2025.2 Crash Domoticz
Abbij
Message par Abbij »
Depuis hier j'ai des crashs de domoticz que je n'arrive pas a expliqué, c'est très aléatoire ca peut tenir 1 jours comme 1 heure ou 10minutes...
Dans les logs
2025-11-20 07:42:55.250 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.250 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.250 Error: > #2 0x0000aaaab4d4fbb4 in CEventSystem::Do_Work() ()
2025-11-20 07:42:55.250 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.250 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.250 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.250 Error: > Thread 32 (Thread 0xffff7dfbef20 (LWP 1429) "RFXCOM"):
2025-11-20 07:42:55.250 Error: > #0 0x0000ffffad3cc0b4 in epoll_pwait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.250 Error: > #1 0x0000aaaab4f53024 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2025-11-20 07:42:55.250 Error: > #2 0x0000aaaab4f549c0 in boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) ()
2025-11-20 07:42:55.250 Error: > #3 0x0000aaaab4f59c3c in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-11-20 07:42:55.251 Error: > #4 0x0000aaaab4f59e9c in boost::detail::thread_data<AsyncSerial::open(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned int, boost::asio::serial_port_base::parity, boost::asio::serial_port_base::character_size, boost::asio::serial_port_base::flow_control, boost::asio::serial_port_base::stop_bits)::{lambda()#2}>::run() ()
2025-11-20 07:42:55.251 Error: > #5 0x0000aaaab53bfdd8 in thread_proxy ()
2025-11-20 07:42:55.251 Error: > #6 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.251 Error: > #7 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.251 Error: > Thread 31 (Thread 0xffff7efdef20 (LWP 1424) "Ampli Yamaha"):
2025-11-20 07:42:55.251 Error: > #0 0x0000ffffad35e834 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.251 Error: > #1 0x0000ffffad361388 in pthread_cond_wait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.251 Error: > #2 0x0000aaaab4f54be8 in boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) ()
2025-11-20 07:42:55.251 Error: > #3 0x0000aaaab4f6173c in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-11-20 07:42:55.251 Error: > #4 0x0000aaaab4f7138c in boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_scheduler_runner>::run() ()
2025-11-20 07:42:55.251 Error: > #5 0x0000aaaab4f4f62c in boost_asio_detail_posix_thread_function ()
2025-11-20 07:42:55.252 Error: >
2025-11-20 07:42:55.252 Error: > Thread 30 (Thread 0xffff7f7eef20 (LWP 1423) "Plugin_ASIO"):
2025-11-20 07:42:55.252 Error: > #0 0x0000ffffad3cc0b4 in epoll_pwait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.252 Error: > #1 0x0000aaaab4f53024 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2025-11-20 07:42:55.252 Error: > #2 0x0000aaaab4f549c0 in boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) ()
2025-11-20 07:42:55.252 Error: > #3 0x0000aaaab529948c in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-11-20 07:42:55.252 Error: > #4 0x0000aaaab529960c in Plugins::BoostWorkers() ()
2025-11-20 07:42:55.252 Error: > #5 0x0000aaaab53bfdd8 in thread_proxy ()
2025-11-20 07:42:55.252 Error: > #6 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.252 Error: > #7 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.252 Error: > Thread 29 (Thread 0xffff7fffef20 (LWP 1422) "NotificationSys"):
2025-11-20 07:42:55.252 Error: > #0 0x0000ffffad35e834 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.252 Error: > #1 0x0000ffffad3619c0 in pthread_cond_clockwait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.252 Error: > #2 0x0000aaaab4dc6950 in CNotificationSystem::QueueThread() ()
2025-11-20 07:42:55.252 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.253 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.253 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.253 Error: > Thread 28 (Thread 0xffff88f9ef20 (LWP 1421) "ZWaveBase"):
2025-11-20 07:42:55.253 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.253 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.253 Error: > #2 0x0000aaaab5281d94 in ZWaveBase::Do_Work() ()
