Produit Silvercrest (Lidl) + Zigbee2MQTT
Plugins DeConz et ZigBee2MQTT
Fredok
Message par Fredok »
Bonjour prise ZB acheté cet aprem. Fonctionne avec zigbee2mqtt et son plugin DZ.
Par contre j'ai du modifier le devices.js et le __init__.py des adaptateur tuya.
Rajout dans devices.js (d'après le site de koenk...)
// Lidl
        fingerprint: [
            {modelID: 'TS011F', manufacturerName: '_TZ3000_kdi2o9m6'}, // EU
            {modelID: 'TS011F', manufacturerName: '_TZ3000_plyvnuf5'}, // CH
            {modelID: 'TS011F', manufacturerName: '_TZ3000_wamqdr3f'}, // FR
            {modelID: 'TS011F', manufacturerName: '_TZ3000_00mk2xzy'}, // BS
        model: 'HG06337',
        vendor: 'Lidl',
        description: 'Silvercrest smart plug (EU, CH, FR, BS)',
        extend: generic.switch,
    meta: {configureKey: 1},
    configure: async (device, coordinatorEndpoint) => {
            const endpoint = device.getEndpoint(11);
            await bind(endpoint, coordinatorEndpoint, ['genOnOff']);
            await configureReporting.onOff(endpoint);
et dans __init__.py (chez moi c'est ici ==> /root/domoticz/plugins/zigbee2mqtt/adapters/tuya)
from adapters.on_off_switch_adapter import OnOffSwitchAdapter
from adapters.generic.blind_adapter import BlindAdapter
from adapters.generic.plug import PlugAdapter
from adapters.generic.temp_hum_sensor import TemperatureHumiditySensorAdapter
from adapters.tuya.TS0002 import TS0002
from adapters.tuya.TS0012 import TS0012
from adapters.tuya.TS0013 import TS0013
from adapters.tuya.TS0015 import TS0015
from adapters.tuya.TS0601 import TS0601
tuya_adapters = {
    'TS0121_plug': PlugAdapter,                 # TuYa 10A UK or 16A EU smart plug
	'TS011F': OnOffSwitchAdapter,
    'TS0201': TemperatureHumiditySensorAdapter, # TuYa Temperature & humidity sensor with display
    'TS0002': TS0002,                           # TuYa 2 gang switch
    'TS0012': TS0012,                           # TuYa Smart light switch - 2 gang without neutral wire
    'TS0013': TS0013,                           # TuYa Smart light switch - 3 gang without neutral wire
    'TS0015': TS0015,                           # TuYa Multiprise with 4 AC outlets and 2 USB super charging ports (10A or 16A)
    'TS0601_curtain': BlindAdapter,             # TuYa Curtain motor
    'TS0601_thermostat': TS0601,                # TuYa Radiator valve with thermostat
    'mcdj3aq': BlindAdapter,                    # TuYa Tubular motor
    'TS130F': BlindAdapter,                     # TuYa Curtain / Blind switch
Après plusieurs tentatives, la prise s'est bien appairée.
Peut-être qu'une seule des 2 modifs aurait suffit ....
Opi
RFXCOM
RFLINK 433 & 315
Mysensors
Wifi & Mqtt
EspEasy - Tasmota
Zigate+
garycooper
Re: Produit Silvercrest (Lidl) + Zigbee2MQTT
Message par garycooper »
Oui, j'ai pas mal galéré aussi mais en passant par la branche dev du plugin zigbee2mqtt et en mettant à jour le plugin domoticz, ça a bien fonctionné ! J'ai pu appairer la prise connectée et les ampoules blanches (j'ai pas acheté les ampoules RGB et le ruban LED).
Pour passer sur la branche dev, c'est ici : https://www.zigbee2mqtt.io/how_tos/how- ... ranch.html
