motorisation avidsen pour portail
bonjour,
mon portail est motorisé par un boitier électronique Avidsen (ref. 644112) et une télécommande 433Mhz Avidsen (ref. 580408).
La télécommande n'est pas reconnue par domoticz quand je lance la procédure de détection auto.
J'ai tracé le log du rflink (Firm. 42) lors des appuis sur les différents 4 boutons et j'obtiens cela :
bouton 1 (haut-gauche)
20;03;DEBUG;Pulses=106;Pulses(uSec)=2310,720,300,690,300,300,690,300,720,300,690,720,300,690,300,690,300,720,300,720,300,720,300,720,330,690,300,690,300,690,300,300,690,300,690,720,300,720,300,300,720,300,690,300,690,720,300,300,690,300,720,300,690,300,690,300,690,300,690,690,300,720,300,690,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,300,690,300,690,300,690,300,690,720,300,720,300,300,690,720,300,720,300,720,300,720,300,720,300,720,300,6990;
bouton 2 (haut-droit) - celui que j'utilise pour le portail
20;04;DEBUG;Pulses=106;Pulses(uSec)=2280,720,300,690,300,300,690,300,720,300,690,690,300,720,300,720,300,720,300,720,300,720,300,720,330,690,300,720,300,720,300,300,690,300,720,690,300,720,300,300,720,300,690,300,690,720,300,300,690,300,690,300,690,330,690,300,690,720,300,300,690,720,300,720,300,690,300,720,300,690,300,720,300,300,690,300,690,300,690,720,300,720,300,300,690,300,690,720,300,300,690,720,300,300,690,300,690,300,690,720,300,720,300,300,690,6990;
bouton 3 (bas-gauche)
20;05;DEBUG;Pulses=106;Pulses(uSec)=2280,720,300,690,330,300,720,300,720,300,720,690,300,720,300,690,300,690,300,690,300,690,300,720,330,690,300,690,300,690,300,300,720,300,690,690,300,690,300,300,720,300,720,300,690,720,300,300,690,300,720,300,690,300,720,300,720,720,300,690,300,300,690,690,300,690,300,690,300,720,300,690,330,690,300,300,720,300,690,720,300,690,300,300,690,300,690,300,720,300,690,720,300,300,720,690,300,300,720,300,690,300,690,300,690,6990;
bouton 4 (bas-droit)
20;06;DEBUG;Pulses=106;Pulses(uSec)=2310,690,300,690,300,300,690,300,720,300,690,690,300,690,300,690,300,690,300,720,300,690,300,690,330,690,300,690,300,720,300,300,690,300,690,690,300,690,300,300,720,300,690,300,690,690,300,300,720,300,690,300,690,300,690,300,720,690,300,690,300,690,300,300,690,690,300,690,300,690,330,690,330,300,690,720,300,690,300,300,690,300,720,690,300,720,300,720,300,300,690,690,300,690,300,300,690,300,720,690,300,690,300,690,300,6990;
serait_il possible que RFLINK supporte cet équipement ?
Merci d'avance
Merci d'avance
Re: motorisation avidsen pour portail
Avec plaisir, par contre les demandes d'ajout de matériel ce font ici : http://www.esp8266.nu/forum/viewforum.p ... 433e69c1e3
Merci pour la réponse.
Je vais poster la demande la bas
Mon petit doigt me dit que c'est déja inclus dans la prochaine version...mvmlt a écrit :Merci pour la réponse.
J'ai une version test de William (4302).
RFlink reconnait les trames Avidsen qd j'appuie sur la télécommande, mais pour l'instant en émission je ne parviens pas à commander mon portail ni ma porte de garage.
William travaille dessus...
A suivre
Tiens nous au courant si t'as du nouveau
bibo
A suivre
bibo
bonjour à tous,
J'ai recu le meme fimrware que toi Bibo456 (4302) et donc les mêmes résultats ... les boutons de la télécommande sont bien reconnus comme des dispositifs Advisen, mais les commandes manuelles depuis Domoticz sont sans effet sur la motorisation. Je vois bien les led TX et RX clignoter durant les envois d'ordre.
to be continued ...
to be continued ...
Je déterre le sujet, aviez vous une solution ?
Cordialement
Cordialement
Raspberry pi 3 B + Rfxcom + Domoticz
Ce sont des codes tournant, donc pas possible de gérer via rflink...
j'ai installé une motorisation de portail Avidsen très récemment et les 4 boutons des télécommandes étaient bien reconnus par le RFLink en auto-apprentissage.
Sinon la solution passe par un module ITL-1000 de chez Intertechno en branchant le contact sec de celui-ci sur le boitier de la motorisation au niveau des bornes prévues pour un bouton physique d'ouverture du portail (chez moi entre 2B et GRND). La temporisation de l'ITL-1000 réglée sur 2s ça marche nickel.
