speedtest
berserk
speedtest
Message par berserk »
je rencontre un souci avec speedtest (le plugin). depuis mercredi 23h30 il ne remonte rien. J'ai bien l'appli speedtest-cli et elle fonctionne. Les scripts sont bien activé dans domoticz (autre). J'ai verifié mon python etc les droits etc et la javoue vous etes ma denière chance!!!!
ci joint mes logs
Merci!
2021-04-14 10:36:51.682 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:36:51.682 (internet) onHeartbeat called
2021-04-14 10:36:51.682 (internet) onHeartbeat called, run again in 323 heartbeats.
2021-04-14 10:37:01.651 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 10:37:01.655 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 10:37:01.655 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:37:01.655 (internet) onHeartbeat called
2021-04-14 10:37:01.655 (internet) onHeartbeat called, run again in 322 heartbeats.
2021-04-14 10:37:11.653 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 10:37:11.673 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 10:37:11.673 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:37:11.673 (internet) onHeartbeat called
2021-04-14 10:37:11.673 (internet) onHeartbeat called, run again in 321 heartbeats.
2021-04-14 10:37:21.655 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 10:37:21.697 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 10:37:21.697 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:37:21.697 (internet) onHeartbeat called
2021-04-14 10:37:21.698 (internet) onHeartbeat called, run again in 320 heartbeats.
2021-04-14 10:37:31.657 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 10:37:31.691 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 10:37:31.691 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:37:31.691 (internet) onHeartbeat called
2021-04-14 10:37:31.691 (internet) onHeartbeat called, run again in 319 heartbeats.
2021-04-14 10:37:41.658 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 10:37:41.661 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 10:37:41.661 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:37:41.661 (internet) onHeartbeat called
2021-04-14 10:37:41.661 (internet) onHeartbeat called, run again in 318 heartbeats.
2021-04-14 10:37:51.660 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 10:37:51.678 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 10:37:51.678 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:37:51.678 (internet) onHeartbeat called
2021-04-14 10:37:51.679 (internet) onHeartbeat called, run again in 317 heartbeats.
2021-04-14 10:38:01.661 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 10:38:01.696 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 10:38:01.696 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:38:01.696 (internet) onHeartbeat called
2021-04-14 10:38:01.696 (internet) onHeartbeat called, run again in 316 heartbeats.
2021-04-14 10:38:11.663 (internet) Pushing 'onHeartbeatCallback' on to queue
2021-04-14 10:38:11.672 (internet) Processing 'onHeartbeatCallback' message
2021-04-14 10:38:11.672 (internet) Calling message handler 'onHeartbeat'.
2021-04-14 10:38:11.672 (internet) onHeartbeat called
2021-04-14 10:38:11.672 (internet) onHeartbeat called, run again in 315 heartbeats.
Sylv_01
Re: speedtest
Message par Sylv_01 »
Je confirme, chez moi non plus...
Mais je n'ai pas plus investigué que ça...
berserk
Re: speedtest
hipiiiiiiii yeah je suis pas tout seul!!!!!!!!!!!!
berserk
Re: speedtest
j'ai posté sur le forum Anglais. On verra bien
Sylv_01
Re: speedtest
Je n'ai pas tout à fait la même utilisation : pour ma part, le script speedtest est présent sur mon NAS, il est lancé toutes les heures et je colle le résultat dans un dummy device de Domoticz...
J'avais mis ça sur une non-réponse du serveur interrogé par speedtest, je n'ai pas refait d'essai depuis...
corly
Re: speedtest
Message par corly »
j'ai le même problème, mais depuis 1 semaine environ (je ne regarde pas tous les jours...)
pourtant si j'exécute manuellement le script depuis mon raspberry, j'ai un résultat et Domoticz est actualisé.
Par contre via le crontab, pas moyen...
je pensais que quelque chose avait merdé et j'ai essayé de réparer mais pas mieux..
je suis "content" de voir que finalement ce n'est peut-être pas de mon côté qu'il y a un soucis..
pour tester, j'ai même mis mon crontab en * * * * path2script/script.sh mais il ne se lance pas...
j'espère qu'on trouvera vite :)
corly
Re: speedtest
Message par corly »
Pour info, j'ai réussi à refaire fonctionner le plugin via la désinstallation et la l'installation de Ookla
https://domoticz.com/forum/viewtopic.php?t=31898
je n'ai pas suivi la procédure de ce post, simplement désinstallé le speediest-cli et suivi la procédure du site https://www.speedtest.net/apps/cli (Ubuntu/Debian pour moi) et install de jq comme indiqué dans le post (honnêtement je ne pense pas qu'il y en ai besoin, si j'ai bien compris ça sert pour le json...)
mais tout fonctionne correctement via le plugin désormais
en espérant que ça vous aide aussi ;)
berserk
Re: speedtest
bonjour merci pour l'info 8-)
Avec ookla ca fonctionne bien. J'ai pas trop compris pour le speedtest, j'ai pas fait de maj. J'ai meme refait ma conf complete (pour d'autre raison) et j'avais le meme pb
Re: speedtest
Je viens de trouver sur le forum anglais un post parlant du problème avec SpeedTest.
Il faut remplacer le fichier /usr/lib/python3/dist-packages/speedtest.py (le chemin dépend de votre Python). J'ai mis le fichier en pièce jointe de ce message.
La solution a fonctionné chez moi : speedtest est à nouveau fonctionnel ;)
speedtest.zip
(14.19 Kio) Téléchargé 342 fois
Seb13
Re: speedtest
Message par Seb13 »
Merci pour l'info.
Cela fonctionne chez moi aussi.
