[Résolu] Ajout - Module Tuya Smart Air Box
brenten
Re: Ajout - Module Tuya Smart Air Box
Message par brenten »
pareil :
2021-07-19 18:54:19.544 Status: (Zigate) Accepting new Hardware: Enable (On)
2021-07-19 18:54:50.301 Status: (Zigate) [-] NEW OBJECT: c26f Active Endpoint Response Ep: 01 LQI: 102
2021-07-19 18:54:50.304 Status: (Zigate) [-] NEW OBJECT: c26f Request Simple Descriptor for Ep: 01
2021-07-19 18:54:50.936 Status: (Zigate) [-] NEW OBJECT: c26f Simple Descriptor Response EP: 0x01 LQI: 90
2021-07-19 18:54:50.936 Status: (Zigate) [-] NEW OBJECT: c26f ProfileID 0104
2021-07-19 18:54:50.936 Status: (Zigate) [-] NEW OBJECT: c26f ZDeviceID 0051
2021-07-19 18:54:50.936 Status: (Zigate) [-] NEW OBJECT: c26f Application Version 0001
2021-07-19 18:54:50.937 Status: (Zigate) [-] NEW OBJECT: c26f Cluster IN Count: 04
2021-07-19 18:54:50.937 Status: (Zigate) [-] NEW OBJECT: c26f Cluster In 1: 0000 (Basic)
2021-07-19 18:54:50.937 Status: (Zigate) [-] NEW OBJECT: c26f Cluster In 2: 0004 (Groups)
2021-07-19 18:54:50.938 Status: (Zigate) [-] NEW OBJECT: c26f Cluster In 3: 0005 (Scenes)
2021-07-19 18:54:50.938 Status: (Zigate) [-] NEW OBJECT: c26f Cluster In 4: ef00
2021-07-19 18:54:50.938 Status: (Zigate) [-] NEW OBJECT: c26f Cluster OUT Count: 02
2021-07-19 18:54:50.939 Status: (Zigate) [-] NEW OBJECT: c26f Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-07-19 18:54:50.939 Status: (Zigate) [-] NEW OBJECT: c26f Cluster Out 2: 000a (Time)
2021-07-19 18:54:52.585 Status: (Zigate) [0] NEW OBJECT: c26f Model Name: TS0601
2021-07-19 18:54:52.681 Error: (Zigate) 'onHeartbeat' failed 'TypeError':'tuya_sirene_registration() got an unexpected keyword argument 'device_reset''.
2021-07-19 18:54:52.681 Error: (Zigate) ----> Line 1107 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2021-07-19 18:54:52.681 Error: (Zigate) ----> Line 721 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2021-07-19 18:54:52.681 Error: (Zigate) ----> Line 561 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py', function processListOfDevices
2021-07-19 18:54:52.681 Error: (Zigate) ----> Line 483 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/pairingProcess.py', function processNotinDBDevices
2021-07-19 18:54:55.540 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000110 Payload: 091a0100001202000400000110
2021-07-19 18:54:55.621 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 000013020004000002ac Payload: 091b01000013020004000002ac
2021-07-19 18:54:56.416 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00011602000400000000 Payload: 091d0100011602000400000000
2021-07-19 18:54:56.511 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00011502000400000000 Payload: 091e0100011502000400000000
2021-07-19 18:54:56.596 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00010202000400000004 Payload: 091f0100010202000400000004
2021-07-19 18:54:57.621 (Zigate) Network Topology progress: 30 %
2021-07-19 18:54:58.053 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000111 Payload: 09200100001202000400000111
2021-07-19 18:54:58.140 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 000013020004000002a9 Payload: 092101000013020004000002a9
2021-07-19 18:54:59.944 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00021602000400000000 Payload: 09220100021602000400000000
2021-07-19 18:55:00.024 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00021502000400000000 Payload: 09230100021502000400000000
2021-07-19 18:55:00.176 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00020202000400000003 Payload: 09240100020202000400000003
2021-07-19 18:55:00.267 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 24 Data: 0007 Payload: 1925240007
2021-07-19 18:55:00.589 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000110 Payload: 09260100001202000400000110
2021-07-19 18:55:00.670 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 000013020004000002aa Payload: 092701000013020004000002aa
2021-07-19 18:55:02.641 (Zigate) Network Topology progress: 46 %
2021-07-19 18:55:03.264 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000111 Payload: 092a0100001202000400000111
2021-07-19 18:55:03.357 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 000013020004000002a7 Payload: 092b01000013020004000002a7
2021-07-19 18:55:03.467 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00011602000400000000 Payload: 092c0100011602000400000000
