Plus rien qui marche
Wolfen38
Message par Wolfen38 »
Tout allait bien jusqu'a ce soir, puis ca a commencé à merder.
J'ai reboot mon raspberry, et depuis la zigate est en carafe....
J'ai ca comme log :
2020-04-02 20:29:29.881 Error: (Zigate) ----> Line 130 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2020-04-02 20:29:29.881 Error: (Zigate) ----> Line 367 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function sendData
2020-04-02 20:29:29.881 Error: (Zigate) ----> Line 196 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function _sendData
2020-04-02 20:29:34.890 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:29:39.899 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:29:39.900 (Zigate) Try to get Firmware version once more HB:4
2020-04-02 20:29:44.911 Status: (Zigate) ZigateConf setting Channel(s) to: 0
2020-04-02 20:29:44.911 Status: (Zigate) setChannel - Channel set to : 00000000
2020-04-02 20:29:44.912 Status: (Zigate) Set Zigate as a Coordinator
2020-04-02 20:29:44.912 Status: (Zigate) Set Zigate as a TimeServer
2020-04-02 20:29:44.912 Status: (Zigate) Start network
2020-04-02 20:29:46.098 (Gateway) Lux (Lux palier)
2020-04-02 20:29:46.128 (Gateway) Lux (Lux palier)
2020-04-02 20:29:49.885 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:29:54.894 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:29:59.905 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:29:59.905 (Zigate) Try to get Firmware version once more HB:8
2020-04-02 20:30:01.238 (Virtualsensor) Light/Switch (Prise sapin)
2020-04-02 20:30:01.225 Status: Schedule item started! Name: Prise sapin, Type: On Time, DevID: 324, Time: 2020-04-02 20:30:01
2020-04-02 20:30:04.888 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:04.586 Status: Notification sent (Email)
2020-04-02 20:30:09.896 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:14.907 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:14.907 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:14.907 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:14.907 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:14.907 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:19.916 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:19.916 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:19.916 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:19.916 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:19.917 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:24.875 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:24.875 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:24.875 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:24.875 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:24.875 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:29.887 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:29.887 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:29.887 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:29.887 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:29.887 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:34.897 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:34.897 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:34.897 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:34.897 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:34.897 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:39.907 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:39.907 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:39.907 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:39.907 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:39.907 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:42.280 Activating Scene/Group: [Lumiere SDB matin]
2020-04-02 20:30:42.285 Activating Scene/Group Device: Ampoule SDB (Off)
2020-04-02 20:30:42.522 (Ampoule) Color Switch (Ampoule SDB)
2020-04-02 20:30:42.592 Activating Scene/Group: [Plafonnier SDB]
2020-04-02 20:30:42.597 Activating Scene/Group Device: Plafonnier SDB (Off)
2020-04-02 20:30:42.689 (Ampoule) Color Switch (Plafonnier SDB)
2020-04-02 20:30:44.923 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:44.923 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:44.923 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:44.923 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:44.923 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:49.892 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:49.892 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:49.892 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:49.892 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:49.892 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:54.902 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:54.902 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:54.902 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:54.902 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:54.902 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:30:59.912 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:30:59.912 Error: (Zigate) Plugin is not started ...
2020-04-02 20:30:59.912 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:30:59.913 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:30:59.913 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:31:01.106 (Gateway) Light/Switch (Detecteur SDB)
2020-04-02 20:31:01.409 Activating Scene/Group: [Plafonnier SDB]
2020-04-02 20:31:01.416 Activating Scene/Group Device: Plafonnier SDB (On)
2020-04-02 20:31:01.596 (Ampoule) Color Switch (Plafonnier SDB)
2020-04-02 20:31:01.389 Status: LUA: Plafonnier lune pour 2 min
2020-04-02 20:31:01.390 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_sdb.lua
2020-04-02 20:31:03.365 Status: Notification sent (Email)
2020-04-02 20:31:04.923 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:31:04.923 Error: (Zigate) Plugin is not started ...
2020-04-02 20:31:04.924 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:31:04.924 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:31:04.924 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:31:09.933 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:31:09.933 Error: (Zigate) Plugin is not started ...
2020-04-02 20:31:09.933 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:31:09.933 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:31:09.933 Error: (Zigate) - unplug/plug the zigate
2020-04-02 20:31:14.910 (Zigate) No Firmware Version received from Zigate
2020-04-02 20:31:14.910 Error: (Zigate) Plugin is not started ...
2020-04-02 20:31:14.910 Error: (Zigate) - Communication issue with the Zigate
2020-04-02 20:31:14.910 Error: (Zigate) - restart once the plugin, and if this remain the same
2020-04-02 20:31:14.910 Error: (Zigate) - unplug/plug the zigate
pipiche
Re: Plus rien qui marche
Message par pipiche »
Vérifies si la zigate n’est pas sur une autre port TTY
A priori le plugin n’arrive pas à y acceder
Wiki ici
chat sur Keybase.io
Wolfen38
C'est a dire un port TTY ? C'est quoi ?
Comme demandé dans les log j'ai débranché et re brancher la zigate sur le même port USB mais ça ne change rien
pipiche
Le port série qui permet de communiquer avec la zigate
Wiki ici
chat sur Keybase.io
Wolfen38
Je ne sais pas comment faire ça.. faut regarder ou ?
