home/patrice/domoticz/plugins/MqttMapper/plugin.py: Extra data: line 1 column 9 (char 8)Code : Tout sélectionner
"Temp1": {
"topic": "gateway/2cf7f11054200049/device/f1ac4afbc81c39b0/event/up",
"type": "80", "subtype": "5", "switchtype": "0",
"mapping": {"item": "temperature", "multiplier": 0.1}
"deduplicationId": "c8e4953b-7579-4bea-9e35-d3561e50c044",
"time": "2024-04-03T11:46:30.312682534+00:00",
"deviceInfo": {
"tenantId": "52f14cd4-c6f1-4fbd-8f87-4025e1d49242",
"tenantName": "SenseCAP",
"applicationId": "b6de024f-a3a5-41df-825e-541ca8730245",
"applicationName": "BFPLora",
"deviceProfileId": "563c992b-5a6c-4f94-8207-ae7cfb30ff22",
"deviceProfileName": "BfpLoraDEvProfile",
"deviceName": "Capteur2",
"devEui": "f1ac4afbc81c39b0",
"tags": {}
"devAddr": "5bb1133d",
"adr": true,
"dr": 5,
"fCnt": 204,
"fPort": 1,
"confirmed": false,
"data": "LTIwMQ==",
"object": {
"temperature": "-201"
"rxInfo": [
"gatewayId": "2cf7f11054200049",
"uplinkId": 1046787505,
"rssi": -69,
"snr": 11.2,
"channel": 2,
"rfChain": 1,
"location": {},
"context": "FDojhA==",
"metadata": {
"region_common_name": "EU868",
"region_config_id": "EU_863_870_TTN"
"crcStatus": "CRC_OK"
"txInfo": {
"frequency": 868500000,
"modulation": {
"lora": {
"bandwidth": 125000,
"spreadingFactor": 7,
"codeRate": "CR_4_5"
}(fin de la question du mauvais élève)
et merci de vos réponses
