Pourtant domoticz est bien accessible depuis l'exterieur. Je doit avoir un loupé dans la configuration ethernet... Je n'ai rien ajouté au niveau dns..
Dans /etc/dhcpcd.conf j'ai mis mon IP fixe 92.168.0.30 et l'@ de la freebox 192.168.0.254
pi@raspberrypi:~$ cat /etc/dhcpcd.conf
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface eth0
static ip_address=192.168.0.30/24 # <i><< change to an ip address in your network</i>
static routers=192.168.0.254 # <i><< change to your gateway</i>
static domain_name_servers=192.168.0.254 # <i><< change to your DNS</i>
