2020-08-09 17:27:37.302 Sunrise: 06:58:00 SunSet: 21:18:00
2020-08-09 17:27:37.302 Day length: 14:20:00 Sun at south: 14:08:00
2020-08-09 17:27:37.302 Civil twilight start: 06:26:00 Civil twilight end: 21:50:00
2020-08-09 17:27:37.305 Nautical twilight start: 05:45:00 Nautical twilight end: 22:30:00
2020-08-09 17:27:37.305 Astronomical twilight start: 05:00:00 Astronomical twilight end: 23:16:00
2020-08-09 17:27:38.035 Active notification Subsystems: email (1/13)
2020-08-09 17:27:38.185 Starting shared server on: 0.0.0.0:6144
2020-08-09 17:27:46.038 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2020-08-09 17:27:48.445 (Zigate) DomoticzVersion: 2020.1
2020-08-09 17:29:07.274 (Zigate) DomoticzVersion: 2020.1
2020-08-09 17:29:13.863 (Zigate) DomoticzVersion: 2020.1
2020-08-09 17:29:14.964 (Zigate) DomoticzVersion: 2020.1
2020-08-09 17:29:14.060 Status: (Zigate) Transport mode: USB
2020-08-09 17:29:14.062 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2020-08-09 17:29:14.062 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyUSB0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-08-09 17:29:14.284 Status: (Zigate) Stop directive received.
2020-08-09 17:29:14.285 Status: (Zigate) Exiting work loop.
2020-08-09 17:29:14.334 Status: (Zigate) onStop called
2020-08-09 17:29:14.487 Status: (Zigate) Stopping threads.
2020-08-09 17:29:14.487 Status: (Zigate) Stopped.
2020-08-09 17:29:14.488 Status: (Zigate) Started.
2020-08-09 17:29:14.935 Status: (Zigate) Entering work loop.
2020-08-09 17:29:14.936 Status: (Zigate) Initialized version 4.9, author 'zaraki673 pipiche38'
2020-08-09 17:29:14.964 Status: (Zigate) Zigate plugin stable-4.9.004 started
2020-08-09 17:29:14.964 Status: (Zigate) Debug: 0
2020-08-09 17:29:14.964 Status: (Zigate) load PluginConf
2020-08-09 17:29:14.967 Status: (Zigate) enableAPSFailureReporting set to 0
2020-08-09 17:29:14.967 Status: (Zigate) channel set to 11
2020-08-09 17:29:14.968 Status: (Zigate) port set to 8084
2020-08-09 17:29:14.968 Status: (Zigate) pluginHome set to /usr/local/domoticz/var/plugins/Zigate/
2020-08-09 17:29:14.968 Status: (Zigate) pluginReports set to /usr/local/domoticz/var/plugins/Zigate/Reports/
2020-08-09 17:29:14.968 Status: (Zigate) pluginData set to /usr/local/domoticz/var/plugins/Zigate/Data/
2020-08-09 17:29:14.968 Status: (Zigate) pluginConfig set to /usr/local/domoticz/var/plugins/Zigate/Conf/
2020-08-09 17:29:14.968 Status: (Zigate) pluginLogs set to /usr/local/domoticz/var/plugins/Zigate/Logs/
2020-08-09 17:29:14.968 Status: (Zigate) homedirectory set to /usr/local/domoticz/var/plugins/Zigate/
2020-08-09 17:29:14.968 Status: (Zigate) filename set to /usr/local/domoticz/var/plugins/Zigate/Conf/PluginConf-05.json
2020-08-09 17:29:14.968 Status: (Zigate) pluginWWW set to /usr/local/domoticz/var/plugins/Zigate/www/
