allez, petit cadeau de noël la version 1.10 avec une nouvelle fonctionnalité, suggérée par Anthony92
original script by rrozema Generic auto-off : https://www.domoticz.com/forum/viewtopic.php?f=72&t=23717&p=205159&hilit=auto+off#p201976
author = papoo
maj : 28/12/2019
this version need a waaren script, Universal function notification :
https://www.domoticz.com/forum/viewtopic.php?f=59&t=26542#p204958
https://pon.fr/dzvents-fonction-de-notification-universelle/
blog url : https://pon.fr/dzvents-script-de-notification-ultime-mais-pas-que
forum url : https://easydomoticz.com/forum/viewtopic.php?f=17&t=8167
github url : https://github.com/papo-o/domoticz_scripts/blob/master/dzVents/scripts/JsonDescription.lua
This script will run every minute and can automatically send an 'Off' command to turn off any device after
it has been on for some specified time. Each device can be individually configured by putting json coded
settings into the device's description field. The settings currently supported are:
- "auto_off_minutes" : <time in minutes>
- "auto_off_motion_device" : "<name of a motion detection device>"
If "auto_off_minutes" is not set, the device will never be turned off by this script. If
"auto_off_minutes" is set and <time in minutes> is a valid number, the device will be turned off when it
is found to be on plus the device's lastUpdate is at least <time in minutes> minutes old. This behavior
can be further modified by specifying a valid device name after "auto_off_motion_device". When a motion
device is specified and the device's lastUpdate is at least <time in minutes> old, the device will not
be turned off until the motion device is off and it's lastUpdate is also <time in minutes> old.
Specifying "auto_off_motion_device" without specifying "auto_off_minutes" does nothing.
Example 1:
turn off the device after 2 minutes :
Exemple 1 :
éteindre l'appareil après 2 minutes :
"auto_off_minutes": 2
Example 2:
turn off the device when it has been on for 5 minutes and no motion has been detected by
the "Overloop: Motion" device :
Exemple 2 : éteindre l'appareil lorsqu'il est allumé depuis 5 minutes et qu'aucun mouvement n'a été détecté par
le dispositif "Overloop: Motion":
"auto_off_minutes": 5,
"auto_off_motion_device": "Overloop: Motion"
Example 3: turn off the device when it has been on for 2 minutes and no motion has been detected by
either of the "Motion1" or the "Motion2" Devicex:
exemple 3: éteindre l'appareil lorsqu'il est allumé depuis 2 minutes et qu'aucun mouvement n'a été détecté par
l’un des dispositifs "Motion1" ou "Motion2":
"auto_off_minutes": 2,
"auto_off_motion_device": {"Device1": "Motion1", "Device2": "Motion2"}
With this new version you can :
- be notified if temperature and or hygrometry exceed min or max threshold.
- be notified if device is on, off or out
you can mix the desired notifications, such as only the maximum temperature rise,
or the minimum and maximum humidity, or do not set quiet hours, or minimum temperature and timout
if you want to use the notification functions, the frequency of notifications is necessary
Avec cette nouvelle version vous pouvez :
- être averti après le délai défini si la température et / ou l'hygrométrie dépassent le seuil minimal ou maximal.
