[Résolu] Zigbee sur domoticz
Re: Zigbee sur domoticz
Ton coordinateur Sonoff est ZBDongle-P ( Texas Instrument ==> ZNP ) ou est-ce ZBDongle-E (Silicon Labs ==> EZSP ) ?
La ZiGate est un autre coordinateur.
Je bascule ton sujet dans le forum dédié au plugin ZigBeeForDomoticZ.
Le coordinateur est le suivant : SONOFF ZigBee 3.0 USB Dongle Plus, TI CC2652P Coordinator
Donc bien le Chipset Texas Instruments
Mais j'ai une erreur dans domoticz
les log sont les suivants
2022-12-03 06:57:57.948 Zibgee: onStop()
2022-12-03 06:57:57.954 Zibgee: Connection closed
2022-12-03 06:57:57.947 Status: Zibgee: Stop directive received.
2022-12-03 06:57:57.979 Status: Zibgee: ZigateTransport: ZiGateSerialListen Thread stop.
2022-12-03 06:57:57.979 Status: Zibgee: ZigateTransport: writer_thread Thread stop.
2022-12-03 06:57:57.979 Status: Zibgee: ZigateTransport: thread_processing_and_sending Thread stop.
2022-12-03 06:57:58.967 Zibgee: logging_thread - ended
2022-12-03 06:57:58.977 Zibgee: Logging Thread shutdown
2022-12-03 06:57:58.977 Zibgee: onStop called (6) Close Logging Management
2022-12-03 06:57:59.173 Status: Zibgee: Exiting work loop.
2022-12-03 06:57:59.248 Status: Zibgee: Stopping threads.
2022-12-03 06:57:59.248 Status: Zibgee: Stopped.
2022-12-03 06:58:09.808 Zibgee: Worker thread started.
2022-12-03 06:58:09.808 Status: Zibgee: Started.
2022-12-03 06:58:09.808 Status: Zibgee: Entering work loop.
2022-12-03 06:58:11.232 Zibgee: Zigbee for Domoticz plugin started!
2022-12-03 06:58:11.230 Status: Zibgee: Initialized version 6.3, author 'pipiche38'
2022-12-03 06:58:11.232 Status: Zibgee: Checking Python modules /home/jeedom/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2022-12-03 06:58:12.797 Zibgee: load PluginConf
2022-12-03 06:58:12.798 Zibgee: Loading PluginConf - into Domoticz sqlite Db
2022-12-03 06:58:12.799 Zibgee: /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json timestamp is 1670047059.8858693
2022-12-03 06:58:12.799 Zibgee: Dz PluginConf is older than Json Dz: 0 Json: 1670047059.8858693
2022-12-03 06:58:12.801 Zibgee: Installing plugin custom page /home/jeedom/domoticz/www/templates/Zibgee.html
2022-12-03 06:58:12.801 Zibgee: Starting LoggingManagement thread
2022-12-03 06:58:12.803 Zibgee: start_logging_thread
2022-12-03 06:58:12.804 Zibgee: logging_thread - listening
2022-12-03 06:58:12.648 Status: Zibgee: Checking Python modules /home/jeedom/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2022-12-03 06:58:12.800 Status: Zibgee: filename set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json
2022-12-03 06:58:12.800 Status: Zibgee: pluginHome set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/
2022-12-03 06:58:12.800 Status: Zibgee: homedirectory set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/
2022-12-03 06:58:12.800 Status: Zibgee: pluginData set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Data/
2022-12-03 06:58:12.800 Status: Zibgee: pluginConfig set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-12-03 06:58:12.800 Status: Zibgee: pluginOTAFirmware set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-12-03 06:58:12.800 Status: Zibgee: pluginReports set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-12-03 06:58:12.800 Status: Zibgee: pluginWWW set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/www/
2022-12-03 06:58:12.800 Status: Zibgee: pluginLogs set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-12-03 06:58:12.804 Status: Zibgee: Please watch plugin log into /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_10.log
2022-12-03 06:58:12.818 Status: Zibgee: Zigbee for Domoticz (z4d) plugin stable6-6.3.006 started
2022-12-03 06:58:12.847 Status: Zibgee: DeviceConf loaded - 22 confs loaded
2022-12-03 06:58:12.838 Error: Zibgee: Device creation failed, Domoticz settings prevent accepting new devices.
2022-12-03 06:58:12.838 Error: Zibgee: createAdminWidget - Fail to create Zigate Status 10. ID: -1, Name: 'Zigate Status 10', nValue: 0, sValue: ''
2022-12-03 06:58:12.838 Error: Zibgee: createNotificationWidget - Fail to create Zigate Notifications 10. ID: -1, Name: 'Zigate Notifications 10', nValue: 0, sValue: ''
2022-12-03 06:58:13.109 Status: Zibgee: DeviceConf loaded - 369 confs loaded
2022-12-03 06:58:13.109 Status: Zibgee: load ListOfDevice
2022-12-03 06:58:13.111 Status: Zibgee: 0 Entries loaded from /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-10.txt
2022-12-03 06:58:13.115 Status: Zibgee: Transport mode: USB
2022-12-03 06:58:13.648 Status: Zibgee: ZigateTransport: Serial Connection open: Serial<id=0x66f3a110, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2022-12-03 06:58:13.653 Status: Zibgee: ZigateTransport: writer_thread Thread start.
