DomoticZ passera sous OpenSSL3 >> Maj nécessaire vers Debian 12 (Bookworm)
Je viens de voir ce post de Gizmocuz sur le forum anglais : Domoticz upcoming beta/release and OpenSSL 3.0
:arrow: Les futures versions Béta de DomoticZ (et certainement la prochaine Stable) ne pourront plus recevoir de mise à jour de DomoticZ si votre système ne dispose pas de OpenSSL3.
La commande pour connaître votre version de SSL est :
openssl version
:!: Les versions Buster et Bullseye fonctionnent sous OpenSSL1. Il faudra migrer vers Bookworm.
Le message d'information en anglais
Message initial copié le 11/05/2025 à 11h25:
gizmocuz a écrit :11 mai 2025, 09:13 Hi there!
[This post can be ignored for users running Domoticz via Docker (Compose) as it does not involve them]
As you are probably well aware, the latest Debian Bookworm is using OpenSSL version 3.
Prior Debian versions (Buster/Bullseye) is using OpenSSL version 1.
Unfortunately OpenSSL is not backwards compatible, and this means we have to move to OpenSSL version 3 if we want to keep running the latest Debian versions (and why not!)
As many users where still running on a older Debian version (Buster/Bullseye) the last release was done with using OpenSSL 1, but from now on, we will be using OpenSSL 3
This means, to keep running the latest Domoticz versions, you have to upgrade your system.
To check if your system has OpenSSL version 3 support, you can issue the below command:
openssl version
At the moment, all build platforms are being converted to Debian Bookworm, and from the 14th of May, we will be using OpenSSL 3
There has been a new beta released that has a modification in the updatebeta script that checks for OpenSSL 3.
If you update now, you will not be able to upgrade to a newer version until you meet the new system requirements (see it as a safety net)
I won't expect a new OpenSSL version (4) for the next 5 years
I found this great guide to update your system from Debian 11 (Bullseye) to Bookworm.
If you are running an older version (Debian 10, Buster), I recommend to upgrade first to Bullseye (11) and then to Bookworm
https://www.cyberciti.biz/faq/update-up ... 2-bookworm
pierrotori
Re: DomoticZ passera sous OpenSSL3 >> Maj nécessaire vers Debian 12 (Bookworm)
Message par pierrotori »
l'occasion de passer sous docker :)
klarf
Message par klarf »
Merci pour l'information.
Je croyais que Bookworm posait souci de compatibilité avec certains logiciels utiles autour de domoticz ?
lost
Message par lost »
pierrotori a écrit : 11 mai 2025, 20:01 l'occasion de passer sous docker :)
Et d'autres sources d'emmerdements! :)
pierrotori
Franchement je ne connaissais pas, et bien ca simplifie vraiment la vie pour les montées de versions os ou applicatives. depuis que je suis sous docker je ne reboot plus l'os et ne fait que les montées de version stable
par contre avec docker tu peux tester une version beta ou une autre application et revenir très rapidement à ta version d'avant
lost
Message par lost »
pierrotori a écrit : 12 mai 2025, 17:46depuis que je suis sous docker je ne reboot plus l'os...
$ uptime
 21:45:13 up 176 days,  4:06,  1 user,  load average: 0.08, 0.06, 0.07
Bah, 176 jours depuis le dernier reboot du PI (qui devait inclure une MAJ kernel ou lib fondamentale genre libc pour y obliger), c'est pas si mal et Domoticz y tourne en natif avec une charge assez ridicule sur un PI3B qui aura 10 ans l'année prochaine.
Phil35
Message par Phil35 »
Migrer de version SSL c'est une bonne chose.
1/ Oui docker j'y pense pour domoticz.
questions : comment est fait le lien entre l'image docker et le port usb (ConBee II pour moi) ?
Y a t il qq chose de spécifique à faire ?
2/ En attendant, un apt update && apt dist-upgrade fait il le job ?
Cordialement
Phil
Production : Raspberry Pi 4 Model B Rev 1.2 (OS 10 / buster) + domoticz 2022.2
Production : Raspberry Pi 3 Model B Rev 1.2 (OS 11 / bullseye) + domoticz V2024.7
J'ai déjà vu des problématiques au niveau de Python si le système était mis à jour de Debian 10 vers 11. Je partirai sur une réinstallation de l'OS pour faire un petit reste après des années d'utilisation.
pierrotori
j’hésite à y passer avec mon rpi2 en 32 bits
actuellement si je dois acheter un rpi 4 2go est-ce une bonne config avec domoticz ?