- être averti si un périphérique est allumé, éteint ou hors service
vous pouvez mélanger les notifications souhaitées, telles que uniquement le dépassement de température maxi,
ou l'hygrométrie mini et maxi, ou ne pas définir d'heures calmes, ou température mini et timeout
si vous souhaitez utiliser les fonctions de notification, la fréquence de notifications est nécessaire
Example 4 : be notified if temperature or hygrometry exceed min or max threshold for a number of minutes
with notifications frequency in minutes and quiet hours notification
Exemple 4 : être averti si la température ou l'hygrométrie dépasse les seuils minimal ou maximal pendant un certain nombre de minutes
avec fréquence de notifications en minutes et notification des heures calmes
"low_threshold_temp": 10,
"high_threshold_temp": 40,
"duration_exceeded_temp": 20,
"low_threshold_hr": 25,
"high_threshold_hr": 75,
"duration_exceeded_hr": 20,
"frequency_notifications": 60,
"quiet_hours":"23:00-07:15"
Example 5 : be notified if device is on since x minutes
Exemple 5 : être averti si le périphérique est allumé depuis x minutes
"time_active_notification": 120,
Example 6 : be notified if device is off since x minutes
Exemple 6 : être averti si le périphérique est éteint depuis x minutes
"time_inactive_notification": 2,
Example 7 : be notified if device is out since x minutes
Exemple 7 : être averti si le périphérique est hors service depuis x minutes
"timeout_notification": 1440,
Example 8 : be notified if a device% exceeds the minimum or maximum thresholds
with frequency of notifications in minutes and notification of quiet hours
Exemple 8 : être averti si un périphérique % dépasse les seuils minimal ou maximal
"low_threshold_percent": 10,
"high_threshold_percent": 40,
"duration_exceeded_percent": 20,
Example 9 : be notified if a Custom Sensor device exceeds the minimum or maximum thresholds
Exemple 9 :être averti si un périphérique Custom Sensor dépasse les seuils minimal ou maximal
"low_threshold_custom": 1000,
"high_threshold_custom": 4000,
Example 10: Be notified if an Alert device exceeds a predefined threshold (1,2,3 or 4)
Exemple 10 : être averti si un périphérique Alert dépasse un seuil prédéfini (1,2,3 ou 4)
"high_threshold_color": 4,
Fonctionnalités proposées par denis_brasseur
Example 11: Be notified if a device's battery is below a low threshold
Exemple 11 : être averti si la batterie d'un périphérique est inférieure un seuil bas
"low_battery_level": 30,
"high_threshold_temp": -15,
Example 12: Be notified if the signal level (zwave, rfxcom) of a device is below a low threshold
Exemple 12 : être averti si le niveau de signal (zwave, rfxcom) d'un périphérique est inférieure un seuil bas
"low_signal_level": 2,
Example 13: Be notified if a power device exceeds a high threshold or a low threshold set
Exemple 13 : être averti si un périphérique puissance dépasse un seuil haut ou un seuil bas défini
"low_watt_usage": 0,
"high_watt_usage": 10000,
Example 14: Be notified if an intensity device exceeds a high threshold or a low threshold set
Exemple 14 : être averti si un périphérique intensité dépasse un seuil haut ou un seuil bas défini
"low_current_usage": 0,
"high_current_usage": 60,
Example 15 : turn on the device after x minutes:
Exemple 15 : allumer l'appareil après x minutes:
"auto_on_minutes": 1
Example 16 : be notified if device is off since x minutes
with notifications frequency in minutes and quiet hours notification only on telegram notifications
Notification systems available:
GOOGLE_CLOUD_MESSAGING, HTTP, KODI, LOGITECH_MEDIASERVER, NMA, PROWL, PUSHALOT, PUSHBULLET,PUSHOVER, PUSHSAFER, TELEGRAM
Exemple 16 : être averti si le périphérique est éteint depuis x minutes
avec fréquence de notifications en minutes et notification des heures calmes seulement via les notifications TELEGRAM
Systèmes de notification disponibles :
"subsystems" : "TELEGRAM",
Example 17 : be notified if device is off since x minutes
with notifications frequency in minutes and quiet hours notification only on TELEGRAM and PUSHBULLET notifications
For multi-system notification, separate the systems with a comma.
Exemple 17 : être averti si le périphérique est éteint depuis x minutes
avec fréquence de notifications en minutes et notification des heures calmes seulement via les notifications TELEGRAM et PUSHBULLET
Pour une notification sur plusieurs systèmes, séparez les systèmes par une virgule.