2022-12-03 06:58:13.655 Status: Zibgee: ZigateTransport: thread_processing_and_sending Thread start.
2022-12-03 06:58:13.661 Status: Zibgee: Start Web Server connection
2022-12-03 06:58:13.696 Status: Zibgee: Web backend for Web User Interface started on port: 9440
2022-12-03 06:58:13.697 Status: Zibgee: Domoticz Widgets usage is at 0.4 % (254 units free)
Dernière modification par Keros le 03 déc. 2022, 07:40, modifié 1 fois.
Raison : Ajout de balise pour les logs
L'erreur est :
Dans DomoticZ / Configuration / Paramètres / Système , est-ce que la case Accepter de nouveaux dispositifs est cochée ?Device creation failed, Domoticz settings prevent accepting new devices.
Effectivement c'etait decocher mais ca ne fonctionne toujours pas ci joint le log
Je dois laissé accepter de nouveau dispositif cocher?2022-12-03 16:53:17.979 Status: Zibgee: Started.
2022-12-03 16:53:19.378 Zibgee: Zigbee for Domoticz plugin started!
2022-12-03 16:53:19.375 Status: Zibgee: Initialized version 6.3, author 'pipiche38'
2022-12-03 16:53:19.378 Status: Zibgee: Checking Python modules /home/jeedom/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2022-12-03 16:53:20.950 Zibgee: load PluginConf
2022-12-03 16:53:20.952 Zibgee: Loading PluginConf - into Domoticz sqlite Db
2022-12-03 16:53:20.952 Zibgee: /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json timestamp is 1670047059.8858693
2022-12-03 16:53:20.952 Zibgee: Dz PluginConf is older than Json Dz: 0 Json: 1670047059.8858693
2022-12-03 16:53:20.954 Zibgee: Installing plugin custom page /home/jeedom/domoticz/www/templates/Zibgee.html
2022-12-03 16:53:20.955 Zibgee: Starting LoggingManagement thread
2022-12-03 16:53:20.957 Zibgee: start_logging_thread
2022-12-03 16:53:20.957 Zibgee: logging_thread - listening
2022-12-03 16:53:20.803 Status: Zibgee: Checking Python modules /home/jeedom/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2022-12-03 16:53:20.954 Status: Zibgee: filename set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json
2022-12-03 16:53:20.954 Status: Zibgee: pluginHome set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/
2022-12-03 16:53:20.954 Status: Zibgee: homedirectory set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/
2022-12-03 16:53:20.954 Status: Zibgee: pluginData set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Data/
2022-12-03 16:53:20.954 Status: Zibgee: pluginConfig set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-12-03 16:53:20.954 Status: Zibgee: pluginOTAFirmware set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-12-03 16:53:20.954 Status: Zibgee: pluginReports set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-12-03 16:53:20.954 Status: Zibgee: pluginWWW set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/www/
2022-12-03 16:53:20.954 Status: Zibgee: pluginLogs set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-12-03 16:53:20.957 Status: Zibgee: Please watch plugin log into /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_10.log
2022-12-03 16:53:20.972 Status: Zibgee: Zigbee for Domoticz (z4d) plugin stable6-6.3.006 started
2022-12-03 16:53:20.981 Error: Zibgee: domoticz_request - wrong URL toget access to Domoticz JSON/API: http://127.0.0.1:8080/json.htm?type=hardware
2022-12-03 16:53:20.991 Error: Zibgee: domoticz_request - wrong URL toget access to Domoticz JSON/API: http://127.0.0.1:8080/json.htm?type=hardware
2022-12-03 16:53:21.010 Status: Zibgee: DeviceConf loaded - 22 confs loaded
2022-12-03 16:53:21.269 Status: Zibgee: DeviceConf loaded - 369 confs loaded
2022-12-03 16:53:21.270 Status: Zibgee: load ListOfDevice
2022-12-03 16:53:21.271 Status: Zibgee: 0 Entries loaded from /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-10.txt
2022-12-03 16:53:21.277 Status: Zibgee: Transport mode: ZigpyZNP
2022-12-03 16:53:21.275 Error: Zibgee: Call to function 'onStart' failed, exception details:
2022-12-03 16:53:21.279 Error: Zibgee: Traceback (most recent call last):
2022-12-03 16:53:21.280 Error: Zibgee: File "/home/jeedom/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1562, in onStart
2022-12-03 16:53:21.280 Error: Zibgee: _plugin.onStart()
2022-12-03 16:53:21.280 Error: Zibgee: File "/home/jeedom/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 549, in onStart
2022-12-03 16:53:21.280 Error: Zibgee: import zigpy
2022-12-03 16:53:21.280 Error: Zibgee: ModuleNotFoundError: No module named 'zigpy'
2022-12-03 16:54:03.068 prise tuya: onHeartbeat called time=1670082843.0686805
2022-12-03 16:54:03.069 prise tuya: in handlethread
2022-12-03 16:54:03.069 prise tuya: Device count: 4
2022-12-03 16:54:04.223 prise tuya: DEV name=Piscine state=True id=bfd85fbc8bd81c23265ac5 online=False
2022-12-03 16:54:04.234 prise tuya: Update 1:'On' (prise tuya - Antela Smart Plug) TimedOut=True
2022-12-03 16:54:04.243 prise tuya: Update 0:'Off' (prise tuya - Antela Smart Plug) TimedOut=True
2022-12-03 16:54:04.243 prise tuya: DeviceID=bfd85fbc8bd81c23265ac5 Turned off because device is offline.
