Problème plugin suite mise à jour
ker49
Re: Problème plugin suite mise à jour
Message par ker49 »
voici ce que j'ai obtenu :
2024-12-15 10:54:23,004 INFO    :b'Z4D starting with stable7-7.1.016'
2024-12-15 10:54:23,017 ERROR   : [  MainThread 1374] Urlopen to http://127.0.0.1:8080/json.htm?type=command&param=gethardware rejected. Error: <urlopen error [Errno 111] Connection refused>
2024-12-15 10:54:23,023 ERROR   : [  MainThread 1374] Urlopen to http://127.0.0.1:8080/json.htm?type=command&param=gethardware rejected. Error: <urlopen error [Errno 111] Connection refused>
2024-12-15 10:54:23,028 INFO    :b'Z4D Database found: DeviceList-2.txt'
2024-12-15 10:54:23,029 INFO    :b'Z4D Certified devices database /usr/local/lib/python3.11/dist-packages/z4d_certified_devices/'
2024-12-15 10:54:23,030 INFO    :b'Z4D loads ZCL Cluster definitions'
2024-12-15 10:54:23,086 INFO    :b'Z4D loaded 16 configuration from legacy database.'
2024-12-15 10:54:23,089 INFO    :b'Z4D loads 16 configuration from the local certified Db.'
2024-12-15 10:54:23,696 INFO    :b'Z4D loads 603 Certified devices from repository.'
2024-12-15 10:54:23,698 INFO    :b'Z4D loading database'
2024-12-15 10:54:23,700 INFO    :b'Z4D configured to use transport mode: ZigpyZNP'
2024-12-15 10:54:27,480 INFO    :b'Z4D starting ZNP'
2024-12-15 10:54:27,482 INFO    :b'zigpyThread starting with a random sleep'
2024-12-15 10:54:27,486 INFO    :b'Z4D starts WebUI'
2024-12-15 10:54:27,518 INFO    :b'WebUI thread started'
2024-12-15 10:54:27,520 INFO    :b'WebUI - server starting on 0.0.0.0 9440'
2024-12-15 10:54:27,521 INFO    :b'++ WebUI - create socket'
2024-12-15 10:54:27,522 INFO    :b'++ WebUI - SSL Certificate /home/acndomo/domoticz/plugins/Domoticz-Zigbee/certs/server.crt'
2024-12-15 10:54:27,522 INFO    :b'++ WebUI - SSL Private key /home/acndomo/domoticz/plugins/Domoticz-Zigbee/certs/server.key'
2024-12-15 10:54:27,526 INFO    :b"Certificate file '/home/acndomo/domoticz/plugins/Domoticz-Zigbee/certs/server.crt' does not exist."
Ce qui m'étonne dans ce fichier log c'est que cela "date" de 10h54 mais j'ai accès au plugin depuis midi donc c'est comme si ce fichier log ne correspondait pas au dernier ? Mais je me trompe peut-être
ker49
Message par ker49 »
dans l'EV j'ai à la fin :
    2024-12-15 14:54:47,780 WARNING :Unknown device AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x9C88)
2024-12-15 14:54:47,782 INFO    :b'decode8002_and_process unknown NwkId: 9c88 for ZCL frame 0180020034ff000104ef000101029c88020000097701002003020004000000dc0003'
2024-12-15 14:54:47,872 WARNING :Unknown device AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x9C88)
2024-12-15 14:54:47,874 INFO    :b'decode8002_and_process unknown NwkId: 9c88 for ZCL frame 0180020034ff000104ef000101029c88020000097701002003020004000000dc0003'
2024-12-15 14:54:47,878 WARNING :Failed to deserialize ZDO packet
  File "/usr/local/lib/python3.11/dist-packages/zigpy_znp/zigbee/application.py", line 473, in on_zdo_message
    zdo_hdr, zdo_args = self._device.zdo.deserialize(
  File "/usr/local/lib/python3.11/dist-packages/zigpy/zdo/__init__.py", line 46, in deserialize
    args, data = t.deserialize(data, param_types)
