Connexion en 3G
Forum dédié à l'accès à DomoticZ depuis l'extérieur de chez vous : routage de ports, VPN, VPS ...
La sécurité, c'est important !!
deennoo
Re: Connexion en 3G
Message par deennoo »
Donne nous dmesg juste après avoir ta clef
romu044
Re: Connexion en 3G
Message par romu044 »
Ah non !!
J'ai rien vu à ce sujet dans le tuto http://www.domopi.eu/envoyer-des-sms-de ... pberry-pi/
J'ai ajouté
model = E1552
dans le fichier mais pas mieux
voici ub lsusb suivi d'un dmesg (tronqué vu la longueur)
Bus 001 Device 007: ID 12d1:141b Huawei Technologies Co., Ltd.
[    5.256012] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[    5.358446] usb 1-1.4: New USB device found, idVendor=12d1, idProduct=1446
[    5.360208] usb 1-1.4: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[    5.362015] usb 1-1.4: Product: HUAWEI Mobile
[    5.364052] usb 1-1.4: Manufacturer: HUAWEI Technology
[    5.371516] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[    5.374427] scsi host0: usb-storage 1-1.4:1.0
[    5.377638] usb-storage 1-1.4:1.1: USB Mass Storage device detected
[    5.380254] scsi host1: usb-storage 1-1.4:1.1
[    6.296366] usb 1-1.4: USB disconnect, device number 6
[    8.233333] random: dd urandom read with 109 bits of entropy available
[    9.250209] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   10.111406] random: nonblocking pool is initialized
[   10.375994] usb 1-1.4: new high-speed USB device number 7 using dwc_otg
[   10.478039] usb 1-1.4: New USB device found, idVendor=12d1, idProduct=141b
[   10.478064] usb 1-1.4: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[   10.478076] usb 1-1.4: Product: HUAWEI Mobile
[   10.478087] usb 1-1.4: Manufacturer: HUAWEI Technology
[   10.480654] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[   10.481513] usb-storage 1-1.4:1.1: USB Mass Storage device detected
[   10.482108] usb-storage 1-1.4:1.2: USB Mass Storage device detected
[   10.482882] scsi host4: usb-storage 1-1.4:1.2
[   10.526148] usbcore: registered new interface driver usbserial
[   10.526269] usbcore: registered new interface driver usbserial_generic
[   10.526364] usbserial: USB Serial support registered for generic
[   10.564436] usbcore: registered new interface driver option
[   10.564633] usbserial: USB Serial support registered for GSM modem (1-port)
[   10.566309] option 1-1.4:1.0: GSM modem (1-port) converter detected
[   10.566835] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB0
[   10.566986] option 1-1.4:1.1: GSM modem (1-port) converter detected
[   10.567461] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB1
[   10.910618] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[   11.482292] scsi 4:0:0:0: Direct-Access     HUAWEI   SD Storage       2.31 PQ: 0 ANSI: 2
[   11.493100] sd 4:0:0:0: [sda] Attached SCSI removable disk
[   11.566358] sd 4:0:0:0: Attached scsi generic sg0 type 0
[   51.916730] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
[  111.227217] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
[  158.587650] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
deennoo
Re: Connexion en 3G
Le modem est sur usb0
romu044
Re: Connexion en 3G
J'ai essayé les deux vu le résultat du dmesg :
Mais cela ne change rien, j'ai toujours le même message d'erreur.
Tu as renseigné le modèle de ta clef dans le fichier ?
deennoo
Re: Connexion en 3G
Il faut que Warp te file un coup de main...la clef n'est pas bien reconnu
romu044
Re: Connexion en 3G
Volontier :D
J'ai regardé la doc de gammu, mais à force de lire des truc à gauche ou droite je mélange.
romu044
Re: Connexion en 3G
Bon j'ai avancé grâce à ce tuto :
https://arno0x0x.wordpress.com/2015/05/ ... -avec-rpi/
C'est avec gammu.
Du coup après avoir suivi le tuto je peux envoyer des sms.
Reste maintenant à intégrer cela à Domoticz, est ce que quelqu'un l'a déjà fait ?
Exemple envoyer des alertes via sms quand la connexion internet est ko, etc
Merci d'avance.
lclem
Re: Connexion en 3G
Message par lclem »
J'espere que tu as trouve la reponse mais au cas ou personnellement j'utilise un script shell lancé dans un script lua. ca marche tres bien.
Je passe en parametre le device qui a changé et suivant le cas dans le script shell j'adapte le contenu du sms envoyé
Rxfcom Somfy Oregon Chacon Imagintronix Z-stickGen5 Qubino HuaweiVodafone et divers gadget chinois (detecteur ouverture, inondation, mouvement,...)
