Zigate plugins 4.0.2 crash
lelouche38
Message par lelouche38 »
Je bataille à essayer de faire fonctionner domoticz avec une sonde de temperature/humidé/pression Xiaomi.
J'ai pu faire l'appairage une fois, ce qui m'a d'ailleurs donné plusieurs devices pour 1 seul capteur mais la le redemarrage crash tout court.
Une idée ?
2018-12-10 12:26:40.862 Status: RxQueue: queue worker started...
2018-12-10 12:26:42.863 Status: (maZigate) Started.
2018-12-10 12:26:42.864 Status: EventSystem: reset all events...
2018-12-10 12:26:42.865 Status: EventSystem: reset all device statuses...
2018-12-10 12:26:43.004 Status: Python EventSystem: Initalizing event module.
2018-12-10 12:26:43.005 Status: EventSystem: Queue thread started...
2018-12-10 12:26:43.006 Status: EventSystem: Started
2018-12-10 12:26:43.206 Status: PluginSystem: Entering work loop.
2018-12-10 12:26:43.511 Status: (maZigate) Entering work loop.
2018-12-10 12:26:43.511 Status: (maZigate) Initialized version 4.0.2, author 'zaraki673 pipiche38'
2018-12-10 12:26:43.516 Status: (maZigate) onStart called - Zigate plugin V 4.0.2
2018-12-10 12:26:43.516 Status: (maZigate) load PluginConf
2018-12-10 12:26:43.517 Status: (maZigate) ZigateMode: ZigBee sendDelay: 0 reTransmit: 1 zTimeOut: 2
2018-12-10 12:26:43.517 Status: (maZigate) logFORMAT: 0 logLQI: 0 allowRemoveZigateDevice: 0
2018-12-10 12:26:43.517 Status: (maZigate) allowStoreDiscoveryFrames: 0 forceCreationDevice: 0 networkScan: 0 channel: ['0']
2018-12-10 12:26:43.529 Status: (maZigate) load ListOfDevice
2018-12-10 12:26:43.557 Error: Domoticz received fatal signal 11 !...
2018-12-10 12:26:43.561 Error: /home/root/domoticz/domoticz() [0x262154]
2018-12-10 12:26:43.561 Error: /home/root/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x26220c]
2018-12-10 12:26:43.561 Error: /lib/arm-linux-gnueabihf/libc.so.6(+0x26aa0) [0xb6da1aa0]
lelouche38
Re: Zigate plugins 4.0.2 crash
J'ai continué mes essais et j'ai
- supprimé tous mes devices de domoticz
- arreté le service domoticz
- detruit le plugin Zigate
- refait un git clone du plugin
- puis redemarré
La ca fonctionne jusqu'a ce que l'appairage avec mon capteur Xiaomi soit fait
et que je redemarre le service domoticz
Apres c'est du crash systematique.
Je joins un log domoticz.
Ca inspire qqn ?
domoticz.7z
(8.75 Kio) Téléchargé 317 fois
lelouche38
Personne n'a d'idée ?
Je suis sur que c'est lié au plugin Zigate. Si j'arrete le service domoticz, supprime le plugin, et relance domoticz, ce dernier demarre et ne crash pas.
olivr2s
Message par olivr2s »
je relance ce sujet sans réponse car ayant acquis une clé USB Zigate je rencontre le même problème.
- Installation du plugin -> OK
- Ajout de la Zigate dans la rubrique matériel -> OK
- Ajout d'un bouton Xiaomi dans domoticz via la Zigate -> OK
- Retour des actions du bouton -> OK
Au bout d'un certain temps Domoticz est Offline.
Restart de Domoticz, mais crash au bout des quelques minutes
Obligé de supprimer le plugin Zigate pour retrouver un Domoticz stable.
Une idée ?
pipiche
Message par pipiche »
Pouvez-vous essayer avec la branche dev-grpmgt ?
 git pull
 git checkout dev-grpmgt
IL a été reporté des problème de crash intempestif lié à l'utilisation du module random (qui a été supprimé) dans la version dev.
Wiki ici
chat sur Keybase.io
pipiche
Bonjour ,
Je viens de pousser un patch qui supprime ce module. Donc tout en restant sur la branche stable, il vous suffit de mettre à jour le plugin avec la commande
git pull
Wiki ici
chat sur Keybase.io
olivr2s
Merci pour la modification :D , mais je ne pourrais pas tester tout de suite étant en déplacement.
Je fais l'essai dès que je peux.
olivr2s
Je viens de faire un git pull.... :D
Super, DZ ne plante plus, il reste stable et même après des redémarrage du service. MERCI ;)
pipiche
Super!
Wiki ici
chat sur Keybase.io
CitrikElektrik
Message par CitrikElektrik »
Merci pour la correction du plugin. J'avais testé en décembre et j'avais rencontré le même problème. Tout marche impec maintenant (Raspbian 9.4).
En revanche, le git pull n'a pas fonctionné. J'ai dû faire :
git fetch --all
puis :
git reset --hard origin/stable
En étant bien sûr positionné dans le répertoire du plugin. J'espère que ça aidera les prochains.
