[Résolu] Sonde Xaomi fuite d'eau : détections intempestives
Re: [Ré-ouvert] Sonde Xaomi fuite d'eau ne fonctionne plus
Suite au redémarrage de ma Zigate, je viens de voir une ligne d'erreur concernant l'interface web (avant dernière ligne) :
2019-11-09 00:03:40.804 Error: Zigate hardware (5) nothing received for more than 12 Hours!....
2019-11-09 00:03:41.805 Error: Restarting: Zigate
2019-11-09 00:03:42.486 Status: (Zigate) DomoticzHash: 99b3ecd3b
2019-11-09 00:03:42.486 Status: (Zigate) DomoticzBuildTime: 2019-08-28 08:25:35
2019-11-09 00:03:42.486 Status: (Zigate) load PluginConf
2019-11-09 00:03:42.487 Status: (Zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-11-09 00:03:42.488 Status: (Zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-11-09 00:03:42.488 Status: (Zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-11-09 00:03:42.488 Status: (Zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-05.json
2019-11-09 00:03:42.488 Status: (Zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-11-09 00:03:42.488 Status: (Zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-11-09 00:03:42.488 Status: (Zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-11-09 00:03:42.488 Status: (Zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-11-09 00:03:42.488 Status: (Zigate) blueLedOff set to 1
2019-11-09 00:03:42.488 Status: (Zigate) Opening DomoticzDB in raw
2019-11-09 00:03:42.497 Status: (Zigate) Domoticz Website credentials Raspberry/3e172ab6fed370a75217b80fd2d94777
2019-11-09 00:03:42.499 Status: (Zigate) Plugin Database: DeviceList-5.txt
2019-11-09 00:03:42.523 Status: (Zigate) DeviceConf loaded
2019-11-09 00:03:42.523 Status: (Zigate) load ListOfDevice
2019-11-09 00:03:42.628 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-5.txt : 18
2019-11-09 00:03:42.641 Status: (Zigate) Transport mode: Wifi
2019-11-09 00:03:42.643 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-11-09 00:03:42.894 Status: (Zigate) setTimeServer - Setting UTC Time to : 626573022
2019-11-09 00:03:42.895 Status: (Zigate) Configure Permit To Join
2019-11-09 00:03:42.895 Status: (Zigate) Request Accepting new Hardware for 180 seconds
2019-11-09 00:03:42.895 Status: (Zigate) Trigger a Topology Scan
2019-11-09 00:03:42.895 Status: (Zigate) Trigger a Energy Level Scan
2019-11-09 00:03:42.947 Status: (Zigate) Major Version Num: 0003
2019-11-09 00:03:42.947 Status: (Zigate) Installer Version Number: 031a
2019-11-09 00:03:43.203 Status: (Zigate) Accepting new Hardware: On
2019-11-09 00:03:43.257 Status: (Zigate) Zigate addresses ieee: 00158d0001ede834 , short addr: 0000
2019-11-09 00:03:43.257 Status: (Zigate) Network state UP, PANID: d2d3 extPANID: 0x471895b0c3f8c028 Channel: 11
2019-11-09 00:03:43.317 Status: (Zigate) Number of devices recently active in Zigate = 17
2019-11-09 00:03:52.463 Status: (Zigate) Switch Blue Led off
2019-11-09 00:03:52.464 Status: (Zigate) Zigate set to Certification : CE
2019-11-09 00:03:52.465 Status: (Zigate) Plugin with Zigate firmware 031a correctly initialized
2019-11-09 00:03:52.465 Error: (Zigate) Looks like you didn't set correctly the Web Admin GUI: False
2019-11-09 00:03:53.094 Status: (Zigate) TxPower Attenuation : 0 dBm
J'ai un problème de configuration ?
Keros a écrit : 09 nov. 2019, 06:57 Suite au redémarrage de ma Zigate, je viens de voir une ligne d'erreur concernant l'interface web (avant dernière ligne) :
A priori tu es sur la version beta du plugin.
Vérifie que tu as bien un numéro de port au niveau de la page 'Hardware' dans domoticz pour le plugin. Là où tu configure l'accès, le type de la Zigate il y a également un numéro de port à renseigner pour l'accès à la la page Web Admin
En effet, je n'ai pas sélectionné de port. J'avais des soucis de connexion avec ma zigate wifi et j'avais trouvé une stabilité en ne sélectionnant aucun port...
