Bon, après avoir relu le message et vu que le FW en question était le plus stable j'ai cherché.
Et trouvé ici:
https://github.com/Elelabs/elelabs-zigb ... /EFR32MG21
Conforté par le fait que celui déjà tenté en downgrade trouvé chez Aeon (ELU0141_MG21_zb_ncp_6103_211204.gbl) était idem au diff, j'ai tenté le ELU0143_MG21_zb_ncp_6103_211211.gbl suggéré.
C'était pas une bonne idée:
~/ziStickFwUpd/elelabs-zigbee-ezsp-utility-master$ venv/bin/python3 Elelabs_EzspFwUtility.py flash -f ELU0143_MG21_zb_ncp_6103_211211.gbl -p /dev/ttyUSB0
2025/07/05 15:50:24 Elelabs_EzspFwUtility: Elelabs Zigbee adapter detected:
2025/07/05 15:50:24 Elelabs_EzspFwUtility: Adapter: ELU0142
2025/07/05 15:50:24 Elelabs_EzspFwUtility: Firmware: 6.10.3-41
2025/07/05 15:50:24 Elelabs_EzspFwUtility: EZSP v8
2025/07/05 15:50:24 Elelabs_EzspFwUtility: Launch in bootloader mode
2025/07/05 15:50:33 Elelabs_EzspFwUtility: EZSP adapter in bootloader mode detected:
2025/07/05 15:50:33 Elelabs_EzspFwUtility: Gecko Bootloader v1.12.10
2025/07/05 15:50:34 Elelabs_EzspFwUtility: Successfully restarted into X-MODEM mode! Starting upload of the new firmware... DO NOT INTERRUPT(!)
2025/07/05 15:51:10 Elelabs_EzspFwUtility: Firmware upload complete
2025/07/05 15:51:10 Elelabs_EzspFwUtility: Rebooting NCP...
2025/07/05 15:51:25 Elelabs_EzspFwUtility: Couldn't communicate with the adapter in Zigbee (EZSP) mode, Thread (Spinel) mode or bootloader mode
Et idem au probe derrière:
~/ziStickFwUpd/elelabs-zigbee-ezsp-utility-master$ venv/bin/python3 Elelabs_EzspFwUtility.py probe -p /dev/ttyUSB0
2025/07/05 15:58:26 Elelabs_EzspFwUtility: Couldn't communicate with the adapter in Zigbee (EZSP) mode, Thread (Spinel) mode or bootloader mode
=> Coordinateur totalement brické cette fois... Après débranchement c'est idem
[35777.105958] usb 7-1.2: USB disconnect, device number 3
[35777.106360] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[35777.106400] ch341 7-1.2:1.0: device disconnected
[35789.059184] usb 7-1.2: new full-speed USB device number 4 using xhci_hcd
[35789.197343] usb 7-1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[35789.197357] usb 7-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[35789.197363] usb 7-1.2: Product: USB Serial
[35789.254772] ch341 7-1.2:1.0: ch341-uart converter detected
[35789.268828] usb 7-1.2: ch341-uart converter now attached to ttyUSB0
Toujours énuméré idem au débranchement/rebranchement, mais Aeon n'avait pas mis d'ID spécifiques.
EDIT:
Ce serait bien que ce message soit changé,
https://github.com/zigpy/zigpy/discussions/1611
Histoire de pas inciter d'autres avec ce coordinateur à refaire la même!
EDIT2: Essai de remettre le FW qui eu fonctionné (mais les pb fonctionnels récents derrière): KO également même si le mode XMODEM passe, le bootloader semble cassé.
venv/bin/python3 Elelabs_EzspFwUtility.py flash -f ELU0141_MG21_zb_ncp_6103_211204.gbl -p /dev/ttyUSB0
2025/07/05 16:24:57 Elelabs_EzspFwUtility: Couldn't communicate with the adapter in Zigbee (EZSP) mode, Thread (Spinel) mode or bootloader mode
2025/07/05 16:25:04 Elelabs_EzspFwUtility: Successfully restarted into X-MODEM mode! Starting upload of the new firmware... DO NOT INTERRUPT(!)
2025/07/05 16:25:16 Elelabs_EzspFwUtility: Failed to restart into bootloader mode. Please see users guide.