"subsystems" : "TELEGRAM,PUSHBULLET",
Example 18 : dim a light at define level(s), day(s) and time(s)
if "silent" : true allows to update the level of a device without action
exemple 18 : moduler une lumière à niveau(x), jour(s) et heure(s) définis
si "silent" : true permet de mettre à jour le niveau d'un device sans action
"dimTo" :
"1":{"level" : 75, "day" : "mon-tue-wed-thu-fri-sat", "hour" : "7:15"},
"2":{"level" : 0, "day" : "mon-tue-wed-thu-fri-sat", "hour" : "7:18"},
"3":{"level" : 25, "day" : "mon-tue-wed-thu-fri-sat", "hour" : "22:15", "silent" : true},
"4":{"level" : 100, "day" : "mon-tue-wed-thu-fri-sat", "hour" : "08:00", "silent" : true}
Fonctionnalité proposée par Anthony72
Example 19 : automatically change the custom icon of a selector switch
syntax
"levelNumber" : "iconNumber",
Exemple 19 : changer automatiquement l'icone personnalisé d'un switch selecteur
syntaxe
{"selectorIcons":{"0":"128","10":"129","20":"130","30":"131","40":"132","50":"133","60":"134","70":"135","80":"136","90":"137"}}
local scriptName = 'Json Description'
local scriptVersion = '1.11'
return {
active = true,
on = {
-- timer triggers
timer = {
'every minute'
-- custom logging level for this script
logging = {
-- level = domoticz.LOG_DEBUG,
level = domoticz.LOG_INFO, -- Seulement un niveau peut être actif; commenter les autres
-- level = domoticz.LOG_ERROR, -- Only one level can be active; comment others
-- level = domoticz.LOG_MODULE_EXEC_INFO,
marker = scriptName..' v'..scriptVersion
-- permet de stocker les valeurs des périphériques avec "duration_exceeded_" sous /home/pi/domoticz/scripts/dzVents/data/__data_JsonDescription.lua
data = {
managedValue = { history = true, maxItems = 3600, maxHours = 6 },
managedId = { history = true, maxItems = 3600, maxHours = 6 },
execute = function(dz, triggeredItem, info)
local cnt = 0
local now = dz.time
local minute
if string.len(now.min) == 1 then minute = '0'..now.min else minute = now.min end
local Time = now.hour..":"..minute
local dayWeek = dz.time.dayAbbrOfWeek
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
--permet de lire les valeurs des périphériques avec "duration_exceeded_temp", "low_threshold_hr", "high_threshold_hr" ou "duration_exceeded_hr"
local function managed(dz, id, duration_exceeded, high_threshold, low_threshold)
test_high_threshold = true
test_low_threshold = true
x = 0
dz.data.managedId.forEach(
function(item)
x = x + 1
if item.data == id then
timeNotif = tonumber(item.time.minutesAgo)
local value = dz.data.managedValue.get(x)
if timeNotif < duration_exceeded then -- on test si l'ancienneté de la valeur est < à la valeur duration_exceeded_temp
if high_threshold ~= nil then -- si la value est < à la valeur de ref, on passe la variable à false => pas d'envoi de notification
if value.data <= high_threshold then test_high_threshold = false end
if low_threshold ~= nil then -- si la value est > à la valeur de ref, on passe la variable à false => pas d'envoi de notification
if value.data >= low_threshold then test_low_threshold = false end
return test_high_threshold, test_low_threshold
local function split(s, delimiter)
if s ~= nil then
result = {};
for match in (s..delimiter):gmatch("(.-)"..delimiter) do
table.insert(result, match);
result = {""};
return result;
local function notificationTable(str)
--NSS_GOOGLE_CLOUD_MESSAGING, NSS_HTTP, NSS_KODI, NSS_LOGITECH_MEDIASERVER, NSS_NMA,NSS_PROWL, NSS_PUSHALOT, NSS_PUSHBULLET, NSS_PUSHOVER, NSS_PUSHSAFER, NSS_TELEGRAM
if (str) then
str = string.gsub (str,"GCM", dz.NSS_GOOGLE_CLOUD_MESSAGING)
str = string.gsub (str,"GOOGLE_CLOUD_MESSAGING", dz.NSS_GOOGLE_CLOUD_MESSAGING)
str = string.gsub (str,"HTTP", dz.NSS_HTTP)
str = string.gsub (str,"LMS", dz.NSS_LOGITECH_MEDIASERVER)
str = string.gsub (str,"LOGITECH_MEDIASERVER", dz.NSS_LOGITECH_MEDIASERVER)
str = string.gsub (str,"NMA", dz.NSS_NMA)
str = string.gsub (str,"PROWL", dz.NSS_PROWL)
str = string.gsub (str,"PUSHALOT", dz.NSS_PUSHALOT)
str = string.gsub (str,"PUSHOVER", dz.NSS_PUSHOVER)
str = string.gsub (str,"PUSHSAFER", dz.NSS_PUSHSAFER)
str = string.gsub (str,"PUSHBULLET", dz.NSS_PUSHBULLET)
str = string.gsub (str,"TELEGRAM", dz.NSS_TELEGRAM)
return (split(str,','))
-- local function setIcon(device, iconNumber)
-- local url = dz.settings['Domoticz url'] .. '/json.htm?type=setused&used=true&name=' .. dz.utils.urlEncode(device.name) ..
-- '&description=' .. dz.utils.urlEncode(device.description) .. -- Required. If not set it will be blanked out.