2020-08-09 17:29:14.969 Status: (Zigate) pluginOTAFirmware set to /usr/local/domoticz/var/plugins/Zigate/OTAFirmware/
2020-08-09 17:29:14.969 Status: (Zigate) Switching Heartbeat to 5 s interval
2020-08-09 17:29:14.969 Status: (Zigate) Python Version - 3.5.1 (default, Jan 29 2018, 14:18:59)
2020-08-09 17:29:14.969 [GCC 4.9.3 20150311 (prerelease)]
2020-08-09 17:29:14.969 Status: (Zigate) DomoticzVersion: 2020.1
2020-08-09 17:29:14.970 Status: (Zigate) DomoticzHash: 0
2020-08-09 17:29:14.970 Status: (Zigate) DomoticzBuildTime: 1970-01-01 01:00:00
2020-08-09 17:29:14.970 Status: (Zigate) Opening DomoticzDB in raw
2020-08-09 17:29:15.044 Status: (Zigate) Plugin Database: DeviceList-5.txt
2020-08-09 17:29:15.052 Status: (Zigate) DeviceConf loaded
2020-08-09 17:29:15.151 Status: (Zigate) --> Config loaded: dict_keys(['lumi.sensor_natgas', 'LIGHTIFY Indoor Flex RGBW', 'LCT024', 'lumi.sensor_switch', 'lumi.remote.b686opcn01-bulb', 'Plug Z3', 'GLEDOPTO', 'TRADFRI remote control', 'BSO-Profalux', 'lumi.sensor_motion.aq2', 'lumi.ctrl_neutral2', 'TRADFRI control outlet', 'lumi.remote.b286acn01', 'LLC010', 'TRADFRI bulb E27 WW clear 250lm', 'EH-ZB-HACT', 'LTW004', 'lumi.ctrl_ln2.aq1', 'lumi.sensor_cube.aqgl01', 'Volet-Profalux', 'Thermostat', 'lumi.ctrl_neutral1', 'Cable outlet', 'Lightify Switch Mini', 'GL-D-003Z', 'lumi.light.aqcn02', 'GL-FL-004TZS', 'Double gangs remote switch', 'lumi.ctrl_86plug.aq1', 'GL-C-008S', 'VoletBSO-Profalux', 'lumi.plug.mmeu01', 'Mobile outlet', 'Pluzzy-TH', 'TRADFRI bulb E14 WS 470lm', '902010/22', 'TRADFRI bulb E14 W opch 400lm', 'GAS_V15', 'lumi.sensor_magnet.aq2', 'lumi.sensor_ht', 'Plug 01', 'lumi.weather', 'TRADFRI bulb E26 WS clear 950lm', 'EH-ZB-BMS', '902010/28', 'TRADFRI bulb E14 WS opal 600lm', 'TRADFRI onoff switch', 'TRADFRI bulb GU10 W 400lm', 'GL-MC-001', 'LXN56-DC27LX1.1', 'Pluzzy-Motion', 'ZPLUG', 'TRADFRI wireless dimmer', 'lumi.remote.b686opcn01', 'lumi.remote.b486opcn01-bulb', 'TRADFRI bulb E27 WS opal 950lm', '3AFE170100510001', 'GL-C-008', 'lumi.remote.b286opcn01-bulb', 'LCT007', 'EH-ZB-SPD-V2', 'Connected outlet', 'EH-ZB-LMACT', 'Shutter switch with neutral', 'lumi.relay.c2acn01', 'lumi.sensor_magnet', 'EH-ZB-RTS', '3c4e4fc81ed442efaf69353effcdfc5f', 'SAL6ET1', 'LTC001', 'TS0013', 'EH-ZB-VACT', 'EH-ZB-SPD', 'lumi.sensor_switch.aq2', 'Lamp_01', 'PST03A-v2.2.5', 'Remote switch', 'TRADFRI motion sensor', 'lumi.sensor_86sw2', 'LST002', 'TS0302', 'FLOALT panel WS 60x60', 'lumi.router', 'SPZB0001', 'TRADFRI bulb E12 WS opal 400lm', 'Shutters central remote switch', 'TRADFRI bulb E27 CWS opal 600lm', 'Pluzzy-Plug', 'lumi.remote.b1acn01', 'ZHA-CSW', 'lumi.sensor_86sw1', 'TRADFRI bulb GU10 WS 400lm', '3AFE140103020000', 'GL-C-009', 'LWB006', 