[Fermé] Module TUYA PIR ZG-204Z identifié comme TS0601
getget
Re: [stable6 / dev - Sonoff] Module TUYA PIR ZG-204Z identifié comme TS0601
Message par getget »
Pas de lux à priori.
Log réinstall :
2023-01-05 21:54:33,597 INFO    : [ZigpyCom_13 3538493] PERMIT-TO-JOIN: {'cmd': 'PERMIT-TO-JOIN', 'datas': {'Duration': 240, 'targetRouter': 'FFFC'}, 'NwkId': None, 'TimeStamp': 1672952073.5698204, 'ACKIsDisable': False, 'Sqn': None}
2023-01-05 21:54:33,598 INFO    : [ZigpyCom_13 3538493] PERMIT-TO-JOIN: duration: 240 for Radio: znp for node: None
2023-01-05 21:54:33,599 INFO    : [ZigpyCom_13 3538493] Calling self.app.permit(time_s=240, node=None )
2023-01-05 21:54:33,611 INFO    : [ZigpyForwarder_13 3538494] Accepting new Hardware: Enable (On)
2023-01-05 21:54:33,616 INFO    : [ZigpyCom_13 3538493] returning from the self.app.permit(time_s=240, node=None )
2023-01-05 21:55:32,890 INFO    : [ZigpyForwarder_13 3538494] --> Adding device 64d4 in self.DevicesInPairingMode
2023-01-05 21:55:32,891 INFO    : [ZigpyForwarder_13 3538494] --> ['64d4']
2023-01-05 21:55:32,892 INFO    : [ZigpyForwarder_13 3538494] [None] NEW OBJECT: 64d4 None
2023-01-05 21:55:33,645 INFO    : [ZigpyForwarder_13 3538494] [-] NEW OBJECT: 64d4 Active Endpoint Response Ep: 01 LQI: 0
2023-01-05 21:55:33,646 INFO    : [ZigpyForwarder_13 3538494] --> Not full scope
2023-01-05 21:55:33,646 INFO    : [ZigpyForwarder_13 3538494] --> Build list of Attributes
2023-01-05 21:55:33,647 INFO    : [ZigpyForwarder_13 3538494] --> ListOfEp with 0x0000: []
2023-01-05 21:55:33,647 INFO    : [ZigpyForwarder_13 3538494] --> Build list Eps for Cluster Basic ['01']
2023-01-05 21:55:33,647 INFO    : [ZigpyForwarder_13 3538494] Request Basic  Manufacturer via Read Attribute request: 0004
2023-01-05 21:55:33,647 INFO    : [ZigpyForwarder_13 3538494] Request Basic  Model Name via Read Attribute request: 0005
2023-01-05 21:55:33,648 INFO    : [ZigpyForwarder_13 3538494] EP: {'01': {}}
2023-01-05 21:55:33,648 INFO    : [ZigpyForwarder_13 3538494] [-] NEW OBJECT: 64d4 Request Simple Descriptor for Ep: 01
2023-01-05 21:55:37,495 INFO    : [ZigpyForwarder_13 3538494] ReadCluster - 0000 / 0005 - Updated Model: >TS0601-motion<
2023-01-05 21:55:37,701 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 1 4 00
2023-01-05 21:55:37,702 INFO    : [ZigpyForwarder_13 3538494] MajDomoDevice NwkId: 64d4 status: 0043 not inDB request IEEE for possible reconnection
2023-01-05 21:55:41,091 INFO    : [MainThread 3538461] [1] NEW OBJECT: 64d4 Model Name: TS0601-motion
2023-01-05 21:55:41,097 INFO    : [MainThread 3538461] [1] NEW OBJECT: 64d4 Manufacturer Name: _TZE200_bh3n6gk8
2023-01-05 21:55:41,100 INFO    : [MainThread 3538461] [None] NEW OBJECT: 64d4 Request Node Descriptor
2023-01-05 21:55:43,448 INFO    : [ZigpyForwarder_13 3538494] ReadCluster - 0000 / 0005 - Updated Model: >TS0601-motion<
2023-01-05 21:55:44,108 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 1 4 00
2023-01-05 21:55:45,496 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 4 2 00000064
2023-01-05 21:55:48,354 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 9 4 02
2023-01-05 21:55:49,794 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 10 4 00
2023-01-05 21:55:53,879 INFO    : [MainThread 3538461] Request Disabling Accepting new Hardware
2023-01-05 21:55:53,964 INFO    : [ZigpyCom_13 3538493] PERMIT-TO-JOIN: {'cmd': 'PERMIT-TO-JOIN', 'datas': {'Duration': 0, 'targetRouter': 'FFFC'}, 'NwkId': None, 'TimeStamp': 1672952153.8784888, 'ACKIsDisable': False, 'Sqn': None}
2023-01-05 21:55:53,966 INFO    : [ZigpyCom_13 3538493] PERMIT-TO-JOIN: duration: 0 for Radio: znp for node: None
Ce que je vois passer :
2023-01-05 21:55:54,089 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 4 2 00000064
2023-01-05 21:55:57,625 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 1 4 00
2023-01-05 21:55:57,864 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 4 2 00000064
2023-01-05 21:55:59,321 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 9 4 02
2023-01-05 21:56:00,549 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 10 4 00
2023-01-05 21:56:00,878 INFO    : [ZigpyForwarder_13 3538494] tuya_motion_response - 64d4 01 1 4 01
Je garde l'alerte par mail activée pour quand tu auras reçu le tien, merci déjà pour ton aide :)
je viens de pousser une modif, qui permet normalement de regler la sensitivité du capteur et également regler la durée d'occupancy.
D'après les logs, le capteur semble etre configuré en
- sensitivité élevé
- durée d'occupancy 10 sec
je viens de recevoir le PIR et il fonctionne nickel.
Il y a eu quelques modifs pour les Tuya qui ont été poussées il y a 3 ou 4 jours,
je te propose d'essayer, tu récupères la dernière version sur la branche dev , tu supprimes les widgets et tu refais l'appairage.
getget
J'ai testé en 6.4.149 et pas de LUX, mais bon, comment être sûr de ce que m'a envoyé le fournisseur ...
Sur la boîte j’avais bien écrit Motion + Lux
getget
Sur les miens c'est indiqué "Zigbee Motion Sensor".
Je vais les contacter :)
Edit : J'ai acheté les muvais :?
