[Résolu] Error: Zigbee: DeviceExist - Found True some inconsistency Inputs
Aile
Re: Error: Zigbee: DeviceExist - Found True some inconsistency Inputs
Message par Aile »
Super ! Les erreurs ont disparu :).
J'en profite pour poser une question : dans mon fichier DeviceList-5.txt, il y a des périphériques qui n'existent pas :
2022-10-22 12:48:40.052 Status: Zigbee: [04] DevID: 00 Network addr: 3c7f IEEE: 00124b0022cf0924 LQI: 000 power: ff Model: TH01 ( T° Buanderie annexe )
2022-10-22 12:48:40.052 Status: Zigbee: [05] DevID: 00 Network addr: 8e7c IEEE: 8cf681fffef2512f LQI: 000 power: ff Model: RC-EF-3.0 ( Télécommande )
2022-10-22 12:48:40.052 Status: Zigbee: [06] DevID: 00 Network addr: 8cf6 IEEE: 81fffef2512f8e7c LQI: 000 power: ff not found in plugin database!
2022-10-22 12:48:40.052 Status: Zigbee: [07] DevID: 00 Network addr: 1859 IEEE: 84fd27fffe0682a6 LQI: 000 power: ff Model: SmokeSensor-EF-3.0 ( Détecteur RDC )
2022-10-22 12:48:40.052 Status: Zigbee: [08] DevID: 00 Network addr: 20e0 IEEE: 50325ffffe305d1b LQI: 000 power: ff Model: TS011F ( Prise étage )
2022-10-22 12:48:40.052 Status: Zigbee: [09] DevID: 00 Network addr: 0ac7 IEEE: 804b50fffeff0d0b LQI: 000 power: ff Model: SmokeSensor-EF-3.0 ( Détecteur étage )
2022-10-22 12:48:40.052 Status: Zigbee: [10] DevID: 00 Network addr: 804b IEEE: 50fffeff0d0b0ac7 LQI: 000 power: ff not found in plugin database!
2022-10-22 12:48:40.052 Status: Zigbee: [11] DevID: 00 Network addr: 8eda IEEE: 00124b0025118c6a LQI: 000 power: ff Model: TH01 ( Salle de bain )
2022-10-22 12:48:40.052 Status: Zigbee: [12] DevID: 00 Network addr: 0012 IEEE: 4b002518fdfb95b6 LQI: 000 power: ff not found in plugin database!
2022-10-22 12:48:40.052 Status: Zigbee: [13] DevID: 00 Network addr: 84fd IEEE: 27fffe0682a61859 LQI: 000 power: ff not found in plugin database!
2022-10-22 12:48:40.052 Status: Zigbee: [14] DevID: 00 Network addr: 4b55 IEEE: 00124b0022cf0b7b LQI: 000 power: ff Model: TH01 ( Salon TV )
2022-10-22 12:48:40.052 Status: Zigbee: [15] DevID: 00 Network addr: f918 IEEE: 50325ffffe2ce394 LQI: 000 power: ff Model: TS011F ( Prise bureau )
2022-10-22 12:48:40.067 Status: Zigbee: [16] DevID: 00 Network addr: 162f IEEE: 50325ffffe531ca6 LQI: 000 power: ff Model: TS011F ( Prise Annexe )
2022-10-22 12:48:40.067 Status: Zigbee: Network state UP, PANID: 7ee7 extPANID: 0xe4e2a5a4516ef948 Channel: 24
Puis-je supprimer ces périphériques dans le fichier DeviceList-5.txt ?
NUC Celeron 1037U / Win 10 Pro
  • EcoCompteur Legrand
  • RFLink Nodo : capteurs T° Alecto / capteurs présence EV1527
  • Clef Sonoff Zigbee 3.0 : capteurs T° Sonoff / capteurs présence Lidl / Détecteurs fumée Heiman
  • BroadLink : pilotage clim
  • Shelly 1
je te recommande de ne pas modifier le fichier DeviceList directement.
Dans ce logs, le message :
Indique simplement qu'on a trouvé une référence d'un device dans le coordinateur mais il n'y a pas de trace dans le Plugin. A priori un device qui a été appairé et qui a été supprimé du plugin.
Donc y-a rien qui me dérange ici
Aile
Message par Aile »
Ok, mais c'est un peu curieux car je n'ai supprimé aucun périphérique et tous mes périphériques sont présents dans le plugin.
Sauf erreur, un périphérique garde toujours le même identifiant ?
Est-ce qu'on peut supprimer ces périphériques dans le coordinateur ?
  • Shelly 1
est-ce que ce device 81fffef2512f8e7c existe dans le Domoticz ?
Est-ce que la clef etait utilisée avant ?
Aile
Message par Aile »
Ben non...
Et la clef est neuve !
  • Shelly 1
c'est bizarre, effectivement.
Donc pour la question peut-on les supprimer, non sans faire un Erase complet
Pour moi c'est pas genant.
J'essaies de pousser l"update sur la branche stable d'ici la fin du week-end ..
Aile
Message par Aile »
Pas grave...
Sans doute que cette clef avait déjà été utilisée, puis rendue au fournisseur.
Je marque le sujet comme résolu.
Dernière question : tu as modifié le plugin pour supprimer ces erreurs ?
Merci encore !
  • Shelly 1
Re: [Résolu] Error: Zigbee: DeviceExist - Found True some inconsistency Inputs
si tu souhaites rebasculer sur la stable6 , c'est possible en faisant
git pull
git checkout stable6
git pull
Après quoi tu relances le plugin et tu devrais te retrouver sur la 6.3.002