Pourtant, dans les premières version bêta avec l'interface d'admin, j'avais l'accès à l'interface avec cette configuration.
Pipiche, sachant que j'ai une zigate wifi et domoticz sur un Raspberry 3B+, quel est le port à sélectionner ?
J'ai /dev/ttyUSB ou ttyAM0 ou ttyS0 ou serial0 ?
Keros a écrit : 09 nov. 2019, 18:56 En effet, je n'ai pas sélectionné de port. J'avais des soucis de connexion avec ma zigate wifi et j'avais trouvé une stabilité en ne sélectionnant aucun port...
Je parle ici du port pour l’accès à l'interface Web Admin, tu peux mettre ce que tu souhaites, mais 9440 est ce qui était par defaut sur la version stable
Screenshot 2019-11-09 at 19.13.01.png (121.85 Kio) Consulté 3738 fois
Ola pardon, j'avais pas vu cet ajout de fonction. :oops:
Le numéro de port était à False > Normal que cela ne fonctionne pas ... Je viens de mettre une valeur et ça refonctionne.
Pourquoi alors, ça c'est désactivé ? Tu as mis à jour le plugin pour donner la possibilité de changer de port (c'est très bien) mais tu le règles à False par défaut pour désactiver son fonctionnement à l'installation. La mise à jour du plugin aurait désactiver mon accès. (Ce n'est pas grave, j'essaie de comprendre ;) )
En tout cas merci et désolé de t'avoir déranger pour ce problème de config.
Keros a écrit : 10 nov. 2019, 07:54 Ola pardon, j'avais pas vu cet ajout de fonction. :oops:
Le plugin n'a pas un accès en ecriture sur ces paramètres (car venant de Domoticz). Sur les version antérieur ce paramètre était déjà utilisé et avait comme valeur False ou True.
Donc à ce stade, c'est à l'utilisateur de faire le changement.
Sachant qu'aujourd'hu c'est uniquement sur la béta, cela n'est pas clairement documenté ;-)
J'allais te poser la question concernant la documentation mais je me suis ravisé sachant tout le boulot que tu fais.
Fin du HS : je reviens sur mon soucis de sondes
Ce matin, ma sonde a détecté une fuite :
2019-11-11 06:13:24.414  (Zigate) UpdateDevice - (Sonde O2 : Cuves) 1:On
Alors qu'il n'y avait toujours pas d'eau ... J'ai déplacé ma sonde sur mon bureau pour faire des test : elle est restée à On.
J'ai passé le plugin avec les log avancées (Input, Cluster et Widget) :
  • Voici les infos reçues lorsque j'ai shunté les plots de mesure :
2019-11-11 06:31:08.800  (Zigate) Touch unit Sonde O2 : Cuves nwkid: ca96
2019-11-11 06:31:08.802  (Zigate) Decode8401 - MsgSQN: ff MsgSrcAddr: ca96 MsgEp:01 MsgClusterId: 0500 MsgZoneStatus: 0001 MsgExtStatus: 00 MsgZoneID: ff MsgDelay: 0000
2019-11-11 06:31:08.802  (Zigate) IAS Zone for device:ca96  - alarm1: 1, alaram2: 0, tamper: 0, battery: 0, Support Reporting: 0, restore Reporting: 0, trouble: 0, acmain: 0, test: 0, battdef: 0
2019-11-11 06:31:08.802  (Zigate) Decode8401 MsgZoneStatus: 01
2019-11-11 06:31:08.803  (Zigate) MajDomoDevice - Device ID : 00158d00023f2ef7 - Device EP : 01 - Type : 0500 - Value : 01 - Hue :   - Attribute_ :
2019-11-11 06:31:08.803  (Zigate) MajDomoDevice - Type = Door
2019-11-11 06:31:08.803  (Zigate) MajDomoDevice - NWKID = ca96 IEEE = 00158d00023f2ef7 Unit = 94
2019-11-11 06:31:08.803  (Zigate) MajDomoDevice - {'0006': {'0000': '01'}, '0500': {'0002': 'alarm1: 1, alaram2: 0, tamper: 0, battery: 0, Support Reporting: 0, restore Reporting: 0, trouble: 0, acmain: 0, test: 0, battdef: 0'}, 'ClusterType': {'94': 'Water'}, '0000': {'ff01': '0121b30b0328150421a8430521120006240300020000082104020a2157e164100100', '0005': 'lumi.sensor_wleak.aq1'}, '0001': {'0000': 2995}}
