Error: Error parsing http request address: ::ffff:172.105.13.165
Moulins58
Message par Moulins58 »
Depuis peu, je suis envahi d'erreur dans les logs:
021-05-06 18:51:09.729 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:09.992 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:10.269 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:10.559 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:10.831 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:11.106 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:12.143 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:12.409 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:12.677 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:12.945 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:13.225 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:13.495 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:13.786 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:14.324 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:14.597 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:14.863 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:15.130 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:15.409 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:15.674 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:15.934 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:16.198 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:16.458 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:16.727 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:17.000 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:17.298 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:17.563 Error: Error parsing http request address: ::ffff:172.105.13.165
2021-05-06 18:51:17.838 Error: Error parsing http request address: ::ffff:172.105.13.165
Quelqu'un aurait-il une réponse?
D'avance merci!
Wolfen38
Re: Error: Error parsing http request address: ::ffff:172.105.13.165
Message par Wolfen38 »
Exactement le même problème, mais je sais pas comment m'en débarrasser.
L'adresse IP est externe et tombe sur un site qui propose des services de scanning : https://ampereinnotech.com/scanning.html
Change de port externe au lieu du 8080 pour un truc plus exotique.
Wolfen38
Pour etre sur, car pas trop fort la dedans.
Ma config actuelle :
redirection dans ma bbox du port 8080 entrant vers port 8080 de mon routeur
redirection dans mon routeur du port 8080 entrant vers port 8080 de mon rpi
Donc quand je tape ipmaison:8080 j'arrive sur dz
J'aurai juste a changer la redirection dans ma bbox, par ex port 8280 entrant vers port 8080 de mon routeur, je touche pas à la redirection du routeur, et quand je taperai ipmaison:8280 j'arriverai sur dz ?
higgins91
Message par higgins91 »
C'est bien ça.
Tu peux choisir un port encore plus exotique 10472 par exemple (suivant possibilité de ton opérateur télécom)
Dz version : 2024.7
Wolfen38
C'est quoi en théorie la plage ? Il me semble qu'on peut pas mettre n'importe quoi ?
Je dirais que plus c'est exotique, moins tu auras de chances qu'un robot puisse le trouver.
higgins91
Wolfen38 a écrit : 07 mai 2021, 18:36 C'est quoi en théorie la plage ? Il me semble qu'on peut pas mettre n'importe quoi ?
Pour le nombre de port:
Chaque machine possède 65 536 ports distincts
Pour choisir, ça dépend vraiment des opérateur(certain réservent des port pour leur propre services), bien sur y'a tous les ports classique à éviter, 21,80,443,465,8080(voir ici: https://www.malekal.com/wp-content/uplo ... nexion.jpg)... Mais à partir du moment ou tu choisis un port exotique dans les 10000 ça passe !
Le mieux c'est d'essayer directement chez toi.
Dz version : 2024.7
Wolfen38
Je vais essayer même si ça me soule a l'avance de devoir refaire tous mes liens tasker et ifttt
Moulins58
J'ai résolu le problème en routant le port **** vers le port 443 qui est lui-même routé vers le 8080 . Ça fonctionne parfaitement, plus une présence de FFFF:***.***.***.***
Le port **** est un port farfelu que j'ai pris au hasard.
Bonne Journée.