Wolfen38
Ok c'est bon j'ai trouvé dans les paramètres... Mais je comprends pas pourquoi ça a sauté tout seul
Wolfen38
Part contre j'ai plus aucun device qui se re connecte, ils sont tous en indéfini...'on verra demain si ça revient dans la nuit
Wolfen38
Au final ce matin, mes 6 volets sont perdus, mes prises ikea sont ok, tous les dispositifs sur pile sont en indéfini.
En gros, y a plus rien qui marche quasiment.... Alors qu'hier tout allait bien, aucune mise a jour, rien.
Pour les volets, j'ai ca :
2020-04-03 07:43:53.722 (Zigate) Receive NACK from Volet parent (82f0) clusterId: 0102
Et pour les devices indéfinis, j'ai rien dans les logs.
Version plugin : Version plugin: 4.7.008
Wolfen38
Comme les devices ne revenaient pas, j'ai refait les appairages, au début ca marchait, puis les derniers ont bloqué.
L'appairage semblait ok
2020-04-03 08:36:43.069 Status: (Zigate) Device Announcement Addr: 5688, IEEE: 00158d00019ca979 Join Flag: 0x00 - join a network through association RSSI: 0
2020-04-03 08:36:43.069 Status: (Zigate) NetworkID : 5688 is replacing 6701 and is attached to IEEE : 00158d00019ca979
Mais au final le device ne réagissait pas.
Donc je l'ai supprimé
2020-04-03 08:38:11.813 Status: (Zigate) onDeviceRemoved - removing End Device
2020-04-03 08:38:11.866 Status: (Zigate) Device Interrupteur chambre2 with IEEE: 00158d00019ca979 fully removed from the system.
2020-04-03 08:38:11.866 Status: (Zigate) onDeviceRemoved - device entry 00158d00019ca979 from Zigate not removed. You need to enable 'allowRemoveZigateDevice' parameter. Do consider that it works only for main powered devices.
Puis remis, mais ca ne veut pas
2020-04-03 08:38:33.540 (Zigate) --> Adding device ead7 in self.DevicesInPairingMode
2020-04-03 08:38:33.540 (Zigate) --> ['ead7']
2020-04-03 08:38:33.539 Status: (Zigate) Device Announcement Addr: ead7, IEEE: 00158d00019ca979 Join Flag: 0x00 - join a network through association RSSI: 0
2020-04-03 08:38:37.669 (Gateway) General/kWh (Prise Xiaomi)
2020-04-03 08:38:47.834 Status: (Zigate) [0] NEW OBJECT: ead7 TimeOut in 0045 restarting at 0x004d
2020-04-03 08:39:02.861 Status: (Zigate) [1] NEW OBJECT: ead7 TimeOut in 0045 restarting at 0x004d
2020-04-03 08:39:17.839 Status: (Zigate) [2] NEW OBJECT: ead7 TimeOut in 0045 restarting at 0x004d
2020-04-03 08:39:32.866 Status: (Zigate) [3] NEW OBJECT: ead7 TimeOut in 0045 restarting at 0x004d
2020-04-03 08:39:47.843 Status: (Zigate) [4] NEW OBJECT: ead7 TimeOut in 0045 restarting at 0x004d
2020-04-03 08:39:52.872 Error: (Zigate) [5] NEW OBJECT: ead7 Not able to get all needed attributes on time
2020-04-03 08:39:52.873 Error: (Zigate) processNotinDB - not able to find response from ead7 stop process at 0045
2020-04-03 08:39:52.873 Error: (Zigate) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model:
2020-04-03 08:39:52.873 Error: (Zigate) processNotinDB - Collected Infos are : {'ProfileID': {}, 'Status': 'UNKNOW', 'Model': '', 'ReadAttributes': {'TimeStamps': {'06-0000': 1585895913, '09-0000': 1585895913, '03-0000': 1585895913, '02-0000': 1585895913, '01-0000': 1585895913}, 'Ep': {'03': {'0000': {}}, '09': {'0000': {}}, '06': {'0000': {}}, '01': {'0000': {}}, '02': {'0000': {}}}}, 'RIA': '5', 'RSSI': {}, 'PowerSource': '', 'Attributes List': {}, 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'DeviceType': 'RFD', 'LogicalType': 'End Device', 'Health': 'Live', 'Stamp': {'LastSeen': 1585895913, 'MsgType': '8011', 'Time': '2020-04-03 08:38:40'}, 'App Version': '', 'NbEp': '', 'ZCL Version': '', 'IEEE': '00158d00019ca979', 'Manufacturer Name': '', 'ZDeviceID': {}, 'ConsistencyCheck': 'Bad Pairing', 'ReceiveOnIdle': '', 'MacCapa': '80', 'Announced': 1585895913.539535, 'SQN': '', 'Last Cmds': [(1585895913.5425935, '0100', None), (1585895913.648672, '0100', None), (1585895913.7514377, '0100', None), (1585895913.8542202, '0100', None), (1585895913.9569404, '0100', None)], 'Type': {}, 'HW Version': '', 'Version': '3', 'Manufacturer': '', 'ZDeviceName': '', 'Battery': {}, 'Ep': {}, 'Stack Version': '', 'Heartbeat': '1'}