2025-11-20 07:42:55.253 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.253 Error: > Thread 27 (Thread 0xffff897aef20 (LWP 1420) "Domoticz_HBWork"):
2025-11-20 07:42:55.254 Error: > #2 0x0000aaaab4fc0894 in CDomoticzHardwareBase::Do_Heartbeat_Work() ()
2025-11-20 07:42:55.254 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.254 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.254 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.254 Error: > Thread 26 (Thread 0xffff89fbef20 (LWP 1419) "Home center 3 l"):
2025-11-20 07:42:55.254 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.254 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.254 Error: > #2 0x0000aaaab50b15ac in MQTT::Do_Work() ()
2025-11-20 07:42:55.254 Error: > Thread 25 (Thread 0xffff8a7cef20 (LWP 1418) "Station Météo"):
2025-11-20 07:42:55.254 Error: > #2 0x0000aaaab512b6b4 in CNetatmo::Do_Work() ()
2025-11-20 07:42:55.255 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.255 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.255 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.255 Error: > Thread 24 (Thread 0xffff8afdef20 (LWP 1417) "Freebox Plugin"):
2025-11-20 07:42:55.255 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.255 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.255 Error: > #2 0x0000aaaab5293258 in Plugins::CPlugin::Do_Work() ()
2025-11-20 07:42:55.256 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.256 Error: > Thread 23 (Thread 0xffff8b7eef20 (LWP 1416) "Compteur Linky"):
2025-11-20 07:42:55.256 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.256 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.256 Error: > #2 0x0000aaaab5293258 in Plugins::CPlugin::Do_Work() ()
2025-11-20 07:42:55.256 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.256 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.256 Error: > Thread 22 (Thread 0xffff8bffef20 (LWP 1415) "Smartlife"):
2025-11-20 07:42:55.257 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.257 Error: > Thread 21 (Thread 0xffff98f9ef20 (LWP 1414) "Logitech Harmon"):
2025-11-20 07:42:55.257 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.257 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.257 Error: > #2 0x0000aaaab50611d8 in CHarmonyHub::Do_Work() ()
2025-11-20 07:42:55.257 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.257 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.257 Error: > Thread 20 (Thread 0xffff997aef20 (LWP 1413) "Ampli Yamaha"):
2025-11-20 07:42:55.258 Error: > #2 0x0000aaaab5293258 in Plugins::CPlugin::Do_Work() ()
2025-11-20 07:42:55.258 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.258 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.258 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.258 Error: > Thread 19 (Thread 0xffff99fbef20 (LWP 1412) "Pont Philips Hu"):
2025-11-20 07:42:55.258 Error: > #0 0x0000ffffad39b924 in wait4 () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.258 Error: > #1 0x0000aaaab4de2384 in dumpstack_gdb(bool) ()
2025-11-20 07:42:55.258 Error: > #2 0x0000aaaab4de28f4 in signal_handler(int, siginfo_t*, void*) ()
2025-11-20 07:42:55.258 Error: > #3 <signal handler called>
2025-11-20 07:42:55.258 Error: > #4 0x0000ffffad363c18 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.258 Error: > #5 0x0000ffffad31a8ac in raise () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.258 Error: > #6 <signal handler called>
2025-11-20 07:42:55.258 Error: > #7 0x0000ffffad363c18 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.259 Error: > #8 0x0000ffffad31a8ac in raise () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.259 Error: > #9 0x0000ffffad307480 in abort () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.259 Error: > #10 0x0000aaaab54e8aa8 in __gnu_cxx::__verbose_terminate_handler() ()
2025-11-20 07:42:55.259 Error: > #11 0x0000aaaab54e73ec in __cxxabiv1::__terminate(void (*)()) ()
2025-11-20 07:42:55.259 Error: > #12 0x0000aaaab54e7450 in std::terminate() ()
2025-11-20 07:42:55.259 Error: > #13 0x0000aaaab54e75e4 in __cxa_throw ()