2021-07-19 18:55:03.552 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00011502000400000000 Payload: 092d0100011502000400000000
2021-07-19 18:55:03.654 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00010202000400000003 Payload: 092e0100010202000400000003
2021-07-19 18:55:05.614 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000112 Payload: 092f0100001202000400000112
2021-07-19 18:55:05.723 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 000013020004000002a0 Payload: 093001000013020004000002a0
2021-07-19 18:55:06.972 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00011602000400000000 Payload: 09310100011602000400000000
2021-07-19 18:55:07.052 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00011502000400000000 Payload: 09320100011502000400000000
2021-07-19 18:55:07.174 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00010202000400000001 Payload: 09330100010202000400000001
2021-07-19 18:55:08.132 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000113 Payload: 09340100001202000400000113
2021-07-19 18:55:08.228 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 0000130200040000029d Payload: 0935010000130200040000029d
2021-07-19 18:55:10.520 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00021602000400000000 Payload: 09360100021602000400000000
2021-07-19 18:55:10.601 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00021502000400000000 Payload: 09370100021502000400000000
2021-07-19 18:55:10.685 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00020202000400000002 Payload: 09380100020202000400000002
2021-07-19 18:55:10.764 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000111 Payload: 09390100001202000400000111
2021-07-19 18:55:10.853 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 0000130200040000029d Payload: 093a010000130200040000029d
2021-07-19 18:55:12.150 MQTT: Topic: domoticz/in, Message: { "idx" : 100 , "svalue" : "Alerte Temp :75.31", "nvalue" : 2 }
2021-07-19 18:55:12.265 MQTT: Topic: domoticz/in, Message: { "idx" : 100 , "svalue" : "Alerte Temp :75.31", "nvalue" : 2 }
2021-07-19 18:55:12.623 (Zigate) Network Topology progress: 38 %
2021-07-19 18:55:13.170 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000110 Payload: 093b0100001202000400000110
2021-07-19 18:55:13.253 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 0000130200040000029e Payload: 093c010000130200040000029e
2021-07-19 18:55:14.036 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00021602000400000000 Payload: 093d0100021602000400000000
2021-07-19 18:55:14.137 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00021502000400000000 Payload: 093e0100021502000400000000
2021-07-19 18:55:14.192 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00020202000400000004 Payload: 093f0100020202000400000004
2021-07-19 18:55:14.670 MQTT: Topic: domoticz/in, Message: { "idx" : 100 , "svalue" : "Alerte Temp :75.31", "nvalue" : 2 }
2021-07-19 18:55:14.789 MQTT: Topic: domoticz/in, Message: { "idx" : 100 , "svalue" : "Alerte Temp :75.31", "nvalue" : 2 }
2021-07-19 18:55:15.397 MQTT: Topic: domoticz/in, Message: { "idx" : 100 , "svalue" : "Alerte Temp :75.31", "nvalue" : 2 }
2021-07-19 18:55:15.722 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001202000400000110 Payload: 09400100001202000400000110
2021-07-19 18:55:15.796 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00001302000400000298 Payload: 09410100001302000400000298
2021-07-19 18:55:16.912 MQTT: Topic: domoticz/in, Message: { "idx" : 100 , "svalue" : "Alerte Temp :75.31", "nvalue" : 2 }
2021-07-19 18:55:17.521 MQTT: Topic: domoticz/in, Message: { "idx" : 62 , "svalue" : "602", "nvalue" : 2 }
2021-07-19 18:55:17.560 (Zigate) inRawAps c26f/01 Cluster ef00 Manuf: None Command: 01 Data: 00011602000400000000 Payload: 09420100011602000400000000
2021-07-19 18:55:17.626 (Zigate) Network Topology progress: 30 %
Zigate - TS0601_Temp-0c4314fffe881712-01
Zigate - TS0601_ThermoSetpoint-0c4314fffe881712-01
Zigate - TS0601_ThermoMode_2-0c4314fffe881712-01
Version : "3"
ZDeviceName : ""
Status : "inDB"
SQN : "5d"
Heartbeat : "42"
RIA : "0"
LQI : 96
Battery : Object {}
Model : "TS0601"
ForceAckCommands : Array[0] []
MacCapa : "8e"
IEEE : "0c4314fffe881712"
Type : "Temp/ThermoSetpoint/ThermoMode_2"
ProfileID : "0104"
ZDeviceID : "0051"
App Version : "68"
Attributes List : Object {}
DeviceType : "FFD"