'lumi.sensor_wleak.aq1', 'CLA60 TW OSRAM', 'Micromodule switch', 'lumi.remote.b486opcn01', 'TI0001', 'FB56-ZCW08KU1.1', 'lumi.sen_ill.mgl01', 'RC 110', 'TS0001', 'RWL021', 'TS0003', 'TS0002', 'LCT001', 'LCT003', 'TS0011', 'lumi.ctrl_ln2', 'TRADFRI bulb E27 W opal 1000lm', 'lumi.sensor_smoke', 'lumi.vibration.aq1', 'ZMOVE', 'COSensor-N', 'TRADFRI bulb E27 WS opal 980lm', 'SMOK_V16', 'RB 248 T', 'ZHUM', 'SPE600', 'lumi.sensor_switch.aq3', 'lumi.remote.b286opcn01', 'SmokeSensor-N', 'ZBT-ExtendedColor', 'RB 285 C', 'SmokeSensor-N-3.0', 'Pluzzy-Door', 'lumi.plug', 'LTW013', 'TRADFRI bulb E26 WS opal 980lm', 'GL-B-008Z', 'lumi.remote.b186acn01', 'Super TR', 'GL-B-007Z', '3AFE28010402000D', 'LTW001', 'PAR16 50 TW', 'TRADFRI bulb E27 opal 1000lm', '902010/21A', 'WarningDevice', 'TRADFRI bulb E27 WS clear 950lm', 'RH3001', 'lumi.sensor_cube', 'DIN power consumption module', 'GL-C-008Z', 'TS0012', 'TRADFRI Driver 30W', 'lumi.sensor_motion', '3AFE130104020015', 'SML002', 'lumi.ctrl_86plug', 'LCT010', 'SML001', 'TRV10RFM', 'TRADFRI bulb E14 WS opal 400lm', 'Dimmer switch wo neutral', 'LCT015', 'LTA001', 'TS0201', 'TRADFRI bulb E27 WS opal 1000lm', 'Telecommande-Profalux', 'FLOALT panel WS 30x90', 'TRADFRI Signal Repeater', 'LIGHTIFY Outdoor Flex RGBW', 'Zigate-Router', '3AFE14010402000D'])
2020-08-09 17:29:15.151 Status: (Zigate) load ListOfDevice
2020-08-09 17:29:15.186 Status: (Zigate) Entries loaded from /usr/local/domoticz/var/plugins/Zigate/Data/DeviceList-5.txt
2020-08-09 17:29:15.194 Status: (Zigate) Transport mode: USB
2020-08-09 17:29:15.196 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2020-08-09 17:29:15.197 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyUSB0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-08-09 17:29:25.082 Status: (Zigate) Major Version Num: 0003
2020-08-09 17:29:25.083 Status: (Zigate) Installer Version Number: 031c
2020-08-09 17:29:45.433 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2020-08-09 17:29:45.439 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2020-08-09 17:31:01.232 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2020-08-09 17:31:01.238 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2020-08-09 17:32:06.120 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2020-08-09 17:32:06.129 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2020-08-09 17:32:26.084 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2020-08-09 17:32:26.092 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2020-08-09 17:32:38.064 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2020-08-09 17:32:38.073 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2020-08-09 17:34:21.373 Status: (Zigate) Stop directive received.
2020-08-09 17:34:21.374 Status: (Zigate) Exiting work loop.