2025-11-20 07:42:55.259 Error: > #14 0x0000aaaab4ce1cac in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2025-11-20 07:42:55.259 Error: > #15 0x0000aaaab539fe8c in Json::Value::operator[](unsigned int) ()
2025-11-20 07:42:55.259 Error: > #16 0x0000aaaab51b5688 in CPhilipsHue::GetGroups(Json::Value const&) ()
2025-11-20 07:42:55.259 Error: > #17 0x0000aaaab51b748c in CPhilipsHue::GetStates() ()
2025-11-20 07:42:55.259 Error: > #18 0x0000aaaab51b7690 in CPhilipsHue::Do_Work() ()
2025-11-20 07:42:55.259 Error: > #19 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.260 Error: > #20 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.260 Error: > #21 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.260 Error: > Thread 18 (Thread 0xffff9a7cef20 (LWP 1411) "Domoticz_HBWork"):
2025-11-20 07:42:55.260 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.260 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.260 Error: > #2 0x0000aaaab4fc0894 in CDomoticzHardwareBase::Do_Heartbeat_Work() ()
2025-11-20 07:42:55.260 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.260 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.260 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.260 Error: > Thread 17 (Thread 0xffff9afdef20 (LWP 1410) "RFXCOM"):
2025-11-20 07:42:55.260 Error: > #2 0x0000aaaab51e7664 in RFXComSerial::Do_Work() ()
2025-11-20 07:42:55.261 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.261 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.261 Error: > Thread 16 (Thread 0xffff9b7eef20 (LWP 1396) "Watchdog"):
2025-11-20 07:42:55.261 Error: > #0 0x0000ffffad396ce0 in clock_nanosleep () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.261 Error: > #1 0x0000ffffad39bcac in nanosleep () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.261 Error: > #2 0x0000aaaab4d64604 in sleep_milliseconds(long) ()
2025-11-20 07:42:55.261 Error: > #3 0x0000aaaab4de2ae0 in Do_Watchdog_Work() ()
2025-11-20 07:42:55.261 Error: > #4 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.261 Error: > #5 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.261 Error: > #6 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.261 Error: > Thread 15 (Thread 0xffff9bffef20 (LWP 1395) "MainWorkerRxMsg"):
2025-11-20 07:42:55.261 Error: > #0 0x0000ffffad35e834 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.261 Error: > #1 0x0000ffffad3619c0 in pthread_cond_clockwait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.261 Error: > #2 0x0000aaaab4dafe24 in MainWorker::Do_Work_On_Rx_Messages() ()
2025-11-20 07:42:55.261 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.262 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.262 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.262 Error: > Thread 14 (Thread 0xffffa0f9ef20 (LWP 1394) "MainWorker"):
2025-11-20 07:42:55.262 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.262 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.262 Error: > #2 0x0000aaaab4dadf20 in MainWorker::Do_Work() ()
2025-11-20 07:42:55.262 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.263 Error: > Thread 13 (Thread 0xffffa17aef20 (LWP 1393) "domoticz"):
2025-11-20 07:42:55.263 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.263 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.263 Error: > #2 0x0000aaaab4d6f174 in CKWHStats::PeriodicSaveKWHStats(int) ()
2025-11-20 07:42:55.263 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.263 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.263 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.263 Error: > Thread 12 (Thread 0xffffa1fbef20 (LWP 1392) "mDnsWorker"):
2025-11-20 07:42:55.263 Error: > #0 0x0000ffffad3c49d0 in select () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.263 Error: > #1 0x0000aaaab4ede9b0 in domoticz_mdns::mDNS::mDnsMainLoop() ()
2025-11-20 07:42:55.263 Error: > #2 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.263 Error: > #3 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.263 Error: > #4 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.264 Error: > Thread 11 (Thread 0xffffa27cef20 (LWP 1391) "TCPServer"):