-- '&idx=' .. device.id ..
-- '&switchtype=' .. device.switchTypeValue ..
-- '&customimage=' .. iconNumber
-- --logWrite(url)
-- return dz.openURL(url)
-- end
local subject = "\xE2\x9A\xA0 /!\\ Attention /!\\ \xE2\x9A\xA0" -- sujet des notifications
dz.devices().forEach(
function(device)
cnt = cnt + 1
local frequency_notifications = nil
local quiet_hours = nil
local message = nil
local subSystems = nil
local description = device.description
local j = string.find(tostring(description), '^{.*}$')
if description ~= nil and description ~= '' and j ~= nil then
local ok, settings = pcall( dz.utils.fromJSON, description)
if ok and settings then
if settings.subsystems ~= nil then -- systeme(s) de notification
subSystems = settings.subsystems
logWrite('le(s) systeme(s) de notification pour '.. device.name .. ' est(sont) ' .. subSystems)
if settings.frequency_notifications ~= nil then -- fréquence de notification
frequency_notifications = settings.frequency_notifications
dz.log('la fréquence de notification pour '.. device.name .. ' est de ' .. settings.frequency_notifications.." minutes")
if settings.quiet_hours ~= nil then -- période silencieuse
quiet_hours = settings.quiet_hours
logWrite('la période silencieuse de notification pour '.. device.name .. ' est définie entre ' .. quiet_hours)
if settings.auto_off_motion_device ~= nil then --
logWrite(device.name .. ' AutoOff type : ' .. type(settings.auto_off_motion_device))
if type(settings.auto_off_motion_device) == "string" then
logWrite(device.name .. ' est asservie au device : ' .. settings.auto_off_motion_device)
elseif type(settings.auto_off_motion_device) == "table" then
local devices = ""
local types = ""
for i,v in pairs(settings.auto_off_motion_device) do
devices = devices .. v ..", "
types = types .. i ..", "
logWrite(device.name .. ' est asservie aux devices : ' .. devices)
logWrite('de type : ' .. types)
if device.temperature ~= nil and settings.high_threshold_temp ~= nil then -- seuil haut température
logWrite(device.name .. ' a un seuil temperature haute défini à ' .. settings.high_threshold_temp..'°C')
if device.temperature ~= nil and settings.low_threshold_temp ~= nil then -- seuil bas température
logWrite(device.name .. ' a un seuil temperature basse défini à ' .. settings.low_threshold_temp..'°C')
if device.percentage ~= nil and settings.high_threshold_percent ~= nil then -- seuil haut %
logWrite(device.name .. ' a un seuil % haut défini à ' .. settings.high_threshold_percent..'%')
if device.percentage ~= nil and settings.low_threshold_percent ~= nil then -- seuil bas %
logWrite(device.name .. ' a un seuil % bas défini à ' .. settings.low_threshold_percent..'%')
--sensorType
if device.sensorType ~= nil and settings.high_threshold_custom ~= nil then -- seuil haut sensorType
logWrite(device.name .. ' a un seuil haut défini à ' .. settings.high_threshold_custom..' '..device.sensorUnit)
if device.sensorType ~= nil and settings.low_threshold_custom ~= nil then -- seuil bas sensorType
logWrite(device.name .. ' a un seuil bas défini à ' .. settings.low_threshold_custom..' '..device.sensorUnit)
--low_watt_usage
if device.WhActual ~= nil and settings.low_watt_usage ~= nil then -- seuil bas sensorType
logWrite(device.name .. ' a un seuil bas défini à ' .. settings.low_watt_usage..' Wh')
if device.WhActual ~= nil and settings.high_watt_usage ~= nil then -- seuil bas sensorType
logWrite(device.name .. ' a un seuil haut défini à ' .. settings.high_watt_usage..' Wh')
if device.current ~= nil and settings.low_current_usage ~= nil then -- seuil bas sensorType
logWrite(device.name .. ' a un seuil bas défini à ' .. settings.low_current_usage..' A')
if device.current ~= nil and settings.high_current_usage ~= nil then -- seuil bas sensorType
logWrite(device.name .. ' a un seuil haut défini à ' .. settings.high_current_usage..' A')
if device.level ~= nil and settings.dimToLevel ~= nil and settings.dimToHour ~= nil then -- seuil bas sensorType
logWrite(device.name .. ' a un changement de luminosité défini à ' .. settings.dimToLevel..' a '..settings.dimToHour)
if device.state == 'Off' or device.state == 'Close' then -- Alarme dispositif inactif
if settings.time_active_notification ~= nil then
logWrite('Le délai est fixé à '.. settings.time_active_notification.. ' minutes.')
elseif device.state == 'On' or device.state == 'Open' then -- Alarme dispositif actif
if settings.time_inactive_notification ~= nil then
logWrite('Le délai est fixé à '.. settings.time_inactive_notification.. ' minutes.')
