Problème au reboot
fab0030
Problème au reboot
Message par fab0030 »
j ai un soucis au reboot
voici les log
La date du début m'interpelle!
Et surtout domoticz me lance une fermeture des volets à 16h (....after sunset!)
2017-05-09 16:00:02.497 Schedule item started! Name: Volet Ethan, Type: After Sunset, DevID: 6, Time: 2017-05-09 16:00:02
une petite idée!
  • 1970-01-01 01:00:15.399 OpenZWave: Driver Ready
    1970-01-01 01:00:15.403 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
    1970-01-01 01:00:15.404 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
    1970-01-01 01:00:15.404 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
    1970-01-01 01:00:15.404 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
    1970-01-01 01:00:15.404 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
    1970-01-01 01:00:15.405 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Up, Instance: 1
    1970-01-01 01:00:15.406 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Down, Instance: 1
    1970-01-01 01:00:15.406 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: BASIC WINDOW COVERING, Label: Open, Instance: 1
    1970-01-01 01:00:15.407 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: BASIC WINDOW COVERING, Label: Close, Instance: 1
    1970-01-01 01:00:15.410 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
    1970-01-01 01:00:15.411 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
    1970-01-01 01:00:15.439 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
    1970-01-01 01:00:15.440 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
    1970-01-01 01:00:15.441 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Alarm Type, Instance: 1
    1970-01-01 01:00:15.442 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Alarm Level, Instance: 1
    1970-01-01 01:00:15.442 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
    1970-01-01 01:00:15.442 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Smoke, Instance: 1
    1970-01-01 01:00:15.443 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Heat, Instance: 1
    1970-01-01 01:00:15.444 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Burglar, Instance: 1
    1970-01-01 01:00:15.444 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Power Management, Instance: 1
    1970-01-01 01:00:15.445 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: System, Instance: 1
    1970-01-01 01:00:15.446 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: BATTERY, Label: Battery Level, Instance: 1
    1970-01-01 01:00:15.447 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR ALARM, Label: General, Instance: 1
    1970-01-01 01:00:15.448 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR ALARM, Label: Smoke, Instance: 1
    1970-01-01 01:00:15.449 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR ALARM, Label: Heat, Instance: 1
    1970-01-01 01:00:15.456 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
    1970-01-01 01:00:15.457 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
    1970-01-01 01:00:15.457 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
    1970-01-01 01:00:15.459 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: BATTERY, Label: Battery Level, Instance: 1
    1970-01-01 01:00:15.460 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR ALARM, Label: General, Instance: 1
    1970-01-01 01:00:15.463 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
    1970-01-01 01:00:15.464 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
    1970-01-01 01:00:15.464 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
    1970-01-01 01:00:15.464 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
    1970-01-01 01:00:15.464 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
    1970-01-01 01:00:15.466 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Open, Instance: 1
    1970-01-01 01:00:15.466 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Close, Instance: 1
    1970-01-01 01:00:15.467 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
    1970-01-01 01:00:15.467 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: METER, Label: Energy, Instance: 1
    1970-01-01 01:00:15.467 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: METER, Label: Power, Instance: 1
    1970-01-01 01:00:15.471 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
    1970-01-01 01:00:15.471 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
    1970-01-01 01:00:15.471 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: METER, Label: Energy, Instance: 1
    1970-01-01 01:00:15.471 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: METER, Label: Power, Instance: 1
    1970-01-01 01:00:15.472 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: THERMOSTAT MODE, Label: Mode, Instance: 1
    1970-01-01 01:00:15.472 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: THERMOSTAT SETPOINT, Label: Heating 1, Instance: 1
    1970-01-01 01:00:15.478 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
    1970-01-01 01:00:15.478 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
    1970-01-01 01:00:15.479 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
    1970-01-01 01:00:15.479 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
    1970-01-01 01:00:15.479 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
    1970-01-01 01:00:15.481 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Open, Instance: 1
    1970-01-01 01:00:15.481 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Close, Instance: 1
    1970-01-01 01:00:15.481 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
    1970-01-01 01:00:15.481 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: METER, Label: Energy, Instance: 1
    1970-01-01 01:00:15.482 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: METER, Label: Power, Instance: 1
    1970-01-01 01:00:15.486 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
    1970-01-01 01:00:15.487 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: BATTERY, Label: Battery Level, Instance: 1
    1970-01-01 01:00:15.547 MQTT: Connecting to localhost:1883
    1970-01-01 01:00:15.554 MySensors: Using serial port: /dev/ttyACM0
    1970-01-01 01:00:15.472 (USB ZWave) General/Thermostat Mode (Thermostat Mode sdb)
    1970-01-01 01:00:15.674 MQTT: connected to: localhost:1883
    1970-01-01 01:00:15.605 (USB ZWave) Thermostat (Consigne temp sdb)
    1970-01-01 01:00:15.779 MQTT: Subscribed
    1970-01-01 01:00:15.723 (Yeelight) Lighting Limitless/Applamp (Lampe portail)
    1970-01-01 01:00:15.854 Incoming connection from: 192.168.1.100
    1970-01-01 01:00:15.863 User: Admin initiated a switch command (129/Lampe Lizea/Off)
    1970-01-01 01:00:16.485 MySensors: Gateway Ready...