2020-08-09 17:34:21.401 Status: (Zigate) onStop called
2020-08-09 17:34:21.426 Status: (Zigate) Statistics on message
2020-08-09 17:34:21.426 Status: (Zigate) Sent:
2020-08-09 17:34:21.426 Status: (Zigate) TX commands : 59
2020-08-09 17:34:21.426 Status: (Zigate) Max Load (Queue) : 0
2020-08-09 17:34:21.426 Status: (Zigate) TX failed : 0 (0.0%)
2020-08-09 17:34:21.426 Status: (Zigate) TX timeout : 0 (0.0%)
2020-08-09 17:34:21.426 Status: (Zigate) TX data timeout : 0 (0.0%)
2020-08-09 17:34:21.426 Status: (Zigate) TX reTransmit : 0 (0.0%)
2020-08-09 17:34:21.426 Status: (Zigate) TX APS Failure : 0 (0.0%)
2020-08-09 17:34:21.426 Status: (Zigate) TX APS Ack : 0 (0.0%)
2020-08-09 17:34:21.426 Status: (Zigate) TX APS Nck : 0 (0.0%)
2020-08-09 17:34:21.426 Status: (Zigate) Received:
2020-08-09 17:34:21.427 Status: (Zigate) RX frame : 118
2020-08-09 17:34:21.427 Status: (Zigate) RX crc errors : 0 (0.0%)
2020-08-09 17:34:21.427 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2020-08-09 17:34:21.427 Status: (Zigate) RX clusters : 0
2020-08-09 17:34:21.427 Status: (Zigate) RX clusters KO : 0
2020-08-09 17:34:21.427 Status: (Zigate) Operating time : 0 Hours 5 Mins 6 Secs
2020-08-09 17:34:21.576 Status: (Zigate) Stopping threads.
2020-08-09 17:34:21.576 Status: (Zigate) Stopped.
2020-08-09 17:34:21.578 Status: (Zigate) Started.
2020-08-09 17:34:22.059 (Zigate) DomoticzVersion: 2020.1
2020-08-09 17:34:22.040 Status: (Zigate) Entering work loop.
2020-08-09 17:34:22.040 Status: (Zigate) Initialized version 4.9, author 'zaraki673 pipiche38'
2020-08-09 17:34:22.059 Status: (Zigate) Zigate plugin stable-4.9.004 started
2020-08-09 17:34:22.059 Status: (Zigate) Debug: 0
2020-08-09 17:34:22.059 Status: (Zigate) load PluginConf
2020-08-09 17:34:22.060 Status: (Zigate) enableAPSFailureReporting set to 0
2020-08-09 17:34:22.061 Status: (Zigate) channel set to 11
2020-08-09 17:34:22.061 Status: (Zigate) port set to 8084
2020-08-09 17:34:22.061 Status: (Zigate) pluginHome set to /usr/local/domoticz/var/plugins/Zigate/
2020-08-09 17:34:22.061 Status: (Zigate) pluginReports set to /usr/local/domoticz/var/plugins/Zigate/Reports/
2020-08-09 17:34:22.061 Status: (Zigate) pluginData set to /usr/local/domoticz/var/plugins/Zigate/Data/
2020-08-09 17:34:22.061 Status: (Zigate) pluginConfig set to /usr/local/domoticz/var/plugins/Zigate/Conf/
2020-08-09 17:34:22.061 Status: (Zigate) pluginLogs set to /usr/local/domoticz/var/plugins/Zigate/Logs/
2020-08-09 17:34:22.061 Status: (Zigate) homedirectory set to /usr/local/domoticz/var/plugins/Zigate/
2020-08-09 17:34:22.061 Status: (Zigate) filename set to /usr/local/domoticz/var/plugins/Zigate/Conf/PluginConf-05.json
2020-08-09 17:34:22.061 Status: (Zigate) pluginWWW set to /usr/local/domoticz/var/plugins/Zigate/www/
2020-08-09 17:34:22.061 Status: (Zigate) pluginOTAFirmware set to /usr/local/domoticz/var/plugins/Zigate/OTAFirmware/