-- Alarme dispositif injoignable
if settings.timeout_notification and device.timedOut then
logWrite(device.name .. ' est injoignable. Sa dernière activité remonte à ' .. device.lastUpdate.minutesAgo .. ' minutes.', dz.LOG_INFO)
message = device.name .. ' est injoignable depuis '.. tostring(settings.timeout_notification) ..' minutes'
dz.helpers.managedNotify(dz, subject, message, notificationTable(subSystems), frequency_notifications , quiet_hours)
--batterie
if device.batteryLevel ~= nil and device.batteryLevel ~= 255 and settings.low_battery_level ~= nil then
logWrite('Le niveau de batterie de '.. device.name .. ' est de ' .. device.batteryLevel .. '%', dz.LOG_INFO)
if settings.low_battery_level ~= nil and device.batteryLevel < settings.low_battery_level then -- seuil bas batterie
logWrite(device.name .. ' a un niveau de batterie de ' .. device.batteryLevel..'%', dz.LOG_INFO)
message = 'Le niveau de batterie '.. device.name .. ' est inférieur au seuil défini ('..settings.low_battery_level..'%). Valeur : '..tostring(dz.utils.round(device.batteryLevel, 1)) ..'%'
--logWrite(message, dz.LOG_INFO)
--low_signal_level
if device.signalLevel ~= nil and settings.low_signal_level ~= nil then
logWrite('Le niveau de signal de '.. device.name .. ' est de ' .. device.signalLevel, dz.LOG_INFO)
if settings.low_signal_level ~= nil and device.signalLevel < settings.low_signal_level then -- seuil bas signal
logWrite(device.name .. ' a un niveau de signal de ' .. device.signalLevel, dz.LOG_INFO)
message = 'Le niveau de signal '.. device.name .. ' est inférieur au seuil défini ('..settings.low_signal_level..'). Valeur : '..device.signalLevel
--low_watt_usage
logWrite('Le niveau de puissance de '.. device.name .. ' est de ' .. device.WhActual..' Wh', dz.LOG_INFO)
if settings.low_watt_usage ~= nil and device.WhActual < settings.low_watt_usage then -- seuil bas puissance
logWrite(device.name .. ' a un niveau de puissance de ' .. device.WhActual..' Wh', dz.LOG_INFO)
message = 'Le niveau de puissance '.. device.name .. ' est inférieur au seuil défini ('..settings.low_watt_usage..'). Valeur : '..device.WhActual..' Wh'
if settings.high_watt_usage ~= nil and device.WhActual > settings.high_watt_usage then -- seuil haut puissance
message = 'Le niveau de puissance '.. device.name .. ' est superieur au seuil défini ('..settings.high_watt_usage..'). Valeur : '..device.WhActual..' Wh'
--low_current_usage
logWrite('Le niveau de '.. device.name .. ' est de ' .. tostring(dz.utils.round(device.current, 0))..' A', dz.LOG_INFO)
if settings.low_current_usage ~= nil and device.current < settings.low_current_usage then -- seuil bas intensite
logWrite(device.name .. ' a un niveau de ' .. tostring(dz.utils.round(device.current, 0)), dz.LOG_INFO)
message = 'Le niveau de '.. device.name .. ' est inférieur au seuil défini ('..settings.low_current_usage..'). Valeur : '..tostring(dz.utils.round(device.current, 0))..' A'
--current
if settings.high_current_usage ~= nil and device.current > settings.high_current_usage then -- seuil haut intensite
message = 'Le niveau '.. device.name .. ' est superieur au seuil défini ('..settings.high_current_usage..'). Valeur : '..tostring(dz.utils.round(device.current, 0))..' A'
-- change selector icons
if settings.selectorIcons ~= nil and device.deviceSubType == 'Selector Switch' then --
logWrite(device.name .. ' : deviceType => ' .. tostring(device.deviceType))
logWrite(device.name .. ' : deviceSubType => ' .. tostring(device.deviceSubType))
logWrite(device.name .. ' : Level => ' .. tostring(device.rawData[1]))
--logWrite(device.name .. ' a pour description ' .. tostring(settings.selectorIcons), dz.LOG_INFO)
--for i, v in pairs(settings.selectorIcons) do
--logWrite('le seuil ' .. i .. ' a pour icone ' .. tostring(v), dz.LOG_INFO)