2025-11-20 07:42:55.264 Error: > #0 0x0000ffffad3cc0b4 in epoll_pwait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.264 Error: > #1 0x0000aaaab4f53024 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2025-11-20 07:42:55.264 Error: > #2 0x0000aaaab4f549c0 in boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) ()
2025-11-20 07:42:55.264 Error: > #3 0x0000aaaab5316a8c in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-11-20 07:42:55.264 Error: > #4 0x0000aaaab5316c48 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<tcp::server::CTCPServer::StartServer(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#1}> > >::_M_run() ()
2025-11-20 07:42:55.264 Error: > #5 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.264 Error: > #6 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.264 Error: > #7 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.264 Error: > Thread 10 (Thread 0xffffa2fdef20 (LWP 1390) "Scheduler"):
2025-11-20 07:42:55.264 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.264 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.264 Error: > #2 0x0000aaaab4dd6e5c in CScheduler::Do_Work() ()
2025-11-20 07:42:55.264 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.265 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.265 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.265 Error: > Thread 9 (Thread 0xffffa37eef20 (LWP 1389) "WebServer_443"):
2025-11-20 07:42:55.265 Error: > #0 0x0000ffffad3cc0b4 in epoll_pwait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.265 Error: > #1 0x0000aaaab4f53024 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2025-11-20 07:42:55.265 Error: > #2 0x0000aaaab4f549c0 in boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) ()
2025-11-20 07:42:55.265 Error: > #3 0x0000aaaab53614dc in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-11-20 07:42:55.265 Error: > #4 0x0000aaaab5366d28 in http::server::server_base::run() ()
2025-11-20 07:42:55.265 Error: > #5 0x0000aaaab4e35348 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#311}> > >::_M_run() ()
2025-11-20 07:42:55.265 Error: > #6 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.265 Error: > #7 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.265 Error: > #8 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.266 Error: > Thread 8 (Thread 0xffffa3ffef20 (LWP 1388) "Webem_ssncleane"):
2025-11-20 07:42:55.266 Error: > #0 0x0000ffffad3cc0b4 in epoll_pwait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.266 Error: > #1 0x0000aaaab4f53024 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2025-11-20 07:42:55.266 Error: > #2 0x0000aaaab4f549c0 in boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) ()
2025-11-20 07:42:55.266 Error: > #3 0x0000aaaab53395ac in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-11-20 07:42:55.266 Error: > #4 0x0000aaaab5339868 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2025-11-20 07:42:55.266 Error: > #5 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.266 Error: > #6 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.266 Error: > #7 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.266 Error: > Thread 7 (Thread 0xffffa8fcef20 (LWP 1387) "WebServer_8080"):
2025-11-20 07:42:55.266 Error: > #3 0x0000aaaab53614dc in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-11-20 07:42:55.267 Error: > #4 0x0000aaaab5366d28 in http::server::server_base::run() ()
2025-11-20 07:42:55.267 Error: > #5 0x0000aaaab4e35348 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#311}> > >::_M_run() ()
2025-11-20 07:42:55.267 Error: > #6 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.267 Error: > #7 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.267 Error: > #8 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.267 Error: > Thread 6 (Thread 0xffffa97def20 (LWP 1386) "Webem_ssncleane"):
2025-11-20 07:42:55.267 Error: > #0 0x0000ffffad3cc0b4 in epoll_pwait () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.267 Error: > #1 0x0000aaaab4f53024 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2025-11-20 07:42:55.267 Error: > #2 0x0000aaaab4f549c0 in boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) ()
