domoticz offline
sphinxou
domoticz offline
Message par sphinxou »
bonsoir
depuis se soir plus possible d'accéder à domot
quand je lance une commande status :
* domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh)
Active: active (running) since dim. 2017-04-30 23:39:33 CEST; 2min 19s ago
Process: 5435 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
Process: 5712 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/domoticz.service
`-5719 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
avril 30 23:39:33 raspberrypi domoticz.sh[5712]: 2017-04-30 23:39:33.668 Do...z
avril 30 23:39:33 raspberrypi domoticz.sh[5712]: 2017-04-30 23:39:33.669 Bu...3
avril 30 23:39:33 raspberrypi domoticz.sh[5712]: 2017-04-30 23:39:33.670 St.../
avril 30 23:39:33 raspberrypi domoticz.sh[5712]: domoticz: Domoticz is start....
avril 30 23:39:33 raspberrypi domoticz[5718]: Domoticz is starting up....
avril 30 23:39:33 raspberrypi domoticz[5719]: Domoticz running...
avril 30 23:39:33 raspberrypi systemd[1]: Started LSB: Home Automation System.
Hint: Some lines were ellipsized, use -l to show in full.
Domoticz 4.9700/ rfxcom /sonde diy/raspberry pi3+HDD/cirusms/contact de porte diy
frenchyyii
Re: domoticz offline
Message par frenchyyii »
Tu n'aurais pas fait un rpi update ?
sphinxou
non juste mise a jour des paquets
sphinxou
status avec la 7703
pi@raspberrypi:~$ sudo service domoticz.sh status
Active: active (exited) since lun. 2017-05-01 00:59:18 CEST; 1min 22s ago
Process: 610 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
mai 01 00:59:17 raspberrypi domoticz.sh[610]: 2017-05-01 00:59:17.196 Domoticz V3.7403 (c)2012-2017 GizMoCuz
mai 01 00:59:17 raspberrypi domoticz[676]: Domoticz is starting up....
mai 01 00:59:17 raspberrypi domoticz.sh[610]: 2017-05-01 00:59:17.196 Build Hash: 78af35c, Date: 2017-04-30 17:33:55
mai 01 00:59:17 raspberrypi domoticz.sh[610]: 2017-05-01 00:59:17.197 Startup Path: /home/pi/domoticz/
mai 01 00:59:17 raspberrypi domoticz.sh[610]: domoticz: Domoticz is starting up....
mai 01 00:59:17 raspberrypi domoticz[1215]: Domoticz running...
mai 01 00:59:18 raspberrypi systemd[1]: Started LSB: Home Automation System.
sphinxou
dans les log de démarrage J'ai sa:
2017-05-01 01:14:10.784 WebServer(HTTP) stopped
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::lock_error> >'
what(): boost: mutex lock failed in pthread_mutex_lock: Invalid argumen
adv
Message par adv »
excuse si c'est peut être un peu facile et bateau mais si j'étais toi (voyant cette erreur incompréhensible) je repartirai avec une autre carte SD (j'en ai toujours une en stock) et une fresh install de raspbian et domoticz + restore de ta DB pour écarter tout risque de corruption de ta carte ou pbm au niveau de l'OS. Tu n'as que 20 minutes à perdre grand max et tu repars au pire sur un système propre à jour...
C'est vrai que c'est un peu frustrant, la même frustration que je rencontre quand je dis a un des utilisateurs au boulot de redémarrer son PC quand il est en vrac (appli plantée ou je ne sais quoi), il n’empêche que parfois (souvent ?!) ça marche !!! :lol:
C'était mon avis perso, bye !
sphinxou
salut
le truc c'est que je boute sur un hdd donc normalement pas de soucis en plus je fait des sauvegarde de de la db sur une clé usb.
j'ai remarquer quand je supprime la db domoticz redémarre est quand je recharge une db de 1 semaine en arrière sa recommence.
toute mais db serai corrompu ou un problème dans la mise a jour domoticz puisque je suis en version beta???