--if device.rawData[1] == i and device.lastUpdate.secondsAgo < 70 then
if device.lastUpdate.secondsAgo < 70 then
device.setIcon(settings.selectorIcons[device.rawData[1]])
logWrite('mise à jour icone ', dz.LOG_INFO)
--end
--dimTo
if device.level ~= nil and settings.dimTo ~= nil then
local dimToLevel
local dimToHour
local silent
local dimDayWeek = true
if type(settings.dimTo) == "table" then
for h, u in pairs(settings.dimTo) do
for i, v in pairs(u) do
if i == "hour" then dimToHour = v
logWrite(device.name .. ' a une heure de variation fixée à : ' .. dimToHour, dz.LOG_INFO)
elseif i == "level" then dimToLevel = v
logWrite(device.name .. ' a une niveau de variation fixée à : ' .. dimToLevel, dz.LOG_INFO)
elseif i == "silent" then silent = v
logWrite(device.name .. ' a un paramètre silent parametré à : ' .. tostring(silent), dz.LOG_INFO)
elseif i == "day" then --"day" : "sun-mon-tue-wed-thu-fri-sat"
--teste si le jour de la semaine correspond au valeur du tableau défini par les jours
testDayWeek = string.find(v, dayWeek)
if testDayWeek == nil then dimDayWeek = false end
logWrite(device.name .. ' a des jours de variation fixés à : ' .. v, dz.LOG_INFO)
if dimDayWeek == true then
if Time == dimToHour and dimToLevel ~= nil and silent == true then
if device.lastUpdate.secondsAgo > 4 then device.dimTo(dimToLevel).silent() return end
elseif Time == dimToHour and dimToLevel ~= nil and silent ~= true then device.dimTo(dimToLevel) return
logWrite(device.name .. ' impossible de traiter la fonction dimTo, manque un élément')
logWrite(device.name .. ' est à l\'état ' .. device.state, dz.LOG_INFO)
if settings.time_inactive_notification ~= nil and device.lastUpdate.minutesAgo >= settings.time_inactive_notification then
logWrite(device.name .. ' est inactif depuis ' .. device.lastUpdate.minutesAgo .. ' minutes. Le délai est fixé à '.. settings.time_inactive_notification.. ' minutes.', dz.LOG_INFO)
message = 'Le délai d\'inactivité fixé à '.. settings.time_inactive_notification .. ' minutes pour '.. device.name .. ' est dépassé'
elseif device.temperature ~= nil or device.humidity ~= nil then
-- Alarme température
if device.temperature ~= nil and (settings.low_threshold_temp ~= nil or settings.high_threshold_temp ~= nil) then
--test settings.duration_exceeded_temp
if settings.duration_exceeded_temp ~= nil then
dz.data.managedValue.add(dz.utils.round(device.temperature, 2))
dz.data.managedId.add(device.id)
if settings.high_threshold_temp ~= nil then high_threshold_temp = settings.high_threshold_temp else high_threshold_temp = nil end
if settings.low_threshold_temp ~= nil then low_threshold_temp = settings.low_threshold_temp else low_threshold_temp = nil end
test_high_threshold, test_low_threshold = managed(dz, device.id, settings.duration_exceeded_temp, high_threshold_temp, low_threshold_temp)
logWrite('La température mesurée par '.. device.name .. ' est de ' .. tostring(dz.utils.round(device.temperature, 1)) ..'°C', dz.LOG_INFO)
if settings.low_threshold_temp ~= nil and device.temperature < settings.low_threshold_temp and test_low_threshold == true then -- seuil bas température
logWrite(device.name .. ' a un seuil temperature basse défini à ' .. settings.low_threshold_temp..'°C', dz.LOG_INFO)
message = 'La température mesurée par '.. device.name .. ' est inférieure au seuil défini ('..settings.low_threshold_temp..'°C)' --. Valeur : '..tostring(dz.utils.round(device.temperature, 1)) ..'°C'
dz.data.managedValue.add(settings.low_threshold_temp)
if settings.high_threshold_temp ~= nil and device.temperature > settings.high_threshold_temp and test_high_threshold == true then -- seuil haut température
logWrite(device.name .. ' a un seuil temperature haute défini à ' .. settings.high_threshold_temp..'°C', dz.LOG_INFO)