2025-11-20 07:42:55.267 Error: > #3 0x0000aaaab53395ac in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-11-20 07:42:55.267 Error: > #4 0x0000aaaab5339868 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2025-11-20 07:42:55.268 Error: > #5 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.268 Error: > #6 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.268 Error: > #7 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.268 Error: > Thread 5 (Thread 0xffffa9feef20 (LWP 1385) "MQTTPush"):
2025-11-20 07:42:55.268 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.268 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.268 Error: > #2 0x0000aaaab4f01d2c in CMQTTPush::Do_Work() ()
2025-11-20 07:42:55.268 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.268 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.268 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.268 Error: > Thread 4 (Thread 0xffffaa7fef20 (LWP 1384) "InfluxPush"):
2025-11-20 07:42:55.269 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.269 Error: > #2 0x0000aaaab4efc9d8 in CInfluxPush::Do_Work() ()
2025-11-20 07:42:55.269 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.269 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.269 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.269 Error: > Thread 3 (Thread 0xffffab5bef20 (LWP 1381) "PluginMgr"):
2025-11-20 07:42:55.269 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.269 Error: > #2 0x0000aaaab5299c48 in Plugins::CPluginSystem::Do_Work() ()
2025-11-20 07:42:55.269 Error: > Thread 2 (Thread 0xffffabdcef20 (LWP 1380) "SQLHelper"):
2025-11-20 07:42:55.270 Error: > #0 0x0000ffffad3c7be4 in syscall () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.270 Error: > #1 0x0000aaaab5537454 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-11-20 07:42:55.270 Error: > #2 0x0000aaaab4dfd12c in CSQLHelper::Do_Work() ()
2025-11-20 07:42:55.270 Error: > #3 0x0000aaaab55678dc in execute_native_thread_routine ()
2025-11-20 07:42:55.270 Error: > #4 0x0000ffffad362030 in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.270 Error: > #5 0x0000ffffad3cbf1c in ?? () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.270 Error: > Thread 1 (Thread 0xffffadba9020 (LWP 1377) "domoticz"):
2025-11-20 07:42:55.270 Error: > #0 0x0000ffffad396ce0 in clock_nanosleep () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.270 Error: > #1 0x0000ffffad39bcac in nanosleep () from /lib/aarch64-linux-gnu/libc.so.6
2025-11-20 07:42:55.270 Error: > #2 0x0000aaaab4d64568 in sleep_seconds(long) ()
2025-11-20 07:42:55.270 Error: > #3 0x0000aaaab4ce307c in main ()
2025-11-20 07:42:55.270 Error: > Main thread:
2025-11-20 07:42:55.271 Error: > #2 0x0000aaaab4d64568 in sleep_seconds(long) ()
2025-11-20 07:42:55.271 Error: > #3 0x0000aaaab4ce307c in main ()
2025-11-20 07:42:55.271 Error: > [Inferior 1 (process 1377) detached]
Si quelqu'un saurait m'aider je suis preneur...
Bonne journée
Dernière modification par Keros le 20 nov. 2025, 20:26, modifié 1 fois.
Raison : Modification des balises
Re: 2025.2 Crash Domoticz
C'est arrivé suite à quelque chose de particulier ? La mise à jour de DomoticZ 2025.2 ?
Abbij
Message par Abbij »
Merci pour la réponse
La mise à jour à bien tourné pendant une quinzaine de jour
Je n'ai pas fait de modification spécifique depuis
J'ai eu une mise à jour de ma box mais à part ça...
Bonne journée
Cela arrive au démarrage ? Plus tard ? De façon régulière (heures fixes par exemple) ?
Abbij
Message par Abbij »
Non c'est assez aléatoire
Mais ca à l'air de tenir de moins en moins longtemps
Ce matin ca a tenu 1 heure
Tu es sur quoi comme OS (nom + version) et comme matériel ?
Ton disque ou ta carte SD n'est pas fatigué ? Je ne dis pas que ça vient de là, c'est juste une piste.
Abbij
Message par Abbij »
J'ai une VM sous debian 11 qui tourne sur ma freebox
Je peux testé d'installer sur le 2eme disque par curiosité
Non, si c'est une VM, il y a peu de risques que ce soit ça.
boum
Message par boum »
On dirait un soucis avec le pont hue. À vérifier que le log de crash redonne la même chose (ou désactiver le plugin).
Début de piste, faut demander aux esperts maintenant.
Edit: à surveiller sur le forum anglais Philips Hue related crashes