HW Version : "1"
Last Cmds : Array[9] [[18,"02","c26f","0100","0101000000000000010004"],[19,"02","c26f","0100","0101000000000000010005"],[23,"02","c26f","0100","0101000000000000010000"],[24,"02","c26f","0100","0101000000000000010001"],[25,"02","c26f","0100","0101000000000000010002"],[26,"02","c26f","0100","0101000000000000010003"],[27,"02","c26f","0100","0101000000000000010004"],[28,"02","c26f","0100","0101000000000000010005"],[29,"02","c26f","0100","0101000000000000010007"]]
LogicalType : "Router"
Manufacturer : ""
Manufacturer Name : "_TZE200_yvx5lh6k"
NbEp : "1"
PowerSource : "Main"
ReadAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":"19/07/2021 18:55:03","iSQN":{"0000":23,"0001":24,"0002":25,"0003":26,"0004":27,"0005":28,"0007":29},"Attributes":{"0000":"00","0001":"00","0002":"00","0003":"00","0004":"00","0005":"00","0007":"00","ffe2":"00","ffe4":"00","ffdf":"00"},"ZigateRequest":{}}}}}
ReceiveOnIdle : ""
Stack Version : "0"
Stamp : Object {"time":1626713731.888558,"Time":"2021-07-19 18:55:31","MsgType":"8011","LastSeen":"19/07/2021 18:55:31"}
ZCL Version : "3"
Health : "Live"
Capability : Array[5] ["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"]
RollingLQI : Array[11] [105,102,102,102,102,84,84,93,93,96,96]
Epv2 : Object {"01":{"ClusterIn":{"0000":{},"0004":{},"0005":{},"ef00":{}},"ClusterOut":{"0019":{},"000a":{}},"ProfileID":"0104","ZDeviceID":"0051"}}
WriteAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"ef00":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"000a":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
ConfigSource : "DeviceConf"
Ep : Object {"01":{"0000":{"0004":"_TZE200_yvx5lh6k","0005":"TS0601","0000":"3","0001":"68","0002":"0","0003":"1","0007":"1","ffe2":"31","ffe4":"0","ffdf":"\u0005\u0000\u0000\u0000\u0000\u0012\u0000\u0000\u0000\u0000\u0012"},"0004":{},"ef00":{},"000a":{},"0019":{},"Type":"Temp/ThermoSetpoint/ThermoMode_2","ClusterType":{"103":"Temp","104":"ThermoSetpoint","105":"ThermoMode_2"}}}
ZDeviceVersion : "0001"
PairingInProgress : true
Bind : Object {"01":{"0019":{"Target":"0000","Stamp":"19/07/2021 18:54:52","Phase":"binded","Status":"00","i_sqn":21},"ef00":{"Target":"0000","Stamp":"19/07/2021 18:54:52","Phase":"binded","Status":"00","i_sqn":22}}}
SQN_000a : "1c"
NeighbourTableSize : 5
MapLQI : Object {"0000":93,"8f87":152,"b826":32,"1b2c":77,"509e":47}
Neighbours : Array[1] [{"Time":"2021-07-19 18:56:12","Devices":[{"0000":{"_relationshp":"Parent","_devicetype":"Coordinator","_depth":0,"_lnkqty":176,"_rxonwhenidl":"Rx-On","_IEEE":"00158d0001ede942","_permitjnt":"??"}},{"1b2c":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":96,"_rxonwhenidl":"Rx-On","_IEEE":"bc33acfffe4f613c","_permitjnt":"??"}},{"509e":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":52,"_rxonwhenidl":"Rx-On","_IEEE":"680ae2fffe71c7a8","_permitjnt":"??"}},{"8f87":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":183,"_rxonwhenidl":"Rx-On","_IEEE":"bc33acfffe5917a9","_permitjnt":"??"}},{"b826":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":48,"_rxonwhenidl":"Rx-On","_IEEE":"bc33acfffe5797bf","_permitjnt":"??"}}]}]
NwkID : "c26f"
re-essayes avec la 5.2.053 ca devrait etre mieux
- supprimer les widgets
- restart du plugin (après update git pull)
- vérifier la version du plugin
lancer l'appairage
brenten
à 1ere vue ça semble nickel
Zigate - TS0601-SmartAir_Temp+Hum-0c4314fffe881712-01
Zigate - TS0601-SmartAir_Temp-0c4314fffe881712-01
Zigate - TS0601-SmartAir_Humi-0c4314fffe881712-01
Zigate - TS0601-SmartAir_CarbonDioxyde-0c4314fffe881712-01
Zigate - TS0601-SmartAir_CH2O-0c4314fffe881712-01
Zigate - TS0601-SmartAir_Voc-0c4314fffe881712-01
les valeurs remontent ^^
faut que je regarde le diff de ce que tu as fait pour comprendre comment ça fonctionne et pas mourir idiot.
en tout cas un grand merci :D
brenten
faudra que je regarde comme pour les valeurs,
CO2 et COV c'est en PPM
les Formaldéhyde en mg/m3
pour la mesure, ça sens vraiment le produit chinois...
entre la sonde netatmo et ce truc j'ai presque le double en CO2
Sans titre.png (40.66 Kio) Consulté 2016 fois
Absolument, j’ai comparé aussi avec netatmo.
Peut-être qu’il faut plus de pollution pour que les mesures soient plus juste.
Il n’y a pas d’étalonnage, ce qui est aussi douteux
si ca fonctionne , merci de mettre à jour le sujet en Résolu ;-)
brenten
Re: [Résolu]Ajout - Module Tuya Smart Air Box
ayai
merci encore