2022-12-03 16:54:04.244 prise tuya: DEV name=Noel state=False id=bfc1cf0753018cfe0fjdzp online=False
2022-12-03 16:54:04.244 prise tuya: DEV name=Tv state=True id=bfb2da694a919ed7dbtfcj online=True
Tu essayes de lire les logs ?
J'ai la case Accepter de nouveaux dispositifs cochée en permanence.
Tes paramètres du plugin dans DomoticZ ne sont pas bon.2022-12-03 16:53:20.981 Error: Zibgee: domoticz_request - wrong URL toget access to Domoticz JSON/API: http://127.0.0.1:8080/json.htm?type=hardware
oui j'ai lu mes logs
mais si je mets mon cette adresse http://monid:MDP@ipdomoticz:8080 ça ne fonctionne pas
Ok donc je peux laisser activé
Les 2 widgets crée dans mesure ne sont pas non plus
le programme domotiz zigbee ne doit pas bien être installé?
As-tu essayé l'adresse par défaut proposée ?
Je ne vois pas d'erreurs qui seraient liées à l'installation.
Oui j'ai essayé par défaut ça ne fonctionne pas.
j'ai cette erreur
Dans API base je dois mettre quel url?
L'url de domoticz chez moi est 192.168.1.141:8080
Dois je mettre celle ci avec mon pseudo et MDP (http://username:password@127.0.0.1:por)?
j'ai cette erreur
Sur Putty j'ai fait un2022-12-04 11:30:14.444 Error: zibgee: domoticz_request - wrong URL toget access to Domoticz JSON/API: http://127.0.0.1:8080/json.htm?type=hardware
2022-12-04 11:30:14.456 Error: zibgee: domoticz_request - wrong URL toget access to Domoticz JSON/API: http://127.0.0.1:8080/json.htm?type=hardware
2022-12-04 11:30:14.753 Error: zibgee: Call to function 'onStart' failed, exception details:
2022-12-04 11:30:14.758 Error: zibgee: Traceback (most recent call last):
2022-12-04 11:30:14.758 Error: zibgee: File "/home/jeedom/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1562, in onStart
2022-12-04 11:30:14.758 Error: zibgee: _plugin.onStart()
2022-12-04 11:30:14.758 Error: zibgee: File "/home/jeedom/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 581, in onStart
2022-12-04 11:30:14.758 Error: zibgee: import bellows
2022-12-04 11:30:14.758 Error: zibgee: ModuleNotFoundError: No module named 'bellows'
sudo udevadm info --query=all --name=ttyUSB0
Donc il s'agit d'un sillicon et non texaspi@raspberrypi:/$ sudo udevadm info --query=all --name=ttyUSB0
P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB0/tty/ttyUSB0
N: ttyUSB0
L: 0
S: serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0
S: serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB0/tty/ttyUSB0
E: DEVNAME=/dev/ttyUSB0
E: MAJOR=188
E: MINOR=0
E: SUBSYSTEM=tty
E: USEC_INITIALIZED=135523028736
E: ID_VENDOR=Silicon_Labs
E: ID_VENDOR_ENC=Silicon\x20Labs
E: ID_VENDOR_ID=10c4
E: ID_MODEL=Sonoff_Zigbee_3.0_USB_Dongle_Plus
E: ID_MODEL_ENC=Sonoff\x20Zigbee\x203.0\x20USB\x20Dongle\x20Plus
E: ID_MODEL_ID=ea60
E: ID_REVISION=0100
E: ID_SERIAL=Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001
E: ID_SERIAL_SHORT=0001
E: ID_TYPE=generic
E: ID_BUS=usb
E: ID_USB_INTERFACES=:ff0000:
E: ID_USB_INTERFACE_NUM=00
E: ID_USB_DRIVER=cp210x
E: ID_VENDOR_FROM_DATABASE=Cygnal Integrated Products, Inc.
E: ID_MODEL_FROM_DATABASE=CP2102/CP2109 UART Bridge Controller [CP210x family]
E: ID_PATH=platform-3f980000.usb-usb-0:1.3:1.0
E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_3_1_0
E: DEVLINKS=/dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0 /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
E: TAGS=:systemd:
Tu as mis http://127.0.0.1:8080 ?
Si le 127.0.01 est autorisé dans les paramètres de DomoticZ pour se connecter sans mot de passe, tu n'as pas besoin de spécifier le user/pass.
Au dos de ton coordinateur Sonoff, quel est le modèle indiqué ZBDongle-E ou ZBDongle-P ?
