J'ai acheter 2 prise connecter smartlife (tuya)
lien amazon : https://www.amazon.fr/gp/product/B07CWL ... UTF8&psc=1
installation sur mon smartphone et sur ALEXA d'amazon sans souci
Je souhaite voir mes prises sur domoticz : j'ai donc appliquez le plugin de git hub
lien : https://github.com/tixi/Domoticz-Tuya-SmartPlug-Plugin
Donc J'obtient bien le moeyn de déclarer sur domoticz mes prises via le plugin tuya
https://drive.google.com/open?id=1beMJh ... _95wnOd8d1
par contre la partie suivante du plugin qui permet de détecter les paramètre des prises ne marche pas
param domo :
https://drive.google.com/open?id=1CCbn7 ... rPFMn0WPH8
lister les params :
Linking a Tuya Device
Add any devices you want to use with tuyapi to the Tuya Smart app.
Install the CLI tool by running npm i @tuyapi/cli -g. If it returns an error, you may need to prefix the command with sudo. (Tip: using sudo to install global packages is not considered best practice. See this NPM article for some help.)
Install AnyProxy by running npm i anyproxy -g. Then run anyproxy-ca.
Run tuya-cli list-app. It will print out a QR code; scan it with your phone and install the root certificate. After installation, trust the installed root certificate.
Configure the proxy on your phone with the parameters provided in the console.
Enable full trust of certificate by going to Settings > General > About > Certificate Trust Settings
Open Tuya Smart and refresh the list of devices by "pulling down".
A list of ID and key pairs should appear in the console.
It's recommended to untrust the root certificate after you're done for security purposes.voici l'erreur :
(node:1071) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
npm ERR! git clone git@github.com:tuyapi/cli Clonage dans le dépôt nu '/root/.npm/_git-remotes/git-github-com-tuyapi-cli-3083bead'
npm ERR! git clone git@github.com:tuyapi/cli Permission denied (publickey).
npm ERR! git clone git@github.com:tuyapi/cli fatal: Impossilble de lire le dépôt distant.
npm ERR! git clone git@github.com:tuyapi/cli Veuillez vérifier que vous avez les droits d'accès
npm ERR! git clone git@github.com:tuyapi/cli et que le dépôt existe.
npm ERR! addLocal Could not install tuyapi/cli
npm ERR! Error: ENOENT: no such file or directory, stat 'tuyapi/cli'
npm ERR! If you need help, you may report this *entire* log,
npm ERR! including the npm and node versions, at:
npm ERR! <http://github.com/npm/npm/issues>
npm ERR! System Linux 4.14.79-v7+
npm ERR! command "/usr/bin/node" "/usr/bin/npm" "i" "@tuyapi/cli" "-g"
npm ERR! cwd /home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin
npm ERR! node -v v8.11.1
npm ERR! npm -v 1.4.21
npm ERR! path tuyapi/cli
npm ERR! syscall stat
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/npm-debug.log
npm ERR! not ok code 0