2020-08-09 17:34:22.061 Status: (Zigate) Switching Heartbeat to 5 s interval
2020-08-09 17:34:22.062 Status: (Zigate) Python Version - 3.5.1 (default, Jan 29 2018, 14:18:59)
2020-08-09 17:34:22.062 [GCC 4.9.3 20150311 (prerelease)]
2020-08-09 17:34:22.062 Status: (Zigate) DomoticzVersion: 2020.1
2020-08-09 17:34:22.062 Status: (Zigate) DomoticzHash: 0
2020-08-09 17:34:22.062 Status: (Zigate) DomoticzBuildTime: 1970-01-01 01:00:00
2020-08-09 17:34:22.062 Status: (Zigate) Opening DomoticzDB in raw
2020-08-09 17:34:22.134 Status: (Zigate) Plugin Database: DeviceList-5.txt
2020-08-09 17:34:22.140 Status: (Zigate) DeviceConf loaded
2020-08-09 17:34:22.211 Status: (Zigate) --> Config loaded: dict_keys(['lumi.sensor_natgas', 'LIGHTIFY Indoor Flex RGBW', 'LCT024', 'lumi.sensor_switch', 'lumi.remote.b686opcn01-bulb', 'Plug Z3', 'GLEDOPTO', 'TRADFRI remote control', 'BSO-Profalux', 'lumi.sensor_motion.aq2', 'lumi.ctrl_neutral2', 'TRADFRI control outlet', 'lumi.remote.b286acn01', 'LLC010', 'TRADFRI bulb E27 WW clear 250lm', 'EH-ZB-HACT', 'LTW004', 'lumi.ctrl_ln2.aq1', 'lumi.sensor_cube.aqgl01', 'Volet-Profalux', 'Thermostat', 'lumi.ctrl_neutral1', 'Cable outlet', 'Lightify Switch Mini', 'GL-D-003Z', 'lumi.light.aqcn02', 'GL-FL-004TZS', 'Double gangs remote switch', 'lumi.ctrl_86plug.aq1', 'GL-C-008S', 'VoletBSO-Profalux', 'lumi.plug.mmeu01', 'Mobile outlet', 'Pluzzy-TH', 'TRADFRI bulb E14 WS 470lm', '902010/22', 'TRADFRI bulb E14 W opch 400lm', 'GAS_V15', 'lumi.sensor_magnet.aq2', 'lumi.sensor_ht', 'Plug 01', 'lumi.weather', 'TRADFRI bulb E26 WS clear 950lm', 'EH-ZB-BMS', '902010/28', 'TRADFRI bulb E14 WS opal 600lm', 'TRADFRI onoff switch', 'TRADFRI bulb GU10 W 400lm', 'GL-MC-001', 'LXN56-DC27LX1.1', 'Pluzzy-Motion', 'ZPLUG', 'TRADFRI wireless dimmer', 'lumi.remote.b686opcn01', 'lumi.remote.b486opcn01-bulb', 'TRADFRI bulb E27 WS opal 950lm', '3AFE170100510001', 'GL-C-008', 'lumi.remote.b286opcn01-bulb', 'LCT007', 'EH-ZB-SPD-V2', 'Connected outlet', 'EH-ZB-LMACT', 'Shutter switch with neutral', 'lumi.relay.c2acn01', 'lumi.sensor_magnet', 'EH-ZB-RTS', '3c4e4fc81ed442efaf69353effcdfc5f', 'SAL6ET1', 'LTC001', 'TS0013', 'EH-ZB-VACT', 'EH-ZB-SPD', 'lumi.sensor_switch.aq2', 'Lamp_01', 'PST03A-v2.2.5', 'Remote switch', 'TRADFRI motion sensor', 'lumi.sensor_86sw2', 'LST002', 'TS0302', 'FLOALT panel WS 60x60', 'lumi.router', 'SPZB0001', 'TRADFRI bulb E12 WS opal 400lm', 'Shutters central remote switch', 'TRADFRI bulb E27 CWS opal 600lm', 'Pluzzy-Plug', 'lumi.remote.b1acn01', 'ZHA-CSW', 'lumi.sensor_86sw1', 'TRADFRI bulb GU10 WS 400lm', '3AFE140103020000', 'GL-C-009', 'LWB006', 'lumi.sensor_wleak.aq1', 'CLA60 TW OSRAM', 'Micromodule switch', 'lumi.remote.b486opcn01', 'TI0001', 'FB56-ZCW08KU1.1', 'lumi.sen_ill.mgl01', 'RC 110', 'TS0001', 'RWL021', 'TS0003', 'TS0002', 'LCT001', 'LCT003', 'TS0011', 'lumi.ctrl_ln2', 'TRADFRI bulb E27 W opal 1000lm', 'lumi.sensor_smoke', 'lumi.vibration.aq1', 'ZMOVE', 'COSensor-N', 'TRADFRI bulb E27 WS opal 