J'ai installé une zigate sur mon micro ordinateur Windows 10. J'ai reussi a faire communiquer un objet avec via leur application.
Sur domoticz, python est bien reconnu, le plugin est bien installé, je le trouve dans ma liste hardware.
Mais lorsque je veux le connecter, impossible de le reconnaitre car il y a des erreurs avec le plugins.
Voici les logs :
2019-09-22 23:24:14.269 Status: (ZIGATE) Started.
2019-09-22 23:24:17.390 (ZIGATE) Debug: -1
2019-09-22 23:24:17.386 Status: (ZIGATE) Initialized version 4.5, author 'zaraki673 pipiche38'
2019-09-22 23:24:17.387 Status: (ZIGATE) Entering work loop.
2019-09-22 23:24:17.390 Status: (ZIGATE) Zigate plugin stable-4.5.4 started
2019-09-22 23:24:17.391 Status: (ZIGATE) Python Version - 3.5.2 (v3.5.2:4def2a2901a5, Jun 25 2016, 22:01:18) [MSC v.1900 32 bit (Intel)]
2019-09-22 23:24:17.391 Status: (ZIGATE) Switching Heartbeat to 5 s interval
2019-09-22 23:24:17.391 Status: (ZIGATE) DomoticzVersion: 4.10717
2019-09-22 23:24:17.391 Status: (ZIGATE) DomoticzHash: b38b49e5
2019-09-22 23:24:17.391 Status: (ZIGATE) DomoticzBuildTime: 2019-05-09 13:04:08
2019-09-22 23:24:17.392 Status: (ZIGATE) load PluginConf
2019-09-22 23:24:17.400 Status: (ZIGATE) homedirectory set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\
2019-09-22 23:24:17.400 Status: (ZIGATE) filename set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-07.json
2019-09-22 23:24:17.400 Status: (ZIGATE) pluginConfig set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Conf/
2019-09-22 23:24:17.401 Status: (ZIGATE) pluginOTAFirmware set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2019-09-22 23:24:17.401 Status: (ZIGATE) pluginWWW set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\www/
2019-09-22 23:24:17.401 Status: (ZIGATE) pluginData set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Data/
2019-09-22 23:24:17.401 Status: (ZIGATE) pluginHome set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\
2019-09-22 23:24:17.401 Status: (ZIGATE) pluginReports set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Reports/
2019-09-22 23:24:17.402 Status: (ZIGATE) Opening DomoticzDB in raw
2019-09-22 23:24:17.461 Status: (ZIGATE) Plugin Database: DeviceList-7.txt
2019-09-22 23:24:17.488 Status: (ZIGATE) DeviceConf loaded
2019-09-22 23:24:17.488 Status: (ZIGATE) load ListOfDevice
2019-09-22 23:24:17.489 Status: (ZIGATE) Transport mode: USB
2019-09-22 23:24:17.490 Status: (ZIGATE) Connection Name: Zigate, Transport: Serial, Address: COM4
2019-09-22 23:24:17.490 Error: (ZIGATE) 'onStart' failed 'AttributeError':''NoneType' object has no attribute 'Connect''.
2019-09-22 23:24:17.490 Error: (ZIGATE) ----> Line 781 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\plugin.py', function onStart
2019-09-22 23:24:17.490 Error: (ZIGATE) ----> Line 313 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\plugin.py', function onStart
2019-09-22 23:24:17.490 Error: (ZIGATE) ----> Line 123 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Classes\Transport.py', function openConn
2019-09-22 23:24:27.407 (ZIGATE) No Firmware Version received from Zigate
2019-09-22 23:24:32.548 Error: (ZIGATE) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'Send''.
2019-09-22 23:24:32.548 Error: (ZIGATE) ----> Line 809 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\plugin.py', function onHeartbeat
2019-09-22 23:24:32.548 Error: (ZIGATE) ----> Line 552 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\plugin.py', function onHeartbeat
2019-09-22 23:24:32.548 Error: (ZIGATE) ----> Line 84 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Modules\output.py', function sendZigateCmd
2019-09-22 23:24:32.548 Error: (ZIGATE) ----> Line 348 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Classes\Transport.py', function sendData
2019-09-22 23:24:32.548 Error: (ZIGATE) ----> Line 177 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Classes\Transport.py', function _sendData
2019-09-22 23:24:37.552 (ZIGATE) No Firmware Version received from Zigate
2019-09-22 23:24:42.621 (ZIGATE) No Firmware Version received from Zigate
2019-09-22 23:24:42.621 (ZIGATE) Try to get Firmware version once more HB:4
2019-09-22 23:24:47.646 (ZIGATE) setTimeServer - Setting UTC Time to : 622509887
2019-09-22 23:24:47.646 Status: (ZIGATE) ZigateConf setting Channel(s) to: 0
2019-09-22 23:24:47.646 Status: (ZIGATE) setChannel - Channel set to : 00000000
2019-09-22 23:24:47.646 Status: (ZIGATE) Set Zigate as a Coordinator
2019-09-22 23:24:47.646 Status: (ZIGATE) Start network
2019-09-22 23:24:52.745 (ZIGATE) No Firmware Version received from Zigate
si vous avez des idées c'est top.
J'ai tenté la mis a jour du zigate, la mise a jour du plugin plusieurs fois... je ne comprends pas.
Zigate plugin - Windows
Re: Zigate plugin - Windows
ce sujet venant d'être déplacé dans la bonne section,
je le remonte au cas où il était passé inaperçu.
Pouvez-vous récupérer une version récente du plugin.
Sur la branche stable (default ) la version est la 4.7.8
Il est possible que le problème soit réglé ....
Wiki ici
chat sur Keybase.io
Wiki ici
chat sur Keybase.io