message = 'La température mesurée par '.. device.name ..' est supérieure au seuil défini ('..settings.high_threshold_temp..'°C)' --. Valeur : '..tostring(dz.utils.round(device.temperature, 1)) ..'°C'
dz.data.managedValue.add(settings.high_threshold_temp)
-- alarme hygrométrie
if device.humidity ~= nil and (settings.low_threshold_hr ~= nil or settings.high_threshold_hr ~= nil) then
--test settings.duration_exceeded_hr
if settings.duration_exceeded_hr ~= nil then
dz.data.managedValue.add(device.humidity)
if settings.high_threshold_hr ~= nil then high_threshold_hr = settings.high_threshold_hr else high_threshold_hr = nil end
if settings.low_threshold_hr ~= nil then low_threshold_hr = settings.low_threshold_hr else low_threshold_hr = nil end
test_high_threshold, test_low_threshold = managed(dz, device.id, settings.duration_exceeded_hr, high_threshold_hr, low_threshold_hr)
logWrite('L\'hygrometrie mesurée par '.. device.name .. ' est de ' .. tostring(device.humidity)..'%hr', dz.LOG_INFO)
if settings.low_threshold_hr ~= nil and device.humidity < settings.low_threshold_hr and test_low_threshold == true then -- seuil bas hygrométrie
logWrite(device.name .. ' a un seuil hygrometrie bassse défini à ' .. settings.low_threshold_hr..'%hr', dz.LOG_INFO)
message = 'L\'humidité mesurée par '.. device.name .. ' est inférieure au seuil défini ('..settings.low_threshold_hr..'%hr).' -- Valeur : '..tostring(device.humidity)..'%hr'
dz.data.managedValue.add(settings.low_threshold_hr)
if settings.high_threshold_hr and device.humidity > settings.high_threshold_hr and test_high_threshold == true then -- seuil haut hygrométrie
logWrite(device.name .. ' a un seuil hygrometrie haute défini à ' .. settings.high_threshold_hr..'%hr', dz.LOG_INFO)
message = 'L\'humidité mesurée par '.. device.name .. ' est supérieure au seuil défini ('..settings.high_threshold_hr..'%hr).' -- Valeur : '..tostring(device.humidity)..'%hr'
dz.data.managedValue.add(settings.high_threshold_hr)
if settings.time_active_notification ~= nil and device.lastUpdate.minutesAgo >= settings.time_active_notification then
logWrite(device.name .. ' est actif depuis ' .. device.lastUpdate.minutesAgo .. ' minutes. Le délai est fixé à '.. settings.time_active_notification.. ' minutes.', dz.LOG_INFO)
message = 'Le délai fixé à '.. settings.time_active_notification .. ' minutes pour '.. device.name .. ' est dépassé'
-- auto on
if settings.auto_on_minutes ~= nil and device.lastUpdate.minutesAgo >= settings.auto_on_minutes then
if settings.state == 'Off' then
logWrite('Allumage de '..device.name .. ' car inactif depuis ' .. settings.auto_on_minutes .. ' minutes.', dz.LOG_INFO)
device.switchOn()
--auto off
if settings.auto_off_minutes ~= nil and device.lastUpdate.minutesAgo >= settings.auto_off_minutes then
if settings.auto_off_motion_device == nil then
logWrite('Extinction de '..device.name .. ' car actif depuis ' .. settings.auto_off_minutes .. ' minutes.', dz.LOG_INFO)
device.switchOff()
elseif type(settings.auto_off_motion_device) == "string" then
local motion_device = dz.devices(settings.auto_off_motion_device)
if motion_device.state == 'Off' then
logWrite('Extinction de '.. device.name .. ' car aucune détection de mouvement dans la piece depuis ' .. settings.auto_off_minutes .. ' minutes.', dz.LOG_INFO)
device.switchOff()
local off = true
--logWrite("l'état de " .. dz.devices(v) .. ' est à : ' .. dz.devices(v).state)
if dz.devices(v).state ~= 'Off' and i == "restartTimer" and dz.devices(v).lastUpdate.minutesAgo >= settings.auto_off_minutes then
off = false
elseif dz.devices(v).state ~= 'Off' and i ~= "restartTimer" then
off = false
if off then
device.switchOff()