2019-11-11 06:31:08.804  (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-11-11 06:31:08.804  (Zigate) MajDomoDevice - NWKID: ca96 SwitchType: 0, DeviceType: Water, ClusterType: Door, old_nVal: 1 , old_sVal: On
2019-11-11 06:31:08.804  (Zigate) UpdateDevice_v2 1:On:_61:57_False (Sonde O2 : Cuves)
2019-11-11 06:31:08.804  (Zigate) UpdateDevice_v2 for : Sonde O2 : Cuves RSSI = 3
2019-11-11 06:31:08.804  (Zigate) UpdateDevice_v2 for : Sonde O2 : Cuves BatteryLevel = 61
  • Et après retirer le shunte, la sonde est passée à Off
2019-11-11 06:31:35.666  (Zigate) Too early for a new update of LastSeen ca96
2019-11-11 06:31:35.666  (Zigate) Decode8401 - MsgSQN: 00 MsgSrcAddr: ca96 MsgEp:01 MsgClusterId: 0500 MsgZoneStatus: 0000 MsgExtStatus: 00 MsgZoneID: ff MsgDelay: 0000
2019-11-11 06:31:35.666  (Zigate) IAS Zone for device:ca96  - alarm1: 0, alaram2: 0, tamper: 0, battery: 0, Support Reporting: 0, restore Reporting: 0, trouble: 0, acmain: 0, test: 0, battdef: 0
2019-11-11 06:31:35.666  (Zigate) Decode8401 MsgZoneStatus: 00
2019-11-11 06:31:35.666  (Zigate) MajDomoDevice - Device ID : 00158d00023f2ef7 - Device EP : 01 - Type : 0500 - Value : 00 - Hue :   - Attribute_ :
2019-11-11 06:31:35.667  (Zigate) MajDomoDevice - Type = Door
2019-11-11 06:31:35.667  (Zigate) MajDomoDevice - NWKID = ca96 IEEE = 00158d00023f2ef7 Unit = 94
2019-11-11 06:31:35.667  (Zigate) MajDomoDevice - {'0006': {'0000': '01'}, '0500': {'0002': 'alarm1: 0, alaram2: 0, tamper: 0, battery: 0, Support Reporting: 0, restore Reporting: 0, trouble: 0, acmain: 0, test: 0, battdef: 0'}, 'ClusterType': {'94': 'Water'}, '0000': {'ff01': '0121b30b0328150421a8430521120006240300020000082104020a2157e164100100', '0005': 'lumi.sensor_wleak.aq1'}, '0001': {'0000': 2995}}
2019-11-11 06:31:35.667  (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-11-11 06:31:35.667  (Zigate) MajDomoDevice - NWKID: ca96 SwitchType: 0, DeviceType: Water, ClusterType: Door, old_nVal: 1 , old_sVal: On
2019-11-11 06:31:35.667  (Zigate) UpdateDevice_v2 0:Off:_61:57_False (Sonde O2 : Cuves)
2019-11-11 06:31:35.667  (Zigate) UpdateDevice_v2 for : Sonde O2 : Cuves RSSI = 3
2019-11-11 06:31:35.667  (Zigate) UpdateDevice_v2 for : Sonde O2 : Cuves BatteryLevel = 61
2019-11-11 06:31:35.667  (Zigate) UpdateDevice - (Sonde O2 : Cuves) 0:Off
2019-11-11 06:31:35.667  (Zigate) Update Values 0:Off: 61:3 False (Sonde O2 : Cuves)
Pipiche, est-ce que tu y vois quelque chose d'anormal ?
Est-ce qu'il faudrait que je laisse les infos Input, Cluster et Widget activée en permanence pour essayer d'avoir plus d'infos au moment du soucis ? (bonjour la taille des logs...)
Rien d’anormal dans les logs. On reçoit bien une détection du capteur dans le 1er et une non/fin de détection dans le 2eme.
Dans le 1er on ne voit pas que la sonde est déjà activée ?
Keros a écrit : 11 nov. 2019, 13:49 Dans le 1er on ne voit pas que la sonde est déjà activée ?
Oui, mais je ne vois rien d'anormal. Je plugin réagit avec ce que le détecteur envoie. Est-ce que ce n’est pas le détecteur qui dconne. Au niveau des piles rien d'anormal ?
