Merci d'avance pour votre aide
C'est un détecteur de fumer avec thermomètre.
https://fr.aliexpress.com/item/10050096 ... pt=glo2fra
version Plugin: 8.1.001 [7.530]
voici les info du périphérique non optimisé
{"Filename":"TS0601.json","Configuration":{"_comment":"","_version":"","_blakadder":"","_source":"","Ep":{"01":{"0004":"","0005":"","ef00":"","0000":"","ed00":"","0019":"","000a":"","Type":{}}},"Type":"","ClusterToBind":[],"ConfigureReporting":{},"ReadAttributes":{"0000":["0001","ffe2","ffe4","0004","0000","0005","0007","fffe"]},"Param":{},"GroupMembership":{}},"rawInfos":{"Version":"3","ZDeviceName":"","Status":"inDB","SQN":"26","Ep":{"01":{"0004":{},"0005":{},"ef00":{},"0000":{"ffcf":"3840","0001":77,"ffe2":56,"ffe4":1,"0004":"_TZE284_gyzlwu5q","0000":3,"0005":"TS0601","0007":3,"fffe":0},"ed00":{},"0019":{},"000a":{}}},"Heartbeat":"16","RIA":"4","LQI":255,"Battery":{},"Model":"TS0601","ForceAckCommands":[],"MacCapa":"80","IEEE":"a4c1385b4d8c20a8","Type":{},"ProfileID":"0104","ZDeviceID":"0051","App Version":77,"Attributes List":{},"DeviceType":"RFD","HW Version":"","Last Cmds":[["None","","0630","0104 - 0000","1002000500"],["03","","0630","0000 - 0004","03300601"],["None","","0630","0104 - 0000","10030004000000010005000700feff"],["1c","","0630","0104 - ef00","181c0b1100"],["None","","0630","0104 - 000a","181e010700002331b65b31"],["1f","","0630","0104 - ef00","181f0b0200"],["20","","0630","0104 - ef00","18200b0200"],["21","","0630","0104 - ef00","18210b0200"],["22","","0630","0104 - ef00","18220b0200"],["23","","0630","0104 - ef00","18230b0200"]],"LogicalType":"End Device","Manufacturer":"1141","Manufacturer Name":"_TZE284_gyzlwu5q","NbEp":"1","PowerSource":"Battery","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":1774771668,"iSQN":{"0004":"03","0000":"03","0001":"03","0005":"03","0007":"03","fffe":"03"},"Attributes":{"0001":"00","ffe2":"00","ffe4":"00","0004":"00","0000":"00","0005":"00","0007":"00","fffe":"00"},"ZigateRequest":{}}}}},"ReceiveOnIdle":"Off","Stack Version":"","Stamp":{"time":1774771668.4442933,"Time":"2026-03-29 10:07:48","MsgType":"8102","LastSeen":1774771591},"ZCL Version":3,"Health":"Live","Capability":["Reduced-Function Device","Standard security","NwkAddr should be allocated"],"ZDPSQN":"03","ErrorManagement":0,"RollingLQI":[255,255,255,255,255,255,255,255,255,255],"_rawNodeDescriptor":"1141004200422a000080424002","Max Buffer Size":"42","Max Rx":"0042","Max Tx":"0042","macapa":"80","bitfield":"4002","server_mask":"2a00","descriptor_capability":"00","Epv2":{"01":{"ProfileID":"0104","ZDeviceID":"0051","ClusterIn":{"0004":{},"0005":{},"ef00":{},"0000":{},"ed00":{}},"ClusterOut":{"0019":{},"000a":{}}}},"ZCLSQN":"03","ReqEpv2":{"01":1774771592.846382},"ZDeviceVersion":"0001","ConfigSource":"8043","RSSI":-33,"RollingRSSI":[-33,-33,-33,-33,-33,-33,-33,-33,-33,-33],"WriteAttributes":{"Ep":{"01":{"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0005":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"ef00":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"ed00":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"000a":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"PairingInProgress":true,"Tuya":{"TUYA_MCU_VERSION_RSP":"40","Valve 0x67":"02"},"SQN_000a":"1e"}}
