[Résolu]Mise à jour de domiticz plus aucun accès
Re: Mise à jour de domiticz plus aucun accès
Par contre la variable name va dans /home/$USERNAME/domoticz/$NAME
Hors moi c'est directement dans /home/$USERNAME/domoticz
J'ai restauré ma vm et refait la maj, mon fichier domoticz.sh est déjà comme sur le lien. J'ai décommenté la ligne des logs mais toujours rien.
#! /bin/sh
### BEGIN INIT INFO
# Provides: domoticz
# Required-Start: $network $remote_fs $syslog
# Required-Stop: $network $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Home Automation System
# Description: This daemon will start the Domoticz Home Automation System
### END INIT INFO
# Do NOT "set -e"
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
DESC="Domoticz Home Automation System"
NAME=domoticz
USERNAME=sebr
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
DAEMON=/home/sebr/domoticz/$NAME
DAEMON_ARGS="-daemon"
#DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8084"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.2-14) to ensure that this file is present
# and status_of_proc is working.
. /lib/lsb/init-functions
pidof_domoticz() {
# if there is actually a domoticz process whose pid is in PIDFILE,
# print it and return 0.
if [ -e "$PIDFILE" ]; then
if pidof domoticz | tr ' ' '\n' | grep -w $(cat $PIDFILE); then
return 0
fi
fi
return 1
# Function that starts the daemon/service
do_start()
# Return
# 0 if daemon has been started
# 1 if daemon was already running
# 2 if daemon could not be started
start-stop-daemon --chuid $USERNAME --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \
|| return 1
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \
$DAEMON_ARGS \
|| return 2
# Function that stops the daemon/service
do_stop()
# Return
# 0 if daemon has been stopped
# 1 if daemon was already stopped
# 2 if daemon could not be stopped
# other if a failure occurred
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --name $NAME
RETVAL="$?"
[ "$RETVAL" = 2 ] && return 2
# Wait for children to finish too if this is a daemon that forks
# and if the daemon is only ever run from this initscript.
# If the above conditions are not satisfied then add some other code
# that waits for the process to drop all resources that could be
# needed by services started subsequently. A last resort is to
# sleep for some time.
start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $DAEMON
[ "$?" = 2 ] && return 2
# Many daemons don't delete their pidfiles when they exit.
rm -f $PIDFILE
return "$RETVAL"
case "$1" in
start)
[ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
do_start
case "$?" in
0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
esac
stop)
[ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
do_stop
case "$?" in
esac
status)
status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $?
reload)
log_daemon_msg "Reloading $DESC" "$NAME"
PID=$(pidof_domoticz) || true
if [ "${PID}" ]; then
kill -HUP $PID
log_end_msg 0
log_end_msg 1
fi
restart)
log_daemon_msg "Restarting $DESC" "$NAME"
do_stop
case "$?" in
0|1)
do_start
case "$?" in
0) log_end_msg 0 ;;
1) log_end_msg 1 ;; # Old process is still running
*) log_end_msg 1 ;; # Failed to start
esac
# Failed to stop
log_end_msg 1
esac
echo "Usage: $SCRIPTNAME {start|stop|status|restart|reload}" >&2
exit 3
esac
Chrominator
Mauvaise interprétation ; domoticz ne tourne pas sur ton système, raison pour laquelle tu ne peux pas accéder à l'interface.titis14 a écrit : 25 août 2021, 20:05 Quand je fais un status il est bien actif si je fais ta commande il y a bien un processCode : Tout sélectionner
sebr@Debian:~$ ps aux | grep domoticz sebr 18143 0.0 0.0 12780 952 pts/0 S+ 20:04 0:00 grep domoticz
le process que tu vois est celui lancé pour filtrer (grep) la liste des process donnée par la commande ps.
Comme dit précédemment, tu pourrais lancer domoticz à la main pour voir ce que dit le log.
RFXtrx433 USB Ver Pro1/1043
Rtl433 RTL-SDR receiver
RFLink Gateway
Zigbee SLZB-06
RFLink Gateway
Zigbee SLZB-06
Salut, alors j'ai fait la commande suivante pour lancer le service et quand je fais un status il me dit actif mais si je fais ensuite ta commande toujours pas de process
Je tente cette commande il me dit OK mais toujours pas de process
Et je n'ai toujours pas de log dans le fichier /tmp
J'ai tenté de modifier le chemin au cas ou qu'il y aurait un manque de droit mais pareil.
Si je lance domoticz.sh pas d'erreur j'ai un retour à la ligne.
sebr@Debian:~$ sudo service domoticz start
sebr@Debian:~$ sudo service domoticz status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
[b]Active: active [/b](exited) since Wed 2021-08-25 21:06:24 CEST; 20h ago
sebr 1852 0.0 0.0 12780 1000 pts/0 S+ 17:47 0:00 grep domoticz
sebr@Debian:~$ sudo /etc/init.d/domoticz.sh start
[ ok ] Starting domoticz.sh (via systemctl): domoticz.service.
sebr 1886 0.0 0.0 12780 928 pts/0 S+ 17:51 0:00 grep domoticz
sebr@Debian:~/domoticz$ sudo bash ./domoticz.sh
Ah je progresse
il maque une libc et libm apparemment.
sebr@Debian:~/domoticz$ sudo ./domoticz
./domoticz: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.27' not found (required by ./domoticz)
./domoticz: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.28' not found (required by ./domoticz)
j'ai lancé installation de libc.so et libm.so mais toujours la même erreur.
Quand je refait la commande j'ai la version 2.24 on peut pas avoir plus avec debian 9 ?
Bon apparemment y a pas sous déb 9 ca fait un chi** car c'est pas comme si mon Debian était si vieux du coup obliger de tout refaire tous les ans si a chaque mise à jour de domoticz il faut une nouvelle version de librairie pour avoir la dernière version.
https://packages.debian.org/fr/libc6
Je fait une migration avec ce tuto https://www.justegeek.fr/tuto-mettre-a- ... 10-buster/
libmason-perl is already the newest version (2.24-1)
glibc-source is already the newest version (2.24-11+deb9u4).https://packages.debian.org/fr/libc6
Yes c'est bon migré de Déb 9 a 10 puis installation de libc.so + libm.so + reboot domoticz OK
Re: [Résolu]Mise à jour de domiticz plus aucun accès
Tant mieux
