The real issue is the creation of the related device.
Here is the code in my arduino:
// Enable debug prints
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
//#define MY_RS485
#include <SPI.h>
#include <MySensors.h>
#include <DHT.h>
// Set this to the pin you connected the DHT's data pin to
#define DHT_DATA_PIN 3
// Set this offset if the sensor has a permanent small offset to the real temperatures
#define SENSOR_TEMP_OFFSET 0
// Sleep time between sensor updates (in milliseconds)
// Must be >1000ms for DHT22 and >2000ms for DHT11
static const uint64_t UPDATE_INTERVAL = 6000;
// Force sending an update of the temperature after n sensor reads, so a controller showing the
// timestamp of the last update doesn't show something like 3 hours in the unlikely case, that
// the value didn't change since;
// i.e. the sensor would force sending an update every UPDATE_INTERVAL*FORCE_UPDATE_N_READS [ms]
static const uint8_t FORCE_UPDATE_N_READS = 10;
#define CHILD_ID_HUM 0
#define CHILD_ID_TEMP 1
float lastTemp;
float lastHum;
uint8_t nNoUpdatesTemp;
uint8_t nNoUpdatesHum;
bool metric = true;
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
DHT dht(DHT_DATA_PIN, DHT11);
void presentation()
sendSketchInfo("TemperatureAndHumidity", "1.1");
present(CHILD_ID_HUM, S_HUM);
present(CHILD_ID_TEMP, S_TEMP);
void setup()
// Sleep for the time of the minimum sampling period to give the sensor time to power up
// (otherwise, timeout errors might occure for the first reading)
sleep(1000);
void loop()
// Force reading sensor, so it works also after sleep()
//dht.readSensor(true);
// Get temperature from DHT library
float temperature =dht.readTemperature();
if (isnan(temperature)) {
Serial.println("Failed reading temperature from DHT!");
} else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS) {
// Only send temperature if it changed since the last measurement or if we didn't send an update for n times
lastTemp = temperature;
// Reset no updates counter
nNoUpdatesTemp = 0;
temperature += SENSOR_TEMP_OFFSET;
send(msgTemp.set(temperature, 1));
} else {
// Increase no update counter if the temperature stayed the same
nNoUpdatesTemp++;
// Get humidity from DHT library
float humidity = dht.readHumidity();
if (isnan(humidity)) {
Serial.println("Failed reading humidity from DHT");
} else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
// Only send humidity if it changed since the last measurement or if we didn't send an update for n times
lastHum = humidity;
nNoUpdatesHum = 0;
send(msgHum.set(humidity, 1));
} else {
// Increase no update counter if the humidity stayed the same
nNoUpdatesHum++;
// Sleep for a while to save energy
sleep(UPDATE_INTERVAL);
