En lisant ce post j'ai essayé de faire de même pour sécuriser mon accès mais je n'ai pas réussi. J'ai remis domoticz.sh comme avant mais deux problèmes se posent :
1) Tout d'abord lorsque je démarre domoticz je vois bien que dans le log il y a un souci avec le SSL
2016-11-10 18:54:23.003 Domoticz V3.5876 (c)2012-2016 GizMoCuz
2016-11-10 18:54:23.003 Build Hash: b97777b, Date: 2016-11-09 12:33:42
2016-11-10 18:54:23.003 Startup Path: /Applications/dev-domoticz/
2016-11-10 18:54:23.010 Sunrise: 04:50:00 SunSet:14:24:00
2016-11-10 18:54:23.010 EventSystem: reset all events...
2016-11-10 18:54:23.012 Active notification subsystems: http (1/12)
2016-11-10 18:54:23.012 WebServer(HTTP) started on address: :: with port 8080
2016-11-10 18:54:23.014 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: use_certificate_chain_file: No such file or directory
2016-11-10 18:54:23.014 Error: WebServer(SSL) check privileges for opening ports below 1024
2016-11-10 18:54:23.014 Proxymanager started.
2016-11-10 18:54:23.015 Error: Exception starting shared server: bind: Address already in use
2016-11-10 18:54:23.015 RxQueue: queue worker started...
2016-11-10 18:54:24.354 Incoming connection from: ::1
2016-11-10 18:54:25.023 WOL: Started
2016-11-10 18:54:25.024 EventSystem: reset all events...
2016-11-10 18:54:25.024 EventSystem: reset all device statuses...
2016-11-10 18:54:25.024 EventSystem: Started
2016-11-10 18:54:25.525 OpenZWave: Starting...
2016-11-10 18:54:25.525 OpenZWave: Version: 1.4-244-ge9e3fce
2016-11-10 18:54:25.525 OpenZWave: using config in: /Applications/dev-domoticz/Config/
2016-11-10 18:54:25.706 OpenZWave: Driver Ready
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Energy, Instance: 1
2016-11-10 18:54:25.708 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Power, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Heat, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Power Management, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: System, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: COLOR, Label: Color, Instance: 1
2016-11-10 18:54:25.709 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: COLOR, Label: Color Index, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: METER, Label: Energy, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: METER, Label: Power, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: METER, Label: Voltage, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: METER, Label: Current, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 12 (0x0c), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 12 (0x0c), CommandClass: METER, Label: Energy, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 12 (0x0c), CommandClass: METER, Label: Power, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 12 (0x0c), CommandClass: METER, Label: Voltage, Instance: 1
2016-11-10 18:54:25.710 OpenZWave: Value_Added: Node: 12 (0x0c), CommandClass: METER, Label: Current, Instance: 1
2016-11-10 18:54:29.738 (Z-Stick) Light/Switch (Plafonnier)
2016-11-10 18:54:29.813 (Z-Stick) Usage (Consommation Plafonnier)
2016-11-10 18:54:29.815 (Z-Stick) General/kWh (kWh Meter)
2016-11-10 18:54:29.852 (Z-Stick) General/kWh (kWh Meter)
2016-11-10 18:54:29.890 (Z-Stick) Usage (Unknown)
2016-11-10 18:54:29.891 (Z-Stick) General/kWh (kWh Meter)
2016-11-10 18:54:29.929 OpenZWave: Alarm Level: Secure
2016-11-10 18:54:29.929 (Z-Stick) Light/Switch (Alarm Type)
2016-11-10 18:54:29.931 (Z-Stick) Light/Switch (Alarm Level)
2016-11-10 18:54:29.932 (Z-Stick) Light/Switch (Heat)
2016-11-10 18:54:29.968 OpenZWave: Alarm Level: Secure
2016-11-10 18:54:29.968 (Z-Stick) Light/Switch (Alarm Type)
2016-11-10 18:54:29.974 (Z-Stick) Light/Switch (Alarm Level)
2016-11-10 18:54:29.975 (Z-Stick) Light/Switch (Power Management)
2016-11-10 18:54:30.007 OpenZWave: Alarm Level: Secure
2016-11-10 18:54:30.007 (Z-Stick) Light/Switch (Alarm Type)
2016-11-10 18:54:30.009 (Z-Stick) Light/Switch (Alarm Level)
2016-11-10 18:54:30.010 (Z-Stick) Light/Switch (System)
2016-11-10 18:54:30.450 (Z-Stick) General/kWh (kWh Meter)
2016-11-10 18:54:30.488 (Z-Stick) Usage (Unknown)
2016-11-10 18:54:30.495 (Z-Stick) General/kWh (kWh Meter)
2016-11-10 18:54:30.526 (Z-Stick) General/Voltage (Tension sur la prise Lampe au sol)
2016-11-10 18:54:30.564 (Z-Stick) Current (Unknown)
2016-11-10 18:54:30.711 (Z-Stick) General/kWh (kWh Meter)
2016-11-10 18:54:30.752 (Z-Stick) Usage (Unknown)
2016-11-10 18:54:30.752 (Z-Stick) General/kWh (kWh Meter)
2016-11-10 18:54:30.789 (Z-Stick) General/Voltage (Tension sur la prise Lampadaire)
2016-11-10 18:54:30.827 (Z-Stick) Current (Unknown)
2016-11-10 18:54:30.829 OpenZWave: All Nodes queried
2016-11-10 18:54:34.554 Incoming connection from: 10.0.1.100
Si je comprends bien il lui manque le certificat mais à partir de là je suis largué...
2) J'ai homebridge d'installé pour faire le lien avec homekit mais je crois que mes manips ont mis le boxon et homebridge n'arrive plus à se lancer :
Là pareil, je ne vois pas d'où peut venir le problème... Peut-être que cette ligne du log de domoticz y est pour quelque chose ?
Merci de votre aide.