  File "/usr/local/lib/python3.11/dist-packages/zigpy/types/__init__.py", line 11, in deserialize
    value, data = type_.deserialize(data)
  File "/usr/local/lib/python3.11/dist-packages/zigpy/types/basic.py", line 924, in deserialize
    item, data = cls._item_type.deserialize(data)
  File "/usr/local/lib/python3.11/dist-packages/zigpy/types/basic.py", line 199, in deserialize
    raise ValueError(f"Data is too short to contain {byte_size} bytes")
ValueError: Data is too short to contain 1 bytes
2024-12-15 14:54:47,938 WARNING :Failed to deserialize ZDO packet
2024-12-15 14:54:47,976 WARNING :Failed to deserialize ZDO packet
2024-12-15 14:54:48,008 WARNING :Failed to deserialize ZDO packet
2024-12-15 14:54:56,172 INFO    :b'decode8002_and_process unknown NwkId: 9670 for ZCL frame 0180020028ff0001040006010102967002000008c40a000010010003'
2024-12-15 14:56:43,423 INFO    :b'decode8002_and_process unknown NwkId: d9ab for ZCL frame 0180020028ff0001040006010102d9ab020000081d0a000010010003'
2024-12-15 14:58:02,991 ERROR   : [ZigpyForwarder_2 2838] Urlopen to http://127.0.0.1:8080/json.htm?type=command&param=getdevices&rid=4 rejected. Error: <urlopen error [Errno 111] Connection refused>
2024-12-15 14:58:02,999 INFO    :b'UpdateDevice - (ZigbeeForDomoticz2 - TS0601-_TZE200_b6wax7g0_Temp-cc86ecfffeb8afaa-01) 0:19.0'
2024-12-15 15:01:43,474 INFO    :b'decode8002_and_process unknown NwkId: d9ab for ZCL frame 0180020028ff0001040006010102d9ab020000081e0a000010010003'
2024-12-15 15:03:50,883 INFO    :b'UpdateDevice - (ZigbeeForDomoticz2 - TS0601-_TZE200_b6wax7g0_Valve-cc86ecfffeb8afaa-01) 0:25'
2024-12-15 15:09:38,830 ERROR   : [ZigpyForwarder_2 2838] Urlopen to http://127.0.0.1:8080/json.htm?type=command&param=getdevices&rid=4 rejected. Error: <urlopen error [Errno 111] Connection refused>
2024-12-15 15:09:38,847 INFO    :b'UpdateDevice - (ZigbeeForDomoticz2 - TS0601-_TZE200_b6wax7g0_Temp-cc86ecfffeb8afaa-01) 0:20.0'
2024-12-15 15:09:56,148 INFO    :b'decode8002_and_process unknown NwkId: 9670 for ZCL frame 0180020028ff0001040006010102967002000008c70a000010010003'
PS : j'ai ouvert le fichier log avec nano mais je ne sais pas comment sélectionner tout le fichier log qui est particulièrement long ! J'ai pris que la fin ; j'espère que cela permettra de détecter le problème
pipiche
Message par pipiche »
effectivement si les heures ne correspondent pas c'est qu'il y a un autre problème ou ce n'est pas le bon fichier ...
as tu corrigé les problèmes liés à l'accès au Domotciz API ?
Wiki ici
chat sur Keybase.io
pipiche
règle le problème d'accès à l'API Domoticz , le plugin doit avoir un accès à l'api Domoticz, et ici ca ne semble pas être possible
Wiki ici
chat sur Keybase.io
ker49
Message par ker49 »
nan, je n'ai pas réussi à régler ce problème d'accès.
je t'ai mis le fichier log plus récent (après 12h00)
je ne comprends pas pourquoi je n'ai pas accès à l'api Domoticz. C'est vrai qu'en refaisant mon nouveau Raspi en repartant de zéro je suis passé en https et en wifi donc c'est peut-être là qu'il y a un problème mais je ne maitrise pas assez pour trouver le conflit.
pipiche
regardes les Settings Sécurité coté Domoticz
Wiki ici
chat sur Keybase.io