980lm', 'SMOK_V16', 'RB 248 T', 'ZHUM', 'SPE600', 'lumi.sensor_switch.aq3', 'lumi.remote.b286opcn01', 'SmokeSensor-N', 'ZBT-ExtendedColor', 'RB 285 C', 'SmokeSensor-N-3.0', 'Pluzzy-Door', 'lumi.plug', 'LTW013', 'TRADFRI bulb E26 WS opal 980lm', 'GL-B-008Z', 'lumi.remote.b186acn01', 'Super TR', 'GL-B-007Z', '3AFE28010402000D', 'LTW001', 'PAR16 50 TW', 'TRADFRI bulb E27 opal 1000lm', '902010/21A', 'WarningDevice', 'TRADFRI bulb E27 WS clear 950lm', 'RH3001', 'lumi.sensor_cube', 'DIN power consumption module', 'GL-C-008Z', 'TS0012', 'TRADFRI Driver 30W', 'lumi.sensor_motion', '3AFE130104020015', 'SML002', 'lumi.ctrl_86plug', 'LCT010', 'SML001', 'TRV10RFM', 'TRADFRI bulb E14 WS opal 400lm', 'Dimmer switch wo neutral', 'LCT015', 'LTA001', 'TS0201', 'TRADFRI bulb E27 WS opal 1000lm', 'Telecommande-Profalux', 'FLOALT panel WS 30x90', 'TRADFRI Signal Repeater', 'LIGHTIFY Outdoor Flex RGBW', 'Zigate-Router', '3AFE14010402000D'])
2020-08-09 17:34:22.212 Status: (Zigate) load ListOfDevice
2020-08-09 17:34:22.244 Status: (Zigate) Entries loaded from /usr/local/domoticz/var/plugins/Zigate/Data/DeviceList-5.txt
2020-08-09 17:34:22.245 Status: (Zigate) Transport mode: USB
2020-08-09 17:34:22.246 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2020-08-09 17:34:22.247 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyUSB0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-08-09 17:34:32.192 Status: (Zigate) Major Version Num: 0003
2020-08-09 17:34:32.192 Status: (Zigate) Installer Version Number: 031c
2020-08-09 17:34:42.234 Error: (Zigate) Zigate not correctly initialized
2020-08-09 17:34:47.243 Error: (Zigate) Zigate not correctly initialized
2020-08-09 17:34:52.246 Error: (Zigate) Zigate not correctly initialized
2020-08-09 17:34:57.257 Error: (Zigate) Zigate not correctly initialized
2020-08-09 17:35:02.171 Error: (Zigate) We are having difficulties to start Zigate. Basically we are not receiving what we expect from Zigate
2020-08-09 17:35:02.172 Error: (Zigate) Plugin is not started ...
2020-08-09 17:35:02.274 Error: (Zigate) Zigate not correctly initialized
2020-08-09 17:35:07.161 Error: (Zigate) We are having difficulties to start Zigate. Basically we are not receiving what we expect from Zigate
2020-08-09 17:35:07.162 Error: (Zigate) Plugin is not started ...
2020-08-09 17:35:07.264 Error: (Zigate) Zigate not correctly initialized
2020-08-09 17:35:12.176 Error: (Zigate) We are having difficulties to start Zigate. Basically we are not receiving what we expect from Zigate
2020-08-09 17:35:12.177 Error: (Zigate) Plugin is not started ...
2020-08-09 17:35:12.290 Error: (Zigate) Zigate not correctly initialized
2020-08-09 17:35:17.208 Error: (Zigate) We are having difficulties to start Zigate. Basically we are not receiving what we expect from Zigate
2020-08-09 17:35:17.209 Error: (Zigate) Plugin is not started ...
2020-08-09 17:35:17.346 Error: (Zigate) Zigate not correctly initialized