elseif device.sensorType ~= nil and (settings.high_threshold_custom ~= nil or settings.low_threshold_custom ~= nil) then
--alarme custom sensor
logWrite('La valeur mesurée par '.. device.name .. ' est de ' .. tostring(dz.utils.round(device.state, 1)) .. device.sensorUnit, dz.LOG_INFO)
if settings.low_threshold_custom ~= nil and tonumber(device.state) < settings.low_threshold_custom then -- seuil bas %
logWrite(device.name .. ' a un seuil bas défini à ' .. settings.low_threshold_custom..device.sensorUnit, dz.LOG_INFO)
message = 'La valeur mesurée par '.. device.name .. ' est inférieure au seuil défini ('..settings.low_threshold_custom..device.sensorUnit..').' -- Valeur : '..tostring(dz.utils.round(device.state, 1))..device.sensorUnit
if settings.high_threshold_custom ~= nil and tonumber(device.state) > settings.high_threshold_custom then -- seuil haut %
logWrite(device.name .. ' a un seuil haut défini à ' .. settings.high_threshold_custom..device.sensorUnit, dz.LOG_INFO)
message = 'La valeur mesurée par '.. device.name ..' est supérieure au seuil défini ('..settings.high_threshold_custom..device.sensorUnit..').' -- Valeur : '..tostring(dz.utils.round(device.state, 1))..device.sensorUnit
elseif device.percentage ~= nil and (settings.high_threshold_percent ~= nil or settings.low_threshold_percent ~= nil) then
-- test settings.duration_exceeded_hr
if settings.duration_exceeded_percent ~= nil then
dz.data.managedValue.add(device.percentage)
if settings.high_threshold_percent ~= nil then high_threshold_percent = settings.high_threshold_percent else high_threshold_percent = nil end
if settings.low_threshold_percent ~= nil then low_threshold_percent = settings.low_threshold_percent else low_threshold_percent = nil end
test_high_threshold, test_low_threshold = managed(dz, device.id, settings.duration_exceeded_percent, high_threshold_percent, low_threshold_percent)
-- alarme pourcentage
logWrite('La valeur mesurée par '.. device.name .. ' est de ' .. tostring(dz.utils.round(device.percentage, 1)) ..'%', dz.LOG_INFO)
if settings.low_threshold_percent ~= nil and device.percentage < settings.low_threshold_percent and test_low_threshold == true then -- seuil bas %
logWrite(device.name .. ' a un seuil % bas défini à ' .. settings.low_threshold_percent..'%', dz.LOG_INFO)
message = 'La valeur mesurée par '.. device.name .. ' est inférieure au seuil défini ('..settings.low_threshold_percent..'%).' -- Valeur : '.. tostring(dz.utils.round(device.percentage, 1)) ..'%'
dz.data.managedValue.add(settings.low_threshold_percent)
if settings.high_threshold_percent ~= nil and device.percentage > settings.high_threshold_percent and test_high_threshold == true then -- seuil haut %
logWrite(device.name .. ' a un seuil % haut défini à ' .. settings.high_threshold_percent..'%', dz.LOG_INFO)
message = 'La valeur mesurée par '.. device.name ..' est supérieure au seuil défini ('..settings.high_threshold_percent..'%).' -- Valeur : '.. tostring(dz.utils.round(device.percentage, 1)) ..'%'
dz.data.managedValue.add(settings.high_threshold_percent)
elseif device.color ~= nil and settings.high_threshold_color ~= nil and device.color > settings.high_threshold_color then
-- notification alerte
logWrite('Le seuil d\'alerte de '.. device.name .. ' est de ' .. tostring(device.color), dz.LOG_INFO)
message = 'Le seuil d\'alerte de '.. device.name ..' est supérieur au seuil défini ('..settings.high_threshold_color..'). Valeur : '.. tostring(device.color) ..' alerte : '.. tostring(device.text)
logWrite( 'la description de '.. device.name ..' n\'est pas au format json. Ignorer cet appareil.', dz.LOG_ERROR)
logWrite('--------------------------------------------------------------------------------------------------', dz.LOG_INFO)
logWrite(tostring(cnt) .. ' devices scannés.', dz.LOG_INFO)
