Memoprog noirot non reconnu par le RFLINK
SylvainR
Message par SylvainR »
J'utilise la version 48 du RFLINK qui est censée supporter le Mémoprog RF Thermostat ainsi que le Calidou Plus Thermostat ... mais chez moi cela ne fonctionne pas :cry: !
Pour être plus précis, la partie RF est parfaitement fonctionnelle (pour preuve je reçois les infos de mes boitiers Oregon si je les allume) mais pour voir une quelconque activité de mon mémoprog, il faut que j'active le RFDebug.
Une fois en RFDebug je reçois des trucs du genre :
2018-12-31 16:25:38 - 20;1C;DEBUG;Pulses=64;Pulses(uSec)=240,30,210,30,180,30,180,30,210,240,390,30,180,30,180,30,180,30,180,30,180,240,390,30,180,30,180,270,390,30,180,60,180,60,180,60,180,30,180,60,180,60,150,270,390,30,180,30,180,60,150,270,390,30,180,270,180,60,150,60,390,60,150,6990;
2018-12-31 16:25:52 - 20;1D;DEBUG;Pulses=84;Pulses(uSec)=1200,0,210,0,210,240,420,0,210,240,420,240,420,30,210,240,420,30,180,30,180,30,180,30,180,30,180,30,210,240,420,30,180,30,180,30,180,30,180,30,180,240,390,30,180,30,180,240,390,30,180,30,180,30,180,60,180,30,180,60,180,60,180,240,390,30,180,60,180,60,180,240,390,60,180,270,180,60,150,60,390,60,150,6990;
2018-12-31 16:26:43 - 20;1E;DEBUG;Pulses=82;Pulses(uSec)=240,0,210,210,420,30,180,210,420,210,420,30,180,240,420,0,210,30,210,30,210,30,210,30,180,30,180,240,390,30,180,30,180,30,180,30,180,30,180,240,390,30,180,60,180,240,390,30,180,30,180,30,180,30,180,30,180,60,180,30,180,270,390,30,180,60,150,60,180,270,360,60,180,270,150,60,150,60,390,60,180,6990;
2018-12-31 16:28:03 - 20;1F;DEBUG;Pulses=80;Pulses(uSec)=240,210,420,0,180,240,420,240,420,30,180,240,390,30,180,30,210,30,180,30,180,30,180,30,180,240,390,30,180,30,180,30,180,30,180,30,180,240,390,30,180,30,180,240,390,30,180,30,180,60,180,30,180,30,180,60,180,30,180,240,390,60,180,30,180,60,180,270,390,60,180,240,180,60,180,60,390,60,180,6990;
2018-12-31 16:31:23 - 20;20;DEBUG;Pulses=32;Pulses(uSec)=300,390,120,420,120,180,390,180,420,330,420,360,120,360,180,180,390,180,330,420,420,390,120,420,120,210,360,180,330,390,420,360;
20;21;DEBUG;Pulses=36;Pulses(uSec)=330,360,150,450,90,210,90,180,90,420,150,180,90,210,120,180,90,180,90,450,120,420,510,270,120,150,420,150,90,210,90,420,150,180,390,360;
2018-12-31 16:41:54 - 20;22;DEBUG;Pulses=72;Pulses(uSec)=480,330,600,210,330,210,240,60,480,60,510,270,450,330,240,300,180,120,480,60,450,330,450,330,210,360,180,150,390,120,420,390,390,390,120,420,150,150,390,150,390,390,390,390,150,420,150,180,360,150,390,420,390,390,120,420,120,180,360,180,360,420,330,420,120,450,120,180,360,150,330,450;
20;23;DEBUG;Pulses=92;Pulses(uSec)=1200,180,60,240,0,480,60,210,300,420,90,240,270,450,300,420,60,210,330,420,90,240,270,420,90,180,90,180,120,210,330,180,90,450,90,180,390,180,120,420,120,210,330,390,150,180,90,180,390,390,120,180,120,180,120,150,120,180,120,210,390,390,120,180,120,180,90,180,120,180,120,180,120,180,390,390,120,180,120,150,120,180,150,150,360,180,120,390,150,180,120,6990;
2018-12-31 16:51:35 - 20;24;DEBUG;Pulses=288;Pulses(uSec)=510,270,420,120,240,60,510,30,450,300,480,330,210,330,210,120,450,90,450,330,420,360,210,330,180,120,420,120,420,360,420,360,180,360,150,150,420,120,390,360,390,390,150,390,150,150,390,150,390,390,390,420,150,390,150,150,390,150,360,420,390,420,90,450,120,210,330,180,360,420,360,450,90,420,120,210,360,210,330,450,360,420,90,450,90,210,330,210,330,420,360,450,90,480,60,210,330,240,330,450,330,480,60,480,60,240,300,210,330,450,330,450,90,450,60,240,330,210,330,450,330,450,60,450,90,210,330,210,330,450,330,450,90,450,90,240,300,240,330,450,330,480,60,480,90,210,330,210,330,450,330,420,90,480,60,240,300,210,330,450,330,450,90,450,90,240,330,210,330,450,330,450,90,450,90,210,60,210,90,450,90,210,90,180,90,210,90,210,90,450,120,450,360,420,120,210,330,210,60,210,90,450,90,180,360,420,120,210,330,450,330,450,90,210,330,420,120,210,330,420,120,210,60,210,120,180,360,240,60,420,120,180,360,180,120,420,120,210,360,420,120,180,120,180,390,420,90,180,120,210,90,210,90,210,90,180,360,420,120,180,120,180,90,210,90,180,90,180,90,180,360,420,120,180,90,210,90,180,90,180,360,180,90,450,90,180,90,6990;
Je comprends donc que le RFlink reçoit bien la communication mais ne sait pas le décoder contrairement à ce que j'avais compris de la release 48.
J'ai tenté un mail en direction de l'équipe de dev mais sans succès ...
Est ce que vous voyez une issue à mon problème ? Est ce que ça marche pour quelqu'un avec le mémoprog ? Savez vous où je pourrais trouver de l'info sur ce sujet ?
Toute aide/idée sera la bienvenue !
Merci d'avance.
foxfr99
Re: Memoprog noirot non reconnu par le RFLINK
Message par foxfr99 »
avez vous trouvé une solution à votre problème ?
je suis dans le même cas avec des moteur de store telco :cry:
bye
teonitro
Message par teonitro »
SylvainR a écrit :Bonjour,
Merci d'avance.
Salut, moi aussi j'ai 3 memoprogs dans 3 radiateur calidouplus et j'aimerai pouvoir les piloter avec le rfxcom. Est-ce que tu sais si du côté de rfxcom leur firmware le supporte ?
Merci à toi
Envoyé de mon ONEPLUS A5010 en utilisant Tapatalk