    1970-01-01 01:00:16.561 MySensors: Gateway Version: 2.0.1-beta
    1970-01-01 01:00:17.064 (OneWire) Temp (Temperature chambre Ehan)
    1970-01-01 01:00:17.524 Hardware Monitor: Fetching data (System sensors)
    1970-01-01 01:00:18.872 Error: YeeLight: Exception: connect: No route to host
    2017-05-09 16:00:01.817 (USB ZWave) Temp (Temperature salle de bain)
    2017-05-09 16:00:02.504 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 13 (0x0d)
    2017-05-09 16:00:02.615 Sunrise: 06:25:00 SunSet:20:55:00
    2017-05-09 16:00:02.615 EventSystem: reset all events...
    2017-05-09 16:00:02.505 (USB ZWave) Light/Switch (Volet Ethan)
    2017-05-09 16:00:02.638 Schedule item started! Name: Volet Lizea, Type: After Sunset, DevID: 43, Time: 2017-05-09 16:00:02
    2017-05-09 16:00:02.639 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 18 (0x12)
    2017-05-09 16:00:02.640 (USB ZWave) Usage (Unknown)
    2017-05-09 16:00:02.644 (USB ZWave) General/kWh (kWh Meter)
    2017-05-09 16:00:02.649 (USB ZWave) Light/Switch (Volet Lizea)
    2017-05-09 16:00:02.750 Schedule item started! Name: jour_nuit, Type: After Sunset, DevID: 114, Time: 2017-05-09 16:00:02
    2017-05-09 16:00:02.754 (Devices virtuels) Lighting 1 (jour_nuit)
    2017-05-09 16:00:02.838 Schedule item started! Name: jour_nuit, Type: After Sunrise, DevID: 114, Time: 2017-05-09 16:00:02
    2017-05-09 16:00:02.842 (Devices virtuels) Lighting 1 (jour_nuit)
    2017-05-09 16:00:02.922 Schedule item started! Name: Consigne temp sdb, Type: On Time, ThermostatID: 72, Time: 2017-05-09 16:00:02
aleph0
Re: Problème au reboot
Message par aleph0 »
Salut !
Ça, ça ressemble fortement à un hardware dont l'horloge interne n'est pas sauvegardée, et qui se met à l'heure après le boot par NTP ou équivalent.
Si c'est le cas, il faudrait que tu règles l'ordre de lancement des services au boot pour avoir 1/ le réseau, 2/ la synchro d'horloge 3/ domoticz
fab0030
ouaou! Je n'ai jamais fait...
je suis preneur de quelques lignes de commande pour m'aider, je vais toutefois chercher!
encore merci
aleph0
Si tu veux plus de détails, il va falloir commencer par en donner ;)
- C'est quoi ton hardware ?
- C'est quoi ta distribution ?
fab0030
Bonne remarque!!
Pi2 avec wheezy
Ca deconne depuis ce we j ai ajouté mqtt et homebridge au démarrage...la gestion du démarrage est encore un mystère pour moi
aleph0
Je vais regarder comment est le boot sur wheezy, et je te dis quoi
Ghislain
Message par Ghislain »
Une petite mise a jour pourrait etre pas mal je pense lol ;)
higgins91
Message par higgins91 »
attention à la mise à jour, surtout du kernel, il n'est plus trop compatible avec les librairies GPIO (je me suis fait avoir)
Dz version : 2024.7
fab0030
bonjour,
j ai réinstallé à partir d'une sauvegarde, ok. Je n'ai pas trouvé mon erreur !
merci à vous
